查看: 2935|回复: 0
[NI驱动程序] NI-DCPower Driver 1.2.2 Win32/64Eng NI DC电源仪器驱动程序下载1.2.2
    3 小时前
  • 签到天数: 3786 天
    连续签到: 37 天
    发表于 2020-10-16 23:44:29 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    NI-DCPower
    1.2.2
    文件大小: 877139614 字节 (836.51 MB)
    修改日期: 2008-08-14 01:21
    MD5: 930bd43ce74374a075329a933dd0e6a3(官方正确)
    SHA1: e3095a1c78b45eef5eb750f8620e252179c39e0d
    SHA256: e6e2fe1f68cddaed73c8b3f962961631d0ab07dce6c5dc2b4aae36fa3a444f98
    CRC32: ac779134
    DCPower1.2.2.txt (261 Bytes, 下载次数: 0, 售价: 10 圆)
    NI-DCPower Readme
    Version 1.2.2
    Thank you for using NI-DCPower for Windows Vista/XP/2000.
    This file contains important information about NI-DCPower and is organized into the following sections:
    • New Features in Version 1.2.2
    • Supported Hardware
    • System Requirements
      • Software
      • Documentation
      • Examples
    • Uninstalling/Modifying NI-DCPower
    • Known Issues
    • Changes by Release
    • Added support for LabVIEW 8.6
    • Removed support for LabVIEW 8.0
    NI-DCPower 1.2.2 and later supports the following power supply and SMU:
    • NI PXI-4110
    • NI PXI-4130
    NOTE:  If you are using a PXI product, notice that MXI-4 is supported under Windows Vista/XP/2000, but MXI-3 is supported under only Windows XP/2000.
    NI-DCPower 1.2.2 and later supports Windows Vista/XP/2000. It is recommended that you have the most recent service pack for your operating system installed.
    Minimum System
    • Processor—Pentium 200 MHz or equivalent
    • RAM—64 MB
    • A screen resolution of 800×600 with 256 colors
    • Windows XP/2000, with all available critical updates and service packs
    Recommended System
    • RAM—256 MB
    • A screen resolution of 1024×768
    • Windows Vista/XP/2000, with all available critical updates and service packs
    • LabVIEW 7.1, 8.2, 8.5, and 8.6
    • LabVIEW Real-Time Module 7.1.1, 8.2, 8.5, and 8.6
    • LabWindows™/CVI™ 7.1, 8.0, 8.1, and 8.5
    • Microsoft Visual Basic 6.0
    Installed File Names and LocationsSoftware
    FilesInstallation Location on Windows XP/2000 and 32-Bit Version of Windows VistaInstallation Location on 64-Bit Version of Windows Vista
    NI-DCPowerProgram Files\IVI\Drivers\niDCPowerProgram Files (x86)\IVI\Drivers\niDCPower
    DocumentationProgram Files\IVI\Drivers\niDCPower\Documentation\Program Files (x86)\IVI\Drivers\niDCPower\Documentation\
    LabVIEW support\instr.lib\niDCPower\instr.lib\niDCPower
    LabVIEW examples\examples\instr\niDCPower\examples\instr\niDCPower
    CVI supportProgram Files\IVI\Drivers\niDCPowerProgram Files (x86)\IVI\Drivers\niDCPower
    CVI 7.1, 8.0, and 8.1 examples\samples\niDCPower\samples\niDCPower
    CVI 8.5 examples\Documents\National Instruments\CVI\samples\niDCPower\Documents\National Instruments\CVI\samples\niDCPower
    VB examplesProgram Files\IVI\Drivers\niDCPower\Examples\VisualBasicProgram Files (x86)\IVI\Drivers\niDCPower\Examples\VisualBasic
    NI-DCPower SFPProgram Files\IVI\Drivers\niDCPowerProgram Files (x86)\IVI\Drivers\niDCPower
    LabVIEW Run-Time Engine 8.5.1Program Files\National Instruments\Shared\LabVIEW Run-Time\8.5Program Files (x86)\National Instruments\Shared\LabVIEW Run-Time\8.5
    NI-DAQmx 8.7.2Program Files\National Instruments\NI-DAQProgram Files (x86)\National Instruments\NI-DAQ
    IVI Compliance Package 3.3Program Files\National Instruments\IVIProgram Files (x86)\National Instruments\IVI
    NI-VISA 4.4WINDOWS\system32WINDOWS\sysWOW64
    Measurement & Automation Explorer 4.5Program Files\National Instruments\MAXProgram Files (x86)\National Instruments\MAX
    Documentation is available at Start»All Programs»National Instruments»NI-DCPower»Documentation. The documentation set is composed of the following documents:
    • NI-DCPower Readme
    • NI DC Power Supplies and SMUs Getting Started Guide
      Printed and PDF format. Includes hardware and software installation, MAX configuration, and signal connection information.
