NI PXI Platform Services 17.0 Driver Win32/64Eng PXI平台服务NI-PXIPS17.0下载
PXI Platform Services用于支持NI PXI机箱和控制器,遵循PXI软件规范,并为其他NI产品提供系统服务。
PXI Platform Services用于识别NI PXI和PXI Express机箱和模块,以及允许触发路由。 对于特定NI模块,使用完整的模块功能仍需要适用的硬件驱动程序。 NI PXI Platform Services已包含在NI仪器驱动程序中,但有些情况下,某些应用程序只需要PXI Platform Services软件,例如在没有安装其他NI PXI硬件驱动程序的情况下使用NI MXI产品或使用NI PXI或PXI Express机箱。
百度网盘下载(限速,请开会员或使用工具下载):
请注册视觉论坛会员,登录购买附件查看,充值请联系在线客服
NI官方下载地址(可能无法下载完成或地址无效):
PXIPS17.0.txt
(282 Bytes, 下载次数: 0, 售价: 10 圆)
文件大小: 500862910 字节 (477.66 MB)
修改日期: 2019-06-25 03:11
MD5: 3c962b55681ca789d5397d6a5438058d
SHA1: 9737e0926fc8b01f2d63b62386ce3c38172a18c8
SHA256: a91e2b4ebefadfa418d992f0885e9d5190901efbf6fd59f7801181572e7ce8fa
CRC32: bc16ee43
PXI Platform Services 17.0 ReadmeApril 2017 This file contains important information about PXI Platform Services, including enhancements and a partial list of bugs fixed for PXI Platform Services 17.0. Parts of this document are only relevant to a full installation and do not apply to a runtime-only installation. Overview Release Notes Supported Interfaces Supported Operating Systems Application Software Support Product Security and Critical Updates PXI System Monitoring Bug Fixes Automating the Installation of NI Products Using NI Software with Microsoft Windows 10 Using NI Software with Microsoft Windows 8.1 Legal Information OverviewPXI Platform Services provides support for customers using NI PXI and PXI Express chassis and controllers. Release NotesIf you are using PXI Platform Services 17.0 to upgrade a Windows system that serves as a host for one or more LabVIEW Real-Time Module targets, it is highly recommended that you also update your targets to leverage new features and improved performance. Note: You cannot use PXI Platform Services 17.0 to configure a LabVIEW RT target with a version of PXI Platform Services earlier than 2.0. Supported InterfacesPXI Platform Services supports PXI and PXI Express functionality. Visit ni.com/info and enter the Info Code pxipshw for a complete list of hardware that is compatible with PXI Platform Services. Supported Operating SystemsPXI Platform Services 17.0 supports the following platforms. For the most up to date information on compatibility with PXI Platform Services, visit ni.com/info and enter the Info Code pxipsos. - Windows 10 (32-bit and 64-bit)
- Windows 8.11 (32-bit and 64-bit)
- Windows 7 with SP12 or later (32-bit and 64-bit)
- Windows Server 2012 R21 (64-bit)
- Windows Server 2008 R2 with SP22 or later (64-bit)
Note: Some hardware may not support all operating systems listed above. Please consult your hardware documentation for more information. Note In 2016, PXI Platform Services dropped support for Windows Vista, Windows XP, Windows Server 2003, and installations of Windows 7 without any service packs. PXI Platform Services will not install or run on an unsupported OS. You cannot deploy or distribute applications that use PXI Platform Services 17.0 to an unsupported OS. Additionally, after installing PXI Platform Services 17.0, you cannot use any installers built on this computer with any version of LabVIEW, LabWindows™/CVI™, NI TestStand™, or Measurement Studio on an unsupported OS. For more information about the changes to our OS support for 2016, refer to KB 79UC78LS, Why Does my LabVIEW, LabWindows/CVI, Measurement Studio, or TestStand Built Installer Fail on Windows XP/Vista and Server 2003?. Note Support for Windows 32-bit operating systems may require disabling physical address extension (PAE). To learn how this might affect your system and what actions you might need to take, visit ni.com/info and enter the Info Code PAESupport. 1 NI software installs VC2015 Runtime and .NET 4.6.2. Windows 8.1 and Windows Server 2012 R2 require Microsoft updates to support these items. Refer to Microsoft KB2919442 and KB2919355 for more information about how to install these updates. 