查看: 3211|回复: 0
[NI驱动程序] NI-VISA15.5Linux 美国国家仪器虚拟仪器软件架构VISA15.5Linux版下载
    昨天 10:12
  • 签到天数: 3791 天
    连续签到: 42 天
    发表于 2020-10-22 23:49:02 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    NI-VISA15.5:
    链接:请注册视觉论坛会员登录后购买附件下载查看
    提取码:请购买附件下载查看
    NI-VISA15.5:
    请购买附件下载查看
    文件名: NI-VISA-15.5.0.iso
    文件大小: 106665984 字节 (101.72 MB)
    修改日期: 2017-08-29 00:55
    MD5: 049033dc8d884c71c53744021e235c3c(重复下载一致)
    SHA1: 85cef7b493fa9f3702d473272a5173a46c6bd7d1
    SHA256: dd28343aaada4ab966e9c5194512febc882445692cd8aadc638632726ac3d68e
    CRC32: 0c2a86cd
    NI-VISA15.5Linux.txt (547 Bytes, 下载次数: 1, 售价: 10 圆)
    NI-VISA(TM) Software for Linux, Version 15.5
    February 2016
    CONTENTS OF THIS FILE
    Installation From the Internet
    Installation FAQs
    USB Issues on Linux
    Known Issues and Bug Fixes
    New Features and Improvements
    SYSTEM REQUIREMENTS
    NI-VISA 15.5 for Linux software requires one of the following distributions:
        openSUSE 13.1
        openSUSE 13.2
        Red Hat Enterprise Linux Desktop + Workstation 6
        Red Hat Enterprise Linux Desktop + Workstation 7
        Scientific Linux 6
        CentOS 7
    You must use the provided INSTALL script to install NI-VISA. Manual
    installation using rpm is not supported.
    At the time of release, NI supports NI-VISA 15.5
    on only the above listed distributions and versions.  For information about
    NI-VISA compatibility on other versions of these distributions,
    including earlier versions of the distributions listed above, refer
    to KB 5CNEG20S on ni.com, "What Linux distributions do National
    Instruments' drivers and software support?".
    After installation, you may need to reboot your machine before attempting
    to use NI-VISA. The installer will prompt you to reboot if it is
    required.
    Refer to ni.com/linux for the most recent information about Linux
    support at NI.
    INSTALLATION FROM THE INTERNET
    You should be logged in as 'root' to perform this installation.
    1) Download the ISO image "NI-VISA-#.#.#.iso" from the ftp site into a
       temporary directory.
    2) Open a Terminal (command prompt) window.
    3) Mount the ISO image. This may be done by typing
       "mount -o loop /NI-VISA-#.#.#.iso ".
    4) Make the mount location your current working directory. This may be done
       by typing "cd ".
    5) Type "./INSTALL" to execute the install script, and follow the instructions
       as prompted.
    INSTALLATION FAQS
    Q1: What action needs to be taken if I upgrade/change my kernel?
    A1: Some action is required to make the existing NI-VISA installation
        work for the new kernel. After upgrading your kernel, run
        updateNIDrivers utility as root. The utility is located in
        /usr/local/bin. Be sure to have sources for your new kernel properly
        installed on your system before running the utility. The utility
        rebuilds the driver using the new kernel sources and copies it to
        the appropriate location for the new kernel. For the changes
        to take place, you will be asked to reboot your machine after the
        utility completes.
    Q2: During installation I get a message similar to the following one:
        "Kernel source does not appear to be configured for the running kernel.
         Configuration of kernel source is required to continue installation."
        I do have kernel sources installed; is there anything else that needs to
        be done?
    A2: This problem can occur even if you have installed the correct kernel
    sources, if the sources require configuration. This problem has been seen on
    openSUSE. However, it is possible that other distributions will require similar
    steps to resolve this problem.
        1. Ensure you have installed kernel-source and kernel-syms packages
           corresponding to the version of the currently running kernel. The
           version of the currently running kernel can be determined by
           issuing the command `uname -r`.
        2. Change the directory to the /usr/src/linux- directory, where
           corresponds to the currently running kernel version.
        3. Run "zcat /boot/symvers-.gz > Module.symvers" as root to prepare
           modversion support.
        4. Run "make cloneconfig" as root to configure the sources for the
        5. Run "make modules_prepare" as root to prepare the headers for
           compilation.
        6. THIS STEP IS STRICTLY OPTIONAL. Completing this step removes the
           warning:
           WARNING: Symbol version dump /usr/src/linux/Module.symvers is missing,
                    modules will have CONFIG_MODVERSIONS disabled.
