查看: 2595|回复: 0
[NI驱动程序] NI-XNET 20.0 Driver Win32/64 Eng/Ger/Jpn NI-XNET仪器驱动程序20.0下载
    昨天 10:50
  • 签到天数: 3604 天
    连续签到: 12 天
    发表于 2020-10-20 23:55:40 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    NI-XNET
    20.0
    文件大小: 1827375104 字节 (1.70 GB)
    修改日期: 2020-05-12 02:44
    MD5: d96c440f8d5077cc2c1a256c770eb742(官方正确)
    SHA1: d3811e1e04c6195b47738a393e2905522964b1b4
    SHA256: 3776b26477c21960bf55c05f4191384606bf7b8caf661f1a1a3f37771a7cce05
    CRC32: 853d5a5d
    NI-XNET20.0.txt (275 Bytes, 下载次数: 1, 售价: 10 元)
    NI-XNET 20.0 Readme
    April 2020
    This file contains important information about NI-XNET, including installation instructions and known issues.
    New Features and Changes
    Additional Programming Topics
    NI-XNET Drops Support for Windows 7 (32- and 64-Bit), Windows Server 2008 R2, and All 32-Bit Windows Operating Systems in 2021
    NI-XNET is an NI instrument driver that features a common set of easy-to-use functions for reading and writing Automotive Ethernet, CAN, LIN, and FlexRay data on many different platforms including USB, PXI, PCI, NI CompactDAQ, and NI CompactRIO.
    NI-XNET supports the following operating systems:
    • Windows 10/8.11/7 SP12
    • Windows Server 2012 R21
    • Windows Server 2008 R2 SP12
    Note  Support for Windows 32-bit operating systems may require disabling physical address extension (PAE). To learn how this might affect your system and what actions you might need to take, visit ni.com/r/PAEsupport.
    The NI-XNET installer does not support Windows Server 2003/NT/Vista/XP/Me/2000/98/95 or the Windows Server non-R2 editions.
    NI-XNET does not support guest accounts on Windows 7. You must log into an administrative or user account to use NI-XNET on these operating systems.
    PXI Automotive Ethernet Interface Modules (PXIe-8521, PXIe-8522, and PXIe-8523) do not support the Phar Lap ETS real-time operating system that installs with the LabVIEW Real-Time Module.
    NI Software will drop support for Phar Lap ETS Real-Time Operating System starting in 2022. Versions of this product that ship after May 1, 2022, may not install or execute correctly on this operating system. For high-level information on the support roadmap for Phar Lap and its replacement, NI Linux Real-Time, please visit ni.com/r/xf35k1. To find out what hardware is supported on PXI controllers running NI Linux Real-Time, please visit ni.com/r/b7g5wi.
    The following table lists the application software versions supported by NI-XNET.
    Application Software3
    Versions Supported by NI-XNET 20.0
    2017, 2018, 2019, and 2020
    LabVIEW Real-Time (RT)
    LabVIEW NXG
    5.0
    LabWindows™/CVI™
    2015 and later
    3 Application software support for LabVIEW NXG is not included with NI-XNET and must be downloaded separately via NI Package Manager. Refer to Installing NI-XNET for LabVIEW NXG for instructions.
    NI-XNET supports the following Microsoft Visual Studio versions and associated programming languages.
    Programming Languages
    Microsoft Visual C/C++
    6.0 and later
    Refer to the following instructions to install NI-XNET from a DVD. To install NI-XNET for LabVIEW NXG, refer to Installing NI-XNET for LabVIEW NXG.
    • Insert the NI-XNET software DVD into the DVD drive. If the installer does not launch automatically, navigate to the DVD using Windows Explorer and launch the autorun.exe file from your NI-XNET software DVD.
    • Click Install.
    New Features and ChangesNew NI-XNET 20.0 Features and Changes as Compared to NI-XNET 19.6
    The NI-XNET 20.0 release adds the following features:
    • Added support for LabVIEW NXG 5.0.
    • Added support for LabVIEW 2020.
