查看: 4118|回复: 0
[LV工具模块] LabVIEW Statechart Module 2015 Win32Eng LV状态图模块SC2015
    前天 16:03
    发表于 2020-9-1 00:18:02 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    LabVIEW状态图模块提供了高级抽象来帮助用户设计基于状态、转换和事件的应用程序。
    LabVIEW状态图模块是LabVIEW编程环境的一个附加软件。该模块可以在所有NI硬件终端上运行,包括台式PC、实时系统、FPGA和ARM微控制器,而且还可帮助您在架构之间轻松移植代码。
    百度网盘下载(限速,请开会员或使用工具下载):
    请注册视觉论坛会员,登录购买附件查看,充值请联系在线客服
    NI官方下载地址(可能无法下载完成或地址无效):
    下载地址1:
    下载地址2:
    SC2015.txt (389 Bytes, 下载次数: 1, 售价: 10 圆)
    文件大小: 105272096 字节 (100.40 MB)
    修改日期: 2015-07-31 21:05
    MD5: 33d9ef3974365c9cf4ca2e01732c595f
    SHA1: dd0c5e7d9024d13109aec71b7f95025271d6905c
    SHA256: 36dcdff8a9f8a39cdaac25d1d41bdaba5de3b12a390d6ea35d6367bbdc56fc18
    CRC32: 791d4e6c
    LabVIEW 2015 Statechart Module Readme
    Version 15.0.0
    June 2015
    This file contains important information about the LabVIEW Statechart Module, including installation instructions and known issues.
    The LabVIEW Statechart Module provides a programming model that you can use to design applications at a higher level than was previously possible. With the LabVIEW Statechart Module, you can develop statechart diagrams, define behaviors with LabVIEW dataflow programming, and deploy the statecharts to desktop PCs, real-time controllers, field-programmable gate arrays (FPGAs), and embedded targets.
    In addition to the system requirements for the LabVIEW Development System, the Statechart Module has the following requirements:
    • LabVIEW 2015 Base, Full, or Professional Development System (32-bit) for Windows
    • At least 250 MB of disk space
    Refer to the LabVIEW Readme for additional system requirements and supported operating systems for LabVIEW 2015.
    You can install all of your LabVIEW products—including the Statechart Module—using the LabVIEW 2015 Platform media. Refer to the LabVIEW Installation Guide on the LabVIEW Platform media for installation instructions and system requirements.
    Note If you purchased this product with an NI Software Suite or NI Product Bundle, use the installation media that shipped with your purchase to install this product.
    You can access the software and documentation known issues list online. Refer to the National Instruments website for an up-to-date list of known issues in the Statechart Module.
    Refer to the LabVIEW Help, accessible by selecting Help»LabVIEW Help from LabVIEW, for information about the Statechart Module.
    Select Help»Find Examples from LabVIEW to launch the NI Example Finder. LabVIEW examples for the Statechart Module are located in the labview\examples\Statechart directory. You can modify an example VI to fit an application, or you can copy and paste from one or more examples into a VI that you create.
    Using NI Launcher
    [tabl]
    [tr][td]Current Application[/td][td]Icon Location[/td][td]Pin to Action[/td][/tr]
    [tr][td]Windows 8.x Desktop[/td][td]Desktop Taskbar[/td][td]Right-click application and select Pin to Taskbar[/td][/tr]
    [tr][td]Windows 8.x Desktop[/td][td]Start screen[/td][td]Right-click application and select Pin to Start[/td][/tr]
    [tr][td]Windows 8.x Start screen[/td][td]Desktop Taskbar[/td][td]Right-click application and select Pin to taskbar from the menu bar on the bottom of the screen[/td][/tr]
    [/table]Finding All Programs
    NI LabVIEW Statechart Module Drops Support for Microsoft Windows Vista, Windows XP, and Windows Server 2003 in 2016
    National Instruments LabVIEW Statechart Module will drop support for Microsoft Windows Vista, Windows XP, and Windows Server 2003 as of July 1, 2016. Versions of Statechart Module that ship after July 1, 2016 will not install or run on Windows Vista, Windows XP, or Windows Server 2003. For detailed information about NI application software product life cycles, visit ni.com/info and enter one of the following Info Codes:
    LabWindows™/CVI™cvi_lifecycle
    © 2007–2015 National Instruments. All rights reserved.
    374719A-01
    GMT+8, 2026-2-25 01:07
