查看: 3132|回复: 0
[NI驱动程序] NI-DCPower Driver 1.5 Win32/64Eng NI DC电源仪器驱动程序下载1.5
    3 小时前
  • 签到天数: 3786 天
    连续签到: 37 天
    发表于 2020-10-16 23:51:02 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    NI-DCPower
    1.5
    文件大小: 1425603368 字节 (1.33 GB)
    修改日期: 2010-11-11 01:35
    MD5: fe2a9bb90c0f56d5e124e160daebd4b8(官方正确)
    SHA1: ba23ee250bb83bb4fdcf3cda802311f44ea6ceb8
    SHA256: 0e6bb58358ce73b9b12a76714ede652cfa2b7ae44e465a399f7d4a485bc508a2
    CRC32: cd544eec
    DCPower1.5.0.txt (259 Bytes, 下载次数: 0, 售价: 10 圆)
    NI-DCPower Readme
    Version 1.5
    Thank you for using NI-DCPower. This file contains important information about NI-DCPower and is organized into the following sections:
    • New Features
    • Supported Hardware
    • System Requirements
      • Software
      • Documentation
      • Examples
    • Uninstalling/Modifying NI-DCPower
    • Known Issues
    • Bug Fixes
    New Features in Version 1.5
    • Support for NI PXIe-4154
    • Support for channel-based sessions
    • Support for measure records
    • The NI PXI-4132 now supports streaming sequences, allowing the size of a sequence to be virtually unlimited.
    New Features in Version 1.4.1
    • Support for LabVIEW 2010 (32-bit and 64-bit)
    • Support removed for LabVIEW 8.2.1
    • Support for LabVIEW 2009 (64-bit)
    • Support for NI PXI-4132
    • Support for 64-bit user mode
    New Features in Version 1.3.1
    • Support for LabVIEW 2009 (32-bit)
    • Support removed for LabVIEW 7.1.1
    • Japanese localization for driver, LabVIEW application programming interface (API), and documentation
    • New behavior: Error and self-test message strings now return localized values in LabVIEW. User applications that check the value of these strings (or trap errors by comparing the error cluster) may experience a change in behavior.
    NI-DCPower 1.5 and later supports the following power supply and source-measure units (SMUs):
    • NI PXI-4110
    • NI PXI-4130
    • NI PXI-4132
    • NI PXIe-4154
    NOTE:  If you are using a PXI product, notice that MXI-4 is supported under Windows 7/Vista/XP, but MXI-3 is only supported under Windows XP.
    NI-DCPower 1.5 and later supports the following operating systems:
    • Windows XP (32-bit)
    NOTE:  NI-DCPower 1.5 and later does not support Windows Server non-R2 editions.
    It is recommended that you have the most recent service pack for your operating system installed. Windows 2000 users must use NI-DCPower 1.4 or earlier.
    NI-DCPower 1.5 and later supports the following real-time operating environments:
    • LabVIEW Real-Time Module
    Minimum System
    • Processor—Pentium 200 MHz or equivalent
    • RAM—64 MB
    • A screen resolution of 800×600 with 256 colors
    • Windows XP, with all available critical updates and service packs
    Recommended System
    • RAM—256 MB
    • A screen resolution of 1024×768
    • Windows 7/Vista/XP, with all available critical updates and service packs
    • LabVIEW 8.5.1, 8.6.1, 2009 (32-bit), 2009 (64-bit), 2010 (32-bit), or 2010 (64-bit)
    • LabVIEW Real-Time Module 8.5.1 or later
    • LabWindows™/CVI™ 8.1.1 or later
    • LabWindows/CVI Real-Time Module 8.1 or later
    • Microsoft Visual Basic 6.0
    Installed File Names and LocationsSoftware
    • National Instruments file folder location, :
      • Windows 7/Vista/XP 32-bit: Program Files\IVI Foundation\IVI\
      • Windows 7/Vista 64-bit: Program Files (x86)\IVI Foundation\IVI\
        NOTES:$(IVIROOTDIR32) is configured as an environment variable on the target system.
        • Windows 7/Vista/XP 32-bit: Program Files\IVI\
        • Windows 7/Vista 64-bit: Program Files (x86)\IVI\
      • Windows Vista 64-bit: Program Files\IVI Foundation\IVI\
        NOTE:$(IVIROOTDIR64) is configured as an environment variable on the target system.
    ItemInstalled Location on Windows 7/Vista/XP
    NI-DCPower\Drivers\niDCPower
    NI-DCPower Function Panel\Drivers\niDCPower\niDCPower.fp
    NI-DCPower Examples\niDCPower\Examples
    NI-DCPower Header files\Include
    NI-DCPower Import Library files (32-bit)\Lib
    NI-DCPower Import Library files (64-bit)\Lib_x64
    NI-DCPower DLL (32-bit)\Bin
    Additional File Locations for Windows 7/Vista 64-bit
    ItemInstalled Location on Windows 7/Vista 64-bit
    NI-DCPower DLL (64-bit)\Bin
    Documentation is available at Start»All Programs»National Instruments»NI-DCPower»Documentation. The documentation set is composed of the following documents:
    • NI-DCPower Readme
    • NI DC Power Supplies and SMUs Getting Started Guide
      Printed and PDF format. Contains hardware and software installation, MAX configuration, and signal connection information.
