NI-Sync 17.0 Driver Win32/64Eng NI PXI同步模块及实时控制器驱动程序下载May.2017
NI-Sync用于支持用户使用PXI同步模块或任何运行实时操作系统的NI控制器。
NI-Sync是一个NI仪器驱动程序,用于配置系统定时和同步,包括基于信号的同步和直接使用时钟。您还可以使用时间协议(如IEEE 1588标准,IEEE 802.1AS标准,IRIG或GPS)执行基于时间的同步,作为时间戳的时间参考或执行同步时钟和触发生成。NI-Sync支持PXI同步模块和实时PXI、CompactDAQ和CompactRIO控制器以及紧凑视觉系统和工业控制器。NI-Sync中还包括高级实用程序及范例,可帮助用户更轻松地创建应用程序。
百度网盘下载(限速,请开会员或使用工具下载):
请注册视觉论坛会员,登录购买附件查看,充值请联系在线客服
NI官方下载地址(可能无法下载完成或地址无效):
NI-Sync17.0.txt
(248 Bytes, 下载次数: 0, 售价: 10 圆)
文件大小: 1655676864 字节 (1.54 GB)
修改日期: 2017-05-20 00:39
MD5: 9282c4d81b949353698597908117dadb
SHA1: 69a4e196a2102fc1dc343dcdae633bbdf7819ffc
SHA256: 441fc9f8bc6dd3423d416e908e8bf244c2c1a1688cd02cfa7101168b7b7c13d3
CRC32: 997fe0cc
NI-Sync 17.0 ReadmeMay 2017 This file includes important information about NI-Sync, including supported operating systems, a partial list of bugs fixed for NI-Sync 17.0, and known issues. If you plan to use LabVIEW NXG, refer to LabVIEW NXG Support and Considerations.
Overview Supported Operating Systems Application Software Support Product Security and Critical Updates New Features Supported Hardware Known Issues Bug Fixes Accessing the Help Finding Examples Automating the Installation of NI Products Using NI Software with Microsoft Windows 10 Using NI Software with Microsoft Windows 8.1 LabVIEW NXG Support and Considerations Legal Information OverviewNI-Sync provides support for customers using NI timing and synchronization hardware modules. Supported Operating SystemsNI-Sync 17.0 supports the following operating systems: - Windows 7 SP1 x86, x64
- Windows 8.1 SP1 x86, x64
- Windows 10 SP1 x86, x64
- Windows Server 2008 R2 (x64)
- Windows Server 2012 R2 (x64)
- NI Real-Time Phar Lap ETS
Note In 2016, NI-Sync dropped support for Windows Vista, Windows XP, Windows Server 2003, and installations of Windows 7 without any service packs. NI-Sync 17.0 will not install or run on an unsupported OS. You cannot deploy or distribute applications that use NI-Sync 17.0 to an unsupported OS. Additionally, after installing NI-Sync 17.0, you cannot use any installers built on this computer with any version of LabVIEW, LabWindows™/CVI™, NI TestStand™, or Measurement Studio on an unsupported OS. For more information about the changes to our OS support for 2016, refer to KB 79UC78LS, Why Does my LabVIEW, LabWindows/CVI, Measurement Studio, or TestStand Built Installer Fail on Windows XP/Vista and Server 2003?. Note Support for Windows 32-bit operating systems may require disabling physical address extension (PAE). To learn how this might affect your system and what actions you might need to take, visit ni.com/info and enter the Info Code PAESupport. 1 NI software installs VC2015 Runtime and .NET 4.6.2. Windows 8.1 and Windows Server 2012 R2 require Microsoft updates to support these items. Refer to Microsoft KB2919442 and KB2919355 for more information about how to install these updates. 2 NI software is signed with a SHA-256 certificate. Windows 7 SP1, Windows Embedded Standard 7 SP1, and Windows Server 2008 R2 SP1 require Microsoft updates to support SHA-256. Refer to Microsoft KB3033929 for more information about how to install this security update. Application Software SupportNI-Sync supports the following application software versions, including service packs. | Application Software | Versions Supported by NI-Sync | | LabVIEW | 2014, 2015, 2016, 2017 | | LabVIEW Real-Time Module | 2014, 2015, 2016, 2017 | | LabWindows�/CVI� | 2012, 2013, 2015, 2017 | Product Security and Critical UpdatesVisit ni.com/security to view and subscribe to receive security notifications about NI products. Visit ni.com/critical-updates for information about critical updates from NI. New Features- The niSync Measure Frequency VI is now supported on PXI-668x modules.
