查看: 2883|回复: 0
[NI驱动程序] NI-DCPower Driver 14.0 Win32/64Eng NI DC电源仪器驱动程序下载14.0
    3 小时前
  • 签到天数: 3786 天
    连续签到: 37 天
    发表于 2020-10-18 22:30:21 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    NI-DCPower
    14.0
    文件大小: 1699730208 字节 (1.58 GB)
    修改日期: 2014-08-05 00:34
    MD5: 4e7eec7d99c1c778295bc2106a7dcd63(官方正确)
    SHA1: 3f5321ea1b56b089639be13a254f6bf4d9417816
    SHA256: 5163504b4b8aa4a1a473f40d825917e9ef39df906ca3842a66b2103f12aca131
    CRC32: deb263c4
    DCPower14.0.txt (263 Bytes, 下载次数: 0, 售价: 10 圆)
    NI-DCPower Readme
    Version 14.0
    Thank you for using NI-DCPower. This file contains important information about NI-DCPower and is organized into the following sections:
    Accessing VIs and Functions
    Driver Version Naming Changes
    Uninstalling/Modifying NI-DCPower
    NI-DCPower Drops Support for Microsoft Windows XP and Windows Server 2003 in 2016
    NI-DCPower 14.0 includes the following new features:
    • Support for LabVIEW 2014 (32- and 64-bit)
    NI-DCPower 1.9 includes the following new features:
    • Support for the NI PXIe-4138/4139
    NI-DCPower 1.8.5 includes the following new features:
    • Support for LabVIEW 2013 (32- and 64-bit)
    • Support removed for LabVIEW 2009 (32- and 64-bit)
    NI-DCPower 1.8 includes the following new features:
    • Support for the NI PXIe-4112/4113
    • Support for self-calibration of the NI PXI-4132
    NI-DCPower 1.7.5 includes the following new features:
    • Support for the NI PXIe-4144/4145
    • Support added for LabVIEW 2012 (32- and 64-bit)
    • Support removed for LabVIEW 8.6.1
    NI-DCPower 1.7 includes the following new features:
    • Support for the NI PXIe-4142/4143
    • Support for NI-DCPower Runtime custom installers built using National Instruments application development environments (ADEs). This installer contains instrument driver run-time components required to deploy applications using NI DC Power Supplies and SMUs.
      Notes:
      • The run-time installer does not contain support for interactively configuring or testing hardware using Measurement & Automation Explorer (MAX).
      • The run-time installer does not support upgrading from NI-DCPower 1.6.x or earlier or NI-DAQmx 8.9.x or earlier. You must uninstall these products prior to installing the NI-DCPower Runtime installer.
    NI-DCPower 14.0 and later supports the following power supply and source-measure units (SMUs):
    • NI PXI-4110
    • NI PXIe-4112
    • NI PXIe-4113
    • NI PXI-4130
    • NI PXI-4132
    • NI PXIe-4138
    • NI PXIe-4139
    • NI PXIe-4140
    • NI PXIe-4141
    • NI PXIe-4142
    • NI PXIe-4143
    • NI PXIe-4144
    • NI PXIe-4145
    • NI PXIe-4154
    Note  MXI Express and MXI-4 are supported on Windows 8/7/Vista/XP, but MXI-3 is supported on only Windows XP.
    Device-specific information about these modules is included in the NI DC Power Supplies and SMUs Help.
    NI-DCPower 14.0 and later supports the following operating systems:
    • Windows 8.1 (32- and 64-bit)
    • Windows 8 (32- and 64-bit)
    • Windows 7 (32- and 64-bit)
    • Windows Vista (32- and 64-bit)
    Note  NI-DCPower 14.0 and later does not support Windows Server non-R2 editions.
    NI recommends that you have the most recent service pack for your operating system installed. Windows 2000 users must use NI-DCPower 1.4 or earlier.
    NI-DCPower 14.0 and later supports the following real-time operating environments:
    • LabVIEW Real-Time Module
    Minimum System Requirements
    • RAM—
      • Windows XP Service Pack 3 (SP3): 128 MB
      • Windows 8/7/Vista: 512 MB
    • Windows 8/7/Vista/XP SP3, with all available critical updates and service packs
    Recommended System
    • RAM—
      • Windows XP SP3: 256 MB
      • Windows 8/7/Vista: 1 GB
    Note:  You should install ADEs, such as NI LabVIEW, NI LabWindows/CVI or Microsoft Visual Studio®, before installing NI-DCPower. To add support for ADEs installed after installing NI-DCPower, modify your NI-DCPower installation or launch the NI-DCPower installer again.
