查看: 2585|回复: 0
[RTE运行引擎] NI-DAQmx 9.1.7 Runtime Win32/64中文/德语/日语/法语/英文/韩语 NI-DAQmx9.1.7运行引擎下载
    10 小时前
    发表于 2020-11-1 21:51:16 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    NI-DAQmx
    9.1.7Runtime
    文件大小: 158018984 字节 (150.70 MB)
    修改日期: 2010-10-04 23:53
    MD5: 2bd5bd5b7ac6b025da06036f49a5a71b(官方正确)
    SHA1: 4e9e2d58ba80629fe2227dbd6202e952b2e32ebd
    SHA256: ccfd5b92d92201620a24b6dda3bfad9307ce0ade23f25de2325674547331d542
    CRC32: be1004ac
    NIDAQmxWin9.1.7RT.txt (277 Bytes, 下载次数: 0, 售价: 5 圆)
    NI-DAQmx 9.1.7 Readme
    September 2010
    Thank you for using NI-DAQmx, version 9.1.7. This version of NI-DAQmx fixes an issue with non-National Instruments human interface devices causing devices to be inaccessible to NI-DAQmx. For more information, refer to Why Do Certain USB Interface Devices Prevent NI Devices from Appearing in MAX?
    The readme contains the following main sections:
    • Important Notice: Microsoft Hotfix for USB DAQ Devices and Windows XP
    • Fixed issues
    • NI-DAQmx 7.x and later software
    • NI-DAQmx considerations
    • Upgrade considerations
    • Using NI-DAQmx and Traditional NI-DAQ (Legacy) on the same computer
    • Software support in NI-DAQmx 9.1.7
    • Device support in NI-DAQmx
    • System requirements
    If you are using NI-DAQmx with a USB DAQ device on Windows XP, you should install the Microsoft hotfix reported in Microsoft Knowledge Base 969238.
    Fixed Issues
    The following issues were fixed in NI-DAQmx 9.1.5
    CAR IDSummary
    147269NI WLS-9163 has poor wireless performance in networks with significant wireless traffic
    211139NI SCXI 1520 does not perform offset null in parallel in large channel-count systems
    218975Calibration constants not correctly applied when SCXI autozero is enabled
    NI-DAQmx 7.x and Later Software
    National Instruments measurement devices are packaged with NI-DAQ driver software, an extensive library of VIs and ANSI C functions you can call from your application software, such as LabVIEW or LabWindows™/CVI™, to program your NI measurement devices. Measurement devices include DAQ devices such as the M Series multifunction I/O (MIO) devices, signal conditioning modules, and switch modules. Driver software has an application programming interface (API ), which is a library of VIs, functions, classes, attributes, and properties for creating applications for your device.
    NI-DAQmx Considerations
    This section covers known issues and considerations specific to NI-DAQmx.
    Aborting Single-Point Reads and Writes in LabVIEW
    Single-point reads and writes do not respond to the Abort Execution button in LabVIEW.
    Configuring MAX Strain Tasks
    MAX strain tasks do not support configuring terminal configurations. By default, the configuration in MAX is differential. For the NI SC-2043-SG, the terminal configuration is NRSE. To avoid configuration issues, use the NI-DAQmx API to create the task.
    Counter Behavior of the NI DAQPad-6015/6016 for USB
    When performing buffered counter measurements on both ctr0 and ctr1 simultaneously, ctr1 returns duplicate counts. If you do not use ctr0 or if ctr0 performs a software-timed measurement, ctr1 functions properly.
    DAQ Assistant Maximum Channel Count
    The maximum number of channels you can have in a task created with the DAQ Assistant is 4096 channels.
    Exporting DAQ Assistant Settings to XML in NI LabVIEW SignalExpress
    Exporting DAQ Assistant project settings to XML in NI LabVIEW SignalExpress is available but not fully supported.
    LabVIEW Long Property Names
    When importing or exporting .ini files and tab-delimited text, LabVIEW long property names are not supported. Only English LabVIEW short property names, CVI property names, and C++/.NET class.property names are supported.
    .NET Remoting
    Accessing objects in the DAQmx .NET class library from a remote application domain with .NET Remoting is not supported in Microsoft Visual Studio .NET 2003.
    NI DAQCard-6715 Analog Output
    Hardware-timed single-point mode and hardware-timed nonbuffered mode are nonfunctional. Your application is using hardware-timed nonbuffered mode if you have set up a sample clock and a buffer size of 0, or set up a sample clock, but do not begin writing until after you start the task. All other waveform and static analog output modes work as expected.
    NI ENET/WLS-9215 Times Out Unexpectedly
    On the NI ENET/WLS-9215, an unexpected timeout can occur in continuous tasks using an external or very slow sample clock. The last sample may not be returned until the next sample clock pulse. To avoid the timeout, increase the timeout time (to allow the next sample clock pulse to occur) or acquire an even number of samples.
    NI-DAQmx Events
    Not all NI-DAQmx events will fire if the conditions for the event occur more quickly than the system can process.
    NI-DAQmx .NET Framework Help Shortcut
    A shortcut to the NI-DAQmx .NET Framework 1.1 Help is installed by default at Start»All Programs»National Instruments»NI-DAQ»Text-Based Code Support»NI-DAQmx .NET Framework 1.1 Help, a shortcut to the NI-DAQmx .NET Framework 2.0 Help is installed by default at Start»All Programs»National Instruments»NI-DAQ»Text-Based Code Support»NI-DAQmx .NET Framework 2.0 Help, and a shortcut to the NI-DAQmx .NET Framework 3.5 Help is installed by default at Start»All Programs»National Instruments»NI-DAQ»Text-Based Code Support»NI-DAQmx .NET Framework 3.5 Help. This documentation is in the Microsoft Help 2.0 format and requires a Microsoft Help 2.0 viewer to be displayed. A Microsoft Help 2.0 viewer is installed with both Microsoft Visual Studio .NET and the Microsoft .NET Framework SDK. The SDK is freely available from MSDN at http://www.microsoft.com/downloads . If you do not have either of these products, you will need a standalone Microsoft Help 2.0 viewer to display the documentation. Some Help 2.0 viewers are available for download, such as Helpware's H2Viewer.
    Some Devices Enumerate Twice
    Supported CompactRIO devices that fit into the NI USB-9162 carrier enumerate twice in MAX. When a device, such as the NI USB-9421, is first installed, it appears as the NI USB-9162 before appearing as the correct device.
