查看: 2937|回复: 1
[NI驱动程序] NI-XNET 19.0 Driver Win32/64 Eng/Ger/Jpn NI-XNET仪器驱动程序19.0下载
    昨天 10:50
  • 签到天数: 3604 天
    连续签到: 12 天
    发表于 2020-10-20 23:43:48 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    NI-XNET
    19.0
    文件大小: 1217067008 字节 (1.13 GB)
    修改日期: 2019-05-14 22:49
    MD5: 37f3f798761438ec1319f47167000f8d(官方正确)
    SHA1: 7215251fe44d8ca94cdc2e11f3041b46aa85f2ff
    SHA256: 9b301b260d7aa4cf62896d5da30e5f92e2ac523ce597aba411b69e536e7890ff
    CRC32: 17977359
    NI-XNET19.0.txt (275 Bytes, 下载次数: 1, 售价: 10 元)
    NI-XNET 19.0 Readme
    May 2019
    This file contains important information about NI-XNET, including installation instructions and known issues.
    New Features and Changes
    Additional Programming Topics
    NI-XNET is an NI instrument driver that features a common set of easy-to-use functions for reading and writing CAN, FlexRay, LIN, and Ethernet frames and signals in many different platforms including USB, PXI, PCI, NI CompactDAQ, and NI CompactRIO.
    NI-XNET supports the following operating systems:
    • Windows 10/8.11/7 SP12
    • Windows Server 2012 R21
    • Windows Server 2008 R2 SP12
    The NI-XNET installer does not support Windows Server 2003/NT/Vista/XP/Me/2000/98/95 or the Windows Server non-R2 editions.
    NI-XNET does not support guest accounts on Windows 7. You must log into an administrative or user account to use NI-XNET on these operating systems.
    The following table lists the application software versions supported by NI-XNET.
    Application Software3
    Versions Supported by NI-XNET 19.0
    2016, 2017, 2018, and 2019
    LabVIEW Real-Time (RT)
    LabVIEW NXG
    3.0, 3.1
    LabWindows™/CVI™
    2012 and later
    3 Application software support for LabVIEW NXG is not included with NI-XNET and must be downloaded separately via NI Package Manager. Refer to Installing NI-XNET for LabVIEW NXG for instructions.
    NI-XNET supports the following Microsoft Visual Studio versions and associated programming languages.
    Programming Languages
    Microsoft Visual C/C++
    6.0 and later
    Refer to the following instructions to install NI-XNET from a DVD. To install NI-XNET for LabVIEW NXG, refer to Installing NI-XNET for LabVIEW NXG.
    • Insert the NI-XNET software DVD into the DVD drive. If the installer does not launch automatically, navigate to the DVD using Windows Explorer and launch the autorun.exe file from your NI-XNET software DVD.
    • Click Install.
    New Features and ChangesNew NI-XNET 19.0 Features and Changes as Compared to NI-XNET 18.5
    The NI-XNET 19.0 release adds the following features:
    • Added support for LabVIEW 2019.
    • Added support for the PXIe-8521 4-port, 100BASE-T1 PXI Automotive Ethernet Interface Module.
      Notes  The PXIe-8521 does not support LabVIEW Real-Time or LabVIEW NXG in NI-XNET 19.0.
    The NI-XNET 19.0 release changes the following:
    • Extended the NI-XNET LabVIEW API to support Automotive Ethernet.
    • Removed support for LabVIEW 2015.
    • Removed support for NI-XNET C series modules in a cDAQ chassis when attached to a controller or host running PharLap. Support for other Operating Systems remains unaffected.
    • Removed support for cRIO-9012 and cRIO-9014 controllers. Note that these targets may still support installation, but they are no longer officially supported, and may be removed in a future release.
    • Changed behavior for Signal Input Waveform sessions to address defects.
    • Changed options for building LabVIEW or CVI application installers: "NI-XNET Runtime" installs only the NI-XNET Runtime, "NI-XNET Utilities" installs the NI-XNET Database Editor and Bus Monitor in addition to the NI-XNET Runtime.
    New NI-XNET 18.5 Features and Changes as Compared to NI-XNET 18.0
    The NI-XNET 18.5 release adds the following features:
    • Added support for LabVIEW NXG 3.0.