           Run "make modules" as root to compile all modules and generate
           Module.symvers; this step may take 30 minutes or more to complete.
        7. Run the INSTALL script for the NI-VISA software for Linux from this
           directory.
    USB ISSUES ON LINUX
    The VISA user must have write access to the file that represents
    the USB device, which is typically somewhere in a subdirectory within
    "/dev/bus/usb". If this is not the case, the USB device is not
    accessible by VISA (it will not be found using viFindRsrc and viOpen will
    fail). The default configuration on most systems is that the 'root' user
    has write access; however, no other user has this access.
    There are a number of options that you can take to provide a non-root
    user access to a USB device.
    1) Use udev rules. By default, NI-VISA installs
    scripts to give all users write access to all USB TMC devices and a
    framework for USB RAW devices. To add write permissions for a specific
    USB RAW device, run the included script:
    "/linux/NIvisa/USB/AddUsbRawPermissions.sh".
    For more information about udev, please visit:
    https://www.kernel.org/pub/linux ... plug/udev/udev.html
    2) The 'root' user may add write permissions to the file that represents
    the USB device which is typically somewhere in a subdirectory within
    "/dev/bus/usb". Unfortunately, these permissions will be lost if the
    device is unplugged and then plugged back in. Because of this, this
    approach is not recommended.
    KNOWN ISSUES AND BUG FIXES
    For a list of Known Issues of NI-VISA 15.5, visit ni.com/info and
    enter the Info Code NIVISA155KnownIssues.
    For a list of Bug Fixes for NI-VISA, visit ni.com/info and enter
    the Info Code NIVISAFixList.
    NEW FEATURES AND IMPROVEMENTS
    NI-VISA 15.0
    Added support for developing 64-bit VISA applications.
    NI-VISA 14.0
    Added support for viGpibControlREN on TCPIP resources that use the
    VXI-11 protocol.
    NI-VISA 5.3
    Improved performance of viRead for a HiSLIP resource.
    NI-VISA 5.2
    Improved performance of viWrite for a HiSLIP resource.
    NI-VISA 5.1
    Added support for HiSLIP.
    Updated the VISA Interactive Control stand-alone application. Refer to the
    NI-VISA Help for more information on the updates to VISAIC.
    NI-VISA 5.0
    Added support for openSUSE 11.1, openSUSE 11.2, and Scientific Linux 5.x
    Added support for 64-bit formatted I/O.
    Dropped support for GPIB-VXI.
    LEGAL INFORMATION
    COPYRIGHT:
    (c) 2016 National Instruments.
    All rights reserved.
    Under the copyright laws, this publication may not be reproduced or transmitted
    in any form, electronic or mechanical, including photocopying, recording,
    storing in an information retrieval system, or translating, in whole or in
    part, without the prior written consent of National Instruments Corporation.
    National Instruments respects the intellectual property of others, and we ask
    our users to do the same. NI software is protected by copyright and other
    intellectual property laws. Where NI software may be used to reproduce
    software or other materials belonging to others, you may use NI software
    only to reproduce materials that you may reproduce in accordance with the
    terms of any applicable license or other legal restriction.
    Third-Party Legal Notices
    You can find NI-VISA third-party legal notices in the
    /usr/local/vxipnp/share/nivisa directory.
    If you are an agency, department, or other entity of the United States
    Government ("Government"), the use, duplication, reproduction, release,
    modification, disclosure or transfer of the technical data included in this
    manual is governed by the Restricted Rights provisions under Federal
    Acquisition Regulation 52.227-14 for civilian agencies and Defense Federal
    Acquisition Regulation Supplement Section 252.227-7014 and 252.227-7015 for
    military agencies.
    Content from the IVI specifications reproduced with permission from the IVI
    Foundation.
    The IVI Foundation and its member companies make no warranty of any kind with
    regard to this material, including, but not limited to, the implied warranties
    of merchantability and fitness for a particular purpose. The IVI Foundation and
    its member companies shall not be liable for errors contained herein or for
    incidental or consequential damages in connection with the furnishing,
    performance, or use of this material.
    TRADEMARKS:
    Refer to the NI Trademarks and Logo Guidelines at ni.com/trademarks for
    information on National Instruments trademarks. Other product and company names
    mentioned herein are trademarks or trade names of their respective companies.
    PATENTS:
    For patents covering the National Instruments products/technology, refer to the
    appropriate location: Help Patents in your software, the patents.txt file on
    your media, or the National Instruments Patent Notice at ni.com/patents.
    GMT+8, 2026-2-3 07:42
