查看: 3354|回复: 0
[LV工具模块] LabVIEW Statechart Module 2012 Win32Eng LV状态图模块SC2012
    前天 16:03
    发表于 2020-9-1 00:10:28 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    LabVIEW状态图模块提供了高级抽象来帮助用户设计基于状态、转换和事件的应用程序。
    LabVIEW状态图模块是LabVIEW编程环境的一个附加软件。该模块可以在所有NI硬件终端上运行,包括台式PC、实时系统、FPGA和ARM微控制器,而且还可帮助您在架构之间轻松移植代码。
    百度网盘下载(限速,请开会员或使用工具下载):
    请注册视觉论坛会员,登录购买附件查看,充值请联系在线客服
    NI官方下载地址(可能无法下载完成或地址无效):
    下载地址1:
    下载地址2:
    SC2012.txt (389 Bytes, 下载次数: 0, 售价: 10 圆)
    文件大小: 76814984 字节 (73.26 MB)
    修改日期: 2012-08-07 04:08
    MD5: 95b7734719cc3e79eccb9698eb572115
    SHA1: 9ed5aac1daa46029b4dba2c9418efee0cffdf674
    SHA256: f2da47378d8ee70fa22aa9ec64a1d69f97f5851be44820ef4b375fd15e32ba2a
    CRC32: 9554038b
    LabVIEW 2012 Statechart Module Readme
    Version 12.0.0
    June 2012
    This file contains important information about the LabVIEW 2012 Statechart Module, including installation instructions, a partial list of bugs fixed, and known issues.
    In addition to the system requirements for the LabVIEW Development System, the LabVIEW 2012 Statechart Module has the following requirements:
    • LabVIEW 2012 Base, Full, or Professional Development System (32-bit) for Windows
    • At least 250 MB of disk space
    Refer to the LabVIEW Readme for additional system requirements and supported operating systems for LabVIEW 2012.
    You can install all of your LabVIEW products—including the LabVIEW Statechart Module—using the LabVIEW 2012 Platform DVDs. Refer to the LabVIEW Installation Guide on the LabVIEW Platform DVD 1 for installation instructions and system requirements.
    To request additional LabVIEW 2012 Platform DVDs, refer to the National Instruments website.
    You can access the software and documentation known issues list online. Refer to the National Instruments website for an up-to-date list of known issues in the LabVIEW 2012 Statechart Module.
    The following items are the IDs and titles of a subset of issues fixed in the LabVIEW 2012 Statechart Module. This is not an exhaustive list of issues fixed in the current version of the Statechart Module. If you have a CAR ID, you can search this list to validate that the issue has been fixed.
    312224Long load times for real-time executables using the Statechart Module
    324812[LV RT] Deployment failure when using the Statechart Module
    165915Feedback node on editable subpanel of state config dialog is broken after you press and drag or after you copy and paste.
    Refer to the LabVIEW Help, accessible by selecting Help»LabVIEW Help in LabVIEW, for information about the Statechart Module.
    Select Help»Find Examples from LabVIEW to launch the NI Example Finder. LabVIEW examples for the Statechart Module are located in the labview\examples\Statechart directory. You can modify an example VI to fit an application, or you can copy and paste from one or more examples into a VI that you create.
    Important Information
    © 2007-2012 National Instruments. All rights reserved.
    GMT+8, 2026-2-25 01:07