    • Added support for LabVIEW 2018 SP1.
    • Added support for the USB-8501 NI-XNET CAN LS/FT Interface.
    • Added support for importing CAN FD settings from FIBEX 4.1.2 databases.
    • Added support for J1939 session property, SAE J1939:Include Destination Address in PGN, in LabVIEW NXG.
    The NI-XNET 18.5 release changes the following:
    • Lowered the default value for the nxPropSession_J1939ResponseTimeTrSD property from 0.05 s to 0 s to improve performance in handling multipacket messages.
    • Improved performance when opening large database files.
    • Removed support for LabVIEW NXG 2.0 and 2.1.
    New NI-XNET 18.0 Features and Changes as Compared to NI-XNET 17.5.1
    The NI-XNET 18.0 release adds the following features:
    • Added ability in SystemDesigner to discover XNET hardware ports and select new names for them. (LabVIEW NXG)
    • Added a new J1939 session property, SAE J1939:Include Destination Address in PGN. (C and LabVIEW 2018 only)
    • Added support for LabVIEW NXG 2.1.
    • Added support for LabVIEW 2018.
    The NI-XNET 18.0 release changes the following:
    • Removed support for LabVIEW 2014.
    New NI-XNET 17.5.1 Features and Changes as Compared to NI-XNET 17.5
    The NI-XNET 17.5.1 release changes the following:
    • Bug Fix for cDAQ-9171 support.
    New NI-XNET 17.5 Features and Changes as Compared to NI-XNET 17.0.1
    The NI-XNET 17.5 release adds the following features:
    • Read LIN clusters from AUTOSAR 3.x and 4.x files.
      • Extract LIN frames and signals. The signal names are the names of the SYSTEM-SIGNAL instances.
      • Attach LIN frames to the ECUs as "Rx/Tx."
      • Extract LIN cluster specific information (i.e. schedules and configuration frames).
      Notes  NI-XNET supports PDUs only if there is a 1:1 mapping between the PDU and frame layout. The import is limited to features supported by the NI-XNET driver.
    • Added user accessible checksum values to NI-XNET LIN frames.
    • Added support for ISC-178X smart cameras.
    • Added support for signals larger than 52 bits in the API and the Database Editor.
      • Signals up to 64 bits can be read/written as double floating point (rounded).
      • Signals of any size can be read/written as byte strings using a conversion session.
    New NI-XNET 17.0.1 Features and Changes as Compared to NI-XNET 17.0
    The NI-XNET 17.0.1 release changes the following:
    • Bug Fix for LabVIEW 64-bit support.
    New NI-XNET 17.0 Features and Changes as Compared to NI-XNET 16.1
    The NI-XNET 17.0 release adds the following features:
    • Support for LabVIEW 2017.
    • Support for PCIe-8510.
    • Read CAN clusters from AUTOSAR 3.x and 4.x files.
      • Extract CAN frames and signals. The signal names are the names of the SYSTEM-SIGNAL instances.
      • Attach CAN frames to the ECUs as "Rx/Tx."
      • Extract CAN FD specific settings.
    The NI-XNET 17.0 release changes the following:
    • Improvements that require a firmware update for NI 9860 modules and the cDAQ integrated XNET port.
    • Removed support for LabVIEW 2013.
    • Removed support for CVI 2010.
    New NI-XNET 16.1 Features and Changes as Compared to NI-XNET 16.0
    The NI-XNET 16.1 release adds the following features:
    • Added support for the USB-8502 and USB-8506.
    • Added C-API examples for J1939.
    • Enabled setting a custom baud rate for ISO CAN FD in the Bus Monitor and Database Editor.
    • Enabled excluding IDs in the Bus Monitor.
    • Enabled setting a node address for J1939 in the Bus Monitor.
    The NI-XNET 16.1 release changes the following:
    • Removed support for CVI 8.5, 9.0, and 2009.
