查看: 2819|回复: 0
[LV工具模块] LabVIEW Touch Panel Module 2013 Win32Eng LabVIEW触摸屏模块2013版下载
    昨天 10:50
  • 签到天数: 3604 天
    连续签到: 12 天
    发表于 2020-10-30 23:48:41 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    LabVIEW触摸屏模块
    LabVIEW触摸屏模块用于开发触摸屏计算机所需的应用程序。
    LabVIEW触摸屏模块是一款软件附加工具,可用于创建和部署人机界面(HMI)应用程序,以便与CompactRIO系统等嵌入式实时平台进行通信。此工具包含多种用户界面开发工具,并具有通信、数据分析和数据存储功能。借助该附加工具,即可通过共享变量、TCP/IP或其他协议与控制器进行通信。您还可以借助内置LabVIEW演示工具,向操作人员显示重要信息。LabVIEW触摸屏模块经过优化,可将HMI部署于运行Windows Embedded Standard系统的NI或第三方工业触摸屏计算机。
    2013
    文件大小: 249987872 字节 (238.41 MB)
    修改日期: 2013-07-03 04:48
    MD5: 109538cdc61383cbfb995d0be63feac0(官方正确)
    SHA1: 7315270c3272188db997bab9e02d2258a865a38b
    SHA256: 480fb4c310e80f17dd67c30d553f41f1a8daba2c4b065086c7dc90efebbecfe1
    CRC32: d78a3e6a
    TPM2013.txt (350 Bytes, 下载次数: 0, 售价: 10 元)
    LabVIEW 2013 Touch Panel Module Readme
    Version 13.0.0
    June 2013
    This file contains important information about the LabVIEW Touch Panel Module, including system requirements, installation instructions, and known issues.
    The LabVIEW Touch Panel Module extends the LabVIEW graphical development environment to Touch Panel devices so you can create human-machine interface (HMI) applications for Touch Panel devices. You can create custom touch panel displays to communicate with National Instruments embedded real-time platforms, such as Compact FieldPoint, CompactRIO, and Compact Vision System.
    In addition to the system requirements for the LabVIEW Development System, the Touch Panel Module has the following requirements:
    • LabVIEW 2013 Base, Full, or Professional Development System (32-bit)
    • At least 250 MB of disk space
    • A Touch Panel device, such as the NI TPC-2512
    Refer to the LabVIEW Readme for additional system requirements and supported operating systems for LabVIEW 2013.
    You can install all of your LabVIEW products—including the Touch Panel Module—using the LabVIEW 2013 Platform DVDs. Refer to the LabVIEW Installation Guide on the LabVIEW Platform DVD 1 for installation instructions and system requirements.
    To request additional LabVIEW Platform DVDs, refer to the National Instruments website.
    Touch Panel Module Updates and Notifications
    Additional Installation Information
    This section contains information that you might find helpful as you install the Touch Panel Module.
    • The Touch Panel Module runs in evaluation mode if you do not activate it. You have the option of activating the Touch Panel Module during the installation process. You also can use the NI License Manager, available by selecting Start»All Programs»National Instruments»NI License Manager, to activate National Instruments products. Refer to the National Instruments License Manager Help, available by selecting Help»Contents in the NI License Manager, for more information about activating NI products.
    • You might need to install additional support for the NI TPC Service to use the Touch Panel Module. Refer to the Installing Support for NI TPC Service section of the Getting Started with the LabVIEW Touch Panel Module manual for more information.
    Installation Information for Windows XP Embedded
    The minimal requirement for National Instruments software on Windows XP is Windows XP SP3. If you want to install NI software on a Touch Panel device with the Windows XP Embedded operating system, refer to the National Instruments website for more information.
    You can access the software and documentation known issues list online. Refer to the National Instruments website for an up-to-date list of known issues in the Touch Panel Module.
    Refer to the LabVIEW Help, accessible by selecting Help»LabVIEW Help from LabVIEW, for information about the Touch Panel Module.
    Select Help»Find Examples from LabVIEW to launch the NI Example Finder. Navigate to the Toolkits and Modules»Touch Panel folder to find LabVIEW examples for the Touch Panel Module. You also can find these examples in the labview\examples\TouchPanel directory. You can modify an example VI to fit an application, or you can copy and paste from one or more examples into a VI that you create.
    Using NI Launcher
    Finding All Programs
    NI LabVIEW Touch Panel Module Drops Support for Microsoft Windows Vista, Windows XP, and Windows Server 2003 in 2016
    National Instruments LabVIEW Touch Panel Module will drop support for Microsoft Windows Vista, Windows XP, and Windows Server 2003 as of July 1, 2016. Versions of Touch Panel Module that ship after July 1, 2016 will not install or run on Windows Vista, Windows XP, or Windows Server 2003. For detailed information about NI application software product life cycles, visit ni.com/info and enter one of the following Info Codes:
    NI LabVIEWlifecycle
    NI TestStandtslcp
    NI DIAdemddlcp
    NI SignalExpressselcp
    NI VeriStandnivslifecycle
    Important Information
    © 2006–2013 National Instruments. All rights reserved.
    GMT+8, 2025-7-26 05:27
