查看: 2476|回复: 0
[LabVIEW] LabVIEW for LEGO Mindstorms 2014SP1
    昨天 08:12
  • 签到天数: 3646 天
    连续签到: 8 天
    发表于 2020-10-13 21:36:20 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    LabVIEW for LEGO MINDSTORMS可帮助学生使用基于EV3和NXT的LEGO MINDSTORMS机器人技术。
    LabVIEW for LEGO MINDSTORMS是系统工程软件,学生可以在教室或机器人竞赛中结合LEGO Education机器人平台使用该软件。该软件可作为教学工具,帮助学生对LEGO MINDSTORMS机器人进行视觉控制和编程。LabVIEW for LEGO MINDSTORMS可以将任何LEGO MINDSTORMS Education改造成为科学和工程学习平台。该软件还包括教程和交互式测试,旨在进一步提高学生的LabVIEW技能。LEGO、LEGO商标和MINDSTORMS是LEGO集团的注册商标。 版权.2019 the LEGO Group.
    文件大小: 2141208576 字节 (1.99 GB)
    修改日期: 2017-07-13 20:58
    MD5: 3794ed08ae57098145920d2368ac07f3(官方正确)
    SHA1: d7a98af453f9b1130b354f4d3e0d95dd1289ac7a
    SHA256: 6f1c552ec3edc4df13c2f6e61c98dcdb0a65dcf92a48d8f5571291c6cc3f693a
    CRC32: e68d0c9e
    LV4LEGO2014SP1.txt (296 Bytes, 下载次数: 0, 售价: 10 圆)
    LabVIEW for LEGO® MINDSTORMS® Readme for Windows
    April 2015
    LabVIEW for LEGO® MINDSTORMS® is a software programming environment tailored for use with the LEGO NXT or EV3 brick. You can use LabVIEW for LEGO MINDSTORMS to teach and learn science and engineering concepts through a project-based curriculum. This readme file contains important information about the software.
    Choosing a Custom Environment
    Installation and Activation
    Finding Help
    LabVIEW for LEGO MINDSTORMS installs the following products. Refer to the readme of each product for information specific to that product.
    • LabVIEW 2014 Service Pack 1 (SP1)
    • LabVIEW for LEGO® MINDSTORMS® custom environment
    • LabVIEW 2014 SP1 Module for LEGO® MINDSTORMS®
    LabVIEW for LEGO MINDSTORMS has the following system requirements:
    • Windows 8/7/Vista/XP SP3 (32-bit)
      • LabVIEW for LEGO MINDSTORMS is a 32-bit application that also runs on 64-bit versions of Windows 8, Windows 7, and Windows Vista.
    • 2.79 GB of disk space for installation of all products
    Refer to the LabVIEW 2014 SP1 Readme on ni.com for information about system requirements for LabVIEW 2014 SP1.
    LabVIEW for LEGO MINDSTORMS allows you to work in customized environments depending on which palettes and options you want readily accessible. You can switch between the LabVIEW for LEGO® MINDSTORMS® environment, which lets you focus on programming the NXT or EV3 brick, or the full LabVIEW environment, which displays all LabVIEW options and palettes. To choose an environment, select Tools»Choose Environment.
    The following items are a subset of issues fixed since the last release of LabVIEW for LEGO MINDSTORMS.
    • Wait For VIs added for EV3 sensors.
    • LEGO Steering On VI added for steering support for LEGO Motors.
    • The NXT/EV3 Terminal and Robot Project Center notifies the user if a brick in firmware update mode is detected.
    Refer to the National Instruments website for a list of bug fixes in LabVIEW 2014 SP1.
    The LabVIEW for LEGO MINDSTORMS software contains the following known issues at the time of release:
    • A LabVIEW crash, an error message about Fantom.dll, and inconsistent behavior from the NXT/EV3 Terminal are all consequences of deleting dependencies of Fantom.dll. To correct this behavior, navigate to the Control Panel\Programs\Programs and Features directory, and repair the LEGO MINDSTORMS NXT Driver installation.