    USB Device Removal During a DAQ Operation
    If a USB DAQ device is unplugged while a DAQ operation is being performed, unexpected results may occur, including causing the operating system to hang. In these occasional, extreme cases, you must reboot the computer. NI recommends stopping all DAQ operations on a USB device before unplugging the device from the computer.
    Using the C++ API from Multiple DLLs in the Same Process
    If you use the C++ API from multiple DLLs in the same process, you must access the API from only one DLL at a time. You must stop using the API in one DLL and destroy all API objects before using the API in another DLL.
    Microsoft Windows 7/Vista and Visual Studio C++, C#, Visual Basic .NET, and ANSI C Examples
    Running certain applications on Microsoft Windows 7/Vista requires administrator privileges, because the application name contains keywords such as setup, update, or install. To avoid this problem, you must add an additional manifest to the application that specifies the privileges required to run the application. Some NI-DAQmx ANSI C, Measurement Studio Visual C++, C#, and Visual Basic .NET examples include these keywords. Therefore, some examples for these application development environments include an additional manifest file that you must embed in the example executable.
    In ANSI C, Measurement Studio Visual C++ , C#, and Visual Basic .NET, the manifest file is named [ExampleName].exe.manifest, where [ExampleName] is the NI-provided example name. The steps for embedding an example varies depending on the programming language. Refer to the comments included with affected examples for additional information.
    Compiling Visual Studio 2005 examples can generate the following warning: manifest authoring warning 81010002: Unrecognized Element "requestedPrivileges" in namespace "urn:schemas-microsoft-com:asm.v3". For more information, refer to the Microsoft Feedback web page. This warning does not affect example execution and can be ignored. This warning happens because of the version of mt.exe that is shipped with Visual Studio 2005. The mt.exe tool embeds the additional manifest in the example executable.
    Important: Performing these steps on Windows XP Service Pack 2 (SP2) may cause your computer to restart when you run the application. Refer to the Microsoft Knowledge Base entry for more information. To avoid a computer restart, build your application using Visual Studio 2005 SP1.
    Upgrade Considerations
    This section covers changes in NI-DAQmx functionality.
    Connecting Real and Simulated Devices
    Connecting simulated devices to real devices is no longer supported as of NI-DAQmx 8.7.
    DAQmx Is Read or Write Late Obsoleted
    The existing DAQmx Is Read or Write Late function/VI has been obsoleted and no longer has any effect. Applications that must check whether they are maintaining real-time behavior have two options. For the strictest checking, use the Wait for Next Sample Clock function/VI. Refer to your API reference help, such as the LabVIEW Help or the NI-DAQmx C Function Reference Help, for more information on this function/VI. To check only whether the application misses any analog input samples, set the Report Missed Samples property to True on the analog input task. In LabVIEW, the Report Missed Samples property is in the Real Time property node. For more details, National Instruments strongly recommends that you read the document referred to by the Wait for Next Sample Clock function/VI.
    Duplicate Count Prevention Defaults
    As of NI-DAQmx 7.4, the default setting for the duplicate count prevention attribute/property on M Series and TIO-based counters has been changed. This change affects all input counter operations, with the exception of single-point edge counting and position measurements. Duplicate count prevention is now on by default as long as the following conditions are met:
    • The duplicate count prevention attribute/property has not been explicitly set.
    • The selected counter timebase source is not set to an internal timebase.
    • The prescaler attribute/property has not been set.
    • The counter output event has not been configured.
    To learn more, refer to Duplicate Count Prevention in the NI-DAQmx help.
    Existing .NET Project Produces Build Errors
    If you are using NI-DAQmx with a .NET language, an existing project can produce build errors that read "error CS0011: Referenced class 'className' has base class or interface 'NationalInstruments.ISynchronizeCallbacks' defined in an assembly that is not referenced. You must add a reference to assembly 'NationalInstruments.Common'." To eliminate this error, add a reference to the NationalInstruments.Common assembly to the project. This problem occurs when an existing project was built with NI-DAQmx 7.2 or earlier and is rebuilt with NI-DAQmx 7.3 or later.
    Multichannel SCXI Convert Clock Default Rate Change in NI-DAQmx 8.5
    Starting in NI-DAQmx 8.5, a delay of 20 μs was added to the fastest possible channel conversion rate on an SCXI chassis connected to a 16-bit or 18-bit E or M Series device. If a sample rate is set fast enough to require a convert clock rate greater than the default rate, warning 200011 is generated, informing the user that the accuracy of the measurement might be compromised. However, since this is a warning, the convert clock used is based on the rate needed by the sample clock set by the user (that is, convert clock = sample clock * number of channels).
    For SCXI chassis containing a module with track-and-hold circuitry, 10 μs of padding is now added to the fastest possible conversion rate when connected to a 12-bit E Series device.
    These changes ensure the most accurate data is being acquired. However, if the effect on the performance due to this change is too great (such as on an RT system using hardware-timed single point in a control loop), then the convert clock rate attribute can be explicitly set, overriding the default rate.
    This change affects only multichannel acquisitions.
    In versions prior to NI-DAQmx 8.5, only 10 μs of delay was added to the fastest possible channel conversion rate on an SCXI chassis without a track-and-hold module connected to any DAQ device. In these versions of NI-DAQmx, no warning was generated when the sample rate needed a faster convert clock than was chosen by default. When an SCXI chassis with a track-and-hold module was present, the convert clock rate selected was the fastest possible rate that the DAQ device can handle, up to 333 kHz.
    NI PCI-6704 and PXI-6704 Current Output Accuracy
    NI-DAQmx 8.3 changes the algorithm used to scale the 20 mA current outputs of the NI 6704 to a method that matches the behavior of Traditional NI-DAQ (Legacy). Previous versions of the NI-DAQmx driver use a second method.
    The effect of the change is that when NI-DAQmx programs the 6704 to output current, the actual current level of the 6704 is 10 μA higher with NI-DAQmx 8.3 compared to previous versions of NI-DAQmx. The actual current output with NI-DAQmx 8.3 is the same compared to Traditional NI-DAQ (Legacy) drivers. This change has no effect on the voltage outputs of the 6704.
