查看: 2942|回复: 0
[LV工具模块] LabVIEW Statechart Module 2009 Win32Eng LV状态图模块SC2009
    前天 16:03
    发表于 2020-8-31 23:59:26 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    LabVIEW状态图模块提供了高级抽象来帮助用户设计基于状态、转换和事件的应用程序。
    LabVIEW状态图模块是LabVIEW编程环境的一个附加软件。该模块可以在所有NI硬件终端上运行,包括台式PC、实时系统、FPGA和ARM微控制器,而且还可帮助您在架构之间轻松移植代码。
    百度网盘下载(限速,请开会员或使用工具下载):
    请注册视觉论坛会员,登录购买附件查看,充值请联系在线客服
    NI官方下载地址(可能无法下载完成或地址无效):
    SC2009.txt (275 Bytes, 下载次数: 3, 售价: 10 圆)
    文件大小: 52206112 字节 (49.79 MB)
    修改日期: 2010-01-07 00:30
    MD5: 9e6bcefb0e6aa912b31e5fc232971a54
    SHA1: b47150bf2771af93e4b136d64a706f80024626d9
    SHA256: dcde3efaa14465aee288d2c8bd142f2d6d5e99b833170c3286c1bae2112987e0
    CRC32: 8af39bc8
    LabVIEW 2009 Statechart Module Readme
    June 2009
    This file contains information to introduce you to the LabVIEW 2009 Statechart Module. This file also provides you with help resources you can use while working with the Statechart Module. The file contains the following information that you need to understand.
    The LabVIEW 2009 Statechart Module includes the following new features.
    Generating Documentation for Statecharts
    You now can generate documentation that describes all components of a completed statechart. Print or save statechart documentation to keep a record you can refer to later.
    You can generate statechart documentation from either the Project Explorer window or the Statechart Editor window. In the Project Explorer window, right-click the .lvsc item, or statechart library, for a statechart and select Generate Documentation from the shortcut menu. In the Statechart Editor window, select File»Generate Documentation. The LabVIEW Statechart Module generates an XML file that contains information about all components, including states, pseudostates, connectors, regions, and transitions, of the statechart. You can view the XML file in a Web browser.
    You also can use the Generate Documentation method to generate statechart documentation programmatically.
    No Code Generation Required for Guard or Action Changes
    In earlier versions of the LabVIEW Statechart Module, when you modify a guard or action in a transition or static reaction, you must re-generate code for the statechart. Code generation can be time-consuming for large statecharts. In the LabVIEW 2009 Statechart Module, you no longer must re-generate code for a statechart when you make modifications to a non-empty guard or action. However, you still must re-generate code if you add code to a previously empty guard or action or if you delete all code from a guard or action.
    Debugging Statecharts for FPGA Targets
    You now can debug statecharts for field-programmable gate array (FPGA) targets executing on the host computer. LabVIEW can run the statechart on the host computer to allow you to debug the statechart before you deploy the statechart to the FPGA target. You cannot debug a statechart that runs on an actual FPGA. Select LabVIEW FPGA Target from the Execution Target pull-down menu on the Statechart Code Generation page of the Project Library Properties dialog box to specify that the statechart executes on an FPGA target.
    Right-click a Run Statechart function and select Debug Statechart from the shortcut menu to debug a statechart for an FPGA target. This action is valid only when you have linked the Run Statechart function to a statechart that runs on the host computer. By default, statechart debugging for FPGA targets is disabled. You can enable statechart debugging for FPGA targets by selecting Enabled from the Debugging pull-down menu on the Statechart Code Generation page of the Project Library Properties dialog box. Enabling statechart debugging for FPGA targets increases the code size of the statechart.
    Configuring Multiple States or Transitions Simultaneously
    You now can configure multiple states and transitions simultaneously. Open multiple Configure State or Configure Transition dialog boxes from the Statechart Editor window. You may not edit the statechart diagram when you open a Configure State or Configure Transition dialog box. The states or transitions you configure display a wrench icon in the Statechart Editor window and change color on the statechart diagram when a Configure State or Configure Transition dialog box is open. The default configuration color is yellow. You can customize the color that the states and transitions you configure turn.
    You also can switch from the open Configure State or Configure Transition dialog boxes to the state or transition you are configuring in the Statechart Editor window. The Configure State dialog box contains a new Jump to State button and the Configure Transition dialog box contains a Jump to Transition button to the left of the Code Status button. The Jump to State and Jump to Transition buttons highlight the state or transition to which the Configure State and Configure Transition dialog boxes correspond. If you attempt to configure a state or transition you are already configuring, the currently open configuration dialog box for the state or transition appears.
    Finding Objects and Text in Statecharts
    You now can search statecharts for a particular object or string of text. Use the Find dialog box to find VIs, Express VIs, objects, or text in the guard and action code of a statechart or to find Statechart Development objects or text in the Statechart Editor window. Select Edit»Find and Replace in the Statechart Editor window to display the Find dialog box.
    You also now can find all instances of triggers and groups in a statechart. Right-click a trigger or group on the Triggers/Groups page of the Configure State or Configure Transition dialog box and select Find Trigger/Group from the shortcut menu to find all static reactions and transitions that react to the trigger or group.
    Browsing a Statechart Hierarchy
    You now can browse the hierarchy of a statechart to identify the relationship of the statechart to other VIs. You can browse the statechart hierarchy from either the Statechart Editor window or the Project Explorer window.
