查看: 3059|回复: 0
[NI驱动程序] NI CompactRIO 16.0 Win32 Eng/Jpn/Chn设备驱动程序完整版下载NICRIO2016Aug
  • 签到天数: 3542 天
    连续签到: 12 天
    发表于 2020-10-28 22:50:56 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    NI CompactRIO 16.0 Win32Eng/Jpn/Chn设备驱动程序完整版下载NICRIO2016Aug
    NI CompactRIO
    16.0
    文件大小: 3254544595 字节 (3.03 GB)
    修改日期: 2016-06-22 00:31
    MD5: e1fbd42729e0dc8a93237f3755c9a45e(官方正确)
    SHA1: 174d0e79e4fe61d85e830626d66d95c36429417a
    SHA256: 976ca133f3d5d384c870fd730bfcfd9751640dad2d94af962bafddf53ef11fd8
    CRC32: 52fa6106
    NICRIOWin16.0.txt (287 Bytes, 下载次数: 1, 售价: 10 元)
    NI CompactRIO Device Drivers August 2016 Readme
    August 2016
    This document contains the following important information about NI CompactRIO Device Drivers August 2016:
    • Installing NI CompactRIO Device Drivers August 2016
    • What's New in NI CompactRIO Device Drivers August 2016
    • Preserving Device Aliases when Upgrading Software
    • Bug Fixes
    • Known Issues
    • Accessing the Help
    • Supported Platforms
    • NI CompactRIO Device Drivers August 2016 Drops Support for Microsoft Windows 7 RTM, Windows Vista, Windows XP, and Windows Server 2003
    • Supported Hardware and Software
    • Product Security and Critical Updates
    • Using NI Software with Microsoft Windows 10
    • Using NI Software with Microsoft Windows 8.1
    • Legal Information
    Note  This installation requires at least 2 GB of RAM in addition to the requirements for LabVIEW, the LabVIEW Real-Time Module, and the LabVIEW FPGA Module.
    Complete the following steps to install NI CompactRIO Device Drivers August 2016 for use with LabVIEW.
    • Install one of the following supported versions of LabVIEW:
      • LabVIEW 2016
      • LabVIEW 2015 SP1
      • LabVIEW 2014 SP1
      • LabVIEW 2013 SP1
    • Install the LabVIEW Real-Time Module.
    • Install the LabVIEW FPGA Module.
    • Install NI CompactRIO Device Drivers August 2016.
    ↑ Back to Top
    • Software support for the following new CompactRIO controllers:
      • cRIO-9035 (Sync)
      • cRIO-9039 (Sync)
    • Scan Interface mode support for the following existing C Series modules:
      • NI 9344
      • NI 9436
    • Support for the NI ELVIS RIO Control Module (NI ELVIS RIO CM)
    ↑ Back to Top
    Ensure that you back up any aliases for local RIO devices before you upgrade the software on your system, or ensure that the devices remain connected to the system during the upgrade. Any local aliases that are not associated with a connected device might be removed during the upgrade.
    ↑ Back to Top
    Refer to the List of Known Issues and Bug Fixes for NI-RIO Device Drivers on ni.com for a list of bug fixes in this release.
    ↑ Back to Top
    Refer to the List of Known Issues and Bug Fixes for NI-RIO Device Drivers on ni.com for a current list of all known issues in this release.
    ↑ Back to Top
    In the LabVIEW Help, click the Contents tab and select NI CompactRIO Device Drivers to access the software help for your NI CompactRIO device.
    ↑ Back to Top
    Supported Platforms
    Use the following Microsoft Windows operating systems and service packs with NI CompactRIO Device Drivers August 2016.
    Operating System64-bit32-bitComments
    Windows 10
    Refer to the Using NI Software with Microsoft Windows 10 section of this document for more information about using NI CompactRIO Device Drivers on Windows 10.
    Windows 8.11
    Refer to the Using NI Software with Microsoft Windows 8.1 section of this document for more information about using NI CompactRIO Device Drivers on Windows 8.1.
    Windows 7 Professional SP12
    Windows Server 2012 R21
    Windows Server 2008 R2 SP12
    Notes:
    1 NI software installs VC2015 Runtime and .NET Framework 4.6.1. Windows 8.1 and Windows Server 2012 R2 require Microsoft updates to support these items. Refer to Microsoft KB2919442 and KB2919355 for more information about how to install these updates.
    ↑ Back to Top
    NI CompactRIO Device Drivers August 2016 drops support for Microsoft Windows 7 RTM (with no service pack), Windows Vista, Windows XP, and Windows Server 2003. NI CompactRIO Device Drivers August 2016 and later will not install or run on an unsupported OS. You cannot deploy or distribute applications that use NI CompactRIO Device Drivers August 2016 to an unsupported OS. Additionally, after installing NI CompactRIO Device Drivers August 2016, you cannot use any installers built on this computer with any version of LabVIEW, LabWindows™/CVI™, NI TestStand™, or Measurement Studio on an unsupported OS.
    ↑ Back to Top
    Refer to the Software Support for CompactRIO, CompactDAQ, Single-Board RIO, R Series, FlexRIO, and EtherCAT support document on ni.com for a complete list of the hardware and LabVIEW software versions supported by each version of NI CompactRIO.
    Visit to ni.com/compactrio for additional NI CompactRIO product support and information.
    ↑ Back to Top
    ↑ Back to Top
    ↑ Back to Top
    ↑ Back to Top
    When you install NI software on Microsoft Windows 8.1, you will notice a few additional tiles in the Apps view, including shortcuts to NI application software products such as NI LabVIEW, Measurement & Automation Explorer (NI MAX), and NI Launcher.
    Using NI Launcher
    Note  NI MAX does not appear as a desktop shortcut when installed on Microsoft Windows 8.1. You can launch NI MAX either from the Apps view or from within NI Launcher.
    Finding All Programs
    ↑ Back to Top
    © 2004–2016 National Instruments. All rights reserved.
    375022D-01
    GMT+8, 2025-5-17 15:01
