查看: 2650|回复: 0
[NI驱动程序] NI-RIO 3.1.1旧版设备驱动Windows系统32位English完整版
  • 签到天数: 3582 天
    连续签到: 2 天
    发表于 2020-10-28 20:29:43 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    NI-RIO(旧版)
    NI-RIO用于为可重配置硬件设备提供支持。
    NI-RIO是一个设备驱动,用于支持可重配置I/O (RIO)硬件的识别、编程和部署。它为CompactRIO模块、多功能可重配置I/O设备、PXI多功能可重配置I/O模块和FlexRIO仪器提供了支持。
    3.1.1
    文件大小: 954131009 字节 (909.93 MB)
    修改日期: 2014-08-28 02:27
    MD5: 6f996650f7497b06d75d4c160a005590(官方正确)
    SHA1: eb873247048447e316503ed9aa0454870eb6ca42
    SHA256: aabdeeda60a58a011fc9beb1173038095ffb19ed1bf55c6e070c665b37a1f91a
    CRC32: 59cc9c13
    NIRIOWin3.1.1.txt (286 Bytes, 下载次数: 0, 售价: 10 元)
    NI-RIO 3.1.1 Readme
    April 2009
    ni.com/support
    This file contains important information about NI-RIO 3.1.1, including information on installing NI-RIO 3.1.1, descriptions of known issues for installing and using NI-RIO 3.1.1, and information about the hardware and software supported by NI-RIO 3.1.1.
    • Installing NI-RIO 3.1.1
    • Bug Fixes in NI-RIO 3.1.1
    • Known Issues for Using NI-RIO 3.1.1
    • Changes in NI-RIO 3.1.1 with LabVIEW 8.6.x
    • No Support for LabVIEW 8.0.x
    • Supported Platforms
    • Supported Hardware and Software
    Complete the following steps to install NI-RIO 3.1.1 for use with LabVIEW FPGA 8.6.1.
    • Install LabVIEW 8.6.1.
    • Install LabVIEW Real-Time 8.6.1.
    • Install LabVIEW FPGA 8.6.1.
    • Install NI-RIO 3.1.1 using the two installation CDs or the NI Driver DVD.
    Back to Top
    Refer to the KnowledgeBase at ni.com for a list of bug fixes in this release.
    Back to Top
    Known Issues for using NI-RIO 3.1.1
    Refer to the KnowledgeBase at ni.com for a current list of all known issues in this release.
    Back to Top
    The following things have changed in NI-RIO 3.1.1 with LabVIEW 8.6.x.
    • CompactRIO chassis item in Project Explorer tree layout—The CompactRIO chassis item is new in NI-RIO 3.x with LabVIEW 8.6.x. Each CompactRIO controller can be associated with one chassis. In the Project Explorer tree layout, the chassis item can contain I/O modules and/or one FPGA target.
    • Each CompactRIO chassis item can contain only one FPGA target item—In previous versions of NI-RIO, projects could contain multiple FPGA targets under one CompactRIO controller item. In NI-RIO 3.x with LabVIEW 8.6.x, each CompactRIO chassis item can contain only one FPGA target item. If you open a project with multiple FPGA target items under a single controller, LabVIEW creates multiple controller items, each with a single chassis item containing one of the FPGA target items from the original project.
    • Maximum update rates for NI 9264 in cRIO-9151 have changed—The following table shows the maximum update rates, by number of channels in use, for the NI 9264 in a cRIO-9151 R Series expansion chassis.
      Number
      of Channels
      Maximum
      Update Rate
      13.7 μs
      26.6 μs
      39.4 μs
      1647 μs
      Refer to the latest version of the NI 9264 Operating Instructions and Specifications on ni.com for more information.
    • Maximum update rate for NI 9403 in cRIO-9151 has changed—The maximum update rate for the NI 9403 in a cRIO-9151 R Series expansion chassis is 8 μs. Refer to the latest version of the NI 9403 Operating Instructions and Specifications on ni.com for more information.
    Back to Top
    NI-RIO 3.1.1 does not support LabVIEW 8.0.x. If you are using LabVIEW 8.0.x, install NI-RIO 2.x.
    Back to Top
    Supported Platforms
    NI-RIO 3.1.1 supports the following platforms:
    • Windows Vista Business (32-bit and 64-bit versions)
    • Windows XP Professional
    • Windows 2000 Professional (Service Pack 3 or higher)
    Back to Top
    Refer to the NI Developer Zone at ni.com for a complete list of the hardware that is supported by this and previous versions of NI-RIO as well as what versions of LabVIEW software are supported by each version of NI-RIO.
    For additional FlexRIO product support and information, please refer to ni.com/flexrio.
    Back to Top
    © 2006–2009 National Instruments Corporation. All rights reserved.
    Back to Top
    GMT+8, 2025-7-2 11:25
