查看: 3181|回复: 0
[NI驱动程序] NI CompactRIO 18.1 Win32 Eng/Jpn/Chn设备驱动程序完整版下载NICRIO2018June
    3 小时前
  • 签到天数: 3582 天
    连续签到: 2 天
    发表于 2020-10-28 23:04:38 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    NI CompactRIO 18.1 Win32Eng/Jpn/Chn设备驱动程序完整版下载NICRIO2018June
    NI CompactRIO
    18.1
    文件大小: 5078771017 字节 (4.73 GB)
    修改日期: 2018-06-26 04:47
    MD5: c9bfd8138e83347a30fb804e80b10cef(官方正确)
    SHA1: a34ba782b967b92456dd388d8c3d5adc7d7cf17d
    SHA256: 9753f3d6d35bd4ef7d26fefeb1ece35b5eda95f3dd45ccb24c4117651e9b9665
    CRC32: 470b5352
    NICRIOWin18.1.txt (287 Bytes, 下载次数: 4, 售价: 10 元)
    NI CompactRIO Device Drivers Readme
    June 2018
    This document contains the following important information about NI CompactRIO Device Drivers June 2018:
    Installing NI CompactRIO Device Drivers June 2018
    What's New in NI CompactRIO Device Drivers June 2018
    Preserving Device Aliases when Upgrading Software
    Note  This installation requires at least 2 GB of RAM in addition to the requirements for LabVIEW, the LabVIEW Real-Time Module, and the LabVIEW FPGA Module.
    Complete the following steps to install NI CompactRIO Device Drivers June 2018 for use with LabVIEW. Refer to the Supported Hardware and Software section to confirm which software versions support your specific hardware devices.
    • Install one of the following supported versions of LabVIEW:
      • LabVIEW 2018
      • LabVIEW 2017 SP1
      • LabVIEW 2016
      • LabVIEW 2015 SP1
    • Install the LabVIEW Real-Time Module.
    • Install the LabVIEW FPGA Module.
    • Install NI CompactRIO Device Drivers June 2018.
    NI CompactRIO Device Drivers supports the following operating systems:
    • Windows 10/8.11/7 SP12
    • Windows Server 2012 R21
    • Windows Server 2008 R2 SP12
    Note  In 2016 NI CompactRIO Device Drivers dropped support for Windows Vista, Windows XP, Windows Server 2003, and installations of Windows 7 without any service packs. NI CompactRIO Device Drivers June 2018 will not install or run on an unsupported OS. You cannot deploy or distribute applications that use NI CompactRIO Device Drivers June 2018 to an unsupported OS. Additionally, after installing NI CompactRIO Device Drivers June 2018, you cannot use any installers built on this computer with any version of LabVIEW, LabWindows™/CVI™, NI TestStand™, or Measurement Studio on an unsupported OS.
    Software support in LabVIEW 2018 for the following new hardware:
    • cRIO-9053
    • cRIO-9054
    • cRIO-9056
    • cRIO-9057
    Refer to the Software Support for CompactRIO, CompactDAQ, Single-Board RIO, R Series, FlexRIO, and EtherCAT support document on ni.com for a complete list of the hardware and LabVIEW software versions supported by each version of NI CompactRIO.
    Visit to ni.com/compactrio for additional NI CompactRIO product support and information.
    Ensure that you back up any aliases for local RIO devices before you upgrade the software on your system, or ensure that the devices remain connected to the system during the upgrade. Any local aliases that are not associated with a connected device might be removed during the upgrade.
    Refer to the List of Known Issues and Bug Fixes for NI-RIO Device Drivers on ni.com for a list of bug fixes in this release.
    Refer to the List of Known Issues and Bug Fixes for NI-RIO Device Drivers on ni.com for a current list of all known issues in this release.
    In the LabVIEW Help, click the Contents tab and select NI CompactRIO Device Drivers to access the software help for your NI CompactRIO device.
    © 2004–2018 National Instruments. All rights reserved.
    375022H-01
    GMT+8, 2025-7-2 12:18
