查看: 2850|回复: 0
[NI驱动程序] NI-DCPower Driver 20.5 Win32/64Eng NI DC电源仪器驱动程序下载20.5
  • 签到天数: 3697 天
    连续签到: 24 天
    发表于 2020-10-18 23:47:12 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    NI-DCPower
    20.5
    (MD5) 9e2e4b78a22a62949dd56542162f8252(官方正确)
    (SHA256) 940dbd385eaf2c3815ec0def8c18c99d3cd9e6020a0a624b79eae4015e1dfd3c
    DCPower20.5.txt (283 Bytes, 下载次数: 0, 售价: 10 圆)
    NI-DCPower 20.5 Readme
    August 2020
    This file contains important information about NI-DCPower, including installation instructions, new features, a partial list of bugs fixed, and known issues.
    NI-DCPower Drops Support for Windows 7 (32- and 64-Bit), Windows Server 2008 R2, and All 32-Bit Windows Operating Systems in 2021
    NI-DCPower is an NI instrument driver that communicates with all NI programmable power supplies and SMUs. NI-DCPower is an interchangeable virtual instrument (IVI)–compliant instrument driver, and it features a set of operations and properties that exercise the functionality of the power supply or SMU and includes an interactive soft front panel and examples.
    NI-DCPower 20.5 has the following requirements:
    Minimum System Requirements
    • RAM—1 GB, 800 MHz DDR2 RAM
    Recommended System
    NI-DCPower 20.5 supports the following operating systems:
    • Windows 10/8.11/7 SP12
    • Windows Server 2012 R21
    • Windows Server 2008 R2 SP12
    • NI Real-Time Phar Lap ETS
    • NI Linux® Real-Time
    Note  In 2016, NI-DCPower dropped support for Windows Vista, Windows XP, Windows Server 2003, and installations of Windows 7 without any service packs. NI-DCPower 20.5 will not install or run on an unsupported OS. You cannot deploy or distribute applications that use NI-DCPower 20.5 to an unsupported OS. Additionally, after installing NI-DCPower 20.5, you cannot use any installers built on this computer with any version of LabVIEW, LabWindows™/CVI™, NI TestStand™, or Measurement Studio on an unsupported OS.
    Note  Support for Windows 32-bit operating systems may require disabling physical address extension (PAE). To learn how this might affect your system and what actions you might need to take, refer to NI Software Fails When Physical Address Extension is Enabled.
    NI-DCPower 20.5 supports the following application software versions, including service packs. If you are not using NI application software, refer to Microsoft Visual Studio Support.
    Versions Supported by NI-DCPower
    LabVIEW2017, 2018, 2019, 2020
    LabVIEW Real-Time Module32017, 2018, 2019, 2020
    LabVIEW NXG5.0
    LabWindows/CVI Real-Time Module32013 and later
    3No support for PXIe-4162/4163 source measure units.
    To use the .NET API, you must select the .NET Framework 4.0 Languages Support or the .NET Framework 4.5 Languages Support packages in the NI-DCPower installer to install the .NET class libraries in addition to the NI device driver. For information about versions of the .NET Framework and the drivers each supports, as well as the download location of the installer files, refer to .NET Resources for NI Hardware and Software.
    • Install an ADE, such as LabVIEW or LabWindows™/CVI™.
    • Visit ni.com/downloads and search for NI-DCPower 20.5.
    • Click NI-DCPower 20.5 and then the download link and run the executable (.exe) file.
    • Follow the instructions in the installation prompts. You may see access and security prompts during installation. Accept the prompts to complete the installation.
    • When the installer completes, select Restart in the dialog box that prompts you to restart, shut down, or restart later.
    Installing NI-DCPower 20.5 for LabVIEW NXG
    • Added measurement autoranging threshold range support for improved accuracy and resolution.
    • Added support for the PXIe-4139 (40W) source measure unit.
