查看: 3647|回复: 0
[NI软件产品] LabVIEW 2017SP1 FPGA Module Xilinx Compilation Tools Linux32Eng LV2017SP1 FPGA编译工具(Vivado 2015.4)
  • 签到天数: 3697 天
    连续签到: 24 天
    发表于 2020-8-26 22:43:15 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    2017SP1FPGA-LinuxVivado,4.09GB
    发布日期
    18-1-23
    受支持的操作系统
    Red Hat Enterprise Linux 6.5
    Red Hat Enterprise Linux 7
    CentOS 7
    语言
    English
    校验和
    MD5: 4a5f02a0e6d55fb3a1101d49b92b02eb
    SHA1: d00d9e6db35e7ef095903097bf3e10ca3636adbe
    SHA256: ccfd7b4738bc79b498ac27611bb622d014bfd0430758b3ab55225e2e3253083a
    CRC32: 0baf52e6
    百度网盘下载(限速,请开会员或使用工具下载):
    请注册视觉论坛会员,登录购买附件查看,充值请联系在线客服
    NI官方下载地址(可能无法下载完成或地址无效):
    FPGACT-Linux-Vivado2015.4-LV2017SP1.txt (287 Bytes, 下载次数: 3, 售价: 10 圆)
    LabVIEW 2017 SP1 FPGA Module Xilinx Compilation Tools for Linux Readme
    September 2017
    This file contains important information about the LabVIEW FPGA Module Xilinx Compilation Tools for Linux, including system requirements and installation instructions.
    The Xilinx compilation tools include tools for Vivado 2015.4 and ISE 14.7, which are supported by the LabVIEW FPGA Module. Install these compilation tools if you want to compile FPGA VIs on a Linux computer.
    The Xilinx compilation tools also support Windows. Refer to the FPGA Module Xilinx Compilation Tools for Windows Readme for more information.
    The Xilinx Compilation Tool for Vivado 2015.4 has the following system requirements:
      • Red Hat Enterprise Linux 6.5 (64-bit)
      • Red Hat Enterprise Linux 7.0 (64-bit)
      • CentOS 7.0 (64-bit)
    • 11 GB of additional disk space
    The Xilinx Compilation Tool for ISE 14.7 has the following system requirements:
    The following sections contain the NI hardware supported by the FPGA Module Xilinx Compilation Tools on Linux:
    Use the Xilinx Compilation Tool for Vivado 2015.4 to compile FPGA VIs for the following devices:
    • cRIO-903x/906x
    • IC-317x
    • myRIO-1900/1950
    • NI ELVIS RIO Control Module
    • NI-9145/9147/9149
    • PCIe-782xR
    • PXIe-517xR/5624R/5840R/659xR/782xR/784x/785x/786xR/793xR/797xR/7902R
    • roboRIO
    • sbRIO-9651/9607/9627/9637
    • USB-784xR/785xR
    • USRP-RIO 294x/295x
    Use the Xilinx Compilation Tool for ISE 14.7 to compile FPGA VIs for the following devices:
    • cRIO-907x/908x/911x
    • NI-9144/9146/9148/915x
    • PCIe-784xR/785xR/1473R
    • PXIe-796xR/564xR
    • PXI-784xR/785xR/795xR
    • sbRIO-9605/9606/961x/962x (excluding 9627)/963x (excluding 9637)/964x
    Complete the following steps to install the FPGA Module Xilinx Compilation Tools for Linux:
    • Use mount to mount the compilation tools installer.
    • If the media type is DVD, change the current directory to the mount point.
      If the media type is USB, change the current directory to mount point/Linux/Vivado2015_4 or mount point/Linux/ISE14_7, depending on which tool you want to install.
    • To run the installation script, enter sh ./INSTALL.
    © 2012–2017 National Instruments. All rights reserved.
    Third-Party Copyright Notices
    /usr/local/natinst/nifpgacompileworker/doc
    374740H-01
    GMT+8, 2025-10-30 02:18
