NI-DCPower Driver 19.1 Win32/64Eng NI DC电源仪器驱动程序下载19.1
NI-DCPower
19.1.0
文件大小: 2123671552 字节 (1.98 GB)
修改日期: 2019-09-06 01:18
MD5: cded525f0458f98f6482950147f7b154(官方正确)
SHA1: 4281417f19b5c62def845760882d4d09ccdcc995
SHA256: f94704ac20b5e4fddff3801777f92c217dec73ceef4acbc3c260144c6843e391
CRC32: 69322b78
DCPower19.1.txt
(283 Bytes, 下载次数: 0, 售价: 10 圆)
NI-DCPower 19.1 ReadmeJuly 2019
This file contains important information about NI-DCPower, including installation instructions, new features, a partial list of bugs fixed, and known issues.
Overview System Requirements Supported Operating Systems Application Software Support Installation Instructions Product Security and Critical Updates New Features Supported Hardware Behavior Changes Known Issues Bug Fixes Accessing the Help Finding Examples LabVIEW NXG Support and Considerations IVI Compliance Package Functionality Automating the Installation of NI Products Using NI Software with Microsoft Windows 10 Using NI Software with Microsoft Windows 8.1 NI-DCPower Drops Support for Windows 7 (32- and 64-Bit), Windows Server 2008 R2, and All 32-Bit Windows Operating Systems in 2021 Legal Information OverviewNI-DCPower is an NI instrument driver that communicates with all NI programmable power supplies and SMUs. NI-DCPower is an interchangeable virtual instrument (IVI)–compliant instrument driver, and it features a set of operations and properties that exercise the functionality of the power supply or SMU and includes an interactive soft front panel and examples.
System RequirementsNI-DCPower 19.1 has the following requirements:
Minimum System Requirements- Processor—2.53 GHz Intel Core 2 Duo processor or equivalent
- RAM—1 GB, 800 MHz DDR2 RAM
Recommended System- Processor—2.3 GHz quad-core Intel Core i7 or equivalent
- RAM—4 GB, dual-channel 1600 MHz DDR3 RAM
Supported Operating SystemsNI-DCPower 19.1 supports the following operating systems:
- Windows 10/8.11/7 SP12
- Windows Server 2012 R21
- Windows Server 2008 R2 SP12
Note In 2016, NI-DCPower dropped support for Windows Vista, Windows XP, Windows Server 2003, and installations of Windows 7 without any service packs. NI-DCPower 19.1 will not install or run on an unsupported OS. You cannot deploy or distribute applications that use NI-DCPower 19.1 to an unsupported OS. Additionally, after installing NI-DCPower 19.1, you cannot use any installers built on this computer with any version of LabVIEW, LabWindows™/CVI™, NI TestStand™, or Measurement Studio on an unsupported OS.
Note Support for Windows 32-bit operating systems may require disabling physical address extension (PAE). To learn how this might affect your system and what actions you might need to take, refer to NI Software Fails When Physical Address Extension is Enabled.
Application Software SupportNI-DCPower 19.1 supports the following application software versions, including service packs. If you are not using NI application software, refer to Microsoft Visual Studio Support.
Application Software | Versions Supported by NI-DCPower | | LabVIEW | 2016, 2017, 2018, 2019 | | LabVIEW Real-Time Module3 | 2016, 2017, 2018, 2019 | | LabVIEW NXG | 3.0, 3.1 | | LabWindows™/CVI™ | 2013 and later | | LabWindows/CVI Real-Time Module3 | 2013 and later |
3No support for PXIe-4162/4163 source measure units.
Microsoft Visual Studio SupportIf you are using the NI-DCPower .NET Class Library, the .NET Framework 4.0 (minimum) is required. The NI-DCPower .NET Class Library can be used with the Visual C# or Visual Basic .NET programming languages in any Visual Studio version that can target the .NET Framework 4.0 or the .NET Framework 4.5.
