查看: 3345|回复: 0
[LV工具模块] LabVIEW Statechart Module 2014 Win32Eng LV状态图模块SC2014
    前天 16:03
    发表于 2020-9-1 00:15:57 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    LabVIEW状态图模块提供了高级抽象来帮助用户设计基于状态、转换和事件的应用程序。
    LabVIEW状态图模块是LabVIEW编程环境的一个附加软件。该模块可以在所有NI硬件终端上运行,包括台式PC、实时系统、FPGA和ARM微控制器,而且还可帮助您在架构之间轻松移植代码。
    百度网盘下载(限速,请开会员或使用工具下载):
    请注册视觉论坛会员,登录购买附件查看,充值请联系在线客服
    NI官方下载地址(可能无法下载完成或地址无效):
    下载地址1:
    下载地址2:
    SC2014.txt (389 Bytes, 下载次数: 2, 售价: 10 圆)
    文件大小: 102503200 字节 (97.75 MB)
    修改日期: 2014-10-20 23:57
    MD5: 0e3b17583fd54c5ab3e7c864de8f7b3a
    SHA1: 3b4f27a91abd137dbc8e3d74f7532eb37aba9f44
    SHA256: 9053c3fe905cb44c19cc6589c8a05fecc5f68db80ef4f6b91ff526ebf30d3ce0
    CRC32: e61a1d2c
    LabVIEW 2014 Statechart Module Readme
    Version 14.0.0
    June 2014
    This file contains important information about the LabVIEW Statechart Module, including installation instructions, a partial list of bugs fixed for LabVIEW 2014 Statechart Module, and known issues.
    In addition to the system requirements for the LabVIEW Development System, the Statechart Module has the following requirements:
    • LabVIEW 2014 Base, Full, or Professional Development System (32-bit) for Windows
    • At least 250 MB of disk space
    Refer to the LabVIEW Readme for additional system requirements and supported operating systems for LabVIEW 2014.
    You can install all of your LabVIEW products—including the Statechart Module—using the LabVIEW 2014 Platform media. Refer to the LabVIEW Installation Guide on the LabVIEW Platform media for installation instructions and system requirements.
    Note If you purchased this product with an NI Software Suite or NI Product Bundle, use the installation media that shipped with your purchase to install this product.
    Visit ni.com/security for security information about National Instruments products. Visit ni.com/critical-updates for information about critical updates from National Instruments.
    You can access the software and documentation known issues list online. Refer to the National Instruments website for an up-to-date list of known issues in the Statechart Module.
    Refer to the LabVIEW Help, accessible by selecting Help»LabVIEW Help from LabVIEW, for information about the Statechart Module.
    Select Help»Find Examples from LabVIEW to launch the NI Example Finder. LabVIEW examples for the Statechart Module are located in the labview\examples\Statechart directory. You can modify an example VI to fit an application, or you can copy and paste from one or more examples into a VI that you create.
    Using NI Launcher
    Finding All Programs
    NI LabVIEW Statechart Module Drops Support for Microsoft Windows Vista, Windows XP, and Windows Server 2003 in 2016
    National Instruments LabVIEW Statechart Module will drop support for Microsoft Windows Vista, Windows XP, and Windows Server 2003 as of July 1, 2016. Versions of Statechart Module that ship after July 1, 2016 will not install or run on Windows Vista, Windows XP, or Windows Server 2003. For detailed information about NI application software product life cycles, visit ni.com/info and enter one of the following Info Codes:
    NI LabVIEWlifecycle
    NI TestStandtslcp
    NI DIAdemddlcp
    NI SignalExpressselcp
    NI VeriStandnivslifecycle
    © 2007–2014 National Instruments. All rights reserved.
    GMT+8, 2026-2-25 01:07
