查看: 3507|回复: 0
[NI驱动程序] NI-DCPower Driver 1.6 Win32/64Eng NI DC电源仪器驱动程序下载1.6
    昨天 07:57
  • 签到天数: 3837 天
    连续签到: 30 天
    发表于 2020-10-16 23:53:14 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    NI-DCPower
    1.6
    文件大小: 1431387724 字节 (1.33 GB)
    修改日期: 2011-09-27 09:46
    MD5: 979b5f8528989ac4301f02084e5dd1a2(官方正确)
    SHA1: eb886d0f850572c61a39080e22e010fae655b588
    SHA256: 09b06c5f6a9039ae30fb9ebc6a446e3d785bf7e443b9989f0de98e4235136221
    CRC32: 5093be94
    DCPower1.6.0.txt (259 Bytes, 下载次数: 0, 售价: 10 圆)
    NI-DCPower Readme
    Version 1.6
    Thank you for using NI-DCPower. This file contains important information about NI-DCPower and is organized into the following sections:
    • New Features
    • Supported Hardware
    • System Requirements
      • Software
      • Documentation
      • Examples
    • Uninstalling/Modifying NI-DCPower
    • Known Issues
    • Bug Fixes
    New Features in Version 1.6
    • Support for NI PXIe-4140/4141
    • Support for new signal routes added to the NI PXI-4132 (Source Complete event to Measure trigger) and the NI PXIe-4140/4141/4154 (Measure trigger to Source trigger, Source trigger to Measure trigger, and Source Complete event to Measure trigger)
    New Features in Version 1.5
    • Support for NI PXIe-4154
    • Support for channel-based sessions
    • Support for measure records
    • The NI PXI-4132 now supports streaming sequences, allowing the size of a sequence to be virtually unlimited.
    New Features in Version 1.4.1
    • Support for LabVIEW 2010 (32-bit and 64-bit)
    • Support removed for LabVIEW 8.2.1
    • Support for LabVIEW 2009 (64-bit)
    • Support for NI PXI-4132
    • Support for 64-bit user mode
    New Features in Version 1.3.1
    • Support for LabVIEW 2009 (32-bit)
    • Support removed for LabVIEW 7.1.1
    • Japanese localization for driver, LabVIEW application programming interface (API), and documentation
    • New behavior: Error and self-test message strings now return localized values in LabVIEW. User applications that check the value of these strings (or trap errors by comparing the error cluster) may experience a change in behavior.
    NI-DCPower 1.6 and later supports the following power supply and source-measure units (SMUs):
    • NI PXI-4110
    • NI PXI-4130
    • NI PXI-4132
    • NI PXIe-4140
    • NI PXIe-4141
    • NI PXIe-4154
    NOTE:  If you are using a PXI product, notice that MXI-4 is supported under Windows 7/Vista/XP, but MXI-3 is only supported under Windows XP.
    NI-DCPower 1.6 and later supports the following operating systems:
    • Windows XP (32-bit)
    NOTE:  NI-DCPower 1.6 and later does not support Windows Server non-R2 editions.
    It is recommended that you have the most recent service pack for your operating system installed. Windows 2000 users must use NI-DCPower 1.4 or earlier.
    NI-DCPower 1.6 and later supports the following real-time operating environments:
    • LabVIEW Real-Time Module
    Minimum System
    • RAM
      • Windows XP: 128 MB
      • Windows 7/Vista: 512 MB
    • Windows 7/Vista/XP, with all available critical updates and service packs
    Recommended System
    • RAM
      • Windows XP: 256 MB
      • Windows 7/Vista: 1 GB
    • If you are running your application on an RT target, 64 MB of memory or more is recommended.
    • LabVIEW 8.5.1, 8.6.1, 2009 SP1 (32-bit), 2009 SP1 (64-bit), 2010 SP1 (32-bit), or 2010 SP1 (64-bit)
    • LabVIEW Real-Time Module 8.5.1 or later
    • LabWindows™/CVI™ 8.1.1 or later
    • LabWindows/CVI Real-Time Module 8.1 or later
    • Microsoft Visual Basic 6.0
    Installed File Names and LocationsSoftware
    • National Instruments file folder location, :
      • Windows 7/Vista/XP 32-bit: Program Files\IVI Foundation\IVI\
      • Windows 7/Vista 64-bit: Program Files (x86)\IVI Foundation\IVI\
        NOTES:$(IVIROOTDIR32) is configured as an environment variable on the target system.
        • Windows 7/Vista/XP 32-bit: Program Files\IVI\
        • Windows 7/Vista 64-bit: Program Files (x86)\IVI\
      • Windows Vista 64-bit: Program Files\IVI Foundation\IVI\
        NOTE:$(IVIROOTDIR64) is configured as an environment variable on the target system.
