查看: 2922|回复: 0
[NI驱动程序] NI-DCPower Driver 18.1.1 Win32/64Eng NI DC电源仪器驱动程序下载18.1.1
  • 签到天数: 3697 天
    连续签到: 24 天
    发表于 2020-10-18 23:17:02 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    NI-DCPower
    18.1.1
    文件大小: 2202578559 字节 (2.05 GB)
    修改日期: 2018-09-25 18:01
    MD5: ee2274510900263ec6d814ed16ff242e(官方正确)
    SHA1: f747457c232ce3af8a1e56af4a12593dfe846aa9
    SHA256: 0fc68ebde04cf740e54f9b93a0ec4bc4eedc0c26d07548496782bc72089ebc9e
    CRC32: 4d040094
    DCPower18.1.1.txt (265 Bytes, 下载次数: 0, 售价: 10 圆)
    NI-DCPower 18.1.1 Readme
    July 2018
    This file contains important information about NI-DCPower, including installation instructions, new features, a partial list of bugs fixed, and known issues.
    NI-DCPower is an NI instrument driver that communicates with all NI programmable power supplies and SMUs. NI-DCPower is an interchangeable virtual instrument (IVI)–compliant instrument driver, and it features a set of operations and properties that exercise the functionality of the power supply or SMU and includes an interactive soft front panel and examples.
    NI-DCPower 18.1.1 has the following requirements:
    Minimum System Requirements
    • RAM—1 GB, 800 MHz DDR2 RAM
    Recommended System
    NI-DCPower 18.1.1 supports the following operating systems:
    • Windows 10/8.11/7 SP12
    • Windows Server 2012 R21
    • Windows Server 2008 R2 SP12
    Note  In 2016 NI-DCPower dropped support for Windows Vista, Windows XP, Windows Server 2003, and installations of Windows 7 without any service packs. NI-DCPower 18.1.1 will not install or run on an unsupported OS. You cannot deploy or distribute applications that use NI-DCPower 18.1.1 to an unsupported OS. Additionally, after installing NI-DCPower 18.1.1, you cannot use any installers built on this computer with any version of LabVIEW, LabWindows™/CVI™, NI TestStand™, or Measurement Studio on an unsupported OS.
    NI-DCPower 18.1.1 supports the following application software versions, including service packs. If you are not using NI application software, refer to Microsoft Visual Studio Support.
    Application SoftwareVersions Supported by NI-DCPower
    LabVIEW2015, 2016, 2017, 2018
    LabVIEW Real-Time Module32015, 2016, 2017, 2018
    LabVIEW NXG2.0, 2.1
    LabWindows/CVI Real-Time Module32013 and later
    3No support for PXIe-4162/4163 source measure units.
    To use the .NET API, you must select the .NET Framework 4.0 Languages Support or the .NET Framework 4.5 Languages Support packages in the NI-DCPower installer to install the .NET class libraries in addition to the NI device driver. For information about versions of the .NET Framework and the drivers each supports, as well as the download location of the installer files, refer to the National Instruments .NET Driver Support document at ni.com/info and enter Info Code NETAPIdriversupport.
    • Install an ADE, such as LabVIEW or LabWindows™/CVI™.
    • Visit ni.com/downloads and search for NI-DCPower 18.1.1.
    • Click NI-DCPower 18.1.1 and then the download link and run the executable (.exe) file.
    • Follow the instructions in the installation prompts. You may see access and security prompts during installation. Accept the prompts to complete the installation.
    • When the installer completes, select Restart in the dialog box that prompts you to restart, shut down, or restart later.
    Installing NI-DCPower 18.1.1 for LabVIEW NXG
    • NI-DCPower 18.1.1 adds support for multiple advanced sequence configurations using NI-DCPower Create Advanced Sequence.
    The following list details the hardware models supported in NI-DCPower 18.1.1:
    NI 411x, 413x, 414x, and 4154 Power Supplies and SMUs
    • PXI-4110
    • PXIe-4112
    • PXIe-4113
    • PXIe-4154
    • PXI-4130
    • PXI-4132
    • PXIe-4135
    • PXIe-4136
    • PXIe-4137
    • PXIe-4138
    • PXIe-4139
    • PXIe-4140
    • PXIe-4141
    • PXIe-4142
    • PXIe-4143
    • PXIe-4144
    • PXIe-4145
    NI 416x SMUs
    • PXIe-4162
    • PXIe-4163
    You can access the software and documentation known issues list online. Refer to the NI website for an up-to-date list of known issues in NI-DCPower 18.1 and 18.1.1.
    Refer to the NI DC Power Supplies and SMUs Help, accessible from Start»All Programs»National Instruments»NI-DCPower»NI-DCPower Documentation, for information about NI-DCPower.
    You can access all the installed NI-DCPower examples at Start»All Programs»National Instruments»NI-DCPower»NI-DCPower Examples and online at ni.com/examples.
    Select Help»Find Examples from LabVIEW or LabWindows/CVI to launch the NI Example Finder. LabVIEW examples for NI-DCPower are located in the LabVIEW XXXX\examples\instr\niDCPower directory. You can modify an example VI to fit an application, or you can copy and paste from one or more examples into a VI that you create.
    • Click the Browse tab to locate modulation examples by task at Hardware Input and Output»Modular Instruments»NI–DCPower or by directory structure at instr»niDCPower.
    The following sections detail considerations for using LabVIEW NXG with NI-DCPower.
    LabVIEW NXG Hardware Support
    • PXI-4110
    • PXIe-4112
    • PXIe-4113
    • PXIe-4154
    • PXI-4130
    • PXI-4132
    • PXIe-4135
    • PXIe-4136
    • PXIe-4137
    • PXIe-4138
    • PXIe-4139
    • PXIe-4140
    • PXIe-4141
    • PXIe-4142
    • PXIe-4143
    • PXIe-4144
    • PXIe-4145
    NI 416x SMUs
    • PXIe-4162
    • PXIe-4163
    LabVIEW NXG Help
    LabVIEW NXG Examples
    • IVI-COM Adapters
    © 2007–2018 National Instruments. All rights reserved.
    375374L-01
    GMT+8, 2025-10-30 02:19