2 NI software is signed with a SHA-256 certificate. Windows 7 SP1, Windows Embedded Standard 7 SP1, and Windows Server 2008 R2 SP1 require Microsoft updates to support SHA-256. Refer to Microsoft KB3033929 for more information about how to install this security update. Application Software SupportPXI Platform Services supports the following application software versions, including service packs. | Application Software | Versions Supported by PXI Platform Services | | LabVIEW | 2014 SP1, 2015 SP1, 2016, 2017 | Product Security and Critical UpdatesVisit ni.com/security to view and subscribe to receive security notifications about NI products. Visit ni.com/critical-updates for information about critical updates from NI. PXI System MonitoringNI PXI Chassis System MonitoringPXI Platform Services 3.2.1 was the first version to support the PXI-8250 module via the NI System Configuration API. Note: NI System Configuration 5.4 (or later) is required for LabVIEW API support. NI PXI Express Chassis System MonitoringPXI Platform Services 3.1 was the first version to support system monitoring via NI System Configuration API. NI PXI Express Remote Controllers may require a firmware update in order to take advantage of the system monitoring features. For more information, visit ni.com/info and enter the Info Code pximxisysmon. NI System Monitor Minimum RequirementIf NI System Monitor is installed on your system, upgrading PXI Platform Services to version 3.1 or later also requires an upgrade of NI System Monitor to version 1.2 or later. Bug FixesThe following items are the IDs and title of a subset of issues fixed in PXI Platform Services. This is not an exhaustive list of issues fixed in the current version of PXI Platform Services. If you have a CAR ID, you can search this list to validate that the issue has been fixed. - Version 17.0
- Version 16.0
- Version 15.1
- Version 15.0.2
- Version 15.0.1
- Version 15.0
- Version 14.1
- Version 14.0
- Version 4.0.1
- Version 4.0
- Version 3.2.3
- Version 3.2.2
- Version 3.2.1
- Version 3.2
- Version 3.1
- Version 3.0.4
- Version 3.0.3
- Version 3.0.2
- Version 3.0.1
- Version 3.0
- Version 2.5.6
- Version 2.5.4
- Version 2.5.3
Enhancements and Bug Fixes in Version 17.0New Hardware SupportAdded support for new PXI hardware. Fixed Issues| ID | Fixed Issue | | 589386 | Fixed issue where the Cable Location attribute may not refresh properly. | | 565983 | Improved error messages for failed BIOS updates to PXI embedded controllers. | | 590724 | Fixed an issue preventing a user from deleting a manually added PXI chassis while National Instruments is not the active PXI Resource Manager. | Enhancements and Bug Fixes in Version 16.0New Hardware SupportAdded support for new PXI hardware. Fan control via NI System Configuration APIPXI Platform Services 16.0 now installs a header file defining the attributes required to set a safe user fan speed through the NI System Configuration C API on supported PXIe chassis. For more details, visit ni.com/info and enter the Info Code pxisafeautofancontrol. Enhancements and Bug Fixes in Version 15.1New Hardware SupportAdded support for new PXI hardware. Fixed Issue: MAX Delay for Network-Capable Chassis374646: There was a short delay in MAX when viewing details for a chassis with a built-in Ethernet port. Enhancements and Bug Fixes in Version 15.0.2New Hardware SupportAdded support for new PXI hardware. Enhancements and Bug Fixes in Version 15.0.1New Hardware SupportAdded support for new PXI Express hardware. Enhancements and Bug Fixes in Version 15.0Self-Test for PXI Platform HardwareSelf-test is available for PXI chassis and embedded and remote controllers; this feature can be accessed through MAX and NI System Configuration API. Self-test verifies basic hardware functionality. Geographic AliasesPXI controllers, MXI modules, and the PXI-8250 now provide an alias that conveys information about their location in a system (for example, PXI2Slot1). You can see this alias in the Devices and Interfaces section in MAX. New Chassis