    Because of this change, NI recommends that you externally calibrate NI 6704 devices with NI-DAQmx 8.3 (or later) before using devices with the NI-DAQmx 8.3 (or later) driver. NI 6704 devices that ship with NI-DAQmx 8.3 have already been calibrated with NI-DAQmx 8.3. For other NI 6704 devices, refer to the manual calibration procedure available at ni.com/calibration.
    Resolving Compiler Warnings from SynchronizingObject in Visual Studio 2005 or Later
    SynchronizingObject has been obsoleted in Measurement Studio class libraries for .NET Framework 2.0 or later. Accessing this property produces compiler warnings. If you were using SynchronizingObject in .NET Framework 1.1, you must update your code to use SynchronizationContext in .NET Framework 2.0 or later. For more information about SynchronizationContext, refer to Events, Callbacks, and Thread Safety in Measurement Studio Class Libraries in the NI-DAQmx .NET Framework 2.0 or later help. You can launch the NI-DAQmx .NET help from the Start menu. The Start menu path is different depending on the version of the .NET Framework you are using. For example, for Visual Studio 2005, you can launch the help from Start»All Programs»National Instruments»NI-DAQ»Text-Based Code Support»NI-DAQmx .NET Framework 2.0 Help.
    USB-9xxx Devices
    Unplug your USB-9xxx and plug it back in or power the USB device down and up after upgrading NI-DAQmx. If the USB-9xxx is connected to a USB hub, make sure to disconnect the USB-9xxx from the hub, not the hub from the computer. Disconnecting power from the USB device causes installed devices to load the correct version of the firmware.
    Virtual TEDS Data for the USB-9233/9237
    If you connect hardware TEDS to USB-9233/9237 channels configured with virtual TEDS, the virtual TEDS will be replaced with hardware TEDS data after upgrading to NI-DAQmx 8.6 or later.
    Using NI-DAQmx and Traditional NI-DAQ (Legacy) on the Same Computer
    Existing applications developed with earlier versions of NI-DAQ will run under Traditional NI-DAQ (Legacy). You can use both the Traditional NI-DAQ (Legacy) API and the NI-DAQmx API on the same computer with the following restrictions:
    • Only one API controls a given device at one time.
      After using a device in NI-DAQmx, you must unreserve all NI-DAQmx tasks that are using that device before you can use that device through Traditional NI-DAQ (Legacy). If you use a device in NI-DAQmx and then use it in Traditional NI-DAQ (Legacy) without unreserving the NI-DAQmx tasks, error code -10461 is returned. To unreserve NI-DAQmx tasks, call the DAQmx Clear Task VI or functions.
      After using a device in Traditional NI-DAQ (Legacy), you must reset the device before you can use that device in NI-DAQmx, or error code -200324 is returned.
      For SCXI devices, you must reset the communicating DAQ device in Traditional NI-DAQ (Legacy) before using it in NI-DAQmx. For example, E Series DAQ devices use lines 0, 1, 2, and 4 on port 0 to communicate with the SCXI module. Error code -200158 is returned if you do not reset the communicating device in Traditional NI-DAQ (Legacy) before using it in NI-DAQmx as follows:
      • Call the Traditional NI-DAQ (Legacy) Device Reset VI or the Init_DA_Brds function
      • To reset devices in Traditional NI-DAQ (Legacy) from MAX, you must reset all devices at once. Right-click the Traditional NI-DAQ (Legacy) Devices folder in MAX and select Reset Driver for Traditional NI-DAQ (Legacy). For a remote RT target, you must use the Traditional NI-DAQ (Legacy) Device Reset VI.
    • NI-DAQmx cannot be used with Traditional NI-DAQ 6.9.3 or earlier.
    • In an SCXI data acquisition system, you must use the same API to program all devices—connected DAQ devices and inserted SCXI modules.
    Refer to ni.com/support for details and instructions about the following topics:
    • How to add NI-DAQmx code to a Traditional NI-DAQ (Legacy) application
    • How to run both Traditional NI-DAQ (Legacy) applications and NI-DAQmx applications that use the same device
    Software Support in NI-DAQmx 9.1.7Operating System Support
    The following operating systems are supported in NI-DAQmx 9.1.7:
    • Windows Vista Business edition (32-bit and 64-bit)
    • Windows XP, Service Pack 2 or greater
    For OS-specific device support information, refer to ni.com/support/daq/versions.
    Note  Support for Windows Server 2003 R2 may require disabling physical address extensions (PAE). To learn how this might affect your use of Windows Server 2003 and what actions you might have to take, visit ni.com/info and enter the info code PAESupport.
    NI-DAQmx 9.1 and later supports Phar Lap only with the LabVIEW Real-Time Module 8.2 and later.
    Windows 2000 users must use NI-DAQmx 9.1.1 or earlier. Windows NT users must use NI-DAQmx 7.5 or earlier. Windows Me/98 users must use NI-DAQmx 7.1 or earlier. Windows 95 users must use NI-DAQ 6.9.3 or earlier.
    To find and download an earlier version of NI-DAQmx that supports other operating systems, refer to ni.com/downloads.
    NI-DAQmx does not support guest accounts on Windows 7/Vista/XP. You must log into an administrative or user account to use NI-DAQmx on these OSes.
    Measurement Studio Operating System Support
    Measurement Studio system requirements depend on the Visual Studio and .NET Framework versions that you have:
    • For Visual Studio .NET 2003 and .NET Framework 1.1, you must have Microsoft Windows XP.
    • For Visual Studio 2005 and .NET Framework 2.0, you must have Microsoft Windows 7/Vista/XP.
    • For Visual Studio 2008 and .NET Framework 3.5, you must have Microsoft Windows 7/Vista/XP.
    Note  If you are using the DAQmx .NET Library, the .NET 1.1 Framework, .NET 2.0 Framework, or .NET 3.5 Framework is required.
    The following table lists the NI application software versions supported by NI-DAQmx. If you are not using NI application software, refer to Microsoft Visual Studio Support.
    In NI-DAQmx 8.6 and prior, when you add the DAQ Component as a new item to your Visual Studio 2005 project, the DAQ Component is located in the Measurement Studio folder and the Visual Basic Items or Visual C# Project Items folders. In NI-DAQmx 8.7 and later, the DAQ Component is located only in the Visual Basic Items or Visual C# Project Items folder and named NI-DAQ Component.
