查看: 3649|回复: 0
[NI软件产品] LabVIEW 2016 FPGA Module Xilinx Compilation Tools Linux32Eng LV2016 FPGA编译工具(Vivado 2015.4)
  • 签到天数: 3697 天
    连续签到: 24 天
    发表于 2020-8-26 22:36:11 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    2016XilinxLinux2015_4,4.09GB
    发布日期
    16-8-1
    受支持的操作系统
    Red Hat Enterprise Linux 6.5
    Red Hat Enterprise Linux 7
    CentOS 7
    语言
    English
    校验和
    MD5: a3296515fd393e78dee8ca84a48629d7
    SHA1: 8e7ad0d2cdb07f2bc3777e5f76ea1d4cbb4594d2
    SHA256: 5a9868a0ea0aec97d52da5d53fbe7bb6684a5e3f8fd899c95445e3eed7390a72
    CRC32: c89d05e0
    百度网盘下载(限速,请开会员或使用工具下载):
    请注册视觉论坛会员,登录购买附件查看,充值请联系在线客服
    NI官方下载地址(可能无法下载完成或地址无效):
    FPGACT-Linux-Vivado2015.4-LV2016.txt (282 Bytes, 下载次数: 4, 售价: 10 圆)
    LabVIEW 2016 FPGA Module Xilinx Compilation Tools for Linux Readme
    June 2016
    This file contains important information about the LabVIEW FPGA Module Xilinx Compilation Tools for Linux, including system requirements and installation instructions.
    The Xilinx compilation tools include tools for Vivado 2015.4 and ISE 14.7, which are supported by the LabVIEW FPGA Module. Install these compilation tools if you want to compile FPGA VIs on a Linux computer.
    The Xilinx compilation tools also support Windows. Refer to the FPGA Module Xilinx Compilation Tools for Windows Readme for more information.
    The Xilinx Compilation Tool for Vivado 2015.4 has the following system requirements:
    • Red Hat Enterprise Linux 6.5 (64-bit) or 7.0, or CentOS 7.0
    • 10 GB of additional disk space
    The Xilinx Compilation Tool for ISE 14.7 has the following system requirements:
    • 11 GB of additional disk space
    The following sections contain the NI hardware supported by the FPGA Module Xilinx Compilation Tools on Linux:
    Use the Xilinx Compilation Tool for Vivado 2015.4 to compile FPGA VIs for the following devices:
    • IC-317x
    • NI 9147, NI 9149
    • NI cRIO-903x, NI cRIO-906x
    • NI PXIe-517xR, NI PXIe-5624R, NI PXIe-5820R, NI PXIe-5840R, NI PXIe-659xR, NI PXIe-782xR, NI PXIe-793xR, NI PXIe-797xR, NI PXIe-7902R
    • NI sbRIO-9651, NI sbRIO-9607, NI sbRIO-9627, NI sbRIO-9637
    • NI USB-784xR, NI USB-785xR
    • NI USRP-RIO 294x, NI USRP-RIO 295x
    Use the Xilinx Compilation Tool for ISE 14.7 to compile FPGA VIs for the following devices:
    • NI 9144, NI 9146, NI 9148, NI 915x
    • NI cRIO-907x, NI cRIO-908x, NI cRIO-911x
    • NI PCIe-784xR, NI PCIe-785xR, NI PCIe-1473R
    • NI PXI-784xR, NI PXI-785xR, NI PXI-795xR
    • NI PXIe-796xR, NI PXIe-564xR
    • NI sbRIO-9605, NI sbRIO-9606, NI sbRIO-961x, NI sbRIO-962x, NI sbRIO-963x, NI sbRIO-964x
    Complete the following steps to install the FPGA Module Xilinx Compilation Tools for Linux:
    • Use mount to mount the compilation tools installer.
    • Change the current directory to the mount point.
    • To run the installation script, enter sh ./INSTALL.
    © 2012–2016 National Instruments. All rights reserved.
    Third-Party Copyright Notices
    /usr/local/natinst/nifpgacompileworker/doc
    374740F-01
    GMT+8, 2025-10-30 02:18
