查看: 2816|回复: 0
[Patch补丁] NI CompactRIO Module Support 13.1.1 Patch Win32Eng/Jpn/Chs NI-CompactRIO模块支持13.1.1补丁
    发表于 2020-10-29 23:04:47 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    NI CompactRIO模块支持
    NI CompactRIO Module Support支持CompactRIO控制器、CompactRIO机箱和CompactRIO单板控制器。
    NI CompactRIO Module Support是一个驱动软件,用于支持CompactRIO系统的识别、编程和部署。除LabVIEW之外,您还必须安装NI CompactRIO Module Support以及LabVIEW Real-Time模块和/或LabVIEW FPGA模块,才能开始对硬件进行编程。
    13.1.1安装补丁之前请先安装NI-RIO 13.1.0。
    文件大小: 266554938 字节 (254.21 MB)
    修改日期: 2014-03-21 00:36
    MD5: db534a2aa49bfd215e4e63e5600c114b(官方正确)
    SHA1: bc8f41081a702901015ce6cfa690f211a89f70b6
    SHA256: 6ecbb611508c34437dc539e6755672c3ee935bce438c5c076788f33b81294919
    CRC32: cf2cc2d9
    NICRIOMS13.1.1.txt (362 Bytes, 下载次数: 0, 售价: 1 圆)
    NI CompactRIO Module Support 13.1.1 Readme
    February 2014
    ni.com/support
    This file contains important information about NI CompactRIO Module Support 13.1.1, including information on installing NI CompactRIO Module Support 13.1.1, descriptions of known issues for installing and using NI CompactRIO Module Support 13.1.1, and information about the hardware and software supported by NI CompactRIO Module Support 13.1.1.
    • Installing NI CompactRIO Module Support 13.1.1
    • What Is New in NI CompactRIO Module Support 13.1.1
    • Supported Platforms
    • Supported Hardware and Software
    • How to Use NI Software with Microsoft Windows 8.x
    • NI CompactRIO Module Support Drops Support for Microsoft Windows Vista, Windows XP, and Windows Server 2003 in 2016
    Complete the following steps to install NI CompactRIO Module Support 13.1.1 for use with LabVIEW.
    • Install one of the following supported versions of LabVIEW:
      • LabVIEW 2013
      • LabVIEW 2012 SP1
      • LabVIEW 2011 SP1
    • Install LabVIEW Real-Time.
    • Install LabVIEW FPGA.
    • Install NI CompactRIO 13.1.
    • Install NI CompactRIO Module Support 13.1.1.
    Other Installation Notes
    • This installation requires that version 3.1 of the MSI Engine is installed on your computer. If you do not have MSI 3.1 or later, the installer updates the engine automatically and may require you to restart your computer.
    • If you are installing NI driver software on Windows Vista, you must first uninstall all National Instruments software versions older than the February 2007 release before you proceed with this installation. For additional information and tools to assist you in upgrading NI driver software on Windows Vista, refer to the How Do I Remove Unsupported NI Software from Windows Vista to Install Officially Supported Versions? National Instruments KnowledgeBase article.
    • If you want to install from a network location, copy the entire contents of the installation disk to a single folder and run from that location.
    Uninstalling NI CompactRIO Module Support
    You can uninstall NI software and drivers by selecting National Instruments Software in the Windows Add/Remove Programs application.
    Back to Top
    • Support for NI 9242 in LabVIEW 2013
    • Support for NI 9244 in LabVIEW 2013
    • Support for NI 9437 in LabVIEW 2013
    Back to Top
    Supported Platforms
    NI CompactRIO Module Support 13.1.1 supports the following platforms:
    Operating System64-bit32-bitComments
    Windows 8.x
    Refer to the How to Use NI Software with Microsoft Windows 8.x section of this document for more information about NI CompactRIO on Windows 8.x.
    Windows 7 Professional
    Windows Vista Business
    Refer to the NI CompactRIO Drops Support for Microsoft Windows Vista, Windows XP, and Windows Server 2003 in 2016 section of this document for more information about NI CompactRIO support for those versions.
    Windows XP Professional SP2
    Windows Server 2012 R2
    Windows Server 2008 R2
    Windows Server 2003 R2
    Support for Windows Server 2003 R2 may require disabling physical address extensions (PAE). To learn how this might affect your use of Windows Server 2003 and what actions you might have to take, visit ni.com/info and enter the info code PAESupport.
    Back to Top
    NI CompactRIO Module Support 13.1.1 provides support for C Series modules in all CompactRIO, Single-Board RIO, and R Series systems. Refer to the NI Developer Zone at ni.com for a complete list of the hardware that is supported by this and previous versions of NI CompactRIO as well as what versions of LabVIEW software are supported by each version of NI CompactRIO.
    For additional CompactRIO product support and information, refer to ni.com/compactrio.
    Back to Top
    Back to Top
    Using NI Launcher
    Finding All Programs
    Back to Top
    NI CompactRIO Module Support will drop support for Microsoft Windows Vista, Windows XP, and Windows Server 2003 as of July 1, 2016. Versions of NI CompactRIO Module Support that ship after July 1, 2016 will not install or run on Windows Vista, Windows XP, or Windows Server 2003. For detailed information about NI application software product life cycles, visit ni.com/info and enter one of the following Info Codes:
    NI LabVIEWlifecycle
    NI TestStandtslcp
    NI DIAdemddlcp
    NI SignalExpressselcp
    NI VeriStandnivslifecycle
    Back to Top
    © 2004–2014 National Instruments. All rights reserved.
    GMT+8, 2025-12-8 07:37