To use the .NET API, you must select the .NET Framework 4.0 Languages Support or the .NET Framework 4.5 Languages Support packages in the NI-DCPower installer to install the .NET class libraries in addition to the NI device driver. For information about versions of the .NET Framework and the drivers each supports, as well as the download location of the installer files, refer to National Instruments .NET Driver Support.
Installation Instructions- Install an ADE, such as LabVIEW or LabWindows™/CVI™.
- Visit ni.com/downloads and search for NI-DCPower 19.1.
- Click NI-DCPower 19.1 and then the download link and run the executable (.exe) file.
- Follow the instructions in the installation prompts. You may see access and security prompts during installation. Accept the prompts to complete the installation.
- When the installer completes, select Restart in the dialog box that prompts you to restart, shut down, or restart later.
- If Windows Update is enabled, the installation process might hang if Windows Update interferes with the installation of Microsoft Visual C++ 2015 Run-Time. For more information and steps to resolve this issue, refer to NI Installer Hangs While Installing Visual C++ 2015 Run-Time.
- If you purchased this product with an NI Software Suite or NI Product Bundle, use the installation media that shipped with your purchase to install this product.
Installing NI-DCPower 19.1 for LabVIEW NXGNI automates LabVIEW NXG installation using NI Package Manager. Visit ni.com/info and enter the Info Code NIPMDownload to download NI Package Manager. Refer to the NI Package Manager Manual for more information about installing, removing, and upgrading NI software using NI Package Manager.
Product Security and Critical UpdatesVisit ni.com/security to view and subscribe to receive security notifications about NI products. Visit ni.com/critical-updates for information about critical updates from NI.
New Features- Added Commit step functionality to advanced sequences. A Commit step configures the device to a known state before an advanced sequence runs.
- Added support for importing and exporting advanced sequences and attribute configurations between NI-DCPower sessions.
Supported HardwareThe following list details the hardware models supported in NI-DCPower 19.1:
NI 411x, 413x, 414x, and 4154 Power Supplies and SMUs
- PXI-4110
- PXIe-4112
- PXIe-4113
- PXIe-4154
- PXI-4130
- PXI-4132
- PXIe-4135
- PXIe-4136
- PXIe-4137
- PXIe-4138
- PXIe-4139
- PXIe-4140
- PXIe-4141
- PXIe-4142
- PXIe-4143
- PXIe-4144
- PXIe-4145
NI 416x SMUs
Behavior ChangesNI‑DCPower 19.0 dropped support for Express VIs in LabVIEW. Existing code created with earlier versions of NI‑DCPower and that contains Express VIs will continue to execute, but the Express VI cannot be reconfigured from a dialog box.
To reconfigure an Express VI, right-click the Express VI and select Open Front Panel»Convert. This will convert the Express VI to code that you can configure on the block diagram. NI recommends converting Express VIs to code before using the Code Conversion Utility in LabVIEW NXG to convert code for LabVIEW NXG.
Known IssuesYou can access the software and documentation known issues list online. Refer to the NI website for an up-to-date list of known issues in NI-DCPower 19.1.
Bug FixesThe following items are the IDs and titles of a subset of issues fixed in NI-DCPower. This is not an exhaustive list of issues fixed in the current version of NI-DCPower. If you have a CAR ID, you can search this list to validate that the issue has been fixed.
The following items are changes in NI-DCPower 18.2 from NI-DCPower 18.1.1.
ID | Fixed Issue | | 711044 | Fixed an issue in which closing the output relay on the PXIe-4135/4136/4137/4138/4139 could cause additional trigger latency in Single Point source mode or during the first step of a sequence.
| Accessing the HelpRefer to the NI DC Power Supplies and SMUs Help, accessible from Start»All Programs»National Instruments»NI-DCPower»NI-DCPower Documentation, for information about NI-DCPower.
Finding ExamplesYou can access all the installed NI-DCPower examples at Start»All Programs»National Instruments»NI-DCPower»NI-DCPower Examples and online at ni.com/examples.