    You can browse the following elements of a statechart hierarchy:
    • .lvsc file—From the Statechart Editor window, select View»Browse Relationships»This VI's Statechart to find the corresponding .lvsc file, or statechart library, for the statechart. From the Project Explorer window, right-click a caller VI or subVI of the statechart and select Find»SubVIs or Find»Callers, respectively, from the shortcut menu to find the corresponding .lvsc file for the statechart.
    • Caller VIs—From the Statechart Editor window, select View»Browse Relationships»This VI's Callers to find the caller VIs of the statechart. You also can right-click the icon in the upper right corner of the Statechart Editor window and select Find All Instances from the shortcut menu to find all caller VIs of the statechart. From the Project Explorer window, right-click the .lvsc file for a statechart and select Find»Callers from the shortcut menu to find the caller VIs of the statechart.
    • SubVIs—From the Statechart Editor window, select View»Browse Relationships»This VI's SubVIs to find the subVIs of the statechart. From the Project Explorer window, right-click the .lvsc file for a statechart and select Find»SubVIs from the shortcut menu to find the subVIs of the statechart.
    • Statechart Editor window—From a caller VI or subVI of the statechart, select View»Browse Relationships»This VI's SubVIs or View»Browse Relationships»This VI's Callers, respectively, to find the corresponding Statechart Editor window for the statechart.
    • LabVIEW 2009 Base, Full, or Professional Development System for Windows
    • 250 MB additional available disk space
    You can install all of your LabVIEW products—including the LabVIEW Statechart Module—using the LabVIEW 2009 Platform DVDs. You can find installation instructions for the LabVIEW Statechart Module along with activation instructions in the following locations:
    • LabVIEW 2009 Platform DVDs Readme, which is available on the top-level of LabVIEW Platform DVD 1.
    To request additional LabVIEW 2009 Platform DVDs, refer to the National Instruments Web site.
    Refer to the LabVIEW Help, accessible by selecting Help»Search the LabVIEW Help from the pull-down menu in LabVIEW, for information about the Statechart Module.
    LabVIEW examples for the Statechart Module are located in the labview\examples\Statechart folder. You can modify an example VI to fit an application, or you can copy and paste from one or more examples into a VI that you create.
    You can access the software and documentation known issues list online. Refer to the National Instruments Web site for an up-to-date list of known issues in the LabVIEW 2009 Statechart Module.
    The following items are the IDs and titles of a subset of issues fixed in the LabVIEW 2009 Statechart Module. If you have a CAR ID, you can search this list to validate that the issue has been fixed. This is not an exhaustive list of issues fixed in the current version of the Statechart Module.
    IDLegacy IDFixed Issue
    413304D6G4PI8Unable to Show/Hide Paths in Library-only Project Window
    445174HFEEM9AThe icon for the statechart .lvsc file is confusing and not presented well
    449334HTEFNWSInternal errors when closing project while statechart configuration dialog is open
    527394BOA749ACertain items from the palette drop at incorrect positions in the statechart configuration dialog
    9164146JGUIUGCannot drag items out of guard or action VIs in the State/Transition configuration dialog
    925234BTF3H9AThe "Replace With" menu option can be used in the statechart diagram to connect statechart objects in non-allowed ways
    928934DKCLN9AStatecharts should not require code generation when only a guard or action has been modified
    930074EB9AAHANo easy way to find out which transitions or Static reactions respond to a particular trigger.
    930084EB9BNHAThere is no way to do find objects in the guard and action code of states/transitions in a Statechart.
    930904EPD3Q9AFinding callers and callees of statecharts on Project window does not working properly.
    934954HKAHJUGApplying changes to statechart type definitions can result in very long delays
    95703
    Easy to move objects outside of the visible region in the guard and action windows of the statechart configuration dialog
    104376
    Quick Drop does not work when configuring a Statechart state node or transition node
    106768
    Compound arithmetic VI appears in incorrect position when dropped in statechart configuration dialog.
    110377
    Double clicking a state or transition twice in quick succession gives a configuration error
    110716
    Drawing or moving objects offscreen in a statechart diagram does not scroll the viewing area.
    112854
    Statecharts from previous LabVIEW versions may miss out on some non-essential mutation when loaded in current LabVIEW
    126845
    Should not be able to edit statechart type definitions in one context while configuring statechart states/transitions in other context
    131651
    Renaming a state's static reaction can delete the reaction's guard/action code
    133221
    Certain statecharts always generate broken code and cannot be run
    134252
    Changing a static reaction's name to that of one that existed when you began your state configuration can cause incorrect reaction ordering and/or guard/action code
    136900
    Edits to one statechart static reaction can be incorrectly applied to another static reaction
    147850
    Breakpoints added on Statechart debug window do not get updated in Breakpoint Manager when it is opened for the first time.
    147853
    Breakpoint added in subdiagram gets hit while debugging but the subdiagram window does not open if it was closed when the breakpoint was hit.
    155447
    Better feedback needed when dropping an unsupported function block node in a statechart guard or action VI
    162458
    Saving a statechart that uses subdiagrams from LabVIEW 8.6 to LabVIEW 8.5 results in problems in LabVIEW 8.5
    Important Information
    GMT+8, 2026-2-25 01:06