    • Added a System Configuration API property, Interrupt Moderation, for PXIe-8522 and PXIe-8523 Automotive Ethernet modules that can improve system performance.
    The NI-XNET 20.0 release changes the following:
    • Removed support for LabVIEW 2016.
    • Removed support for CVI 2013.
    • Removed support for cRIO-9022, cRIO-9023, cRIO-9024, cRIO-9025, cRIO-9081, and cRIO-9082 controllers.
    • Removed support for cRIO-9111, cRIO-9112, cRIO-9113, cRIO-9114, cRIO-9116, and cRIO-9118 chassis.
    New NI-XNET 19.6 Features and Changes as Compared to NI-XNET 19.5
    The NI-XNET 19.6 release adds the following features:
    • Added support for jumbo frames with the PXIe-8522 and PXIe-8523 Automotive Ethernet modules.
    • Added support for Ethernet Frame Filter property.
    • Added support for Automotive Ethernet modules to use Wireshark to monitor Ethernet frames in real-time. (Supported in Windows only and tested with Wireshark 3.0.6.)
    New NI-XNET 19.5 Features and Changes as Compared to NI-XNET 19.1
    The NI-XNET 19.5 release adds the following features:
    • Added support for LabVIEW NXG 4.0.
    • Added support for sbRIO-9603, sbRIO-9608, sbRIO-9609, sbRIO-9628, sbRIO-9629, and sbRIO-9638 chassis.
    • Added support for PXIe-8522 and PXIe-8523 Automotive Ethernet modules.
    New NI-XNET 19.1 Features and Changes as Compared to NI-XNET 19.0
    The NI-XNET 19.1 release adds the following features:
    • Added support for PXI controllers running NI Linux Real-Time for NI-XNET PCI, PXI, PCIe, PXIe, and C Series devices4.
    • Added support for network time synchronization with the PXIe-8521 while in Tap mode.
    • Added support for the PXIe-8521 in LabVIEW NXG 3.1.
    4C Series devices are supported only when used in a supported CompactDAQ chassis.
    New NI-XNET 19.0 Features and Changes as Compared to NI-XNET 18.5
    The NI-XNET 19.0 release adds the following features:
    • Added support for LabVIEW 2019.
    • Added support for the PXIe-8521 4-port, 100BASE-T1 Automotive Ethernet Interface Module.
    Note  The PXIe-8521 does not support LabVIEW Real-Time or LabVIEW NXG in NI-XNET 19.0.
    The NI-XNET 19.0 release changes the following:
    • Extended the NI-XNET LabVIEW API to support Automotive Ethernet.
    • Removed support for LabVIEW 2015.
    • Removed support for NI-XNET C series modules in a cDAQ chassis when attached to a controller or host running Phar Lap. Support for other Operating Systems remains unaffected.
    • Removed support for cRIO-9012 and cRIO-9014 controllers. Note that these targets may still support installation, but they are no longer officially supported, and may be removed in a future release.
    • Changed behavior for Signal Input Waveform sessions to address defects.
    • Changed options for building LabVIEW or CVI application installers: "NI-XNET Runtime" installs only the NI-XNET Runtime, "NI-XNET Utilities" installs the NI-XNET Database Editor and Bus Monitor in addition to the NI-XNET Runtime.
    New NI-XNET 18.5 Features and Changes as Compared to NI-XNET 18.0
    The NI-XNET 18.5 release adds the following features:
    • Added support for LabVIEW NXG 3.0.
    • Added support for LabVIEW 2018 SP1.
    • Added support for the USB-8501 NI-XNET CAN LS/FT Interface.
    • Added support for importing CAN FD settings from FIBEX 4.1.2 databases.
    • Added support for J1939 session property, SAE J1939:Include Destination Address in PGN, in LabVIEW NXG.
    The NI-XNET 18.5 release changes the following:
    • Lowered the default value for the nxPropSession_J1939ResponseTimeTrSD property from 0.05 s to 0 s to improve performance in handling multipacket messages.
    • Improved performance when opening large database files.