Select Help»Find Examples from LabVIEW or LabWindows/CVI to launch the NI Example Finder. LabVIEW examples for NI-DCPower are located in the LabVIEW XXXX\examples\instr\niDCPower directory. You can modify an example VI to fit an application, or you can copy and paste from one or more examples into a VI that you create.
- Click the Browse tab to locate modulation examples by task at Hardware Input and Output»Modular Instruments»NI–DCPower or by directory structure at instr»niDCPower.
- Click the Search tab to search all installed examples by keyword. For example, search for "DCPower" to locate all NI-DCPower examples.
LabVIEW NXG Support and ConsiderationsThe following sections detail considerations for using LabVIEW NXG with NI-DCPower.
LabVIEW NXG Operating Systems and System RequirementsSoftware support for LabVIEW NXG differs in the following ways:
- System requirements—Only 64-bit (x64) processors are supported.
- Operating system—Only 64-bit operating systems are supported. Refer to the Supported Operating Systems section for more information.
LabVIEW NXG Hardware SupportNI 411x, 413x, 414x, and 4154 Power Supplies and SMUs
- PXI-4110
- PXIe-4112
- PXIe-4113
- PXIe-4154
- PXI-4130
- PXI-4132
- PXIe-4135
- PXIe-4136
- PXIe-4137
- PXIe-4138
- PXIe-4139
- PXIe-4140
- PXIe-4141
- PXIe-4142
- PXIe-4143
- PXIe-4144
- PXIe-4145
NI 416x SMUs
LabVIEW NXG HelpView context help in LabVIEW by pressing and hovering over an object.
LabVIEW NXG ExamplesLaunch LabVIEW and click the Learning tab.
IVI Compliance Package FunctionalityNI-DCPower no longer installs IVI Compliance Package. NI-DCPower supports IVI configuration and runtime, but no longer supports the following features:
- LabVIEW and CVI IVI class driver APIs for developing IVI interchangeable applications
- IVI Class Simulation drivers
- IVI-COM Adapters
Automating the Installation of NI ProductsYou can automate the installation of most NI products using command-line arguments to suppress some or all of the installer user interface and dialog boxes.
- For more information about silent installations of individual NI products, refer to KB 4CJDP38M, Customize and Automate Installation of a Single Installer.
- For more information about silent installations of NI products in a suite, such as NI Developer Suite, refer to KB 4GGGDQH0, Customize and Automate Installation of a Suited Installer.
- To determine what version of NI Installers your product contains, refer to KB 4CJDR18M, Determine Type and Version of My National Instruments Installer.
Using NI Software with Microsoft Windows 10Microsoft Windows 10 is the latest version of the Windows operating system and features significant changes compared to previous versions. Windows 10 introduces several new capabilities and also combines features from both Windows 7 and Windows 8. For more information about NI support for Windows 10, visit ni.com/windows10.
Using NI Software with Microsoft Windows 8.1When you install NI software on Microsoft Windows 8.1, you will notice a few additional tiles in the Apps view, including shortcuts to NI application software products such as NI LabVIEW, Measurement & Automation Explorer (NI MAX), and NI Launcher. For more information about NI support for Windows 8.1, visit ni.com/windows8.
NI-DCPower Drops Support for Windows 7 (32- and 64-Bit), Windows Server 2008 R2, and All 32-Bit Windows Operating Systems in 2021NI-DCPower will drop support for Windows 7 (32- and 64-bit), Windows Server 2008 R2, and all 32-bit Windows operating systems starting in 2021. Versions of this product that ship after May 1, 2021, will not install or run on these operating systems. For detailed information about NI operating system support, visit ni.com/r/win32bitsupport.
Product | Info Code | | LabVIEW | lifecycle | | LabWindows/CVI | cvi_lifecycle | | Measurement Studio | mstudiolifecycle | | TestStand | tslcp | | DIAdem | ddlcp | | SignalExpress | selcp | | VeriStand | nivslifecycle |
Legal InformationCopyright
© 2007–2019 National Instruments. All rights reserved.
- Notices are located in the \_Legal Information and directories.
375374U-01 |
