查看: 2477|回复: 0
[NI驱动程序] NI-DCPower Driver 16.0 Win32/64Eng NI DC电源仪器驱动程序下载16.0
  • 签到天数: 3697 天
    连续签到: 24 天
    发表于 2020-10-18 22:53:41 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    NI-DCPower
    16.0
    文件大小: 1708224392 字节 (1.59 GB)
    修改日期: 2016-07-12 02:05
    MD5: 380cfaa2858dd724b6101f8fce9c31d8(官方正确)
    SHA1: 76559c7da0b8386e7f1676bb2c686743320a382e
    SHA256: cbbbdce45b7e668ee929a6bbfbb1041a4dc5e775287841b03a13c3d0060259e9
    CRC32: c13bae8d
    DCPower16.0.txt (263 Bytes, 下载次数: 0, 售价: 10 圆)
    NI-DCPower Readme
    Version 16.0
    Thank you for using NI-DCPower. This file contains important information about NI-DCPower and is organized into the following sections:
    Accessing VIs and Functions
    Driver Version Naming Changes
    Uninstalling/Modifying NI-DCPower
    Using NI Software with Microsoft Windows 10.
    Using NI Software with Microsoft Windows 8.1.
    NI-DCPower 16.0 includes the following new features:
    NI-DCPower 15.2 includes the following new features:
    • Support for the PXIe-4135
    NI-DCPower 15.1 includes the following new features:
    • Support for the NI PXIe-4136/4137
    • Support for advanced sequencing for NI PXIe-4140/4141/4142/4143/4144/4145 devices
    NI-DCPower 15.0 includes the following new features:
    NI-DCPower 14.1 includes the following new features:
    • Support for advanced sequencing for the NI PXIe-4138/4139
    • Support for debugging an NI-DCPower device while in use by another application, by monitoring or controlling the device in the NI-DCPower Soft Front Panel
    NI-DCPower 14.0 includes the following new features:
    • Support for LabVIEW 2014 (32- and 64-bit)
    NI-DCPower 1.9 includes the following new features:
    • Support for the NI PXIe-4138/4139
    NI-DCPower 1.8.5 includes the following new features:
    • Support for LabVIEW 2013 (32- and 64-bit)
    • Support removed for LabVIEW 2009 (32- and 64-bit)
    NI-DCPower 1.8 includes the following new features:
    • Support for the NI PXIe-4112/4113
    • Support for self-calibration of the NI PXI-4132
    NI-DCPower 15.2 and later supports the following power supply and source-measure units (SMUs):
    • PXI-4110
    • PXIe-4112
    • PXIe-4113
    • PXI-4130
    • PXI-4132
    • PXIe-4135
    • PXIe-4136
    • PXIe-4137
    • PXIe-4138
    • PXIe-4139
    • PXIe-4140
    • PXIe-4141
    • PXIe-4142
    • PXIe-4143
    • PXIe-4144
    • PXIe-4145
    • PXIe-4154
    Note  MXI Express and MXI-4 are supported on Windows 10/8.1/8.0/7/Vista/XP, but MXI-3 is supported on only Windows XP.
    Device-specific information about these modules is included in the NI DC Power Supplies and SMUs Help.
    NI-DCPower 16.0 supports the following operating systems:
    • Windows 10 (32- and 64-bit)
    • Windows 8.1 (32- and 64-bit)
    • Windows 8.0 (32- and 64-bit)
    • Windows 7 (32- and 64-bit)
    Note  NI-DCPower 16.0 and later does not support Windows Server non-R2 editions.
    NI recommends that you have the most recent service pack for your operating system installed. Windows Vista/XP users must use NI-DCPower 15.2 or earlier.
    NI-DCPower 16.0 and later supports the following real-time operating environments:
    • LabVIEW Real-Time Module
    Minimum System Requirements
    Recommended System
    • RAM—Windows 10/8.1/8.0/7: 1 GB
    • Windows 10/8.1/8.0/7, with all available critical updates and service packs
    Note:  You should install ADEs, such as NI LabVIEW, NI LabWindows/CVI or Microsoft Visual Studio®, before installing NI-DCPower. To add support for ADEs installed after installing NI-DCPower, modify your NI-DCPower installation or launch the NI-DCPower installer again.
