查看: 4306|回复: 0
[NI软件产品] LabVIEW 2019 FPGA Module Xilinx Compilation Tools Linux64Eng LV2019 FPGA编译工具(Vivado 2017.2)
  • 签到天数: 3697 天
    连续签到: 24 天
    发表于 2020-8-26 22:48:49 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    NI-LVFPGA-2019-LinuxVivado,6.99GB
    发布日期
    19-5-17
    受支持的操作系统
    Red Hat Enterprise Linux 6.7
    Red Hat Enterprise Linux 7.2
    Red Hat Enterprise Linux 7.3
    CentOS 7.2
    CentOS 7.3
    语言
    English
    校验和
    MD5: 686f4c99cfdb5f77d990359ab17db0c3
    SHA1: 2d750a069ee4c0e14f09df4bbcde78408c3f7d08
    SHA256: 58c8f5b32809bd3290dbd62469a322eba53ba3b6667319d143aa6698a9625b99
    CRC32: 07313c05
    百度网盘下载(限速,请开会员或使用工具下载):
    请注册视觉论坛会员,登录购买附件查看,充值请联系在线客服
    NI官方下载地址(可能无法下载完成或地址无效):
    FPGACT-Linux-Vivado2017.2-LV2019.txt (287 Bytes, 下载次数: 1, 售价: 10 圆)
    LabVIEW 2019 FPGA Module Xilinx Compilation Tools for Linux Readme
    March 2019
    This file contains important information about the LabVIEW FPGA Module Xilinx Compilation Tools for Linux, including system requirements and installation instructions.
    The Xilinx compilation tools include tools for Vivado 2017.2 and ISE 14.7, which are supported by the LabVIEW FPGA Module. Install these compilation tools if you want to compile FPGA VIs on a Linux computer.
    The Xilinx compilation tools also support Windows. Refer to the FPGA Module Xilinx Compilation Tools for Windows Readme for more information.
    The Xilinx Compilation Tool for Vivado 2017.2 has the following system requirements:
      • Red Hat Enterprise Linux 6.7 (64-bit)
      • Red Hat Enterprise Linux 7.2 or 7.3 (64-bit)
      • CentOS 7.2 or 7.3 (64-bit)
    • 15 GB of additional disk space
    • Memory—Refer to the Xilinx website at www.xilinx.com for memory requirements of different FPGA targets. Failure to meet the target-specific memory requirement may result in unpredictable compilation results.
      Note  The recommended memory size on the Xilinx website is for one compile job only. If you run multiple compile jobs at a time, the memory requirement increases by multiple times accordingly.
    The Xilinx Compilation Tool for ISE 14.7 has the following system requirements:
    • Red Hat Enterprise Linux 6.5 (64-bit)
    The following sections contain the NI hardware supported by the FPGA Module Xilinx Compilation Tools on Linux. Devices that are compatible with the FPGA Module (64-bit) are in bold.
    Use the Xilinx Compilation Tool for Vivado 2017.2 to compile FPGA VIs for the following devices:
    • cRIO-903x/904x/905x/906x
    • IC-317x
    • myRIO-1900/1950
    • NI ELVIS III
    • NI ELVIS RIO Control Module
    • NI-9145/9147/9149
    • PCIe-576x/577x/5785/782xR/7846/7856/7857/7858/798x
    • PXIe-5163R/5164R/517xR/5624R/5745/576x/577x/5785/5840R/659xR/782xR/784x/785x/786xR/7902R/791x/793xR/797xR/798x
    • roboRIO
    • sbRIO-9651/9607/9627/9637
    • USB-784xR/785xR
    • USRP-RIO devices
    Use the Xilinx Compilation Tool for ISE 14.7 to compile FPGA VIs for the following devices:
    • cRIO-907x/908x/911x
    • IC-312x
    • NI-9144/9146/9148/915x
    • NI CVS-145x/145xRT
    • PCIe-7841R/7842R/7851R/7852R/1473R/8237R
    • PXIe-796xR/564xR
    • PXI-784xR/785xR/795xR
    • sbRIO-9605/9606/961x/962x (excluding 9627)/963x (excluding 9637)/964x
    Complete the following steps to install the FPGA Module Xilinx Compilation Tools for Linux:
    • Use mount to mount the compilation tools installer.
    • If the media type is DVD, change the current directory to the mount point.
      If the media type is USB, change the current directory to mount point/Linux/Vivado2017_2 or mount point/Linux/ISE14_7, depending on which tool you want to install.
    • To run the installation script, enter sh ./INSTALL.
    © 2012–2019 National Instruments. All rights reserved.
    Third-Party Copyright Notices
    /usr/local/natinst/nifpgacompileworker/doc
    374740K-01
    GMT+8, 2025-10-30 02:15