    • Removed support for LabVIEW NXG 2.0 and 2.1.
    New NI-XNET 18.0 Features and Changes as Compared to NI-XNET 17.5.1
    The NI-XNET 18.0 release adds the following features:
    • Added ability in SystemDesigner to discover XNET hardware ports and select new names for them. (LabVIEW NXG)
    • Added a new J1939 session property, SAE J1939:Include Destination Address in PGN. (C and LabVIEW 2018 only)
    • Added support for LabVIEW NXG 2.1.
    • Added support for LabVIEW 2018.
    The NI-XNET 18.0 release changes the following:
    • Removed support for LabVIEW 2014.
    New NI-XNET 17.5.1 Features and Changes as Compared to NI-XNET 17.5
    The NI-XNET 17.5.1 release changes the following:
    • Bug Fix for cDAQ-9171 support.
    New NI-XNET 17.5 Features and Changes as Compared to NI-XNET 17.0.1
    The NI-XNET 17.5 release adds the following features:
    • Read LIN clusters from AUTOSAR 3.x and 4.x files.
      • Extract LIN frames and signals. The signal names are the names of the SYSTEM-SIGNAL instances.
      • Attach LIN frames to the ECUs as "Rx/Tx."
      • Extract LIN cluster specific information (e.g., schedules and configuration frames).
      Notes  NI-XNET supports PDUs only if there is a 1:1 mapping between the PDU and frame layout. The import is limited to features supported by the NI-XNET driver.
    • Added user accessible checksum values to NI-XNET LIN frames.
    • Added support for ISC-178X smart cameras.
    • Added support for signals larger than 52 bits in the API and the Database Editor.
      • Signals up to 64 bits can be read/written as double floating point (rounded).
      • Signals of any size can be read/written as byte strings using a conversion session.
    New NI-XNET 17.0.1 Features and Changes as Compared to NI-XNET 17.0
    The NI-XNET 17.0.1 release changes the following:
    • Bug Fix for LabVIEW 64-bit support.
    New NI-XNET 17.0 Features and Changes as Compared to NI-XNET 16.1
    The NI-XNET 17.0 release adds the following features:
    • Support for LabVIEW 2017.
    • Support for PCIe-8510.
    • Read CAN clusters from AUTOSAR 3.x and 4.x files.
      • Extract CAN frames and signals. The signal names are the names of the SYSTEM-SIGNAL instances.
      • Attach CAN frames to the ECUs as "Rx/Tx."
      • Extract CAN FD specific settings.
    The NI-XNET 17.0 release changes the following:
    • Improvements that require a firmware update for NI 9860 modules and the cDAQ integrated XNET port.
    • Removed support for LabVIEW 2013.
    • Removed support for CVI 2010.
    • USB-8501 Low-Speed/Fault Tolerant USB CAN Interface Device
    • USB-8502 High-Speed/FD USB CAN Interface Device
    • USB-8506 USB LIN Interface Device
    • PCI-8511 Low‑Speed/Fault-Tolerant CAN Interface Device
    • PCI-8512 High‑Speed/FD CAN Interface Device
    • PCI-8513 Software‑Selectable/FD CAN Interface Device
    • PCI-8516 PCI LIN Interface Device
    • PCI-8517 FlexRay Interface Device
    • PCIe-8510 PCIe Vehicle Multi-Protocol Interface Device
    • PXI-8511 Low-Speed/Fault Tolerant PXI CAN Interface Module
    • PXI-8512 High-Speed, Flexible Data Rate PXI CAN Interface Module
    • PXI-8513 Software-Selectable PXI CAN Interface Module
    • PXI-8516 PXI LIN Interface Module
    • PXI-8517 PXI FlexRay Interface Module
    • PXIe-8510 PXI Vehicle Multiprotocol Interface Module
    • PXIe-8521 100BASE-T1 PXI Automotive Ethernet Interface Module