    • NI LabVIEW 2011 SP1 (32- and 64-bit), 2012 SP1 (32- and 64-bit), 2013 SP1 (32- and 64-bit), and 2014 (32- and 64-bit)
    • LabVIEW Real-Time Module 2011 SP1, 2012 SP1, 2013 SP1, and 2014
    • LabWindows™/CVI™ 2009 or later
    • LabWindows/CVI Real-Time Module 2010 or later
    Installed Software, Documentation, and ExamplesSoftware
      • Windows 8 (32-bit)/7 (32-bit)/Vista (32-bit)/XP: Program Files\IVI Foundation\IVI\
      • Windows 8 (64-bit)/7 (64-bit)/Vista (64-bit): Program Files (x86)\IVI Foundation\IVI\
        • Windows 8 (32-bit)/7 (32-bit)/Vista (32-bit)/XP: Program Files\IVI\
        • Windows 8 (64-bit)/7 (64-bit)/Vista (64-bit): Program Files (x86)\IVI\
      • Windows 8 (64-bit)/7 (64-bit)/Vista (64-bit): Program Files\IVI Foundation\IVI\
        Note  $(IVIROOTDIR64) is configured as an environment variable on the target system.
    ItemInstalled Location on Windows 8/7/Vista/XP
    NI-DCPower\Drivers\niDCPower
    NI-DCPower Function Panel\Drivers\niDCPower\niDCPower.fp
    NI-DCPower Examples\niDCPower\Examples
    NI-DCPower Header files\Include
    NI-DCPower Import Library files (32-bit)\Lib
    NI-DCPower Import Library files (64-bit)\Lib_x64
    NI-DCPower DLL (32-bit)\Bin
    Additional File Locations for Windows 8 (64-bit)/7 (64-bit)/Vista (64-bit)
    ItemInstalled Location on Windows 8 (64-bit)/7 (64-bit)/Vista (64-bit)
    NI-DCPower DLL (64-bit)\Bin
    Select Start»All Programs»National Instruments»NI-DCPower»NI-DCPower Soft Front Panel to launch the NI-DCPower Soft Front Panel.
    Documentation is available at Start»All Programs»National Instruments»NI-DCPower»Documentation. The documentation set is composed of the following documents:
    DocumentFormatDescription
    NI DC Power Supplies and SMUs HelpHTML/Windows HelpContains primary help content for NI-DCPower products. The help is an HTML version of a traditional user manual that includes the following information:
    • An introduction to DC Power fundamentals.
    • Hardware device information
    • A complete reference for all NI-DCPower programming functions and VIs
    • Getting Started Guide for your device
    • NI DC Power Supplies and SMUs Getting Started Guide (if your device does not have its own getting started guide)
    Printed and PDFContains software and hardware installation, MAX configuration, signal connection, and troubleshooting information for your device.
    Specifications for your devicePrinted and PDFLists technical specifications for your device.
    NI-DCPower ReadmeHTML (this document)Contains information about supported hardware and operating systems, new features, fixed issues, and legal notices.
    NI-DCPower palette VIs are available from the Functions»Measurement I/O»NI–DCPower palette.
    NI–DCPower functions are available in LabWindows/CVI from the Instrument menu. To load the NI–DCPower function panel (.fp), select Instrument»Load, and navigate to IVI\Drivers\niDCPower\niDCPower.fp.
    In LabVIEW, you can use the NI Example Finder to search or browse examples. NI–DCPower examples are classified by keyword, so you can search for a particular device or measurement function. In LabVIEW, select Help»Find Examples to launch the NI Example Finder. The NI Example Finder offers two ways to access all installed LabVIEW example VIs (including NI–DCPower examples) and their descriptions:
    • Click the Browse tab to locate examples by task at Hardware Input and Output»Modular Instruments»NI–DCPower or by directory structure at instr»niDCPower.
    You can also access all the installed NI–DCPower examples for LabVIEW and LabWindows/CVI at Start»All Programs»National Instruments»NI-DCPower»Examples .
    Examples also are available online that demonstrate NI-DCPower functionality. Refer to ni.com/examples for these examples and for more information.
    Refer to the Installed File Names and Locations section for the installed locations of the example sets.
    NI-DCPower versions are now aligned with the versions of major NI application software products. This alignment gives you information about the year the driver was released and the most recent software version the driver was designed to work with. Driver versions now start with a two-digit year indicator: <;ProductName>. For example, NI-DCPower 14.0 is the version released with LabVIEW 2014. The last version released under the old numbering scheme is NI-DCPower 1.9 The first version released under the new numbering scheme is NI-DCPower 14.0.
    Perform the following procedure to uninstall NI-DCPower 14.0:
    • Launch the Control Panel by selecting Start»Settings.
    • Double-click Add/Remove Programs.
    • Click Change/Remove.
    • Select NI-DCPower 14.0 and later from the dialog box that appears.
    For Windows 8, complete the following steps:
    • Click the Uninstall button.
    As part of the NI-DCPower installation, the following software is installed. To completely remove the NI-DCPower installation from your system, you must also remove all of the following products.
