查看: 3843|回复: 0
[RTE运行引擎] NI-VISA20.0 MACOS Driver Runtime 美国国家仪器虚拟仪器软件架构VISA20.0 苹果系统版驱动运行版下载
    昨天 10:12
  • 签到天数: 3791 天
    连续签到: 42 天
    发表于 2020-10-22 23:32:23 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    注意,NI-VISA从VISA14.0版开始,使用年代名称来命名,即14代表的是2014年,不再延续之前的5.X之类的名称。而在VISA5.4.1及之前的版本,则是使用数字版本来命名的,5并不是代表着2005年之类的。
    NI-VISA 20.0
    发布日期
    20-7-29
    受支持的操作系统
    Mac OS X
    语言
    English
    校验和
    运行时:
    文件大小: 7908749 字节 (7.54 MB)
    修改日期: 2020-10-22 23:20
    MD5: 0a62d54017074446c3ff018e119c664b
    SHA1: 25ec95bb17a04dddd73ce00cd8ef5156521feee5
    SHA256: 0bcc15a2076a9ebd9e9ed593de44d4f4263709b47c4acd1beca87281b739eb11
    CRC32: 2a41bd88
    百度网盘和官方下载地址:
    NI-VISA20.0MAC RT.txt (265 Bytes, 下载次数: 0, 售价: 10 圆)
    NI-VISA 20.0 for macOS Readme
    May 2020
    This file contains important information about NI-VISA 20.0 for macOS, including supported platforms, known issues, new features, and a partial list of bugs fixed for NI-VISA 20.0.
    Contents
    NI Software Support for 32-bit applications
    NI-VISA is the NI implementation of the Virtual Instrument Software Architecture (VISA), a standard for configuring, programming, and troubleshooting instrumentation systems comprising GPIB, VXI, PXI, Serial, Ethernet, and/or USB interfaces.
    NI-VISA 20.0 for macOS supports the following platforms:
    • macOS 10.15.x
    • macOS 10.14.x
    NI-VISA for macOS currently supports the following resource types and utilities:
    • GPIB
    • Serial
    • PXI/PCI
    • TCPIP
    • Remote Client
    • Remote Server
    • ENET Serial
    • USB
    • VISA Interactive Control
    • NI I/O Trace
    Note  NI-VISA for macOS supports only 64-bit applications.
    The following table lists the NI application software versions supported by NI-VISA:
    NI Application SoftwareVersions Supported by NI-VISA
    NI LabVIEW2017, 2018, 2019, 2020
    Installation InstructionsLabVIEW Installation
    You can install all of your LabVIEW products—including NI-VISA—using the LabVIEW 2020 Platform media. Refer to the LabVIEW Installation Guide on the LabVIEW Platform media for installation instructions and system requirements.
    To request additional LabVIEW Platform media, visit ni.com/r/media.
    Installed Files and Paths
    There are three main locations where NI-VISA installs files.
    • The local /Library/Frameworks folder contains the VISA.framework folder. This folder contains all needed headers and supporting Passport libraries that NI-VISA uses.
    • In the local /Applications/National Instruments folder, there is an NI-VISA folder. This folder includes the NI-VISA Help, as well as several groups of C examples using NI-VISA. This NI-VISA folder also includes a graphical utility called NI-VISA Configuration to configure VISA options and the VISA Interactive Control (VISAIC).
    • Finally, the /Library/Preferences folder contains an NIvisa folder with .ini files. These files are used for NI-VISA settings and status codes.
    NI-VISA 19.0 Drops Support for 32-bit Applications in 2019
    NI-VISA dropped support for 32-bit applications starting in 2019. Versions of this product that ship after May 1, 2019 (including NI-VISA 19.0) will not support 32-bit applications. For detailed information about 32-bit application support, visit ni.com/r/32bitsupport.
    New FeaturesNI-VISA 15.0
    Added support for NI MAX.
    NI-VISA 14.0
    Added support for 64-bit versions of LabVIEW.
    Added support for the System Configuration API.
    Added support for viGpibControlREN on TCPIP resources that use the VXI-11 protocol.
    NI-VISA 5.3
    Improved performance of viRead for a HiSLIP resource.
    NI-VISA 5.2
    Improved performance of viWrite for a HiSLIP resource.
    NI-VISA 5.1.2
    Added support for 64-bit kernel for OS X.
    Added OS X 10.7 support.
    NI-VISA 5.1
    Added support for HiSLIP.
    Added the VISA Interactive Control (VISAIC) stand-alone application. Refer to the NI-VISA Help for more information on the updates to VISAIC.
    NI-VISA 5.0
    Added OS X 10.6 support.
    Added support for 64-bit formatted I/O.
    Dropped GPIB-VXI support.
    NI-VISA 4.5
    Added automatic detection of LXI (TCP/IP) devices that support the mDNS and DNS-SD technologies.
    NI-VISA 4.0.1
    Added support for the PXI/PCI Passport on the x86 architecture.
    Added native support for the NI-VISA Configuration Utility on the x86 architecture.
    NI-VISA 4.0
    Added support for OS X on the x86 architecture, aka Mactel.
    Added support for 64-bit data transfers in register-based operations, to support the VISA 4.0 specification.
    Added support for DTR/DSR flow control. The Agilent 34401A requires DTR/DSR flow control when used via Serial. Note that not all Serial port drivers on OS X support DTR/DSR. We have tested the Agilent 34401A with NI-VISA 4.0 using the Keyspan USA-19HS and verified that it works properly.
    You can access the software and documentation known issues list online. For a list of known issues with NI-VISA 20.0, visit the ni.com/r/visaknownissues list on ni.com
    For a list of bug fixes for NI-VISA, visit ni.com/info and enter the Info Code ni.com/r/nivisafixlist.
    © 1995–2020 National Instruments. All rights reserved.
    Third-Party Legal Notices
    You can find third-party legal notices in the /Library/Application Support/National Instruments/Legal Information directory.
    375354H-01
    GMT+8, 2026-2-3 04:39
