查看: 3320|回复: 0
[NI驱动程序] NI-Sync 18.0 Driver Win32/64Eng NI PXI同步模块及实时控制器驱动程序下载May.2018
    14 小时前
  • 签到天数: 3765 天
    连续签到: 16 天
    发表于 2020-9-3 00:12:23 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    NI-Sync用于支持用户使用PXI同步模块或任何运行实时操作系统的NI控制器。
    NI-Sync是一个NI仪器驱动程序,用于配置系统定时和同步,包括基于信号的同步和直接使用时钟。您还可以使用时间协议(如IEEE 1588标准,IEEE 802.1AS标准,IRIG或GPS)执行基于时间的同步,作为时间戳的时间参考或执行同步时钟和触发生成。NI-Sync支持PXI同步模块和实时PXI、CompactDAQ和CompactRIO控制器以及紧凑视觉系统和工业控制器。NI-Sync中还包括高级实用程序及范例,可帮助用户更轻松地创建应用程序。
    百度网盘下载(限速,请开会员或使用工具下载):
    请注册视觉论坛会员,登录购买附件查看,充值请联系在线客服
    NI官方下载地址(可能无法下载完成或地址无效):
    NI-Sync18.0.txt (244 Bytes, 下载次数: 0, 售价: 10 圆)
    文件大小: 1693736896 字节 (1.58 GB)
    修改日期: 2018-05-17 00:56
    MD5: b2d1477cd77e38118478b3ef96102df7
    SHA1: 1187a40de68ba5c75fba1ce6b381b9e0c4276acb
    SHA256: faa976c0cfaef80eaccd03a3d001997f2cb3934039a254dcdf6961e07c42729e
    CRC32: 6e842b37
    NI-Sync 18.0 Readme
    May 2018
    This file includes important information about NI-Sync, including supported operating systems, a partial list of bugs fixed for NI-Sync 18.0, and known issues.
    NI-Sync provides support for customers using NI timing and synchronization hardware modules.
    NI-Sync 18.0 supports the following operating systems:
    • Windows 10/8.11/7 SP12
    • Windows Server 2012 R21 (x64)
    • Windows Server 2008 R2 SP12 (x64)
    • NI Real-Time Phar Lap ETS
    Note  In 2016, NI-Sync dropped support for Windows Vista, Windows XP, Windows Server 2003, and installations of Windows 7 without any service packs. NI-Sync 18.0 will not install or run on an unsupported OS. You cannot deploy or distribute applications that use NI-Sync 18.0 to an unsupported OS. Additionally, after installing NI-Sync 18.0, you cannot use any installers built on this computer with any version of LabVIEW, LabWindows™/CVI™, NI TestStand™, or Measurement Studio on an unsupported OS.
    NI-Sync supports the following application software versions, including service packs.
    Application SoftwareVersions Supported by NI-Sync
    LabVIEW2015 SP1, 2016 SP1, 2017 SP1, 2018
    LabVIEW Real-Time Module2015, 2016, 2017, 2018
    LabWindows�/CVI�2012, 2013, 2015, 2017
    • The NI-Sync 18.0 API now supports monitoring and configuring system time synchronization on Linux RT targets where NI-TimeSync time references are installed.
    NI-Sync 18.0 supports the following devices:
    Signal-Based Modules
    • PXI-6651
    • PXI-6652
    • PXI-6653
    • PXIe-6672
    • PXIe-6674
    • PXIe-6674T
    Time-Based Modules
    • PCI-1588
    • PXI-6682
    • PXI-6682H
    • PXI-6683
    • PXI-6683H
    You can access the software and documentation known issues list online. For a list of known issues with NI-Sync 18.0, visit ni.com/info and enter the Info Code NISync180KnownIssues.
    The following items are the IDs and titles of a subset of issues fixed in the NI-Sync. This is not an exhaustive list of issues fixed in the current version of NI-Sync. For a complete list of bug fixes in NI-Sync, visit ni.com/info and enter the Info Code NISyncFixList. If you have a CAR ID, you can search this list to validate that the issue has been fixed.
    IDFixed IssueIssue DetailsFixed Version
    592326Windows 10 sometimes crashes following driver installation and upon the next reboot, or during installation.17.0
    439129Modifying the calibration password updates the calibration timestamp.Calibration passwords for all modules can now be modified outside a calibration session.17.0
    632346PLL Locked? property does not consistently update when lock is lost.The property now updates when the lock is lost.17.0
    Refer to the NI-Sync Help, accessible from Help»LabVIEW Help..., for information about using NI-Sync with LabVIEW.
    Select Help»Find Examples from LabVIEW to launch the NI Example Finder. LabVIEW examples for NI-Sync are located in the \examples\instr\niSync directory. You can modify an example VI to fit an application, or you can copy and paste from one or more examples into a VI that you create.
    • For signal-based examples that use clocks and triggers directly, open the NI Example Finder and navigate to Hardware Input and Output»Timing and Synchronization»Signal-Based.
    • For time-based examples that use time references such as IEEE 1588-2008 or GPS as a basis for synchronization, open the NI Example Finder and navigate to Hardware Input and Output»Timing and Synchronization»Time-Based.
    • For more information on silent installations of suited NI products, such as NI Developer Suite, refer to KB 4GGGDQH0, How Do I Automate the Installation of a Suited Installer?.
    When you install NI software on Microsoft Windows 8.1, you will notice a few additional tiles in the Apps view, including shortcuts to NI application software products such as LabVIEW, Measurement & Automation Explorer (NI MAX), and NI Launcher. For more information about NI support for Windows 8.1, visit ni.com/windows8.
    Note  MAX does not appear as a desktop shortcut when installed on Microsoft Windows 8.x. You can launch MAX either from the Apps view or from within NI Launcher.
    ©2003-2018 National Instruments. All rights reserved.
    For patents covering the NI products/technology, refer to the appropriate location: Help�Patents in your software, the patents.txt file on your media, or the NI Patent Notice at ni.com/patents.
    375085H-01
    GMT+8, 2026-1-7 23:35