    ItemInstalled Location on Windows 7/Vista/XP
    NI-DCPower\Drivers\niDCPower
    NI-DCPower Function Panel\Drivers\niDCPower\niDCPower.fp
    NI-DCPower Examples\niDCPower\Examples
    NI-DCPower Header files\Include
    NI-DCPower Import Library files (32-bit)\Lib
    NI-DCPower Import Library files (64-bit)\Lib_x64
    NI-DCPower DLL (32-bit)\Bin
    Additional File Locations for Windows 7/Vista 64-bit
    ItemInstalled Location on Windows 7/Vista 64-bit
    NI-DCPower DLL (64-bit)\Bin
    Documentation is available at Start»All Programs»National Instruments»NI-DCPower»Documentation. The documentation set is composed of the following documents:
    • NI-DCPower Readme
    • NI DC Power Supplies and SMUs Getting Started Guide
      Printed and PDF format. Contains hardware and software installation, MAX configuration, and signal connection information.
    • NI DC Power Supplies and SMUs Help
      HTML help format. Contains power supply fundamentals, hardware device overview, programming information, LabVIEW reference, and C/CVI/VB reference sections.
    • NI PXI-4110 Specifications
      Printed and PDF format. Lists specifications for the NI PXI-4110 triple-output, programmable DC power supply.
    • NI PXI-4110 Calibration Procedure
      PDF format. Contains calibration instructions for the NI PXI-4110.
    • NI PXI-4130 Specifications
      Printed and PDF format. Lists specifications for the NI PXI-4130 dual-channel, power SMU.
    • NI PXI-4130 Calibration Procedure
      PDF format. Contains calibration instructions for the NI PXI-4130.
    • NI PXI-4132 Specifications
      Printed and PDF format. Lists specifications for the NI PXI-4132 single-channel, precision SMU.
    • NI PXI-4132 Calibration Procedure
      PDF format. Contains calibration instructions for the NI PXI-4132.
    • NI PXIe-4140/4141 Specifications
      Printed and PDF format. Lists specifications for the NI PXI-4140 four-channel, four-quadrant SMU and the NI PXIe-4141 four-channel, four-quadrant precision SMU with enhanced capabilities including programmable compensation.
    • NI PXIe-4140/4141 Calibration Procedure
      PDF format. Contains calibration instructions for the NI PXI-4140/4141.
    • NI PXIe-4154 Specifications
      Printed and PDF format. Lists specifications for the NI PXIe-4154 battery simulator.
    • NI PXIe-4154 Calibration Procedure
      PDF format. Contains calibration instructions for the NI PXIe-4154.
    • Maintain Forced-Air Cooling Note to Users
      Printed format. Contains important cooling information for NI DC power supplies and SMUs.
    • Read Me First: Safety and Electromagnetic Compatibility
      Printed format. Contains safety instructions and electromagnetic compatibility (EMC) information for the hardware it accompanies.
    Examples
    Refer to Start»All Programs»National Instruments»NI-DCPower»Examples for the examples for the supported ADEs.
    Refer to the Installed File Names and Locations section for the installed locations of the example sets.
    • Launch the Control Panel by selecting Start»Settings.
    • Double-click Add/Remove Programs.
    • Click Change/Remove.
    • Select NI-DCPower 1.6 from the dialog box that appears.
    As part of the NI-DCPower installation, the following list of software was installed. To completely remove NI-DCPower from your system, you must remove all of these packages also.
    • NI IVI Compliance Package 4.2
    • NI Measurement & Automation Explorer 4.7.2
    • NI-DAQmx 9.1.7
    • NI-VISA 5.0
    • NI Spy 2.7.2
    You can access the software and documentation known issues list online. Refer to the NI-DCPower 1.6 Known Issues List web page on the National Instruments Web site for an up-to-date list of known issues in NI-DCPower 1.6.
    The following items are changes in NI-DCPower 1.6 from NI-DCPower 1.5.
    283254Warning 1073364993 is now returned instead of error -1074118605 if a measurement is taken while the device is performing a range change.
    The following items are changes in NI-DCPower 1.5 from NI-DCPower 1.4.
    217333The source delay attribute will be coerced to a minimum of 30μs on the NI PXI-4132.
    178242When handshaking on the NI PXI-4132 with other devices using the source trigger and measure complete event, the source trigger will no longer be missed.
    Important Information
    © 2006–2011 National Instruments Corporation. All rights reserved.
    GMT+8, 2026-3-27 11:18
