NI-DCPower Driver 18.5.1 Win32/64Eng NI DC电源仪器驱动程序下载18.5.1
NI-DCPower
18.5.1离线版
文件大小: 2254178030 字节 (2.10 GB)
修改日期: 2019-01-30 08:02
MD5: 80ce742da2e802e59c7cbed9452e9442(官方正确)
SHA1: 7f2272d4e57883c246bc934f338f029fc77a5fa9
SHA256: 8538e562fba90e583e180bda247880ce75b40ff50284fb3cd2d3c6739fee0082
CRC32: 791ea78b
18.5.1ZIP
文件大小: 2210942966 字节 (2.06 GB)
修改日期: 2019-02-08 00:01
MD5: bd88c8a7f7c9def392011c05b5991154(官方正确)
SHA1: fc6b03e8b74958faa8b72116abd493748f181a94
SHA256: 96c34f36e54a1d412f859dfc3f2da2ac190ce5d6363c471790a31280edf9a85a
CRC32: c0cc45b7
DCPower18.5.1.txt
(488 Bytes, 下载次数: 2, 售价: 10 圆)
NI-DCPower 18.5.1 ReadmeJanuary 2019 This file contains important information about NI-DCPower, including installation instructions, new features, a partial list of bugs fixed, and known issues. If you plan to use LabVIEW NXG, refer to LabVIEW NXG Support and Considerations.
Overview System Requirements Supported Operating Systems Application Software Support Installation Instructions Product Security and Critical Updates New Features Supported Hardware Known Issues Bug Fixes Accessing the Help Finding Examples LabVIEW NXG Support and Considerations IVI Compliance Package Functionality Automating the Installation of NI Products Using NI Software with Microsoft Windows 10 Using NI Software with Microsoft Windows 8.1 Legal Information OverviewNI-DCPower is an NI instrument driver that communicates with all NI programmable power supplies and SMUs. NI-DCPower is an interchangeable virtual instrument (IVI)–compliant instrument driver, and it features a set of operations and properties that exercise the functionality of the power supply or SMU and includes an interactive soft front panel and examples. System RequirementsNI-DCPower 18.5.1 has the following requirements: Minimum System Requirements- Processor—2.53 GHz Intel Core 2 Duo processor or equivalent
- RAM—1 GB, 800 MHz DDR2 RAM
Recommended System- Processor—2.3 GHz quad-core Intel Core i7 or equivalent
- RAM—4 GB, dual-channel 1600 MHz DDR3 RAM
Refer to the LabVIEW Readme for additional system requirements and supported operating systems for LabVIEW. Supported Operating SystemsNI-DCPower 18.5.1 supports the following operating systems: - Windows 10/8.11/7 SP12
- Windows Server 2012 R21
- Windows Server 2008 R2 SP12
1 NI software installs VC2015 Runtime and .NET 4.6.2. Windows 8.1 and Windows Server 2012 R2 require Microsoft updates to support these items. Refer to Microsoft KB2919442 and KB2919355 for more information about how to install these updates. 2 NI software is signed with a SHA-256 certificate. Windows 7 SP1, Windows Embedded Standard 7 SP1, and Windows Server 2008 R2 SP1 require Microsoft updates to support SHA-256. Refer to Microsoft KB3033929 for more information about how to install this security update. Note In 2016 NI-DCPower dropped support for Windows Vista, Windows XP, Windows Server 2003, and installations of Windows 7 without any service packs. NI-DCPower 18.5.1 will not install or run on an unsupported OS. You cannot deploy or distribute applications that use NI-DCPower 18.5.1 to an unsupported OS. Additionally, after installing NI-DCPower 18.5.1, you cannot use any installers built on this computer with any version of LabVIEW, LabWindows™/CVI™, NI TestStand™, or Measurement Studio on an unsupported OS. For more information about the changes to our OS support for 2016, refer to KB 79UC78LS, Why Does My NI ADE Installer Fail on Windows XP/Vista and Windows Server 2003?. Note Support for Windows 32-bit operating systems may require disabling physical address extension (PAE). To learn how this might affect your system and what actions you might need to take, visit ni.com/info and enter the Info Code PAESupport. Application Software SupportNI-DCPower 18.5.1 supports the following application software versions, including service packs. If you are not using NI application software, refer to Microsoft Visual Studio Support. | Application Software | Versions Supported by NI-DCPower | | LabVIEW | 2015, 2016, 2017, 2018 | | LabVIEW Real-Time Module3 | 2015, 2016, 2017, 2018 | | LabVIEW NXG | 3.0 | | LabWindows™/CVI™ | 2013 and later | | LabWindows/CVI Real-Time Module3 | 2013 and later |
3No support for PXIe-4162/4163 source measure units. Microsoft Visual Studio SupportIf you are using the NI-DCPower .NET Class Library, the .NET Framework 4.0 (minimum) is required. The NI-DCPower .NET Class Library can be used with the Visual C# or Visual Basic .NET programming languages in any Visual Studio version that can target the .NET Framework 4.0 or the .NET Framework 4.5. To use the .NET API, you must select the .NET Framework 4.0 Languages Support or the .NET Framework 4.5 Languages Support packages in the NI-DCPower installer to install the .NET class libraries in addition to the NI device driver. For information about versions of the .NET Framework and the drivers each supports, as well as the download location of the installer files, refer to the National Instruments .NET Driver Support document at ni.com/info and enter Info Code NETAPIdriversupport. Installation Instructions- Install an ADE, such as LabVIEW or LabWindows™/CVI™.