    • PXIe-8522 1000BASE-T1 PXI Automotive Ethernet Interface Module
    • PXIe-8523 100/1000BASE-T1 PXI Automotive Ethernet Interface Module
    • TRC-8542 CAN HS/FD Transceiver Cable
    • TRC-8543 CAN HS/FD or LS/FT Transceiver Cable
    • TRC-8546 LIN Transceiver Cable
    C Series modules:
    • NI 9860 C Series Vehicle Multiprotocol Interface Module
    • NI 9861 Low-Speed/Fault Tolerant C Series CAN Interface Module
    • NI 9862 High-Speed, Flexible Data Rate C Series CAN Interface Module
    • NI 9866 C Series LIN Interface Module
    • CompactDAQ—NI-DAQmx 17.1 (or later) is required for:
      • USB Chassis: cDAQ-9171, cDAQ-9174, cDAQ-9178, and cDAQ-9179
      • Ethernet Chassis: cDAQ-9181, cDAQ-9184, and cDAQ-9188
      • Wireless Chassis: cDAQ-9191
      • cDAQ Controller: cDAQ-9138 (Windows only) and cDAQ-9139 (Windows only)
      • cDAQ Controller: cDAQ-9132 (Windows and RT) and cDAQ-9134 (Windows and RT)
      • cDAQ Controller: cDAQ-9133 (Windows and RT) and cDAQ-9135 (Windows and RT)
      • cDAQ Controller: cDAQ-9136 (Windows and RT) and cDAQ-9137 (Windows and RT)
      • Ethernet Chassis: cDAQ-9185 and cDAQ-9189
    • CompactRIO—CompactRIO 20.0 (or later) and LabVIEW 2017 (or later) are required for the following targets:
      • Integrated CompactRIO Real-Time Controller: cRIO-906x, and cRIO-903x
      • Single-Board RIO: sbRIO-9627, sbRIO-9607
      • CompactRIO Real-Time Controller: cRIO-9032, cRIO-9037
      • CompactRIO Real-Time Controller: cRIO-9035 (Sync), cRIO-9039 (Sync)
      • When using a cRIO-903x or cRIO-906x, a bit stream is not needed with NI 986x modules in the project
      • When using a cRIO-903x, cRIO-906x, or sbRIO-96x7, installation in the "Other" programming environment is not supported
      • CompactRIO Real-Time Controller: cRIO-9040, cRIO-9042, cRIO-9043, cRIO-9045, cRIO-9047, cRIO-9048, and cRIO-9049
      • When using a cRIO-904x, NI 986x modules will only be usable in Real-Time mode, and no bit stream is necessary
    • CompactRIO—CompactRIO 20.0 (or later) and LabVIEW 2018 (or later) are required for the following targets:
      • CompactRIO Real-Time Controller: cRIO-9053, cRIO-9054, cRIO-9056, and cRIO-9057
      • When using a cRIO-905x, NI 986x modules will only be usable in Real-Time mode, and no bit stream is necessary
    • CompactRIO—CompactRIO 20.0 (or later) and LabVIEW 2019 (or later) are required for the following targets:
      • Single-Board RIO: sbRIO-9603, sbRIO-9608, sbRIO-9609, sbRIO-9628, sbRIO-9629, sbRIO-9638
      • When using an sbRIO-9603, sbRIO-9608, sbRIO-9609, sbRIO-9628, sbRIO-9629, or sbRIO-9638, NI 986x modules will only be usable in Real-Time mode, and no bit stream is necessary
    Note  The NI-XNET software supports only National Instruments Automotive Ethernet, CAN, FlexRay, and LIN hardware products. For information about software for CAN products from other vendors, refer to the documentation you received with those products.
    Bug ID
    Summary
    210421
    Installing a new version of NI-XNET or NI-XNET Runtime can break NI-XNET I/O control dialogs in older versions of the LabVIEW ADE and deployable applications.
    419486
    Inserting a USB-850x device can result in an unusable device with internal errors on Phar Lap. Workaround: Remove and reinsert the device or reboot the system.
    199635
    NI-XNET CAN FD sessions (non-BRS) require CAN FD Baud Rate to be set.