    NI Application SoftwareVersions Supported by NI-DAQmx and the DAQ Assistant
    8.5.x, 8.6.x, 2009, and 2010
    8.5.x and later (including 2009 and later)
    LabWindows/CVI
    8.1 and later (including 2009 and later)
    LabWindows/CVI Real-Time Module
    Measurement Studio
    7.x and later (including 2009 and later)
    2.x and later (including 2009 and later)
    Measurement Studio Examples
    The directories that the Measurement Studio examples install to depends on which component is installed, the version of Visual Studio or the .NET Framework the example supports, the version of Measurement Studio installed, and the operating system. For detailed information on examples for Measurement Studio, refer to Where To Find Examples in the NI Measurement Studio Help.
    The following table lists the programming languages and Microsoft Visual Studio versions supported by NI-DAQmx.
    Programming LanguageVisual Studio Versions Supported by NI-DAQmx
    ANSI C
    2003, 2005, and 2008
    Visual C++ MFC
    20031, 20052, and 20083
    .NET Framework 1.1 Languages
    (C# and Visual Basic.NET)
    2003
    .NET Framework 2.0 Languages
    2005
    .NET Framework 3.5 Languages
    2008
    Visual Basic 6
    Legacy4
    1 Requires Measurement Studio 7.x — Measurement Studio 2009
    2 Requires Measurement Studio 8.0.1 — Measurement Studio 2009
    3 Requires Measurement Studio 8.6 — Measurement Studio 2009
    4 NI-DAQmx includes limited support for Visual Basic 6. For more information, visit ni.com/info and enter the info code daqmxvstudio.
    Earlier versions of NI-DAQmx support other application software and language versions. To find and download an earlier version of a driver, refer to ni.com/downloads.
    LabVIEW SignalExpress LE gives you a 30-day trial of the full version of LabVIEW SignalExpress. For more information on the trial version, refer to Getting Started with LabVIEW SignalExpress, installed by default at Start»All Programs»National Instruments»LabVIEW SignalExpress.
    IP Support for Network DAQ Devices
    Network DAQ Devices support Internet Protocol version 4 (IPv4). IPv6 is not supported.
    Device Support in NI-DAQmx
    The following lists detail the devices supported in NI-DAQmx. Device support is divided into the following categories:
    • Devices supported in NI-DAQmx
    • Devices Not Supported in NI-DAQmx on Windows 7/Vista
    • Devices No Longer Supported in NI-DAQmx 8.3 and Later
    For MXI-3 and MXI-4 OS-specific support information, refer to ni.com/kb and search for KnowledgeBase entry 45MA9LF7.
    Devices Supported in NI-DAQmx
    NI-DAQmx supports the following devices:
    • NI 9201 C Series 8-channel, ±10 V, 12-bit analog input module
    • NI 9201 (DSUB)
    • NI 9203 C Series 8-channel, ±20 mA, 16-bit analog input module
    • NI 9205 C Series 32-channel, 16-bit analog input module with gain and analog trigger (AI, PFI only)
    • NI 9206 C Series 32-channel, 16-bit analog input module for fuel cells (AI, PFI only)
    • NI 9207 C Series 16-channel combination voltage and current analog input module
    • NI 9208 C Series 16-channel current analog input module
    • NI 9211 C Series 12 S/s, 24-bit, thermocouple analog input, 4-channel scanned analog input module
    • NI 9213 C Series 16-channel thermocouple input module
    • NI 9215 100 kS/s, 16-bit, 4-channel isolated SMIO analog input module
    • NI 9215 (BNC)
    • NI 9217 C Series 4-channel, 24-bit, 100 ohm RTD analog input module
    • NI 9219 C Series 4-channel, 24-bit, universal analog input module
    • NI 9221 C Series 8-channel, ±60 V, 12-bit analog input module
    • NI 9221 (DSUB)
    • NI 9225 C Series 3-channel, ±300 Vrms, 24-Bit simultaneous analog input module
    • NI 9227 C Series analog input module
    • NI 9229 C Series 4-channel, ±60 V, 24-bit, simultaneous analog input module
    • NI 9233 C Series 50 kS/s, 24-bit, 4-channel dynamic signal acquisition module
    • NI 9234 C Series 4-channel, 51.2 kS/s, 24-bit software selectable IEPE and AC/DC analog input module
    • NI 9234B C Series analog input module
    • NI 9235 C Series 8-channel, 24-bit quarter-bridge analog input module
    • NI 9236 C Series 8-channel, 24-bit quarter-bridge analog input module
    • NI 9237 C Series 4-channel, 24-bit half/full-bridge analog input module
    • NI 9237 (DSUB) strain module
    • NI 9239 C Series 4-channel, ±10 V, 24-bit, simultaneous analog input module
    • NI 9239 (BNC)
    • NI 9263 C Series 4-channel analog output module
    • NI 9264 C Series 16-channel, ±10 V, 16-bit analog voltage output module
    • NI 9264 (DSUB) AO module
    • NI 9265 C Series 4-channel, 0-20 mA, 16-bit analog current output module
    • NI 9269 C Series channel-to-channel isolated 10 V analog output module
    • NI 9401 C Series 8-channel, bidirectional, nibble-configurable digital I/O module
    • NI 9402 C Series 4-channel, LVTTL digital I/O module
    • NI 9403 C Series 32-channel, TTL digital input/output module
    • NI 9411 C Series 6-channel, differential or TTL digital input module
    • NI 9421 C Series 8-channel, 24 V digital input module
    • NI 9421 (DSUB)
    • NI 9422 C Series 8-channel, 24 V, sinking/sourcing digital input module
    • NI 9423 C Series 8-channel, 24 V, high-speed digital input module
    • NI 9425 C Series 32-channel, 24 V, sinking digital input module