- Visit ni.com/downloads and search for NI-DCPower 18.5.1.
- Click NI-DCPower 18.5.1 and then the download link and run the executable (.exe) file.
- Follow the instructions in the installation prompts. You may see access and security prompts during installation. Accept the prompts to complete the installation.
- When the installer completes, select Restart in the dialog box that prompts you to restart, shut down, or restart later.
Note - If Windows Update is enabled, the installation process might hang if Windows Update interferes with the installation of Microsoft Visual C++ 2015 Run-Time. Visit ni.com/info and enter the Info Code exjq43 for more information and steps to resolve this issue.
- If you purchased this product with an NI Software Suite or NI Product Bundle, use the installation media that shipped with your purchase to install this product.
Installing NI-DCPower 18.5.1 for LabVIEW NXGNI automates LabVIEW NXG installation using NI Package Manager. Visit ni.com/info and enter the Info Code NIPMDownload to download NI Package Manager. Refer to the NI Package Manager Manual for more information about installing, removing, and upgrading NI software using NI Package Manager. Product Security and Critical UpdatesVisit ni.com/security to view and subscribe to receive security notifications about NI products. Visit ni.com/critical-updates for information about critical updates from NI. New Features- NI-DCPower 18.5 adds support for LabVIEW NXG 3.0.
Supported HardwareThe following list details the hardware models supported in NI-DCPower 18.5.1: NI 411x, 413x, 414x, and 4154 Power Supplies and SMUs - PXI-4110
- PXIe-4112
- PXIe-4113
- PXIe-4154
- PXI-4130
- PXI-4132
- PXIe-4135
- PXIe-4136
- PXIe-4137
- PXIe-4138
- PXIe-4139
- PXIe-4140
- PXIe-4141
- PXIe-4142
- PXIe-4143
- PXIe-4144
- PXIe-4145
NI 416x SMUs Known IssuesYou can access the software and documentation known issues list online. Refer to the NI website for an up-to-date list of known issues in NI-DCPower 18.5 and 18.5.1. Bug FixesThe following items are the IDs and titles of a subset of issues fixed in NI-DCPower. This is not an exhaustive list of issues fixed in the current version of NI-DCPower. If you have a CAR ID, you can search this list to validate that the issue has been fixed. The following items are changes in NI-DCPower 18.5.1 from NI-DCPower 18.5. | ID | Fixed Issue | | 715478 | Increased accuracy of over-current detection and protection response to fix an issue in which over-current protection response was stronger than necessary for PXIe-4162 and PXIe-4163 SMUs.
| Accessing the HelpRefer to the NI DC Power Supplies and SMUs Help, accessible from Start»All Programs»National Instruments»NI-DCPower»NI-DCPower Documentation, for information about NI-DCPower. Finding ExamplesYou can access all the installed NI-DCPower examples at Start»All Programs»National Instruments»NI-DCPower»NI-DCPower Examples and online at ni.com/examples. Select Help»Find Examples from LabVIEW or LabWindows/CVI to launch the NI Example Finder. LabVIEW examples for NI-DCPower are located in the LabVIEW XXXX\examples\instr\niDCPower directory. You can modify an example VI to fit an application, or you can copy and paste from one or more examples into a VI that you create. The NI Example Finder offers two ways to access all installed LabVIEW example VIs and their descriptions: - Click the Browse tab to locate modulation examples by task at Hardware Input and Output»Modular Instruments»NI–DCPower or by directory structure at instr»niDCPower.
- Click the Search tab to search all installed examples by keyword. For example, search for "DCPower" to locate all NI-DCPower examples.
LabVIEW NXG Support and ConsiderationsThe following sections detail considerations for using LabVIEW NXG with NI-DCPower. LabVIEW NXG Operating Systems and System RequirementsSoftware support for LabVIEW NXG differs in the following ways: - System requirements—Only 64-bit (x64) processors are supported.
- Operating system—Only 64-bit operating systems are supported. Refer to the Supported Operating Systems section for more information.