    • NI LabVIEW 2013 SP1, 2014 SP1, 2015 SP1, or 2016
    • LabVIEW Real-Time Module 2013 SP1, 2014 SP1, 2015 SP1, or 2016
    • LabWindows™/CVI™ 2012 or later
    • LabWindows/CVI Real-Time Module 2012 or later
    Installed Software, Documentation, and ExamplesSoftware
      • Users\Public\Documents\National Instruments
      • (32-bit) Program Files\IVI Foundation\IVI\
      • (64-bit) Program Files (x86)\IVI Foundation\IVI\
        Note  $(IVIROOTDIR64) is configured as an environment variable on the target system.
        • (32-bit) Program Files\IVI\
        • (64-bit) Program Files (x86)\IVI\
      • (64-bit) Program Files\IVI Foundation\IVI\
    ItemInstalled Location
    NI-DCPower\Drivers\niDCPower
    NI-DCPower Function Panel\Drivers\niDCPower\niDCPower.fp
    NI-DCPower Examples\niDCPower\Examples
    NI-DCPower Header files\Include
    NI-DCPower Import Library files (32-bit)\Lib
    NI-DCPower Import Library files (64-bit)\Lib_x64
    NI-DCPower DLL (32-bit)\Bin
    Additional File Locations for 64-bit operating systems
    NI-DCPower DLL (64-bit)\Bin
    Select Start»All Programs»National Instruments»NI-DCPower»NI-DCPower Soft Front Panel to launch the NI-DCPower Soft Front Panel.
    Documentation is available at Start»All Programs»National Instruments»NI-DCPower»Documentation. The documentation set is composed of the following documents:
    DocumentFormatDescription
    NI DC Power Supplies and SMUs HelpHTML/Windows HelpContains primary help content for NI-DCPower products. The help is an HTML version of a traditional user manual that includes the following information:
    • An introduction to DC Power fundamentals
    • Hardware device information
    • A complete reference for all NI-DCPower programming functions and VIs
    Getting Started Guide for your device or NI DC Power Supplies and SMUs Getting Started Guide (if your device does not have its own getting started guide)Printed and PDFContains software and hardware installation, MAX configuration, signal connection, and troubleshooting information for your device.
    Specifications for your devicePrinted and PDFLists technical specifications for your device.
    NI-DCPower ReadmeHTML (this document)Contains information about supported hardware and operating systems, new features, fixed issues, and legal notices.
    Note  To view the specifications, you need to have Adobe Acrobat Reader installed. You can install the viewer from www.adobe.com/reader.
    NI-DCPower palette VIs are available from the Functions»Measurement I/O»NI–DCPower palette.
    NI–DCPower functions are available in LabWindows/CVI from the Instrument menu. To load the NI–DCPower function panel (.fp), select Instrument»Load, and navigate to IVI\Drivers\niDCPower\niDCPower.fp.
    In LabVIEW, you can use the NI Example Finder to search or browse examples. NI–DCPower examples are classified by keyword, so you can search for a particular device or measurement function. In LabVIEW, select Help»Find Examples to launch the NI Example Finder. The NI Example Finder offers two ways to access all installed LabVIEW example VIs (including NI–DCPower examples) and their descriptions:
    • Click the Browse tab to locate examples by task at Hardware Input and Output»Modular Instruments»NI–DCPower or by directory structure at instr»niDCPower.
    You can also access all the installed NI–DCPower examples for LabVIEW and LabWindows/CVI at Start»All Programs»National Instruments»NI-DCPower»Examples .
    Examples also are available online that demonstrate NI-DCPower functionality. Refer to ni.com/examples for these examples and for more information.
    NI-DCPower 16.0 Drops Support for Microsoft Windows 7 RTM, Windows Vista, Windows XP, and Windows Server 2003
    With this release, NI-DCPower 16.0 drops support for Microsoft Windows 7 RTM (with no service pack), Windows Vista, Windows XP, and Windows Server 2003. NI-DCPower 16.0 and later will not install or run on an unsupported OS. You cannot deploy or distribute applications that use NI-DCPower 16.0 to an unsupported OS. Additionally, after installing NI-DCPower 16.0, you cannot use any installers built on this computer with any version of LabVIEW, LabWindows™/CVI™, NI TestStand™, or Measurement Studio on an unsupported OS.
