查看: 2804|回复: 0
[DataPlugin] FlexLogger插件开发套件1.0 Win64Eng NI Flexlogger Plugin Development Kit 1.8.0
    11 小时前
  • 签到天数: 3601 天
    连续签到: 9 天
    发表于 2020-10-11 22:53:25 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    FlexLogger插件开发套件扩展了FlexLogger软件,以从第三方硬件设备获取数据并控制第三方硬件设备。
    FlexLogger插件开发套件是一个附加软件工具,用于开发LabVIEW插件来实现与第三方仪器的通信。FlexLogger软件可自动生成所需的用户界面来配置插件测量。如果要编译这些插件,使其能够与FlexLogger软件一起使用,需要先安装LabVIEW和LabVIEW应用程序生成器模块。
    操作系统:
    Windows 7 (SP1) 64-bit
    Windows 8.1 64-bit
    Windows Server 2012 R2 64-bit
    文件大小: 166897664 字节 (159.17 MB)
    修改日期: 2019-06-28 21:30
    MD5: 3cbaf4a11d3c72fe5caab9eab4917c25(官方正确)
    SHA1: c64dab95f9d06266b877d62a951808d5118460c7
    SHA256: db30bfe8632767f5435fee4b816a21c7595259b5b0df629df37dd29825fc13b3
    CRC32: 7a098b27
    FlexLogger Plugin1.0.txt (330 Bytes, 下载次数: 0, 售价: 10 元)
    FlexLogger Plugin Development Kit 1.0 Readme
    July 2019
    This file contains important information about the FlexLogger Plugin Development Kit (version 1.0), including system requirements and installation instructions.
    The FlexLogger IO Plugin Development Kit consists of the following components:
    Component
    Where to Find
    FlexLogger Plugin Development Kit Manual for information on installation, development, debugging, and importing FlexLogger I/O plugins.:\Documents\National Instruments\FlexLogger\Plugins\FlexLogger Plugin Development Kit 1.0 Manual
    A LabVIEW FlexLogger IO Plugin template for a basic project to either consume or product data from or to FlexLogger.In LabVIEW, create a project and select FlexLogger IO Plugin from the Create Project window.
    LabVIEW APIs for your pluginIn LabVIEW on the Functions»FlexLogger palette.
    Examples of LabVIEW-based FlexLogger IO plugins.:\Program Files\National Instruments\LabVIEW 2019\examples\FlexLogger
    Refer to the FlexLogger 2019 R3 Readme and the LabVIEW 2019 Readme for system requirements.
    The FlexLogger Plugin Development Kit supports the following software:
    • LabVIEW 2019 (64-bit) or higher
    • FlexLogger 2019 R3 or higher
    Complete the following steps to install the FlexLogger IO Plugin Development Kit software:
    • Install LabVIEW 2019 (64-bit). Refer to the LabVIEW 2019 Readme for more information.
    • Install FlexLogger 2019 R3. Refer to the FlexLogger 2019 R3 Readme for more information.
    • Open NI Package Manager and search for FlexLogger Plugin Development Kit.
    • Select FlexLogger Plugin Development Kit and click Install.
    • Follow the instructions on the following screens to complete installation.
    Accessing the HelpFlexLogger Manual
    The online FlexLogger manual contains the most current help for your product version. Refer to the FlexLogger Manual, accessible from Help»Online manual, for more information about using FlexLogger.
    Users without online access can choose to use an offline version of the FlexLogger manual if that option is selected at installation. To enable the use of the offline FlexLogger manual, go to Preferences»General and select Use the installed FlexLogger manual.
    LabVIEW Help
    Refer to the LabVIEW Help, accessible by selecting Help»LabVIEW Help from LabVIEW, for information about LabVIEW.
    Navigate to :\Program Files\National Instruments\LabVIEW 2019\examples\FlexLogger to find LabVIEW examples for the FlexLogger Plugin Development Kit. You can modify an example VI to fit an application, or you can copy and paste from one or more examples into a VI that you create.
    © 2019 National Instruments. All rights reserved.
    378088A-01
    GMT+8, 2025-7-22 21:36