    • USB-8501 (Low-Speed/Fault-Tolerant CAN)
    • USB-8502 (High-Speed/FD CAN)
    • USB-8506 (LIN)
    • PCI-8511 (Low-Speed/Fault-Tolerant CAN)
    • PCI-8512 (High-Speed/FD CAN)
    • PCI-8513 (Software-Selectable/FD CAN)
    • PCI-8516 (LIN)
    • PCI-8517 (FlexRay)
    • PCIe-8510 (Hardware-Selectable)
    • PXI-8511 (Low-Speed/Fault-Tolerant CAN)
    • PXI-8512 (High-Speed/FD CAN)
    • PXI-8513 (Software-Selectable/FD CAN)
    • PXI-8516 (LIN)
    • PXI-8517 (FlexRay)
    • PXIe-8510 (Hardware-Selectable)
    • PXIe-8521 (Automotive Ethernet)
    • TRC-8542 NI-XNET CAN HS/FD Transceiver Cable
    • TRC-8543 NI-XNET CAN XS (LS/FT, HS/FD)Transceiver Cable
    • TRC-8546 NI-XNET LIN Transceiver Cable
    C Series modules:
    • NI 9860 (C Series Hardware-Selectable)
    • NI 9861 (C Series Low-Speed CAN)
    • NI 9862 (C Series High-Speed/FD CAN)
    • NI 9866 (C Series LIN)
    • CompactDAQ—NI-DAQmx 16.0 (or later) is required for:
      • USB Chassis: cDAQ-9171, cDAQ-9174, cDAQ-9178, and cDAQ-9179
      • Ethernet Chassis: cDAQ-9181, cDAQ-9184, and cDAQ-9188
      • Wireless Chassis: cDAQ-9191
      • cDAQ Controller: cDAQ-9138 (Windows only) and cDAQ-9139 (Windows only)
      • cDAQ Controller: cDAQ-9132 (Windows and RT) and cDAQ-9134 (Windows and RT)
      • cDAQ Controller: cDAQ-9133 (Windows and RT) and cDAQ-9135 (Windows and RT)
      • cDAQ Controller: cDAQ-9136 (Windows and RT) and cDAQ-9137 (Windows and RT)
    • CompactDAQ—NI-DAQmx 17.1 (or later) is required for:
      • Ethernet Chassis: cDAQ-9185 and cDAQ-9189
    • CompactRIO—CompactRIO 19.0 (or later) and LabVIEW 2016 (or later) are required for the following targets:
      • LabVIEW FPGA is required to build and deploy a bit stream with NI 986x modules in the project, unless otherwise specified.
      • Real-Time Controller: cRIO-9022, cRIO-9023, cRIO-9024, and cRIO-9025
      • CompactRIO Reconfigurable Chassis: cRIO-9111, cRIO-9112, cRIO-9113, cRIO-9114, cRIO-9116, and cRIO-9118
      • Integrated CompactRIO Real-Time Controller: cRIO-9081, cRIO-9082, cRIO-906x, and cRIO-903x
      • Single-Board RIO: sbRIO-9627, sbRIO-9607
      • CompactRIO Real-Time Controller: cRIO-9032, cRIO-9037
      • CompactRIO Real-Time Controller: cRIO-9035 (Sync), cRIO-9039 (Sync)
      • When using a cRIO-903x or cRIO-906x, a bit stream is not needed with NI 986x modules in the project.
    • CompactRIO—CompactRIO 19.0 (or later) and LabVIEW 2017 (or later) are required for the following targets:
      • CompactRIO Real-Time Controller: cRIO-9040, cRIO-9042, cRIO-9043, cRIO-9045, cRIO-9047, cRIO-9048, and cRIO-9049
      • When using a cRIO-904x, NI 986x modules will only be usable in Real-Time mode, and no bit stream is necessary.
    Note  The NI-XNET software supports only National Instruments Automotive Ethernet, CAN, FlexRay, and LIN hardware products. For information about software for CAN products from other vendors, refer to the documentation you received with those products.
    Issue Number
    Summary
    672838
    Inserting a USB-850x device can result in an unusable device with internal errors on PharLap. Workaround: Remove and reinsert the device or reboot the system.
    687624
    NI-XNET CAN FD sessions (non-BRS) require CAN FD Baud Rate to be set.
    697677
    NI-XNET does not import the DBC BO_TX_BU property from DBC files and prevents a TX frame from being mapped to multiple transmit ECUs.