- Most modules' temperature, firmware revision, and hardware revision are now reported through System API.
Supported HardwareNI-Sync 17.0 supports the following devices: Signal-Based Modules- PXI-6651
- PXI-6652
- PXI-6653
- PXIe-6672
- PXIe-6674
- PXIe-6674T
Time-Based Modules- PCI-1588
- PXI-6682
- PXI-6682H
- PXI-6683
- PXI-6683H
Known IssuesYou can access the software and documentation known issues list online. For a list of known issues with NI-Sync 17.0, visit ni.com/info and enter the Info Code NISync170KnownIssues. Bug FixesThe following items are the IDs and titles of a subset of issues fixed in the NI-Sync. This is not an exhaustive list of issues fixed in the current version of NI-Sync. For a complete list of bug fixes in NI-Sync, visit ni.com/info and enter the Info Code NISyncFixList. If you have a CAR ID, you can search this list to validate that the issue has been fixed. | ID | Fixed Issue | Issue Details | Fixed Version | | 592326 | Windows 10 sometimes crashes following driver installation and upon the next reboot, or during installation. | | 17.0 | | 439129 | Modifying the calibration password updates the calibration timestamp. | Calibration passwords for all modules can now be modified outside a calibration session. | 17.0 | | 632346 | PLL Locked? property does not consistently update when lock is lost. | The property now updates when the lock is lost. | 17.0 |
Accessing the HelpRefer to the NI-Sync Help, accessible from Help»LabVIEW Help..., for information about using NI-Sync with LabVIEW. Finding ExamplesSelect Help»Find Examples from LabVIEW to launch the NI Example Finder. LabVIEW examples for NI-Sync are located in the \examples\instr\niSync directory. You can modify an example VI to fit an application, or you can copy and paste from one or more examples into a VI that you create. - For signal-based examples that use clocks and triggers directly, open the NI Example Finder and navigate to Hardware Input and Output»Timing and Synchronization»Signal-Based.
- For time-based examples that use time references such as IEEE 1588-2008 or GPS as a basis for synchronization, open the NI Example Finder and navigate to Hardware Input and Output»Timing and Synchronization»Time-Based.
Automating the Installation of NI ProductsYou can automate the installation of most NI products using command-line arguments to suppress some or all of the installer user interface and dialog boxes. If the NI product you are installing uses Microsoft .NET 4.0, the .NET installer may run before any NI software installs and may require a reboot before the installation of NI software begins. To avoid a .NET reboot, install .NET 4.0 separately before you install NI software. For more information about automating the installation of NI products, refer to the following KnowledgeBase articles: - For more information on silent installations of individual NI products, refer to KB 4CJDP38M, Automating the Installation of a Single Installer.
- For more information on silent installations of suited NI products, such as NI Developer Suite, refer to KB 4GGGDQH0, How Do I Automate the Installation of a Suited Installer?.
- To determine what version of NI Installers your product contains, refer to KB 4CJDR18M, How Can I Determine the Type and Version of My National Instruments Installer?.