Attributes in MAXHardware revision and PXI_CLK10 source information is now available for PXI chassis in MAX. Patch for PXIe-1085/PXIe-1078 ChassisPXI Platform Services 15.0 includes the PXIe-1085/PXIe-1078 patch that was released for PXI Platform Services 3.2.2 through 14.1. Visit ni.com/info and enter the Info Code pxipspatch_2015_en for more details about this patch. Fixed Issues: Improved MAX Stability378807, 440251, 507983, 520787, 520922: In some cases, there could be stability issues with PXI hardware in MAX. Fixed Issue: Duplicate Devices in MAX363174: MXI-4 and PXI-8360 devices were shown twice in Devices and Interfaces in MAX. Enhancements and Bug Fixes in Version 14.1New Hardware SupportAdded support for new PXI Express hardware. Fixed Issue: Could not create chassis item in Measurement & Automation Explorer (MAX)505008: When using the LabVIEW Real-Time Module with some older NI PXI controllers that are unable to automatically identify, the chassis could not be created in MAX. Enhancements and Bug Fixes in Version 14.0Driver Version Naming ChangesPXI Platform Services versions are now aligned with the versions of major NI application software products. This alignment gives you information about the year the driver was released and the most recent software version the driver was designed to work with. Driver versions now start with a two-digit year indicator: PXI Platform Services 14.0. For example, PXI Platform Services 14.0 is the version released with LabVIEW 2014. The last version released under the old numbering scheme is PXI Platform Services 4.0.1. The first version released under the new numbering scheme is PXI Platform Services 14.0. Runtime InstallerStarting with version 14.0, PXI Platform Services is available as a runtime installer. PXI Platform Services Runtime is a minimal installer which does not include configuration through Measurement & Automation Explorer (MAX). When building an installer using NI application development environments (ADEs) such as LabVIEW, you will now have the option of including this subset of PXI Platform Services in your distribution. System MonitorSupport for System Monitor is deprecated in PXI Platform Services and will be removed in a future release. Monitoring capabilities are available through the NI System Configuration API. Customers using System Monitor should migrate their applications to NI System Configuration API. Fixed issue: Chassis not automatically identified in MAX441696: When using a PXI Express Chassis and controller under a heavy load, the chassis could sometimes fail to auto-identify in MAX. Enhancements and Bug Fixes in Version 4.0.1New Hardware SupportAdded support for new PXI Express hardware. Enhancements and Bug Fixes in Version 4.0PXI Specification UpdatesPXI Platform Services 4.0 adds support for the new PXI-9 specification, revision 1.0. This version also includes updates to meet the requirements of the following PXISA specification versions: - PXI-2 Software Specification, revision 2.4
- PXI-4 Module Description, revision 1.1
- PXI-6 PXI Express Software Specification, revision 1.2
The PXI Express chassis description files now list the PXI specification compliance version. For more information on PXI specifications, go to pxisa.org. PXI Platform Services on Real-Time SystemsWhen deploying software to your Real-Time system, PXI Platform Services is now visible in the Add/Remove Software tree in Measurement & Automation Explorer (MAX). If you have more than one version of PXI Platform Services 4.0 or later installed on your host, you may select which version of PXI Platform Services will be deployed to the target. For more information about deploying software to Real-Time targets, see the MAX Help, available on the Help menu in MAX. Fixed Issues in Measurement & Automation ExplorerPXI Platform Services 4.0 fixes the following issues in MAX: - 37850: In some instances, NI PXI-8360 and PXI-MXI-4 devices may not be visible in MAX.
