查看: 3275|回复: 0
[LV工具模块] LabVIEW 2016 LEGO MINDSTORMS Module for MAC
    前天 16:03
    发表于 2020-10-15 00:09:34 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    LEGO MINDSTORMS Module for LabVIEW
    LEGO MINDSTORMS Module模块用于帮助学生使用基于LEGO MINDSTORMS EV3和NXT的机器人。
    LEGO MINDSTORMS模块是用于LabVIEW的一款系统工程软件,学生可以在教室或机器人竞赛中结合LEGO Education机器人平台使用该软件。该软件可作为教学工具,帮助学生对LEGO MINDSTORMS机器人进行视觉控制和编程。LEGO MINDSTORMS模块可以将任何LEGO MINDSTORMS Education平台改造为科学和工程学习平台。该模块还提供包括教程和交互式练习,旨在帮助学生进一步提高LabVIEW技能。LEGO、LEGO商标和MINDSTORMS是LEGO集团的注册商标。 版权.2020 the LEGO Group。
    2016
    文件大小: 112217310 字节 (107.02 MB)
    修改日期: 2016-06-06 23:40
    MD5: 729f891f1084acebc209c0b574f767dc(官方正确)
    SHA1: 95987231b41ecbd054dfa003073e5348486c363a
    SHA256: 04fac736b65cdb12d658e5c7e036e8dfa5cc10d6da8015de4cbdbdf2a599a8f0
    CRC32: 3e757ecf
    LMM2016.txt (378 Bytes, 下载次数: 0, 售价: 10 圆)
    LabVIEW 2016 Module for LEGO® MINDSTORMS® Readme for OS X
    June 2016
    This file contains information about the LabVIEW Module for LEGO® MINDSTORMS®, including bugs fixed for this release and a list of known issues.
    Finding Applications and Examples
    Use the LabVIEW Module for LEGO MINDSTORMS to create VIs that either run directly on an NXT or EV3 brick or that run on a host computer and communicate with an NXT or EV3 brick through a USB, Bluetooth, or Wi-Fi connection.
    The LabVIEW 2016 Module for LEGO MINDSTORMS requires the LabVIEW 2016 Full or Professional Development System.
    Refer to the LabVIEW 2016 Readme on the National Instruments website for information about system requirements for LabVIEW 2016.
    The following items are a subset of fixed issues since the last release of LabVIEW Module for LEGO MINDSTORMS.
    • 528913—Steering On runs motors in Remote mode.
    • 581245—Direct Only VIs are accessible from the Mail polymorphic VI to more easily support messaging to and from the host.
    • 581306—NOT, NOR, NAND, XNOR are supported for integers on NXT.
    Refer to the National Instruments website for a list of bug fixes in LabVIEW 2016.
    The following list describes known issues at the time of release:
    • The Moving output of the Motor Status VI is TRUE only when performing a move with the Move a Fixed Distance VI. These Boolean outputs always return FALSE if the move initiates with the Move DC Motors VI.
    • The following code is not supported in VIs that you download to an EV3 brick:
      • Some auto-indexing capabilities on While Loops—Auto-indexing input tunnels are supported.
      • Compare Elements mode for the Max & Min function is not supported for arrays and clusters.
      • Conditional terminals or parallelism on For Loops
      • Formula Nodes
      • Complex numbers used with the asin, acos, atan, and atan2 functions.
    • The following code is not supported in VIs that you download to an NXT brick:
      • Byte Array To String functions if you try to coerce a 32-bit array
      • Numeric operations involving a cluster and an array of clusters
      • Not function if you try to negate an array
      • Divide function if both inputs are zeros—Divide function returns zero instead of NaN.
      • Conversion functions if you try to convert floating-point numbers to integers—Outputs are truncated instead of rounded to the nearest integer.
      • Formula Nodes
    • The Value property does not update front panel objects. Use local variables or wire values directly to terminals to update front panel objects.
    • Filenames with special or multibyte characters are not supported in the Robot Project Center.
    • Unexpected behavior can occur in the Schematic Editor when you work on a remote desktop.
    • When adding an image for your robot project profile, use an image that is 123 × 89 pixels (width × height).
    • In Direct Mode, the Draw VIs that are instances of the Display polymorphic VI do not clear the screen before drawing over the running program or menu screen. To avoid this, use the Clear Display VI before using the Draw VIs.
    • The LabVIEW Module for LEGO MINDSTORMS API is not supported in Application Builder.
    Refer to the following documents for more information about the LabVIEW Module for LEGO MINDSTORMS:
    • LabVIEW LEGO MINDSTORMS NXT Module Help—Use the LabVIEW LEGO MINDSTORMS NXT Module Help to access information about LabVIEW Module for LEGO MINDSTORMS programming concepts, step-by-step instructions for using the LabVIEW Module for LEGO MINDSTORMS, and reference information about the NXT/EV3 VIs, palettes, menus, dialog boxes, and so on. Access the LabVIEW LEGO MINDSTORMS NXT Module Help by selecting Help»MINDSTORMS Module Help.
    • LabVIEW Help—Refer to the LabVIEW Help, accessible by selecting Help»LabVIEW Help in LabVIEW, for information about advanced LabVIEW concepts and procedures.
    Select Tools»NXT/EV3 Application Browser to access applications that you can run on an NXT or EV3 brick. These applications demonstrate several types of programs you can create with the LabVIEW Module for LEGO MINDSTORMS.
    Access example VIs that demonstrate common tasks using the LabVIEW Module for LEGO MINDSTORMS in the NI Example Finder by selecting Help»Find Examples from the pull-down menu and selecting Toolkits and Modules»NXT Robotics in the NI Example Finder window. You also can access these VIs by referring to the labview\examples\NXT Robotics directory. You can modify an example VI to fit an application, or you can copy and paste from one or more examples into a VI that you create.
    Important Information
    © 2009–2016 National Instruments. All rights reserved.
    You can find third-party legal notices in the /Library/Application Support/National Instruments/Legal Information directory.
    Refer to the NI Trademarks and Logo Guidelines at ni.com/trademarks for information on National Instruments trademarks.
    LEGO and MINDSTORMS are trademarks of the LEGO Group. Other product and company names mentioned herein are trademarks or trade names of their respective companies.
    GMT+8, 2026-2-25 02:43
