查看: 2506|回复: 0
[NI驱动程序] NI-DCPower Driver 17.5 Win32/64Eng NI DC电源仪器驱动程序下载17.5
  • 签到天数: 3697 天
    连续签到: 24 天
    发表于 2020-10-18 23:04:30 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    NI-DCPower
    17.5
    文件大小: 1828011912 字节 (1.70 GB)
    修改日期: 2018-01-10 07:11
    MD5: ecde48af37ba8277588d90fb79b40812(官方正确)
    SHA1: 849a7e924a61df9b05d062d5a3c56c53f81a7ff1
    SHA256: 6a97152059e7fde22d00568a5df83b904f96732c79046b62136623194969f526
    CRC32: f440d83d
    DCPower17.5.txt (263 Bytes, 下载次数: 0, 售价: 10 圆)
    NI-DCPower 17.5 Readme
    January 2018
    This file contains important information about NI-DCPower, including installation instructions, new features, a partial list of bugs fixed, and known issues.
    NI-DCPower is an NI instrument driver that communicates with all NI programmable power supplies and SMUs. NI-DCPower is an interchangeable virtual instrument (IVI)–compliant instrument driver, and it features a set of operations and properties that exercise the functionality of the power supply or SMU and includes an interactive soft front panel and examples.
    NI-DCPower 17.5 has the following requirements:
    Minimum System Requirements
    Recommended System
    • RAM—Windows 10/8.1/8.0/7: 1 GB
    NI-DCPower 17.5 supports the following operating systems:
    • Windows 10/8.11/7 SP12
    • Windows Server 2012 R21
    • Windows Server 2008 R2 SP12
    Note  In 2016 NI-DCPower dropped support for Windows Vista, Windows XP, Windows Server 2003, and installations of Windows 7 without any service packs. NI-DCPower 17.5 will not install or run on an unsupported OS. You cannot deploy or distribute applications that use NI-DCPower 17.5 to an unsupported OS. Additionally, after installing NI-DCPower 17.5, you cannot use any installers built on this computer with any version of LabVIEW, LabWindows™/CVI™, NI TestStand™, or Measurement Studio on an unsupported OS.
    NI-DCPower 17.5 supports the following application software versions, including service packs. If you are not using NI application software, refer to Microsoft Visual Studio Support.
    Application SoftwareVersions Supported by NI-DCPower
    LabVIEW2014 SP1 (32-bit), 2014 SP1 (64-bit), 2015 SP1 (32-bit), 2015 SP1 (64-bit), 2016 (32-bit), 2016 (64-bit), or 2017
    LabVIEW Real-Time Module2014 SP1, 2015 SP1, 2016, or 2017
    LabVIEW NXG2.0
    LabWindows/CVI Real-Time Module2013 and later
    To use the .NET API, you must install the .NET class libraries or the .NET wrapper in addition to the NI device driver. For information about versions of the .NET Framework and the drivers each supports, as well as the download location of the installer files, refer to the National Instruments .NET Driver Support document at ni.com/info and enter Info Code NETAPIdriversupport.
    • NI-DCPower 17.5 adds support for LabVIEW NXG 2.0.
    The following list details the hardware models supported in NI-DCPower 17.5.
    PXI Programmable Power Supply
    • PXI-4110
    • PXIe-4112
    • PXIe-4113
    • PXIe-4154
    PXI Source Measure Unit
    • PXI-4130
    • PXI-4132
    • PXIe-4135
    • PXIe-4136
    • PXIe-4137
    • PXIe-4138
    • PXIe-4139
    • PXIe-4140
    • PXIe-4141
    • PXIe-4142
    • PXIe-4143
    • PXIe-4144
    • PXIe-4145
    You can access the software and documentation known issues list online. Refer to the NI website for an up-to-date list of known issues in NI-DCPower 17.5.
    The following items are the IDs and titles of a subset of issues fixed in NI-DCPower. This is not an exhaustive list of issues fixed in the current version of NI-DCPower. If you have a CAR ID, you can search this list to validate that the issue has been fixed.
    The following items are changes in NI-DCPower 17.1 from NI-DCPower 17.0.
    671016Fixed an issue in which the PXIe-4138 or PXIe-4139 failed to load upon system boot or device reset.
    647700Fixed an issue in which in rare cases, the PXI-4138 or PXIe-4139 failed to load due to a hardware error but the front panel LED did not reflect the presence of a hardware error.
    Refer to the NI DC Power Supplies and SMUs Help, accessible from Start»All Programs»National Instruments»NI-DCPower»NI-DCPower Documentation, for information about NI-DCPower.
    You can access all the installed NI-DCPower examples at Start»All Programs»National Instruments»NI-DCPower»NI-DCPower Examples and online at ni.com/examples.
    Select Help»Find Examples from LabVIEW or LabWindows/CVI to launch the NI Example Finder. LabVIEW examples for NI-DCPower are located in the LabVIEW XXXX\examples\instr\niDCPower directory. You can modify an example VI to fit an application, or you can copy and paste from one or more examples into a VI that you create.
    • Click the Browse tab to locate modulation examples by task at Hardware Input and Output»Modular Instruments»NI–DCPower or by directory structure at instr»niDCPower.
    The following sections detail considerations for using LabVIEW NXG with NI-DCPower.
    LabVIEW NXG Hardware Support
    411x, 4113x, 414x, and 4154 Devices
    • PXI-4110
    • PXIe-4112
    • PXIe-4113
    • PXIe-4154
    • PXI-4130
    • PXI-4132
    • PXIe-4135
    • PXIe-4136
    • PXIe-4137
    • PXIe-4138
    • PXIe-4139
    • PXIe-4140
    • PXIe-4141
    • PXIe-4142
    • PXIe-4143
    • PXIe-4144
    • PXIe-4145
    LabVIEW NXG Help
    LabVIEW NXG Examples
    • IVI-COM Adapters
    If you want to use the above features, you must install IVI Compliance Package separately, either from ni.com/downloads or from the NI Device Drivers 2017 DVD.
    © 2007–2018 National Instruments. All rights reserved.
    375374F-01
    GMT+8, 2025-10-30 02:15