    • After you connect to an NXT or EV3 brick using Bluetooth, the Find NXT/EV3 window displays the brick as available for connection even when Bluetooth is disabled or the brick is not present. If you try to connect to the brick when the Bluetooth connection is off, the display updates the status to unavailable.
    • The Moving output of the Motor Status VI is TRUE only when performing a move with the Move a Fixed Distance VI. These Boolean outputs always return FALSE if the move initiates with the Move DC Motors VI.
    • The following code is not supported in VIs that you download to an EV3 brick:
      • Some auto-indexing capabilities on While Loops—Auto-indexing input tunnels are supported.
      • Compare Elements mode for the Max & Min function is not supported for arrays and clusters.
      • Conditional terminals or parallelism on For Loops
      • Formula Nodes
      • Complex numbers used with the asin, acos, atan, and atan2 functions.
    • The following code is not supported in VIs that you download to an NXT brick:
      • Formula Nodes
      • Byte Array To String functions if you try to coerce a 32-bit array
      • Numeric operations involving a cluster and an array of clusters
      • Not function if you try to negate an array
      • Divide function if both inputs are zeros—Divide function returns zero instead of NaN.
      • Conversion functions if you try to convert floating point numbers to integers—Outputs are truncated instead of rounded to the nearest integer.
    • The Value property does not update front panel objects. Use local variables or wire values directly to terminals to update front panel objects.
    • Filenames with special or multibyte characters are not supported in the Robot Project Center.
    • Unexpected behavior can occur in the Schematic Editor when you work on a remote desktop.
    • When adding an image for your robot project profile, use an image that is 123 × 89 pixels (width × height).
    • In Direct Mode, the Draw VIs that are instances of the Display polymorphic VI do not clear the screen before drawing over the running program or menu screen. To avoid this, use the Clear Display VI before using the Draw VIs.
    • The LabVIEW Module for LEGO MINDSTORMS API is not supported in Application Builder.
    • If a VI targeted to an NXT or EV3 brick is open when you change environments by selecting Tools»Choose Environment, the menus of that VI become unresponsive. Click the X in the corner of the VI window to close the VI.
    Refer to the LabVIEW for LEGO MINDSTORMS DVD packaging for information about installing and activating LabVIEW for LEGO MINDSTORMS.
    Finding Help
    Follow the steps in the printed LabVIEW for LEGO MINDSTORMS Quick Start Guide to start using the software immediately.
    Refer to the LabVIEW LEGO MINDSTORMS NXT Module Help, accessible by selecting Help»MINDSTORMS Module Help in LabVIEW, for detailed information about the LabVIEW Module for LEGO MINDSTORMS included with LabVIEW for LEGO MINDSTORMS.
    Refer to the LabVIEW Help, accessible by selecting Help»LabVIEW Help in LabVIEW, for information about advanced LabVIEW concepts and procedures.
    In LabVIEW for LEGO MINDSTORMS, select Help»Find Examples and then select Toolkits and Modules»NXT Robotics in the NI Example Finder window. You can modify an example VI to fit an application, or you can copy and paste from one or more examples into a VI that you create. You can also refer to the labview\examples\NXT Robotics directory for example VIs that demonstrate common tasks using the LabVIEW Module for LEGO MINDSTORMS.
    Using NI Launcher
    Note  Unlike previous versions of Microsoft Windows, MAX does not appear as a desktop shortcut. You can launch MAX either from the Start screen or from within NI Launcher.
    Finding All Programs
    Important Information
    © 2009–2015 National Instruments. All rights reserved.
    Refer to the NI Trademarks and Logo Guidelines at ni.com/trademarks for information on National Instruments trademarks.
    LEGO and MINDSTORMS are trademarks of the LEGO Group. Other product and company names mentioned herein are trademarks or trade names of their respective companies.
    GMT+8, 2025-9-9 03:22
