查看: 3050|回复: 0
[NI驱动程序] NI-DCPower 1.0 Driver Win32/64Eng NI DC电源仪器驱动程序下载1.0
    3 小时前
  • 签到天数: 3786 天
    连续签到: 37 天
    发表于 2020-10-16 23:33:08 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    NI-DCPower
    1.0
    文件大小: 467670674 字节 (446.01 MB)
    修改日期: 2007-07-11 04:36
    MD5: 7ed9c4296908acbfff936914b852b916(官方正确)
    SHA1: 1b09bf65227c091489ea16ed2c883dc503f2612d
    SHA256: 9187cd9faf04df67009844538d39c4479b54bc674b771d77a6c80bf36285c529
    CRC32: 58e455ad
    DCPower1.0.txt (260 Bytes, 下载次数: 0, 售价: 10 圆)
    NI-DCPower Readme
    National Instruments™, NI™, ni.com™ and LabVIEW™ are trademarks of National Instruments Corporation. Product and company names mentioned herein are trademarks or trade names of their respective companies.
    © Copyright 2006 National Instruments Corporation. All rights reserved.
    Version 1.0
    Thank you for using NI-DCPower.
    This file contains important information about NI-DCPower and is organized into the following sections:
    • Supported Hardware
    • System Requirements
      • Software
      • Documentation
    • Uninstalling/Modifying NI-DCPower
    • Examples
    • Known Issues
    NI-DCPower 1.0 and later supports the following power supply:
    • NI PXI-4110
    System RequirementsMinimum System
    • Processor—Pentium 200 MHz or equivalent
    • RAM—64 MB
    • A screen resolution of 800×600 with 256 colors
    • Windows 2000/XP, with all available critical updates and service packs
    Recommended System
    • RAM—256 MB
    • A screen resolution of 1024×768
    • LabVIEW 7.0 or later
    • LabWindows™/CVI™ 7.0 or later
    • Microsoft Visual Basic 6.0
    Installed File Names and LocationsSoftware
    ItemInstalled Location
    NI-DCPowerProgram Files\IVI\Drivers\niDCPower
    DocumentationProgram Files\IVI\Drivers\niDCPower\Documentation\
    NI-DCPower LabVIEW support\instr.lib\niDCPower
    NI-DCPower LabVIEW Examples\examples\instr\niDCPower
    NI-DCPower CVI 7.0 or later supportProgram Files\IVI\Drivers\niDCPower
    NI-DCPower CVI Examples\samples\niDCPower
    NI-DCPower VB ExamplesProgram Files\IVI\Drivers\niDCPower\Examples\VisualBasic
    NI-DCPower Test PanelProgram Files\IVI\Drivers\niDCPower
    LabVIEW Run-Time Engine 7.1Program Files\National Instruments\Shared\LabVIEW Run-Time\7.1
    NI-DAQmx 8.0Program Files\National Instruments\NI-DAQ
    IVI Compliance Package 2.3Program Files\National Instruments\IVI
    NI-VISA 3.4WINDOWS\system32
    Documentation is available at Start»All Programs»National Instruments»NI-DCPower»Documentation. The documentation set is composed of the following documents:
    • NI-DCPower Readme
    • NI DC Power Supplies Getting Started Guide
      Printed and PDF format. Includes hardware and software installation, MAX configuration, and signal connection information.
    • NI DC Power Supplies Help
      HTML help format. Includes power supply fundamentals, hardware device overview, programming information, LabVIEW reference, and C/CVI/VB reference sections.
    • NI PXI-4110 Specifications
      Printed and PDF format. Lists specifications for the NI PXI-4110 triple-output, programmable DC power supply.
    • NI PXI-4110 Calibration Procedure
      PDF format. Includes calibration instructions for the NI PXI-4110.
    • Maintain Forced-Air Cooling Note to Users
      Printed format. Includes important cooling information for NI DC power supplies.
    • Readme First: Safety and Radio-Frequency Interference
      Printed format. Includes safety instructions and information about the radio-frequency interference characteristics of the hardware it accompanies.
    For Windows 2000/XP, complete the following steps to uninstall or modify NI-DCPower:
    • Open the Control Panel from the Start»Control Panel Menu and select Add or Remove Programs.
    • Select National Instruments Software from the list provided and click Change or Remove.
    • Select NI-DCPower 1.0 from the list provided and choose Modify or Remove.
    Examples
    Refer to Start»All Programs»National Instrument»NI-DCPower»Examples for the examples for the supported ADEs.
    Refer to the Installed File Names and Locations section for the installed locations of the example sets.
    • Accessing the NI-DCPower API in LabVIEW 7.x
      • (LabVIEW 7.x) From the Functions palette, select All Functions»Instrument I/O»Instrument Drivers»NI-DCPower.
      • (LabVIEW 8.0 or later) From the Functions palette, select Measurement I/O»NI-DCPower.
    • SignalExpress 1.1.1 and the IVI Power Supply step
    The IVI Power Supply step does not support NI-DCPower in Signal Express 1.1.1. Use the native NI-DCPower Express step to access NI-DCPower from within SignalExpress 1.1.1.
    GMT+8, 2026-1-28 10:54