    • NI 9426 C Series 32-channel, 24 V, sourcing digital input module
    • NI 9435 C Series 4-channel, AC/DC universal digital input module
    • NI 9472 C Series 8-channel, 24 V digital output module
    • NI 9472 (DSUB)
    • NI 9474 C Series 8-channel, 24 V, high-speed, sourcing digital output module
    • NI 9475 C Series 8-channel, 60 V, high-speed, sourcing digital output module
    • NI 9476 C Series 32-channel, 24 V, high-speed, sourcing digital output module
    • NI 9477 C Series 32-channel, 5-60 V, sinking digital output module
    • NI 9478 C Series 16-channel, 0-50 V, sinking digital output module with programmable current limit
    • NI 9481 C Series 4-channel Form A SPST Relay digital output module
    • NI 9485 C Series 8-channel solid-state relay, 60 VDC/30 Vrms, 750 mA module
    • NI BNC-2096 TEDS device
    • NI cDAQ-9172 CompactDAQ chassis
    • NI cDAQ-9174 CompactDAQ chassis
    • NI cDAQ-9178 CompactDAQ chassis
    • NI DAQCard-6024E 200 kS/s, 12-bit, 16 analog input channel, two analog output channel, 8 digital I/O line, two counter/timer device
    • NI DAQCard-6036E 200 kS/s, 16-bit, 16 analog input channel, two analog output channel, 8 digital I/O line, two counter/timer device
    • NI DAQCard-6062E 500 kS/s, 12-bit, 16 analog input channel device
    • NI DAQCard-6715 for PCMCIA 1 MS/s 12-bit analog output device
    • NI DAQCard-DIO-24 for PCMCIA 24-channel 5V/TTL/CMOS digital I/O device
    • NI DAQPad-6015 for USB (does not have NI-DAQmx simulated device capability)
    • NI DAQPad-6015 for USB (BNC) (does not have NI-DAQmx simulated device capability)
    • NI DAQPad-6015 for USB (Mass Termination) (does not have NI-DAQmx simulated device capability)
    • NI DAQPad-6016 for USB (does not have NI-DAQmx simulated device capability)
    • NI ELVIS II educational design and prototyping platform
    • NI ELVIS II+ educational design and prototyping platform with high-speed digitizer
    • NI ENET-9205 analog input module
    • NI ENET-9206 analog input module
    • NI ENET-9211 14 S/s, 24-bit, thermocouple analog input, 4-channel scanned analog input module
    • NI ENET-9213 16-channel, 75 S/s, 24-bit, thermocouple input module
    • NI ENET-9215 100 kS/s, 16-bit, 4-channel isolated SMIO analog input module
    • NI ENET-9219 4-channel, 24-bit, universal analog input module
    • NI ENET-9234 4-channel, 51.2 kS/s, 24-bit software selectable IEPE and AC/DC analog input
    • NI ENET-9237 4-channel, 24-bit half/full-bridge analog input module
    • NI ENET-9421 8-channel, 24 V digital input module
    • NI ENET-9421(DSUB) 8-channel, 24 V digital input module
    • NI ENET-9472 8-channel, 24 V digital output module
    • NI ENET-9472(DSUB) 8-channel, 24 V digital output module
    • NI ENET-9481 4-channel Form A SPST Relay digital output module
    • NI myDAQ portable data acquisition device
    • NI PCI-4461 204.8 kS/s, 24-bit, 2 analog input channel, 2 analog output channel dynamic signal acquisition TEDS device
    • NI PCI-4021 switch controller
    • NI PCI-4462 24-bit, 4 analog input channel dynamic signal acquisition TEDS device
    • NI PCI-4472 102.4 kS/s, 24-bit, 8 analog input channel dynamic signal acquisition device
    • NI PCI-4474 102.4 kS/s, 24-bit, 4 analog input channel dynamic signal acquisition device
    • NI PCI-6010 16 analog input channel device (does not have NI-DAQmx simulated device capability)
    • NI PCI-6013 200 kS/s, 16-bit, 16 analog input, 8 digital I/O line, two counter/timer device (does not have NI-DAQmx simulated device capability)
    • NI PCI-6014 200 kS/s, 16-bit, 16 analog input channel, two analog output channel, 8 digital I/O line, two counter/timer analog input device (does not have NI-DAQmx simulated device capability)
    • NI PCI-6023E 200 kS/s, 12-bit, 16 analog input channel, 8 digital I/O line, two counter/timer device
    • NI PCI-6024E 200 kS/s, 12-bit, 16 analog input channel, two analog output channel, 8 digital I/O line, two counter/timer device
    • NI PCI-6025E 200 kS/s, 12-bit, 16 analog input channel, two analog output channel, 32 digital I/O line, two counter/timer device
    • NI PCI-6031E 100 kS/s, 16-bit, 64 analog input channel, two analog output channel, 8 digital I/O line, two counter/timer device
    • NI PCI-6032E 100 kS/s, 16-bit, 16 analog input channel, two analog output channel, 8 digital I/O line, two counter/timer device
    • NI PCI-6033E 100 kS/s, 16-bit, 64 analog input channel, 8 digital I/O line, two counter/timer device
    • NI PCI-6034E 200 kS/s, 16-bit, 16 analog input channel, 8 digital I/O line, two counter/timer device
    • NI PCI-6035E 200 kS/s, 16-bit, 16 analog input channel, two analog output channel, 8 digital I/O line, two counter/timer device
    • NI PCI-6036E 200 kS/s, 16-bit, 16 analog input channel, two analog output channel, 8 digital I/O line, two counter/timer device
    • NI PCI-6052E 333 kS/s, 16-bit, 16 analog input channel, two analog output channel, 8 digital I/O line, two counter/timer device
    • NI PCI-6071E 1.25 MS/s, 12-bit, 64 analog input channel, two analog output channel, 8 digital I/O line, two counter/timer device
    • NI PCI-6110 5 MS/s, 12-bit, 4 channel device
    • NI PCI-6111 5 MS/s, 12-bit, 2 channel device
    • NI PCI-6115 10 MS/s 12-bit device