    • NI DC Power Supplies and SMUs Help
      HTML help format. Includes power supply fundamentals, hardware device overview, programming information, LabVIEW reference, and C/CVI/VB reference sections.
    • NI PXI-4110 Specifications
      Printed and PDF format. Lists specifications for the NI PXI-4110 triple-output, programmable DC power supply.
    • NI PXI-4110 Calibration Procedure
      PDF format. Includes calibration instructions for the NI PXI-4110.
    • NI PXI-4130 Specifications
      Printed and PDF format. Lists specifications for the NI PXI-4130 dual-channel, power source-measure unit (SMU).
    • NI PXI-4130 Calibration Procedure
      PDF format. Includes calibration instructions for the NI PXI-4130.
    • Maintain Forced-Air Cooling Note to Users
      Printed format. Includes important cooling information for NI DC power supplies and SMUs.
    • Readme First: Safety and Radio-Frequency Interference
      Printed format. Includes safety instructions and information about the radio-frequency interference characteristics of the hardware it accompanies.
    Examples
    Refer to Start»All Programs»National Instrument»NI-DCPower»Examples for the examples for the supported ADEs.
    Refer to the Installed File Names and Locations section for the installed locations of the example sets.
    For Windows 2000/XP, complete the following steps:
    • Launch the Control Panel by selecting Start»Settings.
    • Double-click Add/Remove Programs.
    • Click Change/Remove.
    • Select NI-DCPower 1.x from the dialog box that appears.
    For Windows Vista, complete the following steps:
    • Accessing the NI-DCPower API in LabVIEW 7.1
      • (LabVIEW 7.1) From the Functions palette, select All Functions»Instrument I/O»Instrument Drivers»NI-DCPower.
      • (LabVIEW 8.2 or later) From the Functions palette, select Measurement I/O»NI-DCPower.
    • SignalExpress 1.1.1 and the IVI Power Supply step
      The IVI Power Supply step does not support NI-DCPower in Signal Express 1.2. Use the native NI-DCPower Express step to access NI-DCPower from within SignalExpress 1.1.1.
    • Running the NI-DCPower Simultaneous Update CVI example under Windows Vista
      The Installer Detection feature in Windows Vista requests elevated privileges to run the NI-DCPower Simultaneous Update CVI example. To successfully launch the example from CVI, you must run CVI with elevated privileges. To run CVI with elevated privileges, right-click the NI LabWindows CVI icon and select the "Run as administrator" option from the context menu. Then, launch the NI-DCPower Simultaneous Update example in CVI.
    • If you click a topic link in the NI–DCPower Function Reference Help section of the NI DC Power Supplies and SMUs Help, you cannot use the Back button in the HTML Help window toolbar to return to the original topic.
    • When you run setup.exe to install the software from the CD, you are prompted to choose whether you want to always trust software from National Instruments. If you do not select this option, your installation may be interrupted by one or more Microsoft Windows security dialog boxes. However, if you run setup from the command line, you will not receive this prompt, and the installer will automatically install NI's Software Publisher Certificate to the your Windows Trusted Publisher Store. If you do not want to make this change to your Windows Trusted Publisher Store, do not choose this installation method.
    • NI recommends that you disable Windows power management modes, such as sleep, standby, and hibernate, when using this product. These modes terminate any NI-DCPower operation in progress. Notice that in Windows Vista or on a laptop computer, the default power management settings are likely to enable sleep mode.
    Changes by Release1.2.2 from 1.2.1
    1.2.1 from 1.2
    • Added increment/decrement buttons to the voltage/current controls of the NI-DCPower Express VI
    1.2 from 1.1.2
    • Support for the NI PXI-4130 dual-channel, power SMU
    • Support for the NI-DCPower Soft Front Panel (SFP)
    © 2006–2008 National Instruments Corporation. All rights reserved.
    GMT+8, 2026-1-28 10:54