Using NI Software with Microsoft Windows 10Microsoft Windows 10 is the latest version of the Windows operating system and features significant changes compared to previous versions. Windows 10 introduces several new capabilities and also combines features from both Windows 7 and Windows 8. For more information about NI support for Windows 10, visit ni.com/windows10. Using NI Software with Microsoft Windows 8.1When you install NI software on Microsoft Windows 8.1, you will notice a few additional tiles in the Apps view, including shortcuts to NI application software products such as LabVIEW, Measurement & Automation Explorer (NI MAX), and NI Launcher. For more information about NI support for Windows 8.1, visit ni.com/windows8. | Note MAX does not appear as a desktop shortcut when installed on Microsoft Windows 8.x. You can launch MAX either from the Apps view or from within NI Launcher. | LabVIEW NXG Support and ConsiderationsThe following sections detail considerations for using LabVIEW NXG with NI-Sync. LabVIEW NXG Operating Systems and System RequirementsSoftware support for LabVIEW NXG differs in the following ways: - System requirements—Only 64-bit (x64) processors are supported.
- Operating system—Only 64-bit operating systems are supported. Refer to the Supported Operating Systems section for more information.
LabVIEW NXG Hardware Support- PXI-6683
- PXI-6683H
- PXIe-6674T
- PXIe-6672
Installing NI-Sync 17.0 for LabVIEW NXGNI automates LabVIEW NXG installation using a package manager. Complete the following steps to install NI-Sync for LabVIEW NXG. - Visit ni.com/info and enter the info code NXGDownload to access the LabVIEW NXG download page.
- Click Download LabVIEW NXG 1.0.
- NI Package Manager installs, then automatically opens a download window.
- Select LabVIEW NXG Suite and click the green Install button.
- Select LabVIEW NXG 1.0 and NI-Sync.
- Complete the installer instructions to download LabVIEW NXG 1.0 and NI-Sync.
LabVIEW NXG HelpView context help in LabVIEW by pressing and hovering over an object. Search for items using the search bar in the upper right corner of the LabVIEW window. You can also view context help for the search results. Additional documentation is available online at ni.com/manuals. LabVIEW NXG ExamplesLaunch LabVIEW and click the Learning tab. LabVIEW lessons are located in the Lessons tab, and LabVIEW Examples are located in the Examples tab. Follow the instructions in the lessons and examples. Legal InformationCopyright ©2003-2017 National Instruments. All rights reserved. Under the copyright laws, this publication may not be reproduced or transmitted in any form, electronic or mechanical, including photocopying, recording, storing in an information retrieval system, or translating, in whole or in part, without the prior written consent of National Instruments Corporation. NI respects the intellectual property of others, and we ask our users to do the same. NI software is protected by copyright and other intellectual property laws. Where NI software may be used to reproduce software or other materials belonging to others, you may use NI software only to reproduce materials that you may reproduce in accordance with the terms of any applicable license or other legal restriction. End-User License Agreements and Third-Party Legal Notices You can find end-user license agreements (EULAs) and third-party legal notices in the following locations after installation: - Notices are located in the \_Legal Information and directories.
U.S. Government Restricted Rights If you are an agency, department, or other entity of the United States Government ("Government"), the use, duplication, reproduction, release, modification, disclosure or transfer of the technical data included in this manual is governed by the Restricted Rights provisions under Federal Acquisition Regulation 52.227-14 for civilian agencies and Defense Federal Acquisition Regulation Supplement Section 252.227-7014 and 252.227-7015 for military agencies. IVI Foundation Copyright Notice Content from the IVI specifications reproduced with permission from the IVI Foundation. The IVI Foundation and its member companies make no warranty of any kind with regard to this material, including, but not limited to, the implied warranties of merchantability and fitness for a particular purpose. The IVI Foundation and its member companies shall not be liable for errors contained herein or for incidental or consequential damages in connection with the furnishing, performance, or use of this material. Trademarks Refer to the NI Trademarks and Logo Guidelines at ni.com/trademarks for information on NI trademarks. Other product and company names mentioned herein are trademarks or trade names of their respective companies. Patents For patents covering the NI products/technology, refer to the appropriate location: Help�Patents in your software, the patents.txt file on your media, or the NI Patent Notice at ni.com/patents. 375085F-01 |