- 393204: In some cases, there could be stability issues with PXI hardware in MAX.
Enhancements and Bug Fixes in Version 3.2.3New Hardware SupportAdded support for new PXI Express hardware. Enhancements and Bug Fixes in Version 3.2.2New Hardware SupportAdded support for new PXI and PXI Express hardware. Removed Hardware SupportPXI Platform Services will no longer provide support for the following hardware: - PXI-1002 chassis
- PXI-1006 chassis
- PXI-1010 chassis
- PXI-1011 chassis
- PXI-1020 chassis
- PXI-1025 chassis
- PXI-8150 controller
- PXI-8150B controller
- PXI-8170 controller
- PXI-8174 controller
- PXI-8175 controller
- PXI-8176 controller
- PXIe-8103 controller
Enhancements and Bug Fixes in Version 3.2.1Windows 8 FixesMinor updates to improve the Windows 8 user experience. Enhancements and Bug Fixes in Version 3.2Windows 8 SupportPXI Platform Services 3.2 adds support for Windows 8 (32-bit and 64-bit). The following are known issues with Windows 8: - The fast startup capability introduced in Windows 8 may cause improper functioning of your hardware and device drivers. To properly initialize drivers, choose Restart or Shut Down when prompted at the end of the installation. To prevent future problems with installing or removing hardware, NI recommends disabling fast startup. Visit ni.com/info and enter the Info Code Win8FastStartup for more information.
- Upgrading from a Windows 7 (or older) system is not supported
NI PXI Express Remote Controller Firmware UpdaterPXI Platform Services has enabled the ability to update NI PXI Express Remote Controller Firmware. For more information, refer to the documentation of the specific firmware. Enhancements and Bug Fixes in Version 3.1NI PXI Express Chassis MonitoringAdded support for monitoring NI PXI Express chassis via NI System Configuration API. LabVIEW SupportSupport for LabVIEW 8.6 and LabVIEW 2009 is discontinued in this release. Enhancements and Bug Fixes in Version 3.0.4New Hardware SupportAdded support for new PXI and PXI Express hardware. Enhancements and Bug Fixes in Version 3.0.3New Hardware SupportAdded support for new PXI and PXI Express hardware. Enhancements and Bug Fixes in Version 3.0.2New Hardware SupportAdded support for new PXI and PXI Express hardware. Enhancements and Bug Fixes in Version 3.0.1Fixed Issue: Addressed failure with RT Reboot of Hypervisor System313181 Fatal exception, Code:0xC0000005 error, detected when restarting RT side of a Hypervisor system. Enhancements and Bug Fixes in Version 3.0Updates to Measurement & Automation Explorer Graphical User InterfacePXI Platform Services has updated the user interface for PXI Systems in Measurement & Automation Explorer. The following changes were made: - Better error detection.
- Improved performance.
- Identify bus as a chassis function replaced with Create New Chassis Wizard.
- Updated help.
- Controllers and MXI Modules now appear inside Slot View and Devices and Interfaces.
- Majority of National Instruments PXI embedded controllers are now automatically identified.
- MXI connectivity information is provided through Devices and Interfaces.
- Removed redundant PXI System tree under Devices and Interfaces.