    • NI PCI-6120 800 kS/s, 16-bit, 4 analog input simultaneous-sampling device
    • NI PCI-6122 500 kS/s, 16-bit S Series device
    • NI PCI-6123 500 kS/s, 16-bit, 8-channel S Series device
    • NI PCI-6132 4-channel, 32 MB S Series device
    • NI PCI-6133 3 MS/s, 14-bit, 8 analog input channel S Series device
    • NI PCI-6143 250 kS/s, 16-bit, 8 analog input channel S Series device
    • NI PCI-6154 4 analog input channel, 4 analog output channel, 16-bit isolated S Series device
    • NI PCI-6220 16 analog input channel, 250 kS/s, 16-bit M Series device
    • NI PCI-6221 (68-pin) 16 analog input channel, 250 kS/s, 16-bit M Series device
    • NI PCI-6221 (37-pin) 16 analog input channel, 250 kS/s, 16-bit M Series device
    • NI PCI-6224 32 analog input channel, 250 kS/s, 16-bit M Series device
    • NI PCI-6225 80 analog input channel, 250 kS/s, 16-bit M Series device
    • NI PCI-6229 32 analog input channel, 250 kS/s, 16-bit M Series device
    • NI PCI-6230 bank isolated, 8 analog input channel, 250 kS/s, 16-bit M Series device
    • NI PCI-6232 250 kS/s, 16-bit, 16 single-ended or 8 differential analog input channel isolated M Series device
    • NI PCI-6233 250 kS/s, 16-bit, 16 single-ended or 8 differential analog input channel isolated M Series device
    • NI PCI-6236 250 kS/s, 4 differential analog input (current input) channel M Series device
    • NI PCI-6238 250 kS/s, 8 differential analog input (current input) channel isolated M Series device
    • NI PCI-6239 250 kS/s, 8 differential analog input (current input) channel isolated M Series device
    • NI PCI-6250 16 analog input channel, 1 MS/s, 16-bit M Series device
    • NI PCI-6251 16 analog input channel, 1 MS/s, 16-bit M Series device
    • NI PCI-6254 32 analog input channel, 1 MS/s, 16-bit M Series device
    • NI PCI-6255 80 analog input channel, 1.25 MS/s, 16-bit M Series device
    • NI PCI-6259 32 analog input channel, 1 MS/s, 16-bit M Series device
    • NI PCI-6280 16 analog input channel, 500 kS/s, 18-bit M Series device
    • NI PCI-6281 16 analog input channel, 500 kS/s, 18-bit M Series device
    • NI PCI-6284 32 analog input channel, 500 kS/s, 18-bit M Series device
    • NI PCI-6289 32 analog input channel, 500 kS/s, 18-bit M Series device
    • NI PCI-6503 24-channel 5V/TTL/CMOS digital I/O device
    • NI PCI-6509 industrial 96-channel 5V/TTL/CMOS digital I/O device with high current (24 mA)
    • NI PCI-6510 digital I/O device
    • NI PCI-6511 digital I/O device
    • NI PCI-6512 digital I/O device
    • NI PCI-6513 digital I/O device
    • NI PCI-6514 digital I/O device
    • NI PCI-6515 industrial 32 source/sink digital input, 32 sink digital output bank isolated digital I/O device
    • NI PCI-6516 digital I/O device
    • NI PCI-6517 digital I/O device
    • NI PCI-6518 digital I/O device
    • NI PCI-6519 digital I/O device
    • NI PCI-6520 relay board
    • NI PCI-6521 relay board
    • NI PCI-6527 24 digital input, 24 digital output CH/CH isolated digital I/O device
    • NI PCI-6528 industrial 24 digital input, 24 digital output CH/CH isolated digital I/O device
    • NI PCI-6533 (DIO-32HS) 32-channel 5 V TTL/CMOS high-speed digital I/O and handshaking device
    • NI PCI-6534 32-channel 5 V TTL/CMOS high-speed digital I/O and handshaking device with onboard memory
    • NI PCI-6601 counter/timer device
    • NI PCI-6602 counter/timer device
    • NI PCI-6624 industrial 8-channel CH/CH isolated counter/timer device
    • NI PCI-6703 16-bit analog output device
    • NI PCI-6704 16-bit analog output device
    • NI PCI-6711 1 MS/s, 12-bit, 4 channel analog output device
    • NI PCI-6713 1 MS/s, 12-bit, 8 channel analog output device
    • NI PCI-6722 13-bit, 8 channel analog output device
    • NI PCI-6723 13-bit, 32 channel analog output device
    • NI PCI-6731 1 MS/s, 16-bit, 4 channel analog output device
    • NI PCI-6733 1 MS/s, 16-bit, 8 channel analog output device
    • NI PCI-DIO-96 96-channel parallel digital I/O device
    • NI PCI-MIO-16E-1 (PCI-6070) 12-bit, 1.25 MS/s, 16 analog input channel, two analog output channel, 8 digital I/O line, two counter/timer device
    • NI PCI-MIO-16E-4 (PCI-6040E) 500 kS/s (1-channel), 250 kS/s (multichannel), 12-bit, 16 analog input channel, two analog output channel, 8 digital I/O line, two counter/timer device
    • NI PCI-MIO-16XE-10 (PCI-6030E) 100 kS/s, 16-bit, 16 analog input channel, two analog output channel, 8 digital I/O line, two counter/timer device
    • NI PCI-MIO-16XE-50 20 kS/s, 16-bit, 16 analog input channel, two analog output channel, 8 digital I/O line, two counter/timer device
    • NI PCIe-6251 16 analog input channel, 1 MS/s, 16-bit M Series device
    • NI PCIe-6259 32 analog input channel, 1 MS/s, 16-bit M Series device
    • NI PCIe-6320 16 analog input channel, 250 kS/s, 16-bit X Series device
    • NI PCIe-6321 16 analog input channel, 250 kS/s, 16-bit X Series device
    • NI PCIe-6323 32 analog input channel, 250 kS/s, 16-bit X Series device
    • NI PCIe-6341 16 analog input channel, 500 kS/s, 16-bit X Series device
    • NI PCIe-6343 32 analog input channel, 500 kS/s, 16-bit X Series device
    • NI PCIe-6351 16 analog input channel, 1.25 MS/s, 16-bit X Series device
    • NI PCIe-6353 32 analog input channel, 1.25 MS/s, 16-bit X Series device
    • NI PCIe-6361 16 analog input channel, 2 MS/s, 16-bit X Series device
