查看: 3418|回复: 0
[NI驱动程序] NI-XNET 17.0.1 Driver Win32/64 Eng/Ger/Jpn NI-XNET仪器驱动程序17.0.1下载
    昨天 09:54
  • 签到天数: 3808 天
    发表于 2020-10-20 23:23:34 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    NI-XNET
    17.0.1
    文件大小: 706410883 字节 (673.69 MB)
    修改日期: 2019-06-25 02:43
    MD5: 0fcf50cbe9b08aff5114100a29b1eda7(官方正确)
    SHA1: fe39d8a5a1272ae7be7e057cd33f6d67e8a43d75
    SHA256: 75dd6d38690037d0e21580c87206ef4a1b9ed7b5a67092a7eb55f722c4ad7c96
    CRC32: 398dc3de
    NI-XNET17.0.1.txt (272 Bytes, 下载次数: 0, 售价: 10 圆)
    NI-XNET 17.0.1 Readme
    May 2017
    This file contains important information about NI-XNET, including installation instructions, new features, a partial list of bugs fixed for NI-XNET 17.0.1, and known issues.
    New Features and Changes
    Additional Programming Topics
    NI-XNET supports the following operating systems:
    • Windows 8.11
    • Windows 7 SP12
    • Windows Server 2012 R21
    • Windows Server 2008 R2 SP12
    The NI-XNET installer does not support Windows Server 2003/NT/Vista/XP/Me/2000/98/95 or the Windows Server non-R2 editions.
    NI-XNET does not support guest accounts on Windows 7. You must log into an administrative or user account to use NI-XNET on these operating systems.
    This version of the NI-XNET software supports the following development environments:
    • LabVIEW 2014, 2015, 2016, and 2017
    • LabVIEW Real-Time (RT) 2014, 2015, 2016, and 2017
    • LabWindows/CVI 2012 and higher
    • Microsoft Visual C/C++ 6.0
    • Insert the NI-XNET software CD into your CD-ROM drive. The installer launches if your CD-ROM drive plays data CDs automatically. If the installer does not launch automatically, navigate to the CD using Windows Explorer and launch the autorun.exe file from your NI-XNET software CD.
    New NI-XNET 17.0.1 Features and Changes as Compared to NI-XNET 17.0
    The NI-XNET 17.0.1 release changes the following:
    • Bug Fix for LabVIEW 64-bit support.
    New NI-XNET 17.0 Features and Changes as Compared to NI-XNET 16.1
    The NI-XNET 17.0 release adds the following features:
    • Support for LabVIEW 2017.
    • Support for NI PCIe-8510
    • Support for import of AUTOSAR ARXML files for version 3.x and 4.x
    The NI-XNET 17.0 release changes the following:
    • Improvements that require a firmware update for NI 9860 modules and the cDAQ integrated XNET port.
    • Removed support for LabVIEW 2013.
    • Removed support for CVI 2010.
    New NI-XNET 16.1 Features and Changes as Compared to NI-XNET 16.0
    The NI-XNET 16.1 release adds the following features:
    • Added support for the NI USB-850x USB modules.
    • Added C-API examples for J1939.
    • Enabled setting a custom baudrate for ISO CAN FD in the Bus Monitor and Database Editor.
    • Enabled excluding IDs in the Bus Monitor.
    • Enabled setting a node address for J1939 in the Bus Monitor.
    The NI-XNET 16.1 release changes the following:
    • Removed support for CVI 8.5, 9.0, and 2009.
    • NI USB-8502 (High-Speed/FD CAN)
    • NI USB-8506 (LIN)
    • NI PCI-8511 (Low-Speed/Fault-Tolerant CAN)
    • NI PCI-8512 (High-Speed/FD CAN)
    • NI PCI-8513 (Software-Selectable/FD CAN)
    • NI PCI-8516 (LIN)
    • NI PCI-8517 (FlexRay)
    • NI PCIe-8510 (Hardware-Selectable)
    • NI PXI-8511 (Low-Speed/Fault-Tolerant CAN)
    • NI PXI-8512 (High-Speed/FD CAN)
    • NI PXI-8513 (Software-Selectable/FD CAN)
    • NI PXI-8516 (LIN)
    • NI PXI-8517 (FlexRay)
    • NI PXIe-8510 (Hardware-Selectable)
    • NI TRC-8542 NI-XNET CAN HS/FD Transceiver Cable
    • NI TRC-8543 NI-XNET CAN XS (LS/FT, HS/FD)Transceiver Cable
    • NI TRC-8546 NI-XNET LIN Transceiver Cable
    • C Series modules:
      • NI 9861 (C Series Low-Speed CAN)
      • NI 9862 (C Series High-Speed/FD CAN)
      • NI 9866 (C Series LIN)
      • NI 9860 (C Series Hardware-Selectable)
        • CompactDAQ—NI-DAQmx 9.6 (or newer) is required for:
          • USB Chassis: NI cDAQ-9171, NI cDAQ-9174, and NI cDAQ-9178
          • Ethernet Chassis: NI cDAQ-9181, NI cDAQ-9184, and NI cDAQ-9188
          • Wireless Chassis: NI cDAQ-9191
          • cDAQ Controller: NI cDAQ-9138 (Windows and RT) and NI cDAQ-9139 (Windows and RT)
        • CompactDAQ—NI-DAQmx 14.0 (or newer) is required for:
          • cDAQ Controller: NI cDAQ-9132 (Windows) and NI cDAQ-9134 (Windows)
        • CompactDAQ—NI-DAQmx 14.1 (or newer) is required for:
          • cDAQ Controller: NI cDAQ-9132 (RT) and NI cDAQ-9134 (RT)