    Note  The following NI-DCPower features are currently unsupported on LinuxRT systems:
    • Autopopulation of resource names in LabVIEW
    • Test panels as accessible from Measurement & Automation Explorer (MAX)
    NI-DAQmx-Based Power Supplies and SMUs
    • PXI-4110
    • PXIe-4112
    • PXIe-4113
    • PXI-4130
    • PXI-4132
    • PXIe-4135
    • PXIe-4136
    • PXIe-4137
    • PXIe-4138
    • PXIe-4139
    • PXIe-4140
    • PXIe-4141
    • PXIe-4142
    • PXIe-4143
    • PXIe-4144
    • PXIe-4145
    • PXIe-4154
    Non-NI-DAQmx-Based Power Supplies and SMUs
    • PXIe-4147
    • PXIe-4162
    • PXIe-4163
    You can access NI-DCPower known issues online at NI-DCPower 20.5 Known Issues.
    You can access the NI-DCPower bug fix list online at NI-DCPower 20.5 Bug Fixes. This list describes a subset of issues fixed in NI-DCPower. If you have a Bug ID, you can search this list to validate that the issue has been fixed.
    Refer to the NI DC Power Supplies and SMUs Help accessible from Start»All Programs»National Instruments»NI-DCPower»NI-DCPower Documentation, for information about NI-DCPower.
    You can access all the installed NI-DCPower examples at Start»All Programs»National Instruments»NI-DCPower»NI-DCPower Examples and online at ni.com/examples.
    Select Help»Find Examples from LabVIEW or LabWindows/CVI to launch the NI Example Finder. LabVIEW examples for NI-DCPower are located in the LabVIEW XXXX\examples\instr\niDCPower directory. You can modify an example VI to fit an application, or you can copy and paste from one or more examples into a VI that you create.
    • Click the Browse tab to locate modulation examples by task at Hardware Input and Output»Modular Instruments»NI–DCPower or by directory structure at instr»niDCPower.
    The following sections detail considerations for using LabVIEW NXG with NI-DCPower.
    LabVIEW NXG Hardware Support
    NI 411x, 413x, 414x, and 4154 Power Supplies and SMUs
    • PXI-4110
    • PXIe-4112
    • PXIe-4113
    • PXI-4130
    • PXI-4132
    • PXIe-4135
    • PXIe-4136
    • PXIe-4137
    • PXIe-4138
    • PXIe-4139
    • PXIe-4140
    • PXIe-4141
    • PXIe-4142
    • PXIe-4143
    • PXIe-4144
    • PXIe-4145
    • PXIe-4147
    • PXIe-4154
    NI 416x SMUs
    • PXIe-4162
    • PXIe-4163
    LabVIEW NXG Help
    LabVIEW NXG Examples
    • IVI-COM Adapters
    • To determine what version of NI Installers your product contains, refer to KB 4CJDR18M, Determine Type and Version of My NI Installer.
    NI-DCPower will drop support for Windows 7 (32- and 64-bit), Windows Server 2008 R2, and all 32-bit Windows operating systems starting in 2021. Versions of this product that ship after May 1, 2021, will not install or run on these operating systems. For detailed information about NI operating system support, visit ni.com/r/win32bitsupport.
    Info Code
    LabWindows/CVIcvi_lifecycle
    NI Software will drop support for Phar Lap ETS Real-Time Operating System starting in 2022. Versions of this product that ship after May 1, 2022, may not install or execute correctly on this operating system. For high-level information on the support roadmap for Phar Lap and its replacement, NI Linux Real-Time, please visit ni.com/r/xf35k1. To find out what hardware is supported on PXI controllers running NI Linux Real-Time, please visit ni.com/r/b7g5wi.
    Note  The PXIe-4139 (40W) SMU does not support NI Real-Time Phar Lap ETS.
    © 2007–2020 National Instruments Corporation. All rights reserved.
    375374AA-01
    GMT+8, 2025-10-30 02:19