LabVIEW SupportSupport for LabVIEW 8.5 is discontinued in this release. Enhancements and Bug Fixes in Version 2.5.6New Software SupportPXI Platform Services 2.5.6 adds support for PXI Express systems on NI Real-Time Hypervisor. LabVIEW 8.2 SupportSupport for LabVIEW 8.2 is discontinued in this release. Enhancements and Bug Fixes in Version 2.5.4Windows 2000PXI Platform Services 2.5.4 removes support for Windows 2000. Windows Server SupportPXI Platform Services 2.5.4 adds support for Windows Server 2003 R2 (32-bit only) and Windows Server 2008 R2. Enhancements and Bug Fixes in Version 2.5.3Windows 7 SupportPXI Platform Services 2.5.3 adds support for Windows 7 x86 (32-bit) and Windows 7 x64 (64-bit). Automating the Installation of NI ProductsYou can automate the installation of most NI products using command-line arguments to suppress some or all of the installer user interface and dialog boxes. However, starting with the August 2012 releases (products using NI Installers version 3.1 or later), you may need to perform additional steps before or during a silent installation of NI software. If the NI product you are installing uses Microsoft .NET 4.0, the .NET installer may run before any NI software installs and may require a reboot before the installation of NI software begins. To avoid a .NET reboot, install .NET 4.0 separately before you install NI software. For more information about automating the installation of NI products, refer to the following KnowledgeBase articles: - For more information on silent installations of individual NI products, refer to KB 4CJDP38M, Automating the Installation of a Single Installer.
- For more information on silent installations of NI products in a suite, such as NI Developer Suite, refer to KB 4GGGDQH0, Automating the Installation of a Suited Installer.
- To determine what version of NI Installers your product contains, refer to KB 4CJDR18M, How Can I Determine the Type and Version of My National Instruments Installer?.
Using NI Software with Microsoft Windows 10Microsoft Windows 10 is the latest version of the Windows operating system and features significant changes compared to previous versions. Windows 10 introduces several new capabilities and also combines features from both Windows 7 and Windows 8. For more information about NI support for Windows 10, visit ni.com/windows10. Using NI Software with Microsoft Windows 8.1When you install NI software on Microsoft Windows 8.1, you will notice a few additional tiles in the Apps view, including shortcuts to NI application software products such as NI LabVIEW, Measurement & Automation Explorer (NI MAX) and NI Launcher. For more information about NI support for Windows 8.1, visit ni.com/windows8. Legal InformationCopyright © 1998–2017 National Instruments. All rights reserved. Under the copyright laws, this publication may not be reproduced or transmitted in any form, electronic or mechanical, including photocopying, recording, storing in an information retrieval system, or translating, in whole or in part, without the prior written consent of National Instruments Corporation. National Instruments respects the intellectual property of others, and we ask our users to do the same. NI software is protected by copyright and other intellectual property laws. Where NI software may be used to reproduce software or other materials belonging to others, you may use NI software only to reproduce materials that you may reproduce in accordance with the terms of any applicable license or other legal restriction. End-User License Agreements and Third-Party Legal Notices You can find end-user license agreements (EULAs) and third-party legal notices in the following locations after installation: - Notices are located in the \_Legal Information and directories.
U.S. Government Restricted Rights If you are an agency, department, or other entity of the United States Government ("Government"), the use, duplication, reproduction, release, modification, disclosure or transfer of the technical data included in this manual is governed by the Restricted Rights provisions under Federal Acquisition Regulation 52.227-14 for civilian agencies and Defense Federal Acquisition Regulation Supplement Section 252.227-7014 and 252.227-7015 for military agencies. IVI Foundation Copyright Notice Content from the IVI specifications reproduced with permission from the IVI Foundation. The IVI Foundation and its member companies make no warranty of any kind with regard to this material, including, but not limited to, the implied warranties of merchantability and fitness for a particular purpose. The IVI Foundation and its member companies shall not be liable for errors contained herein or for incidental or consequential damages in connection with the furnishing, performance, or use of this material. Trademarks Refer to the NI Trademarks and Logo Guidelines at ni.com/trademarks for information on National Instruments trademarks. Other product and company names mentioned herein are trademarks or trade names of their respective companies. Patents For patents covering the National Instruments products/technology, refer to the appropriate location: Help» Patents in your software, the patents.txt file on your media, or the National Instruments Patent Notice at ni.com/patents. 374995D-01 |
