查看: 2846|回复: 0
[Patch补丁] NI CompactRIO Module Support 14.1.0 Patch Win32Eng/Jpn/Chs NI-CompactRIO模块支持14.1.0补丁
    发表于 2020-10-29 23:07:40 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    NI CompactRIO模块支持
    NI CompactRIO Module Support支持CompactRIO控制器、CompactRIO机箱和CompactRIO单板控制器。
    NI CompactRIO Module Support是一个驱动软件,用于支持CompactRIO系统的识别、编程和部署。除LabVIEW之外,您还必须安装NI CompactRIO Module Support以及LabVIEW Real-Time模块和/或LabVIEW FPGA模块,才能开始对硬件进行编程。
    14.1.0安装补丁之前请先安装NI-RIO 2014。
    (MD5)
    25fdd2b32dc022f46016cf327a502acb(官方校验和)
    文件大小: 292771666 字节 (279.21 MB)
    修改日期: 2014-12-23 05:45
    MD5: 6543b9190fc93ca6c0e6486d5b7da7b3(多种方式重复下载校验和且可百度秒传说明其他人传的也是这个校验和)
    SHA1: 4378da527e290e020860b624f729fd609f863082
    SHA256: 55dcbc65fe2bfc1483b6df816f2d795a44d5ffc9a224f6ec78f1da2593dc53aa
    CRC32: e5fec08d
    NICRIOMS14.1.0.txt (364 Bytes, 下载次数: 0, 售价: 1 圆)
    NI CompactRIO Module Support 14.1 Readme
    December 2014
    ni.com/support
    This document contains important information about installing NI CompactRIO Module Support 14.1, descriptions of known issues for installing and using NI CompactRIO Module Support 14.1, and information about the hardware and software that NI CompactRIO Module Support 14.1 supports.
    • Installing NI CompactRIO Module Support 14.1
    • What's New in NI CompactRIO Module Support 14.1
    • Bug Fixes
    • Known Issues
    • Supported Platforms
    • Supported Hardware and Software
    • Product Security and Critical Updates
    • How to Use NI Software with Microsoft Windows 8.x
    • NI CompactRIO Module Support Drops Support for Microsoft Windows Vista, Windows XP, and Windows Server 2003 in 2016
    Complete the following steps to install NI CompactRIO Module Support 14.1 for use with LabVIEW.
    • Install one of the following supported versions of LabVIEW:
      • LabVIEW 2014
      • LabVIEW 2013 SP1
      • LabVIEW 2012 SP1
      • LabVIEW 2011 SP1
    • Install LabVIEW Real-Time.
    • Install LabVIEW FPGA.
    • Install NI CompactRIO 14.0.
    • Install NI CompactRIO Module Support 14.1.
    Other Installation Notes
    • This installation requires that MSI Engine version 3.1 is installed on your computer. If you do not have MSI Engine version 3.1 or later, the installer updates the engine automatically and may require you to restart your computer.
    • If you are installing NI driver software on Microsoft Windows Vista, you must first uninstall all National Instruments software versions older than the February 2007 release before you proceed with this installation. Refer to the How Do I Remove Unsupported NI Software from Windows Vista to Install Officially Supported Versions? support document on ni.com for additional information and tools to assist you in upgrading NI driver software on Windows Vista.
    • If you want to install from a network location, copy the entire contents of the installation disk to a single folder and run from that location.
    ↑ Back to Top
    This release provides support for the following C Series modules:
    • NI 9260
    • NI 9344
    ↑ Back to Top
    Refer to the List of Known Issues and Bug Fixes for NI-RIO Device Drivers on ni.com for a list of bug fixes in this release.
    ↑ Back to Top
    Refer to the List of Known Issues and Bug Fixes for NI-RIO Device Drivers on ni.com for a current list of all known issues in this release.
    ↑ Back to Top
    Supported Platforms
    NI CompactRIO Module Support 14.1 supports the following platforms:
    Operating System64-bit32-bitComments
    Windows 8.x
    Refer to the How to Use NI Software with Microsoft Windows 8.x section of this document for more information about NI CompactRIO Module Support on Windows 8.x.
    Windows 7 Professional
    Windows Vista Business
    Refer to the NI CompactRIO MOdule Support Drops Support for Microsoft Windows Vista, Windows XP, and Windows Server 2003 in 2016 section of this document for more information about NI CompactRIO Module Support support for those versions.
    Windows XP Professional SP2
    Windows Server 2012 R2
    Windows Server 2008 R2
    Windows Server 2003 R2
    Support for Windows Server 2003 R2 may require disabling physical address extensions (PAE). To learn how this might affect your use of Windows Server 2003 and what actions you might have to take, visit ni.com/info and enter the info code PAESupport.
    ↑ Back to Top
    Refer to the Software Support for CompactRIO, CompactDAQ, Single-Board RIO, R Series, FlexRIO, and EtherCAT support document on ni.com for a complete list of the hardware and LabVIEW software versions supported by each version of NI CompactRIO Module Support.
    Visit to ni.com/compactrio for additional CompactRIO product support and information.
    ↑ Back to Top
    ↑ Back to Top
    ↑ Back to Top
    Using NI Launcher
    Finding All Programs
    ↑ Back to Top
    NI CompactRIO Module Support will drop support for Microsoft Windows Vista, Windows XP, and Windows Server 2003 as of July 1, 2016. Versions of NI CompactRIO Module Support that ship after July 1, 2016 will not install or run on Windows Vista, Windows XP, or Windows Server 2003. For detailed information about NI application software product life cycles, visit ni.com/info and enter one of the following Info Codes:
    NI LabVIEWlifecycle
    NI TestStandtslcp
    NI DIAdemddlcp
    NI SignalExpressselcp
    NI VeriStandnivslifecycle
    ↑ Back to Top
    © 2004–2014 National Instruments. All rights reserved.
    GMT+8, 2025-12-8 07:37
