查看: 2841|回复: 0
[NI驱动程序] NI-DCPower Driver 19.0 Win32/64Eng NI DC电源仪器驱动程序下载19.0
  • 签到天数: 3697 天
    连续签到: 24 天
    发表于 2020-10-18 23:33:08 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    NI-DCPower
    19.0离线版
    文件大小: 2104678400 字节 (1.96 GB)
    修改日期: 2019-05-14 03:21
    MD5: e7bfad4dd2523f639a25730837192a11(官方正确)
    SHA1: a7ef7d9c96cb6bdb89fe0ffc9175cb2e6bc9fc41
    SHA256: c9c8fc4b2dfcbb5eb24fa25245bf3db50537e436641fa7b2c5f2fcae982fed21
    CRC32: 70d3474c
    DCPower19.0.txt (283 Bytes, 下载次数: 0, 售价: 10 圆)
    NI-DCPower 19.0 Readme
    February 2019
    This file contains important information about NI-DCPower, including installation instructions, new features, a partial list of bugs fixed, and known issues.
    NI-DCPower Drops Support for Windows 7 (32- and 64-Bit), Windows Server 2008 R2, and All 32-Bit Windows Operating Systems in 2021
    NI-DCPower is an NI instrument driver that communicates with all NI programmable power supplies and SMUs. NI-DCPower is an interchangeable virtual instrument (IVI)–compliant instrument driver, and it features a set of operations and properties that exercise the functionality of the power supply or SMU and includes an interactive soft front panel and examples.
    NI-DCPower 19.0 has the following requirements:
    Minimum System Requirements
    • RAM—1 GB, 800 MHz DDR2 RAM
    Recommended System
    NI-DCPower 19.0 supports the following operating systems:
    • Windows 10/8.11/7 SP12
    • Windows Server 2012 R21
    • Windows Server 2008 R2 SP12
    Note  In 2016 NI-DCPower dropped support for Windows Vista, Windows XP, Windows Server 2003, and installations of Windows 7 without any service packs. NI-DCPower 19.0 will not install or run on an unsupported OS. You cannot deploy or distribute applications that use NI-DCPower 19.0 to an unsupported OS. Additionally, after installing NI-DCPower 19.0, you cannot use any installers built on this computer with any version of LabVIEW, LabWindows™/CVI™, NI TestStand™, or Measurement Studio on an unsupported OS.
    Note  Support for Windows 32-bit operating systems may require disabling physical address extension (PAE). To learn how this might affect your system and what actions you might need to take, refer to NI Software Fails When Physical Address Extension is Enabled.
    NI-DCPower 19.0 supports the following application software versions, including service packs. If you are not using NI application software, refer to Microsoft Visual Studio Support.
    Versions Supported by NI-DCPower
    LabVIEW2016, 2017, 2018, 2019
    LabVIEW Real-Time Module32016, 2017, 2018, 2019
    LabVIEW NXG3.0, 3.1
    LabWindows/CVI Real-Time Module32013 and later
    3No support for PXIe-4162/4163 source measure units.
    To use the .NET API, you must select the .NET Framework 4.0 Languages Support or the .NET Framework 4.5 Languages Support packages in the NI-DCPower installer to install the .NET class libraries in addition to the NI device driver. For information about versions of the .NET Framework and the drivers each supports, as well as the download location of the installer files, refer to National Instruments .NET Driver Support.
    • Install an ADE, such as LabVIEW or LabWindows™/CVI™.
    • Visit ni.com/downloads and search for NI-DCPower 19.0.
    • Click NI-DCPower 19.0 and then the download link and run the executable (.exe) file.
    • Follow the instructions in the installation prompts. You may see access and security prompts during installation. Accept the prompts to complete the installation.
    • When the installer completes, select Restart in the dialog box that prompts you to restart, shut down, or restart later.
    Installing NI-DCPower 19.0 for LabVIEW NXG
    • NI-DCPower 19.0 adds support for LabVIEW 2019 and LabVIEW NXG 3.1.
