查看: 3367|回复: 0
[NI驱动程序] NI-XNET 1.0 Driver Win32Eng/Ger/Jpn NI-XNET仪器驱动程序1.0下载
    昨天 09:54
  • 签到天数: 3808 天
    发表于 2020-10-20 22:23:41 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    NI-XNET
    1.0
    文件大小: 278588810 字节 (265.68 MB)
    修改日期: 2019-06-25 02:42
    MD5: 3ca831a452cbef3a83449539adbebe4d(官方正确)
    SHA1: 1758e4fb9d80f130581a581fae14d60d4ea1e6b8
    SHA256: 496331267507747353cbd56e142cb5065d3455bd979e58cf59f215d5ac5a67b2
    CRC32: 5d59bb55
    NI-XNET1.0.txt (277 Bytes, 下载次数: 0, 售价: 10 圆)
    NI-XNET 1.0 Readme
    August 2009
    ni.com/support
    This file contains information about the NI-XNET software for Windows Vista/XP and LabVIEW™ Real-Time (RT). Information in this file is organized in the following sections:
    • Documentation
    • Supported Platforms
    • Installing NI-XNET 1.0
    The XNET Software and Hardware Installation Guide included with the NI-XNET CD includes instructions for installing National Instruments CAN and FlexRay hardware and software.
    The NI-XNET Hardware and Software Help is the primary document for NI XNET products. This help includes an introduction to CAN and FlexRay, specifications for hardware, information about how to get started with application development, and a complete reference for all NI-XNET functions.
    Open the help from Start»All Programs»National Instruments»NI-XNET.
    Links to the NI-XNET Hardware and Software Help are in the online help for each NI-XNET function within the National Instruments LabVIEW and LabWindows™/CVI™ development environments.
    Online help for the NI-XNET features within Measurement & Automation Explorer (MAX) is in the MAX Help Topics menu. The MAX Help Topics menu for NI-XNET also includes a link to the NI-XNET Hardware and Software Help.
    Back to Top
    • Insert the NI-XNET software CD into your CD-ROM drive. The installer launches if your CD-ROM drive plays data CDs automatically. If the installer does not launch automatically, navigate to the CD using Windows Explorer and launch the autorun.exe file from your NI-XNET software CD.
    Installing NI-XNET Silently
    You can control programmatically which features in the NI-XNET distribution to enable or disable for installation. You therefore can install a subset of the NI-XNET distribution silently. Refer to the template_spec.txt file in the Specfiles directory on the NI-XNET CD for more information about installing NI-XNET silently and selecting which features to install automatically.
    Back to Top
    You must install and run this version of the NI-XNET software on the following operating systems:
    • Windows XP 32-bit
      For more information about using National Instruments hardware and software products with Windows Vista, visit ni.com/vista.
    This version of the NI-XNET software supports the following National Instruments hardware products on Windows and LabVIEW RT (PXI hardware only):
    • NI PCI-8511 (Low-Speed/Fault-Tolerant CAN)
    • NI PCI-8512 (High-Speed CAN)
    • NI PCI-8513 (Software-Selectable HS/LS/SW CAN)
    • NI PCI-8517 (FlexRay)
    • NI PXI-8511 (Low-Speed/Fault-Tolerant CAN)
    • NI PXI-8512 (High-Speed CAN)
    • NI PXI-8513 (Software-Selectable HS/LS/SW CAN)
    • NI PXI-8517 (FlexRay)
    The NI-XNET software supports only National Instruments CAN and FlexRay hardware products. For information about software for CAN products from other vendors, refer to the documentation you received with those products.
    This version of the NI-XNET software supports the following development environments:
    • LabVIEW 8.5, 8.6, and LabVIEW 2009 (32-bit)
    • LabVIEW Real-Time (RT) 8.5, 8.6, and 2009
    • LabWindows/CVI 8.5 and higher
    • Microsoft Visual C/C++ 6.0
    Back to Top
    If you intend to use the NI-CAN API with your NI-XNET hardware, refer to the NI-XNET Compatibility for NI-CAN appendix in the NI-CAN Hardware and Software Manual.
    Back to Top
    GMT+8, 2026-2-26 06:11