    703292
    The J1939 address claim procedure does not detect conflicts between two ECUs running on the same XNET interface.
    704022
    XNET Read (Frame CAN) can return fewer than the requested number of J1939 frames without reporting an error as specified in the documentation.
    705533
    Frame Output Queued sessions do not retransmit cyclic J1939 frames with payloads greater than 8 bytes. These transmit one time when the session starts, and then only when new data is written to the session.
    705671
    Switching a J1939 session to a different ECU Node Name does not use the address from the new ECU, even if that ECU has already claimed an address. The node address must be set after the node name to properly configure the session.
    710192
    The NI-XNET Database Editor does not allow you to create a signal with the same name as one that was previously deleted. Avoid this issue by saving the database and re-opening it after deleting the signal.
    710389
    XNET Wait (Transmit Complete) may cause a stale FlexRay frame to retransmit if the transmit queue is already empty.
    722862
    XNET Blink errors when using an Ethernet interface with a monitor path ("/monitor").
    724930
    If XNET Read (Frame Raw) times out partly through reading Ethernet frames, the subset of frames that were successfully read are discarded and are no longer available from the NI-XNET session.
    727473
    NI-XNET Signal Output Single-Point sessions always write mode 0 subframes by default, even if no mode 0 subframe is present for the multiplexer. Avoid this issue by writing initial signal values, including the multiplexer signal, prior to starting the session.
    730930
    Ethernet device PHY State and Port Mode properties are not reset to default values after NI-XNET is uninstalled and reinstalled.
    The following items are the IDs and titles of a subset of issues fixed in this release. This is not an exhaustive list of issues fixed. If you have a CAR ID, you can search this list to validate that the issue has been fixed.
    Bug ID
    Summary
    696254NI-XNET may incorrectly set the CAN I/O Mode for CAN FD clusters and frames imported from ARXML databases.
    701025Rare crash in MAX when both NI-XNET FlexRay devices and C Series modules are present in a cDAQ chassis.
    714785NI-XNET interface I/O control dropdowns are empty when any device requires a firmware upgrade.
    715907NI-XNET Compatibility for NI-CAN: ncReadNetMult loses or corrupts frames after about 2000 frames.
    716271NI-XNET Compatibility for NI-CAN: When ncCloseObject is used to close the final CAN Object or Network Interface Object on a port, ncConfigObject and ncOpenObject can fail on unrelated ports with 0xBFF63131.
    722040Signal Input Waveform sessions accrue samples when stopped or when the interface was started before the session, and flushing has no effect on accrued samples.
    723073Deploying a database containing a CAN FD cluster to LabVIEW Real-Time incorrectly configures the first cluster (regardless of protocol) to use a baud rate of 500000.
    727891PCIe-8510 and PXIe-8510 devices may be unusable after Windows boots if a PCI rebalance was necessary; if this happens, disable and re-enable the devices.
    730493CAN Frame Input sessions do not set the data length code (DLC) correctly when transmitting a remote frame.
    If you intend to use the NI-CAN API with NI-XNET hardware, refer to the NI-XNET Compatibility for NI-CAN appendix in the NI-CAN Hardware and Software Manual.
    Removing and inserting C Series modules on CompactRIO targets during device communication is not supported
    Inserting a module into or removing a module from a cRIO chassis that is actively communicating with an NI 986x module can cause application failures and possibly device damage. This does not apply to controllers which support the NI-DAQmx programming method, such as the cRIO-904x family.
    The following sections detail considerations for using NI-XNET with LabVIEW NXG.
    LabVIEW NXG is installed using NI Package Manager. Complete the following steps to install NI-XNET for LabVIEW NXG.
    • Click Download LabVIEW NXG.
    • NI Package Manager installs, and then automatically opens a download window.
    • Select LabVIEW NXG Suite, and click the green Install button.
    • Select LabVIEW NXG and NI-XNET.
    • Complete the installer instructions to download LabVIEW NXG and NI-XNET.
    LabVIEW NXG Help
    LabVIEW NXG Examples
    374802N-01
  • 签到天数: 5 天
    发表于 2020-10-22 21:23:58 | 显示全部楼层 来自:浙江省杭州市 华数宽带
    GMT+8, 2025-7-26 08:23
