查看: 2535|回复: 0
[LV工具模块] LabVIEW Touch Panel Module 2012SP1 Win32Eng LabVIEW触摸屏模块2012SP1版下载
    昨天 10:50
  • 签到天数: 3604 天
    连续签到: 12 天
    发表于 2020-10-30 23:46:17 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    LabVIEW触摸屏模块
    LabVIEW触摸屏模块用于开发触摸屏计算机所需的应用程序。
    LabVIEW触摸屏模块是一款软件附加工具,可用于创建和部署人机界面(HMI)应用程序,以便与CompactRIO系统等嵌入式实时平台进行通信。此工具包含多种用户界面开发工具,并具有通信、数据分析和数据存储功能。借助该附加工具,即可通过共享变量、TCP/IP或其他协议与控制器进行通信。您还可以借助内置LabVIEW演示工具,向操作人员显示重要信息。LabVIEW触摸屏模块经过优化,可将HMI部署于运行Windows Embedded Standard系统的NI或第三方工业触摸屏计算机。
    文件大小: 270990400 字节 (258.44 MB)
    修改日期: 2013-09-10 00:21
    MD5: 8b6bc46b359675ee4d55b2a7c363b7a9
    SHA1: 14d6deed90fff5f52e383d53174231ecbd4743d6
    SHA256: 05a45a7827c0e409b3be61433f86a55d16079e886e79222cc93f01d24298e0e8
    CRC32: c271bd9b
    TPM2012SP1.txt (262 Bytes, 下载次数: 0, 售价: 10 元)
    LabVIEW 2012 SP1 Touch Panel Module Readme
    Version 12.0.1
    December 2012
    This file contains important information about the LabVIEW Touch Panel Module, including installation instructions, a partial list of bugs fixed for Touch Panel Module 2012 SP1, and known issues.
    The LabVIEW Touch Panel Module extends the LabVIEW graphical development environment to Touch Panel devices so you can create human-machine interface (HMI) applications for Touch Panel devices running Windows CE or Windows Embedded Standard. You can create custom touch panel displays to communicate with National Instruments embedded real-time platforms, such as Compact FieldPoint, CompactRIO, and Compact Vision System.
    Note  National Instruments has recently announced discontinued production and support of Windows CE in the Touch Panel Module. The last version of the Touch Panel Module that will include support for Touch Panel devices running Windows CE is the Touch Panel Module 2012 SP1. For existing users of the Touch Panel Module for Windows CE, National Instruments will continue to offer extended support according to the guidelines found in the NI LabVIEW Life Cycle Policy at ni.com/labview/product-lifecycle.
    In addition to the system requirements for the LabVIEW Development System, the Touch Panel Module has the following requirements:
    • LabVIEW 2012 SP1 Base, Full, or Professional Development System (32-bit)
    • At least 250 MB of disk space
    • (Windows CE) A Touch Panel device, such as the NI TPC-2006, running Windows CE 4.2 or 5.0
    • (Windows Embedded Standard) A Touch Panel device, such as the NI TPC-2512, running Windows Embedded Standard
    Refer to the LabVIEW Readme for additional system requirements and supported operating systems for LabVIEW 2012 SP1.
    You can install all of your LabVIEW products—including the Touch Panel Module—using the LabVIEW 2012 SP1 Platform DVDs. Refer to the LabVIEW Installation Guide on the LabVIEW Platform DVD 1 for installation instructions and system requirements.
    To request additional LabVIEW Platform DVDs, refer to the National Instruments website.
    Additional Installation Information
    This section contains information that you might find helpful as you install the Touch Panel Module.
    • The Touch Panel Module runs in evaluation mode if you do not activate it. In evaluation mode, you can create VIs, but any Touch Panel applications you build run only for five minutes. You have the option of activating the Touch Panel Module during the installation process. You also can use the NI License Manager, available by selecting Start»All Programs»National Instruments»NI License Manager, to activate National Instruments products. Refer to the National Instruments License Manager Help, available by selecting Help»Contents in the NI License Manager, for more information about activating NI products.
    • The Touch Panel Module includes Microsoft tools, such as Microsoft ActiveSync on Windows XP. Some of these Microsoft tools might interfere with any existing installations of Visual Studio, Windows Embedded, or Windows CE toolkits.
    • (Windows XP) The Touch Panel Module installs ActiveSync 4.2 if you do not already have ActiveSync 4.2 or later installed. The Touch Panel Module works with ActiveSync 4.2 or later.
    • (Windows 7/Vista) You must install Windows Mobile Device Center to use the Touch Panel Module. Refer to the Microsoft website at www.microsoft.com to download Windows Mobile Device Center.
    • You might need to install the additional tools, such as NI-DAQmxBase, NI TPC Service support, Shared Variable support, or NI-VISA, to use the Touch Panel Module. Refer to the Installing Additional Tools section of the Getting Started with the LabVIEW Touch Panel Module manual for more information about additional tools.
    Uninstalling the Touch Panel Module (Windows CE)
    If you uninstall the Touch Panel Module, you also must uninstall the following:
    • (Windows XP) Microsoft ActiveSync
    • (Windows 7/Vista) Windows Mobile Device Center
    • Microsoft Device Emulator version 1.0 – ENU
    • Microsoft Visual C++ 2005 Redistributable
    You can access the software and documentation known issues list online. Refer to the National Instruments website for an up-to-date list of known issues in the Touch Panel Module.
    The following items are the IDs and titles of a subset of issues fixed in the Touch Panel Module. This is not an exhaustive list of issues fixed in the current version of the Touch Panel Module. If you have a CAR ID, you can search this list to validate the issue has been fixed.
    346902TCP Wait on Listener never times out on LabVIEW Touch Panel Module for Windows CE.
    Refer to the LabVIEW Help, accessible by selecting Help»LabVIEW Help from LabVIEW, for information about the Touch Panel Module.
    Select Help»Find Examples from LabVIEW to launch the NI Example Finder. LabVIEW examples for the Touch Panel Module are located in the labview\examples\TouchPanel directory. You can modify an example VI to fit an application, or you can copy and paste from one or more examples into a VI that you create.
    Using NI Launcher
    Note  Unlike previous versions of Microsoft Windows, MAX does not appear as a desktop shortcut. You can launch MAX either from the Start screen or from within NI Launcher.
    Finding All Programs
    Important Information
    © 2006–2012 National Instruments. All rights reserved.
    GMT+8, 2025-7-26 05:26
