查看: 3414|回复: 0
[Patch补丁] NI CompactRIO Module Support 17.1.0 Patch Win32Eng/Jpn/Chs NI-CompactRIO模块支持17.1.0补丁
    发表于 2020-10-29 23:21:21 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    NI CompactRIO模块支持
    NI CompactRIO Module Support支持CompactRIO控制器、CompactRIO机箱和CompactRIO单板控制器。
    NI CompactRIO Module Support是一个驱动软件,用于支持CompactRIO系统的识别、编程和部署。除LabVIEW之外,您还必须安装NI CompactRIO Module Support以及LabVIEW Real-Time模块和/或LabVIEW FPGA模块,才能开始对硬件进行编程。
    17.1.0安装补丁之前请先安装NI CompactRIO 17.0。
    文件大小: 95330312 字节 (90.91 MB)
    修改日期: 2017-09-30 01:30
    MD5: 75c15d623c53e682f107c4aeb04ac73d(官方正确)
    SHA1: 6b623de49af69bf64e575c1de8220a1eec99db2a
    SHA256: 74ccdc34bfe34928ad2bcf60a3b423c1715dd013f1639caaddec25ef03464e07
    CRC32: 678cdc71
    NICRIOMS17.1.0.txt (335 Bytes, 下载次数: 0, 售价: 1 圆)
    NI CompactRIO Module Support 17.1 Readme
    August 2017
    This document contains important information about installing NI CompactRIO Module Support 17.1, descriptions of known issues for installing and using NI CompactRIO Module Support 17.1, and information about the hardware and software that NI CompactRIO Module Support 17.1 supports.
    • Installing NI CompactRIO Module Support 17.1
    • What's New in NI CompactRIO Module Support 17.1
    • Preserving Device Aliases when Upgrading Software
    • Bug Fixes
    • Known Issues
    • Accessing the Help
    • Supported Platforms
    • Supported Hardware and Software
    • Product Security and Critical Updates
    • Using NI Software with Microsoft Windows 10
    • Using NI Software with Microsoft Windows 8.1
    • Legal Information
    Complete the following steps to install NI CompactRIO Module Support 17.1 for use with LabVIEW.
    • Install LabVIEW 2017.
    • Install the LabVIEW Real-Time Module.
    • Install the LabVIEW FPGA Module.
    • Install NI CompactRIO Device Drivers May 2017.
    • Install NI CompactRIO Module Support 17.1.
    Other Installation Notes
    • This installation requires that MSI Engine version 3.1 is installed on your computer. If you do not have MSI Engine version 3.1 or later, the installer updates the engine automatically and may require you to restart your computer.
    • If you are installing NI driver software on Microsoft Windows Vista, you must first uninstall all National Instruments software versions older than the February 2007 release before you proceed with this installation. Refer to the How Do I Remove Unsupported NI Software from Windows Vista to Install Officially Supported Versions? support document on ni.com for additional information and tools to assist you in upgrading NI driver software on Windows Vista.
    • If you want to install from a network location, copy the entire contents of the installation disk to a single folder and run from that location.
    ↑ Back to Top
    This release adds support for the following new hardware and functionality in LabVIEW 2017:
    • NI 9202 C Series module
    • NI 9262 C Series module
    • sbRIO-9698
    ↑ Back to Top
    Ensure that you back up any aliases for local RIO devices before you upgrade the software on your system, or ensure that the devices remain connected to the system during the upgrade. Any local aliases that are not associated with a connected device might be removed during the upgrade.
    ↑ Back to Top
    Refer to the List of Known Issues and Bug Fixes for NI-RIO Device Drivers on ni.com for a list of bug fixes in this release.
    ↑ Back to Top
    Refer to the List of Known Issues and Bug Fixes for NI-RIO Device Drivers on ni.com for a current list of all known issues in this release.
    ↑ Back to Top
    In the LabVIEW Help, click the Contents tab and select NI CompactRIO Device Drivers to access the software help for your C Series device.
    ↑ Back to Top
    Supported Platforms
    NI CompactRIO Module Support 17.1 supports the following platforms:
    Operating System64-bit32-bitComments
    Windows 10
    Refer to the Using NI Software with Microsoft Windows 10 section of this document for more information about using NI CompactRIO Module Support on Windows 10.
    Windows 8.1 Update 11
    Refer to the Using NI Software with Microsoft Windows 8.1 section of this document for more information about using NI CompactRIO Module Support on Windows 8.1.
    Windows 7 Professional SP12
    Windows Server 2012 R2 Update1
    Windows Server 2008 R2 SP12
    Notes:
    1 NI software installs VC2015 Runtime and .NET Framework 4.6.1. Windows 8.1 Update 1 and Windows Server 2012 R2 Update require Microsoft updates to support these items. Refer to Microsoft KB2919442 and KB2919355 for more information about how to install these updates.
    ↑ Back to Top
    Refer to the Software Support for CompactRIO, CompactDAQ, Single-Board RIO, R Series, FlexRIO, and EtherCAT support document on ni.com for a complete list of the hardware and LabVIEW software versions supported by each version of NI CompactRIO Module Support.
    Visit to ni.com/compactrio for additional CompactRIO product support and information.
    ↑ Back to Top
    ↑ Back to Top
    ↑ Back to Top
    ↑ Back to Top
    ↑ Back to Top
    © 2004–2017 National Instruments. All rights reserved.
    375025H-01
    GMT+8, 2025-12-8 07:35