    NI-DCPower versions are now aligned with the versions of major NI application software products. This alignment gives you information about the year the driver was released and the most recent software version the driver was designed to work with. Driver versions now start with a two-digit year indicator: <;ProductName>. For example, NI-DCPower 15.0 is the version released with LabVIEW 2015. The last version released under the old numbering scheme is NI-DCPower 1.9. The first version released under the new numbering scheme is NI-DCPower 14.0.
    • Click Uninstall/Change.
    • Select NI-DCPower 16.0 from the dialog box that appears.
    For Windows 10/8.1/8.0, complete the following steps:
    • Right-click on the Start button
    • Select Control Panel.
    • Click the Uninstall button.
    As part of the NI-DCPower 16.0 installation, the following software is installed. To completely remove the NI-DCPower 16.0 installation from your system, you must also remove all of the following products.
    • NI-DCPower Runtime 16.0
    • NI IVI Compliance Package 16.0
    • NI Measurement & Automation Explorer 16.0
    • NI-DAQmx 15.0*
    • NI-VISA Runtime 16.0
    • NI I/O Trace 15.0
    • NI System Configuration 16.0
    Caution   Several of the software packages listed above are shared with other NI software packages. If you attempt to remove a piece of software that something else is dependent on, a message launches to warn you about the software dependencies. You can choose to either uninstall all of the software or to leave the shared software installed. If you choose to uninstall the shared software, some of your other NI software may no longer function correctly.
    *Starting with driver version 15.0, NI-DCPower installation includes NI-DAQmx Runtime and Configuration support but not NI-DAQmx LabVIEW ADE support. To install NI-DAQmx LabVIEW ADE support, install the full version of NI-DAQmx from ni.com/downloads.
    You can access the software and documentation known issues list online. Refer to the NI-DCPower 16.0 Known Issues at ni.com/info and enter the Info Code exeevt for an up-to-date list of known issues in NI-DCPower 16.0.
    The following items are changes in NI-DCPower 15.2 from NI-DCPower 15.1.
    Added support for monitoring SFP Debug Driver Sessions when sequencing.
    The following items are changes in NI-DCPower 14.1.2 from NI-DCPower 14.1.1.
    519695Fixed an issue in which NI-DCPower Self Calibrate could cause a voltage and current measurement offset on the NI PXIe-4138/4139.
    The following items are changes in NI-DCPower 14.1.1 from NI-DCPower 14.1.
    501023A hardware error in an NI-DCPower device no longer causes other devices in the system to fail to initialize properly.
    The following items are changes in NI-DCPower 14.1 from NI-DCPower 1.9.
    450955Running short sequences (three or fewer steps) or quickly aborting a sequence no longer occasionally returns an error.
    405305Fixed an issue with the NI  PXIe-414x in which calling the niDCPower Configure Output Enabled VI after outputting a sequence of currents returned an error if you set nondefault current ranges. You can now set nondefault current ranges under these circumstances.
    The following items are changes in NI-DCPower 1.9 from NI-DCPower 1.8.
    404741Under certain configurations, the NI PXIe-4154 could inadvertently toggle from remote sense to local sense, then back to remote sense at NIDCPower Initiate, forcing the user to add additional settling time before taking a measurement. This has been resolved.
    The following items are changes in NI-DCPower 1.8 from NI-DCPower 1.7.5.
    286821Fixed an issue in which you must run LabWindows/CVI with elevated privileges to successfully launch the NI-DCPower Simultaneous Update example from LabWindows/CVI. NI has renamed this example to NI-DCPower Simultaneous Operation, and you no longer need to run LabWindows/CVI with elevated privileges to launch this example.
    371368Fixed an issue in which temperature changes degraded the output accuracy on the NI PXI-4132. You can now self-calibrate the NI PXI-4132 to maintain output accuracy.
    © 2007–2016 National Instruments. All rights reserved.
    375374C-01
    GMT+8, 2025-10-30 02:19