    • NI-DCPower Runtime 14.0 and later
    • NI Measurement & Automation Explorer 14.0
    • NI-DAQmx 9.1.7
    • NI-VISA Runtime 5.0
    • NI Spy 2.7.2
    • NI System Configuration 14.0
    Caution   Several of the software packages listed above are shared with other NI software packages. If you attempt to remove a piece of software that something else is dependent on, a message launches to warn you about the software dependencies. You can choose to either uninstall all of the software or to leave the shared software installed. If you choose to uninstall the shared software, some of your other NI software may no longer function correctly.
    You can access the software and documentation known issues list online. Refer to the NI-DCPower 1.9 and 14.0 Known Issues List web page on the National Instruments Web site for an up-to-date list of known issues in NI-DCPower 14.0.
    The are no changes in NI-DCPower 14.0 from NI-DCPower 1.9
    The following items are changes in NI-DCPower 1.9 from NI-DCPower 1.8.
    404741Under certain configurations, the NI PXIe-4154 could inadvertently toggle from remote sense to local sense, then back to remote sense at NIDCPower Initiate, forcing the user to add additional settling time before taking a measurement. This has been resolved.
    The following items are changes in NI-DCPower 1.8 from NI-DCPower 1.7.5.
    286821Fixed an issue in which you must run LabWindows/CVI with elevated privileges to successfully launch the NI-DCPower Simultaneous Update example from LabWindows/CVI. NI has renamed this example to NI-DCPower Simultaneous Operation, and you no longer need to run LabWindows/CVI with elevated privileges to launch this example.
    371368Fixed an issue in which temperature changes degraded the output accuracy on the NI PXI-4132. You can now self-calibrate the NI PXI-4132 to maintain output accuracy.
    The following items are changes in NI-DCPower 1.7.5 from NI-DCPower 1.7.
    369565In a few rare cases, when users wrote to nonvolatile storage on the NI PXIe-4140/4141/4142/4143, calibration constants became invalid, causing the device to become unusable until its next external calibration. Now you can write to nonvolatile storage on the NI PXIe-4140/4141/4142/4143 without issue.
    The following items are changes in NI-DCPower 1.7 from NI-DCPower 1.6.3.
    352628The first measurement taken after opening a new session for the NI PXI-4132 no longer has the potential to be incorrect.
    347012Configuring the niDCPower Output Connected property to TRUE or the NIDCPOWER_ATTR_OUTPUT_CONNECTED attribute to VI_TRUE while in the Running state no longer incorrectly configures the NI PXI-4132 for remote sense.
    346464In SignalExpress, using the NI-DCPower Generate step while sweeping no longer sources only the first point in the sequence.
    346154LabVIEW code generated in SignalExpress from the NI-DCPower Generate step no longer returns an error when run while sweeping.
    342622,
    341027
    The performance of the NI PXIe-4140/4141 range change algorithm is improved.
    328629When configuring the device in the Committed state in Single Point source mode after a property or attribute is configured in the Running state, the incorrect previous property or attribute value is no longer retained.
    283258Previously, the Measure Record Length property or NIDCPOWER_ATTR_MEASURE_RECORD_LENGTH attribute permitted a measurement record to be composed of up to 231-1 measurements, but the driver and hardware would silently ignore a measurement record composed of more than 224 measurements. The driver now returns an error if you attempt to compose a measurement record of more than 224 measurements. This change in behavior may change how existing code is executed.
    318481The NI PXI-4132 output disabled current limit is now 2% of the current limit range, as intended.
    When you install National Instruments software on Microsoft Windows 8.x, you will notice a few additional tiles on the Start screen, including shortcuts to NI application software products such as NI LabVIEW, Measurement & Automation Explorer (MAX), and the new NI Launcher.
    Using NI Launcher
    Note  MAX does not appear as a desktop shortcut when installed on Microsoft Windows 8.x. You can launch MAX either from the Start screen or from within NI Launcher.
    Finding All Programs
    If you want to find a particular application or related files, such as documentation files, from the Start screen, you can access all installed files from the Apps view. To get to the Apps view, right-click anywhere on the Start screen and select All apps (Windows 8.x) or click the down arrow on the bottom left of the screen (Windows 8.x.1).
    For more information about NI support for Windows 8.x.x, visit ni.com/windows8.
    NI-DCPower Drops Support for Microsoft Windows Vista, Windows XP, and Windows Server 2003 in 2016
    National Instruments NI-DCPower will drop support for Microsoft Windows Vista, Windows XP, and Windows Server 2003 as of July 1, 2016. Versions of NI-DCPower that ship after July 1, 2016 will not install or run on Windows Vista, Windows XP, or Windows Server 2003. For detailed information about NI application software product life cycles, visit ni.com/info and enter one of the following Info Codes:
    NI LabVIEWlifecycle
    NI LabWindows/CVIcvi_lifecycle
    NI TestStandtslcp
    NI DIAdemddlcp
    NI SignalExpressselcp
    NI VeriStandnivslifecycle
    © 2007–2014 National Instruments. All rights reserved.
    GMT+8, 2026-1-28 10:55