    The following list details the hardware models supported in NI-DCPower 19.0:
    NI 411x, 413x, 414x, and 4154 Power Supplies and SMUs
    • PXI-4110
    • PXIe-4112
    • PXIe-4113
    • PXIe-4154
    • PXI-4130
    • PXI-4132
    • PXIe-4135
    • PXIe-4136
    • PXIe-4137
    • PXIe-4138
    • PXIe-4139
    • PXIe-4140
    • PXIe-4141
    • PXIe-4142
    • PXIe-4143
    • PXIe-4144
    • PXIe-4145
    NI 416x SMUs
    • PXIe-4162
    • PXIe-4163
    • NI‑DCPower 19.0 drops support for Express VIs in LabVIEW. Existing code created with earlier versions of NI‑DCPower and that contains Express VIs will continue to execute, but the Express VI cannot be reconfigured from a dialog box.
      To reconfigure an Express VI, right-click the Express VI and select Open Front Panel»Convert. This will convert the Express VI to code that you can configure on the block diagram. NI recommends converting Express VIs to code before using the Code Conversion Utility in LabVIEW NXG to convert code for LabVIEW NXG.
    You can access the software and documentation known issues list online. Refer to the NI website for an up-to-date list of known issues in NI-DCPower 19.0.
    The following items are the IDs and titles of a subset of issues fixed in NI-DCPower. This is not an exhaustive list of issues fixed in the current version of NI-DCPower. If you have a CAR ID, you can search this list to validate that the issue has been fixed.
    The following items are changes in NI-DCPower 18.2 from NI-DCPower 18.1.1.
    ID
    Fixed Issue
    711044Fixed an issue in which closing the output relay on the PXIe-4135/4136/4137/4138/4139 could cause additional trigger latency in Single Point source mode or during the first step of a sequence.
    Refer to the NI DC Power Supplies and SMUs Help, accessible from Start»All Programs»National Instruments»NI-DCPower»NI-DCPower Documentation, for information about NI-DCPower.
    You can access all the installed NI-DCPower examples at Start»All Programs»National Instruments»NI-DCPower»NI-DCPower Examples and online at ni.com/examples.
    Select Help»Find Examples from LabVIEW or LabWindows/CVI to launch the NI Example Finder. LabVIEW examples for NI-DCPower are located in the LabVIEW XXXX\examples\instr\niDCPower directory. You can modify an example VI to fit an application, or you can copy and paste from one or more examples into a VI that you create.
    • Click the Browse tab to locate modulation examples by task at Hardware Input and Output»Modular Instruments»NI–DCPower or by directory structure at instr»niDCPower.
    The following sections detail considerations for using LabVIEW NXG with NI-DCPower.
    LabVIEW NXG Hardware Support
    • PXI-4110
    • PXIe-4112
    • PXIe-4113
    • PXIe-4154
    • PXI-4130
    • PXI-4132
    • PXIe-4135
    • PXIe-4136
    • PXIe-4137
    • PXIe-4138
    • PXIe-4139
    • PXIe-4140
    • PXIe-4141
    • PXIe-4142
    • PXIe-4143
    • PXIe-4144
    • PXIe-4145
    NI 416x SMUs
    • PXIe-4162
    • PXIe-4163
    LabVIEW NXG Help
    LabVIEW NXG Examples
    • IVI-COM Adapters
    NI-DCPower will drop support for Windows 7 (32- and 64-bit), Windows Server 2008 R2, and all 32-bit Windows operating systems starting in 2021. Versions of this product that ship after May 1, 2021, will not install or run on these operating systems. For detailed information about NI operating system support, visit ni.com/r/win32bitsupport.
    Info Code
    LabWindows/CVIcvi_lifecycle
    © 2007–2019 National Instruments. All rights reserved.
    375374T-01
    GMT+8, 2025-10-30 02:15