    • NI PCIe-6363 32 analog input channel, 2 MS/s, 16-bit X Series device
    • NI PCIe-6535 10 MHz, 5.0/3.3/2.5 V high-speed digital I/O device
    • NI PCIe-6536 25 MHz, 5.0/3.3/2.5 V high-speed digital I/O device
    • NI PCIe-6537 50 MHz, 5.0/3.3/2.5 V high-speed digital I/O device
    • NI PXI-1010 8-slot PXI backplane with a 4-slot SCXI backplane chassis
    • NI PXI-1011 4-slot PXI backplane with a 8-slot SCXI backplane chassis
    • NI PXI-2501 FET multiplexer
    • NI PXI-2503 relay multiplexer
    • NI PXI-2510 68-Channel 2A fault insertion unit
    • NI PXI-2512 7-Channel 10A fault insertion unit
    • NI PXI-2514 7-Channel 40A fault insertion unit
    • NI PXI-2515 high-speed digital I/O signal insertion switch
    • NI PXI-2531 512-crosspoint matrix
    • NI PXI-2527 32x1 relay multiplexer
    • NI PXI-2529 128-crosspoint relay matrix
    • NI PXI-2530 128-channel reed relay multiplexer/matrix
    • NI PXI-2532 512-crosspoint matrix
    • NI PXI-2533 256-crosspoint 4x64 SSR matrix
    • NI PXI-2534 256-crosspoint 8x32 SSR matrix
    • NI PXI-2535 544-crosspoint 4x136 FET matrix
    • NI PXI-2536 544-crosspoint 8x68 FET matrix
    • NI PXI-2545 2.7 GHz 4x1 terminated 50 ohm multiplexer
    • NI PXI-2546 2.7 GHz dual 4x1 50 ohm multiplexer
    • NI PXI-2547 2.7 GHz 8x1 50 ohm multiplexer
    • NI PXI-2548 2.7 GHz 4-SPDT 50 ohm relay module
    • NI PXI-2549 2.7 GHz terminated 2-SPDT 50 ohm relay module
    • NI PXI-2554 2.5 GHz 4x1 75 ohm multiplexer
    • NI PXI-2555 2.5 GHz 4x1 terminated 75 ohm multiplexer
    • NI PXI-2556 2.5 GHz dual 4x1 75 ohm multiplexer
    • NI PXI-2557 2.5 GHz 8x1 75 ohm multiplexer
    • NI PXI-2558 2.5 GHz 4-SPDT 75 ohm relay module
    • NI PXI-2559 2.5 GHz terminated 2-SPDT 75 ohm relay module
    • NI PXI-2564 16-SPST relay module
    • NI PXI-2565 16-SPST relay module
    • NI PXI-2566 16-SPDT relay module
    • NI PXI-2567 64-channel relay driver
    • NI PXI-2568 31-channel SPST relay module
    • NI PXI-2569 100-channel SPST relay module
    • NI PXI-2570 40-SPDT relay module
    • NI PXI-2575 196x1 relay multiplexer
    • NI PXI-2576 multi-bank multiplexer
    • NI PXI-2584 high-voltage multiplexer
    • NI PXI-2585 10-channel multiplexer
    • NI PXI-2586 10-channel SPST relay module
    • NI PXI-2590 1x4 1.3 GHz multiplexer
    • NI PXI-2591 1x4 4 GHz multiplexer
    • NI PXI-2593 500 MHz dual 8x1 50 ohm multiplexer
    • NI PXI-2594 1x4 2.5 GHz multiplexer
    • NI PXI-2595 1x4 5.5 GHz multiplexer
    • NI PXI-2596 dual 1x6 26.5 GHz multiplexer
    • NI PXI-2597 1x6 26.5 GHz terminated multiplexer
    • NI PXI-2598 dual 26.5 GHz transfer switch
    • NI PXI-2599 dual 26.5 GHz SPDT
    • NI PXI-4021 switch controller
    • NI PXI-4200 integrated signal conditioning module
    • NI PXI-4204 8-channel 100 V analog input module
    • NI PXI-4220 2-channel high-speed strain module
    • NI PXI-4224 signal conditioning module
    • NI PXI-4461 204.8 kS/s, 24-bit, 2 analog input channel, 2 analog output channel dynamic signal acquisition device
    • NI PXI-4462 24-bit, 4 analog input channel dynamic signal acquisition TEDS device
    • NI PXI-4472 102.4 kS/s, 24-bit, 8 analog input channel dynamic signal acquisition device
    • NI PXI-4472B 102.4 kS/s, 24-bit, 8 analog input channel dynamic signal acquisition device
    • NI PXI-4495 204.8 kS/s, 24-Bit, 16 AI channel dynamic signal acquisition device
    • NI PXI-4496 204.8 kS/s, 24-bit, 16 AI channel, AC-coupled, IEPE DSA device
    • NI PXI-4498 16 AI channel, 204.8 kS/s, 24-bit, AC-coupled, IEPE DSA device
    • NI PXI-6025E 200 kS/s, 12-bit, 16 analog input channel, two analog output channel, 32 digital I/O line, two counter/timer device
    • NI PXI-6030E 100 kS/s, 16-bit, 16 analog input channel, two analog output channel, 8 digital I/O line, two counter/timer device
    • NI PXI-6031E 100 kS/s, 16-bit, 64 analog input channel, two analog output channel, 8 digital I/O line, two counter/timer device
    • NI PXI-6040E 500 kS/s (1-channel), 250 kS/s (multichannel), 12-bit, 16 analog input channel, two analog output channel, 8 digital I/O line, two counter/timer device
    • NI PXI-6052E 333 kS/s, 16-bit, 16 analog input channel, two analog output channel, 8 digital I/O line, two counter/timer device
    • NI PXI-6070E 1.25 MS/s, 12-bit, 16 analog input channel, two analog output channel, 8 digital I/O line, two counter/timer device
    • NI PXI-6071E 1.25 MS/s, 12-bit, 64 analog input channel, two analog output channel, 8 digital I/O line, two counter/timer device
    • NI PXI-6115 10 MS/s, 12-bit device
    • NI PXI-6120 800 kS/s, 16-bit, 4 analog input simultaneous-sampling device
    • NI PXI-6122 500 kS/s, 16-bit S Series device
    • NI PXI-6123 500 kS/s, 16-bit, 8-channel S Series device
    • NI PXIe-6124 4 MS/s, 16-bit, 4 analog input channel, 2 analog output channel S Series device
    • NI PXI-6132 4-channel, 32 MB S Series device
    • NI PXI-6133 3 MS/s, 14-bit, 8 analog input channel S Series device
    • NI PXI-6143 250 kS/s, 16-bit, 8 analog input channel S Series device
    • NI PXI-6220 16 analog input channel, 250 kS/s, 16-bit M Series device
    • NI PXI-6221 (68-pin) 16 analog input channel, 250 kS/s, 16-bit M Series device
    • NI PXI-6224 32 analog input channel, 250 kS/s, 16-bit M Series device