        • CompactDAQ—NI-DAQmx 14.5 (or newer) is required for:
          • cDAQ Controller: NI cDAQ-9135
        • CompactDAQ—NI-DAQmx 15.1 (or newer) is required for:
          • USB Chassis: NI cDAQ-9179
          • cDAQ Controller: NI cDAQ 9136/37
        • CompactRIO—NI Compact RIO 17.0 (or newer) and LabVIEW 2014 (or newer) are required for the following targets:
          • Real-Time Controller: NI cRIO-9012, NI cRIO-9014, NI cRIO-9022, NI cRIO-9023, NI cRIO-9024, and NI cRIO-9025
          • CompactRIO Reconfigurable Chassis: NI cRIO-9111, NI cRIO-9112, NI cRIO-9113, NI cRIO-9114, NI cRIO-9116, and NI cRIO-9118
          • Integrated CompactRIO Real-Time Controller: NI cRIO-9081, NI cRIO-9082, NI cRIO-906x, and NI cRIO-903x
          • LabVIEW FPGA 2014 is required to build and deploy a bitstream with NI 986x modules in the project.
          • When using NI Compact RIO 17.0 (or newer) with NI cRIO-903x or NI cRIO-906x, a bitstream is not needed with NI 986x modules in the project.
        • CompactRIO—NI Compact RIO 17.0 (or newer) and LabVIEW 2015 (or newer) are required for the following targets:
          • Single-Board RIO: NI sbRIO-9627, NI sbRIO-9607
          • CompactRIO Real-Time Controller: NI cRIO-9032, NI cRIO-9037
          • LabVIEW FPGA 2015 (or newer) is required to build and deploy a bitstream with NI 986x modules in the project.
        • CompactRIO—NI Compact RIO 17.0 (or newer) and LabVIEW 2016 (or newer) are required for the following targets:
          • CompactRIO Real-Time Controller: cRIO-9035 (Sync), cRIO-9039 (Sync)
    The NI-XNET software supports only National Instruments CAN, FlexRay, and LIN hardware products. For information about software for CAN products from other vendors, refer to the documentation you received with those products.
    Issue NumberIssue
    When using an .ncd or .dbc database, the baud rate defaults to 500 k (250 k for J1939 databases), and the IO mode defaults to CAN 2.0. You need to programmatically override these values in your session if you need different values.
    Changing transceiver cables on NI 9860 and NI PXIe-8510 modules requires a restart of LabVIEW.
    Changed behavior of Frame Default Payload property: If Application Protocol of a Cluster is J1939, the default for Default Payload bytes is now 0xFF instead of 0x00. As a consequence, unused bits in the frame will be set to 1 instead of 0 when J1939 is used (like required by J1939).
    Variant Handling, as described within the AUTOSAR 4.x Generic Structure Template, is unsupported by NI-XNET. All AUTOSAR XML elements using the tag will be discarded.
    If reading AUTOSAR files, some types of frames are not assigned to ECUs as "Tx" (transmitted frames) or "Rx" (received frames).
    The following items are the IDs and titles of a subset of issues fixed between NI-XNET 16.1 and NI-XNET 17.0.1. If you have a CAR ID, you can search this list to validate that the issue has been fixed. This is not an exhaustive list of issues fixed in the current version of NI-XNET.
    Bug IDFixed Issue
    639597The option "Browse for Database File" on an NI-XNET IO control crashes LabVIEW 2017 (64-Bit).
    612384NI-XNET Compatibility Library for NI-CAN does not support hardware with transceiver cables.
    612146DBC Import: Unable to read the frame name if there are space characters behind the last character of the frame name and the ':' character following the name.
    611887NI-XNET controls fail to trigger the value changed event.
    610257Error for too many Frame Stream sessions says too many frames instead of too many sessions in NI-XNET error code 0xBFF63012.
    609492NI-XNET LIN C Series devices are unrecoverable after bus power is removed and error -1074384887 is detected.
    If you intend to use the NI-CAN API with your NI-XNET PCI/PXI hardware, refer to the NI-XNET Compatibility for NI-CAN appendix in the NI-CAN Hardware and Software Manual.
    Removing and inserting C Series modules on CompactRIO targets during device communication is not supported
    Inserting a module into or removing a module from a cRIO chassis that is actively communicating with an NI 986x module can cause application failures and possibly device damage.
    Refer to the NI-XNET Hardware and Software Help, accessible from National Instruments»NI-XNET»NI-XNET Documentation, for information about NI-XNET.
    © 2009–2017 National Instruments. All rights reserved.
    374802H-01
    GMT+8, 2026-2-26 06:13