    • NI DC Power Supplies and SMUs Help
      HTML help format. Contains power supply fundamentals, hardware device overview, programming information, LabVIEW reference, and C/CVI/VB reference sections.
    • NI PXI-4110 Specifications
      Printed and PDF format. Lists specifications for the NI PXI-4110 triple-output, programmable DC power supply.
    • NI PXI-4110 Calibration Procedure
      PDF format. Contains calibration instructions for the NI PXI-4110.
    • NI PXI-4130 Specifications
      Printed and PDF format. Lists specifications for the NI PXI-4130 dual-channel, power SMU.
    • NI PXI-4130 Calibration Procedure
      PDF format. Contains calibration instructions for the NI PXI-4130.
    • NI PXI-4132 Specifications
      Printed and PDF format. Lists specifications for the NI PXI-4132 single-channel, precision SMU.
    • NI PXI-4132 Calibration Procedure
      PDF format. Contains calibration instructions for the NI PXI-4132.
    • NI PXIe-4154 Specifications
      Printed and PDF format. Lists specifications for the NI PXIe-4154 battery simulator.
    • NI PXIe-4154 Calibration Procedure
      PDF format. Contains calibration instructions for the NI PXIe-4154.
    • Maintain Forced-Air Cooling Note to Users
      Printed format. Contains important cooling information for NI DC power supplies and SMUs.
    • Read Me First: Safety and Electromagnetic Compatibility
      Printed format. Contains safety instructions and electromagnetic compatibility (EMC) information for the hardware it accompanies.
    Examples
    Refer to Start»All Programs»National Instruments»NI-DCPower»Examples for the examples for the supported ADEs.
    Refer to the Installed File Names and Locations section for the installed locations of the example sets.
    • Launch the Control Panel by selecting Start»Settings.
    • Double-click Add/Remove Programs.
    • Click Change/Remove.
    • Select NI-DCPower 1.x from the dialog box that appears.
    As part of the NI-DCPower installation, the following list of software was installed. To completely remove NI-DCPower from your system, you must remove all of these packages also.
    • NI IVI Compliance Package 4.2
    • NI Measurement & Automation Explorer 4.7
    • NI-DAQmx 9.1.5
    • NI-VISA 5.0
    • NI Spy 2.7.2
    • When linking to a topic in the NI DC Power Supplies and SMUs Help from the context help or opening the help file from a VI within LabVIEW, the NI DC Power Supplies and SMUs Help launches and the relevant topic displays, but the location of the topic might not be highlighted in the table of contents.
    • NI-DCPower devices might not be visible in Measurement & Automation Explorer (MAX) when deploying to a LabVIEW Real-Time target. For more information, search ni.com/kb using the code 4RCAMBD4.
    • SignalExpress 1.2 or earlier and the IVI Power Supply step
      The IVI Power Supply step does not support NI-DCPower in Signal Express 1.2 or earlier. Use the native NI-DCPower Express step to access NI-DCPower from within SignalExpress 1.2 or earlier. In SignalExpress 2.0 or later, you can use either the IVI Power Supply step or the NI-DCPower Express step.
    • Running the NI-DCPower Simultaneous Update CVI example under Windows 7/Vista
      The Installer Detection feature in Windows 7/Vista requests elevated privileges to run the NI-DCPower Simultaneous Update CVI example. To successfully launch the example from CVI, you must run CVI with elevated privileges. To run CVI with elevated privileges, right-click the NI LabWindows CVI icon and select the Run as administrator option from the context menu. Then, launch the NI-DCPower Simultaneous Update example in CVI.
    • If you click a topic link in the NI–DCPower Function Reference Help section of the NI DC Power Supplies and SMUs Help, you cannot use the Back button in the HTML Help window toolbar to return to the original topic.
    • When you run setup.exe to install the software from the CD, you are prompted to choose whether you want to always trust software from National Instruments. If you do not select this option, your installation may be interrupted by one or more Microsoft Windows security dialog boxes. However, if you run the installer in silent mode from the command line, you will not receive this prompt, and the installer will automatically install NI's Software Publisher Certificate to the your Windows Trusted Publisher Store. If you do not want to make this change to your Windows Trusted Publisher Store, do not choose this installation method.
    • NI recommends that you disable Windows power management modes, such as sleep, standby, and hibernate, when using this product. These modes terminate any NI-DCPower operation in progress. Notice that in Windows 7/Vista or on a laptop computer, the default power management settings are likely to enable sleep mode.
    217333The source delay attribute will be coerced to a minimum of 30μs on the NI PXI-4132.
    178242When handshaking on the NI PXI-4132 with other devices using the source trigger and measure complete event, the source trigger will no longer be missed.
    Important Information
    © 2006–2010 National Instruments Corporation. All rights reserved.
    GMT+8, 2026-1-28 10:55