LabVIEW NXG Hardware SupportNI 411x, 413x, 414x, and 4154 Power Supplies and SMUs - PXI-4110
- PXIe-4112
- PXIe-4113
- PXIe-4154
- PXI-4130
- PXI-4132
- PXIe-4135
- PXIe-4136
- PXIe-4137
- PXIe-4138
- PXIe-4139
- PXIe-4140
- PXIe-4141
- PXIe-4142
- PXIe-4143
- PXIe-4144
- PXIe-4145
NI 416x SMUs LabVIEW NXG HelpView context help in LabVIEW by pressing and hovering over an object. Search for items using the search bar in the upper right corner of the LabVIEW window. You can also view context help for the search results. Additional documentation is available online at ni.com/manuals. LabVIEW NXG ExamplesLaunch LabVIEW and click the Learning tab. LabVIEW lessons are located in the Lessons tab, and LabVIEW Examples are located in the Examples tab. Follow the instructions in the lessons and examples. IVI Compliance Package FunctionalityNI-DCPower no longer installs IVI Compliance Package. NI-DCPower supports IVI configuration and runtime, but no longer supports the following features: - LabVIEW and CVI IVI class driver APIs for developing IVI interchangeable applications
- IVI Class Simulation drivers
- IVI-COM Adapters
If you want to use the above features, you must install IVI Compliance Package separately, either from ni.com/downloads or from the NI Device Drivers 2018 DVD. Automating the Installation of NI ProductsYou can automate the installation of most NI products using command-line arguments to suppress some or all of the installer user interface and dialog boxes. If the NI product you are installing uses Microsoft .NET 4.0, the .NET installer may run before any NI software installs and may require a reboot before the installation of NI software begins. To avoid a .NET reboot, install .NET 4.0 separately before you install NI software. For more information about automating the installation of NI products, refer to the following KnowledgeBase articles: - For more information about silent installations of individual NI products, refer to KB 4CJDP38M, Customize and Automate Installation of a Single Installer.
- For more information about silent installations of NI products in a suite, such as NI Developer Suite, refer to KB 4GGGDQH0, Customize and Automate Installation of a Suited Installer.
- To determine what version of NI Installers your product contains, refer to KB 4CJDR18M, Determine Type and Version of My National Instruments Installer.
Using NI Software with Microsoft Windows 10Microsoft Windows 10 is the latest version of the Windows operating system and features significant changes compared to previous versions. Windows 10 introduces several new capabilities and also combines features from both Windows 7 and Windows 8. For more information about NI support for Windows 10, visit ni.com/windows10. Using NI Software with Microsoft Windows 8.1When you install NI software on Microsoft Windows 8.1, you will notice a few additional tiles in the Apps view, including shortcuts to NI application software products such as NI LabVIEW, Measurement & Automation Explorer (NI MAX), and NI Launcher. For more information about NI support for Windows 8.1, visit ni.com/windows8. Legal InformationCopyright © 2007–2019 National Instruments. All rights reserved. Under the copyright laws, this publication may not be reproduced or transmitted in any form, electronic or mechanical, including photocopying, recording, storing in an information retrieval system, or translating, in whole or in part, without the prior written consent of National Instruments Corporation. NI respects the intellectual property of others, and we ask our users to do the same. NI software is protected by copyright and other intellectual property laws. Where NI software may be used to reproduce software or other materials belonging to others, you may use NI software only to reproduce materials that you may reproduce in accordance with the terms of any applicable license or other legal restriction. End-User License Agreements and Third-Party Legal Notices You can find end-user license agreements (EULAs) and third-party legal notices in the following locations after installation: - Notices are located in the \_Legal Information and directories.
U.S. Government Restricted Rights If you are an agency, department, or other entity of the United States Government ("Government"), the use, duplication, reproduction, release, modification, disclosure or transfer of the technical data included in this manual is governed by the Restricted Rights provisions under Federal Acquisition Regulation 52.227-14 for civilian agencies and Defense Federal Acquisition Regulation Supplement Section 252.227-7014 and 252.227-7015 for military agencies. IVI Foundation Copyright Notice Content from the IVI specifications reproduced with permission from the IVI Foundation. The IVI Foundation and its member companies make no warranty of any kind with regard to this material, including, but not limited to, the implied warranties of merchantability and fitness for a particular purpose. The IVI Foundation and its member companies shall not be liable for errors contained herein or for incidental or consequential damages in connection with the furnishing, performance, or use of this material. Trademarks Refer to the NI Trademarks and Logo Guidelines at ni.com/trademarks for information on NI trademarks. Other product and company names mentioned herein are trademarks or trade names of their respective companies. Patents For patents covering the NI products/technology, refer to the appropriate location: Help» Patents in your software, the patents.txt file on your media, or the NI Patent Notice at ni.com/patents. 375374R-01 |