    201375
    NI-XNET does not import the DBC BO_TX_BU property from DBC files and prevents a TX frame from being mapped to multiple transmit ECUs.
    199608
    The J1939 address claim procedure does not detect conflicts between two ECUs running on the same XNET interface.
    199657
    XNET Read (Frame CAN) can return fewer than the requested number of J1939 frames without reporting an error as specified in the documentation.
    199702
    Frame Output Queued sessions do not retransmit cyclic J1939 frames with payloads greater than 8 bytes. These transmit one time when the session starts, and then only when new data is written to the session.
    199696
    Switching a J1939 session to a different ECU Node Name does not use the address from the new ECU, even if that ECU has already claimed an address. The node address must be set after the node name to properly configure the session.
    420680
    The NI-XNET Database Editor does not allow you to create a signal with the same name as one that was previously deleted. Avoid this issue by saving the database and re-opening it after deleting the signal.
    199741
    XNET Wait (Transmit Complete) may cause a stale FlexRay frame to retransmit if the transmit queue is already empty.
    199598
    If XNET Read (Frame Raw) times out partly through reading Ethernet frames, the subset of frames that were successfully read are discarded and are no longer available from the NI-XNET session.
    199704
    NI-XNET Signal Output Single-Point sessions always write mode 0 subframes by default, even if no mode 0 subframe is present for the multiplexer. Avoid this issue by writing initial signal values, including the multiplexer signal, prior to starting the session.
    197052
    Ethernet device PHY State and Port Mode properties are not reset to default values after NI-XNET is uninstalled and reinstalled.
    The following items are the IDs and titles of a subset of issues fixed in this release. This is not an exhaustive list of issues fixed. If you have a Bug ID, you can search this list to validate that the issue has been fixed.
    Bug ID
    Summary
    962213
    Firmware timeout in Frame Input Single-point Session when receiving a frame with a payload length that differs from the frame's database definition.
    895923
    nxdbDeleteObject (when called on a cluster) and XNET Database Delete (Cluster) do not delete LIN schedules or LIN schedule entries correctly.
    941856
    LIN No Response frames are not recorded after stopping a Frame Output Session on an interface that is logging bus errors.
    897065
    Editing an Automotive Ethernet Project Session incorrectly displays a dialog related to a missing database alias.
    If you intend to use the NI-CAN API with NI-XNET hardware, refer to the NI-XNET Compatibility for NI-CAN appendix in the NI-CAN Hardware and Software Manual.
    Removing and inserting C Series modules on CompactRIO targets during device communication is not supported
    Inserting a module into or removing a module from a cRIO chassis that is actively communicating with an NI 986x module can cause application failures and possibly device damage. This does not apply to controllers which support the NI-DAQmx programming method, such as the cRIO-904x family.
    RT Bus Monitor requires LabVIEW Real-Time
    Installing software to a Real-Time target using the "Other" programming environment will not run the RT Bus Monitor. To use this utility, select a "LabVIEW" or "LabVIEW NXG" programming environment.
    NI-XNET will drop support for Windows 7 (32- and 64-bit), Windows Server 2008 R2, and all 32-bit Windows operating systems starting in 2021. Versions of this product that ship after May 1, 2021, may not install or execute correctly on these operating systems. For detailed information about NI operating system support, visit ni.com/r/win32bitsupport.
    The following sections detail considerations for using NI-XNET with LabVIEW NXG.
    LabVIEW NXG is installed using NI Package Manager. Complete the following steps to install NI-XNET for LabVIEW NXG.
    • Click Download LabVIEW NXG.
    • NI Package Manager installs, and then automatically opens a download window.
    • Select LabVIEW NXG Suite, and click the green Install button.
    • Select LabVIEW NXG and NI-XNET.
    • Complete the installer instructions to download LabVIEW NXG and NI-XNET.
    LabVIEW NXG Help
    LabVIEW NXG Examples
    © 2009–2020 National Instruments. All rights reserved.
    374802U-01
    GMT+8, 2025-7-26 08:05
