查看: 3506|回复: 0
[LV工具模块] LabVIEW Touch Panel Module 2009 Win32Eng LabVIEW触摸屏模块2009版下载
    昨天 10:50
  • 签到天数: 3604 天
    连续签到: 12 天
    发表于 2020-10-30 23:35:47 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    LabVIEW触摸屏模块
    LabVIEW触摸屏模块用于开发触摸屏计算机所需的应用程序。
    LabVIEW触摸屏模块是一款软件附加工具,可用于创建和部署人机界面(HMI)应用程序,以便与CompactRIO系统等嵌入式实时平台进行通信。此工具包含多种用户界面开发工具,并具有通信、数据分析和数据存储功能。借助该附加工具,即可通过共享变量、TCP/IP或其他协议与控制器进行通信。您还可以借助内置LabVIEW演示工具,向操作人员显示重要信息。LabVIEW触摸屏模块经过优化,可将HMI部署于运行Windows Embedded Standard系统的NI或第三方工业触摸屏计算机。
    2009
    文件大小: 221280800 字节 (211.03 MB)
    修改日期: 2012-08-03 22:09
    MD5: c0c42e5861eda2728148320df3f54668(重复下载一致)
    SHA1: e62511b07e0994f795acd1dccc1809f5a4667925
    SHA256: 256b60396e7bb00e887fe5d445da0115271c38948a2671d345ba295b2e8d1c0a
    CRC32: f3f1fbc8
    TPM2009.txt (260 Bytes, 下载次数: 0, 售价: 10 元)
    LabVIEW 2009 Touch Panel Module Readme
    June 2009
    This file contains important last-minute information about the LabVIEW 2009 Touch Panel Module, including installation issues.
    Installation
    Resources
    Installation
    You can install all of your LabVIEW products—including the Touch Panel Module—using the LabVIEW 2009 Platform DVDs. You can find installation instructions for the VI Analyzer Toolkit along with activation instructions in the following locations:
    • LabVIEW 2009 Platform DVDs Readme, which is available on the top-level of LabVIEW Platform DVD 1.
    To request additional LabVIEW 2009 Platform DVDs, refer to the National Instruments Web site.
    You can access the software and documentation known issues list online. Refer to the National Instruments Web site for an up-to-date list of known issues in the LabVIEW 2009 Touch Panel Module.
    IDLegacy IDFixed Issue
    166732-Including an implicit value property node can cause a Touch Panel application to exit.
    157776-Error building Touch Panel application that includes an empty tab control.
    122441-You cannot build a VI that includes the Beep VI, a shared variable, and a case structure into a Touch Panel application.
    117037-Passing a control reference through a zero-iteration For Loop can cause a crash.
    117411-Users can select items in a tree indicator.
    117311-If a dial is on a tab control but not on the initially displayed tab, the dial has the background rectangle color of the front panel instead of that of the tab control when the dial is shown.
    3590644698H30If you copy and paste global variables, you receive a link error when you try to build the Touch Panel VI into an application.
    Resources
    LabVIEW includes extensive online and PDF documentation for new and experienced LabVIEW users. Refer to the Related Documentation section in the Getting Started with the Touch Panel Module manual for more information about LabVIEW documentation. Visit the National Instruments Web site at ni.com for software drivers and updates, a searchable KnowledgeBase, product manuals, step-by-step troubleshooting wizards, thousands of example programs, tutorials, application notes, instrument drivers, and so on. The following KnowledgeBase articles contain more information about the NI TPC targets:
    • KnowledgeBase 45BE6367: Where Can I Find the Microsoft Tools I Need for the LabVIEW Touch Panel Module?
    • KnowledgeBase 45ABJV2M: What Target Do I Select for TPC-2006, TPC-2012, and 3rd Party TPCs
    • KnowledgeBase 40EAE6X1: Improved Display Driver for TPC-2006 Industrial Touch Panel Computer
    • KnowledgeBase 402A280F: Changing the Splash Screen Logo on NI TPC-2006
    • KnowledgeBase 4361GBMK: Shared Variable and/or PNG Support Is Not Active After Rebooting the TPC-2006
    © 2006-2009 National Instruments Corporation. All rights reserved.
    GMT+8, 2025-7-26 05:33