    • NI PXI-6225 80 analog input channel, 250 kS/s, 16-bit M Series device
    • NI PXI-6229 32 analog input channel, 250 kS/s, 16-bit M Series device
    • NI PXI-6230 bank isolated, 8 analog input channel, 250 kS/s, 16-bit M Series device
    • NI PXI-6232 250 kS/s, 16-bit, 16 single-ended or 8 differential analog input channel isolated M Series device
    • NI PXI-6233 250 kS/s, 16-bit, 16 single-ended or 8 differential analog input channel isolated M Series device
    • NI PXI-6236 250 kS/s, 4 differential analog input (current input) channel M Series device
    • NI PXI-6238 250 kS/s, 8 differential analog input (current input) channel isolated M Series device
    • NI PXI-6239 250 kS/s, 8 differential analog input (current input) channel isolated M Series device
    • NI PXI-6250 16 analog input channel, 1 MS/s, 16-bit M Series device
    • NI PXI-6251 16 analog input channel, 1 MS/s, 16-bit M Series device
    • NI PXI-6254 32 analog input channel, 1 MS/s, 16-bit M Series device
    • NI PXI-6255 80 analog input channel, 1.25 MS/s, 16-bit M Series device
    • NI PXI-6259 32 analog input channel, 1 MS/s, 16-bit M Series device
    • NI PXI-6280 16 analog input channel, 500 kS/s, 18-bit M Series device
    • NI PXI-6281 16 analog input channel, 500 kS/s, 18-bit M Series device
    • NI PXI-6284 32 analog input channel, 500 kS/s, 18-bit M Series device
    • NI PXI-6289 32 analog input channel, 500 kS/s, 18-bit M Series device
    • NI PXI-6508 96-channel 5V/TTL/CMOS digital I/O device
    • NI PXI-6509 industrial 96-channel 5V/TTL/CMOS digital I/O device with high current (24 mA)
    • NI PXI-6511 digital I/O device
    • NI PXI-6512 digital I/O device
    • NI PXI-6513 digital I/O device
    • NI PXI-6514 industrial 32 source/sink digital input, 32 source digital output bank isolated digital I/O device
    • NI PXI-6515 industrial 32 source/sink digital input, 32 sink digital output bank isolated digital I/O device
    • NI PXI-6520 relay board
    • NI PXI-6521 relay board
    • NI PXI-6527 24 digital input, 24 digital output CH/CH isolated digital I/O device
    • NI PXI-6528 industrial 24 digital input, 24 digital output CH/CH isolated digital I/O device
    • NI PXI-6529 industrial 48 digital input, isolated digital I/O device
    • NI PXI-6533 32-channel 5 V TTL/CMOS high-speed digital I/O and handshaking device
    • NI PXI-6534 32-channel 5 V TTL/CMOS high-speed digital I/O and handshaking device with onboard memory
    • NI PXI-6602 counter/timer device
    • NI PXI-6608 counter/timer device
    • NI PXI-6624 counter/timer device
    • NI PXI-6704 16-bit analog output device
    • NI PXI-6711 1 MS/s, 12-bit, 4 channel analog output device
    • NI PXI-6713 1 MS/s, 12-bit, 8 channel analog output device
    • NI PXI-6722 13-bit, 8 channel analog output device
    • NI PXI-6723 13-bit, 32 channel analog output device
    • NI PXI-6733 1 MS/s, 16-bit, 8 channel analog output device
    • NI PXIe-2512 7-Channel 10A fault insertion unit
    • NI PXIe-2514 7-Channel 40A fault insertion unit
    • NI PXIe-2515 high-speed digital I/O signal insertion switch
    • NI PXIe-2527 32x1 relay multiplexer
    • NI PXIe-2529 128-crosspoint relay matrix
    • NI PXIe-2531 512-crosspoint matrix
    • NI PXIe-2532 512-crosspoint matrix
    • NI PXIe-2569 100-channel SPST relay module
    • NI PXIe-2575 196x1 Relay Multiplexer
    • NI PXIe-2593 500 MHz dual 8x1 50 ohm multiplexer
    • NI PXIe-4300 8-channel simultaneously sampling analog input device
    • NI PXIe-4330 8-channel, 25.6 kS/s strain device
    • NI PXIe-4331 8-channel, 102.4 kS/s strain device
    • NI PXIe-4353 32-channel thermocouple device
    • NI PXIe-4496 16 AI channel, 204.8 kS/s, 24-bit, AC-coupled, IEPE DSA device
    • NI PXIe-4498 16 AI channel, 204.8 kS/s, 24-bit, AC-coupled, IEPE DSA device
    • NI PXIe-6251 16 analog input channel, 1 MS/s, 16-bit M Series device
    • NI PXIe-6259 32 analog input channel, 1 MS/s, 16-bit M Series device
    • NI PXIe-6341 16 analog input channel, 500 kS/s, 16-bit X Series device
    • NI PXIe-6356 8 analog input channel, 1.25 MS/s, 16-bit X Series device
    • NI PXIe-6358 16 analog input channel, 1.25 MS/s, 16-bit X Series device
    • NI PXIe-6361 16 analog input channel, 2 MS/s, 16-bit X Series device
    • NI PXIe-6363 32 analog input channel, 2 MS/s, 16-bit X Series device
    • NI PXIe-6366 8 analog input channel, 2 MS/s, 16-bit X Series device
    • NI PXIe-6368 16 analog input channel, 2 MS/s, 16-bit X Series device
    • NI PXIe-6535 10 MHz, 5.0/3.3/2.5 V high-speed digital I/O device
    • NI PXIe-6536 25 MHz, 5.0/3.3/2.5 V high-speed digital I/O device
    • NI PXIe-6537 50 MHz, 5.0/3.3/2.5 V high-speed digital I/O device
    • NI SC-2350 TEDS device
    • NI SCXI-1000 4-slot chassis
    • NI SCXI-1000DC 4-slot DC-powered chassis
    • NI SCXI-1001 12-slot chassis
    • NI SCXI-1100 32-channel analog input module
    • NI SCXI-1102 thermocouple amplifier module
    • NI SCXI-1102B/C amplifier multiplexer module
    • NI SCXI-1104/C multiplexer module
    • NI SCXI-1112 thermocouple amplifier module
    • NI SCXI-1120/D isolation amplifier module
    • NI SCXI-1121 isolation amplifier with excitation module
    • NI SCXI-1122 isolated multiplexer amplifier module
    • NI SCXI-1124 analog output module
    • NI SCXI-1125 isolation amplifier module
    • NI SCXI-1126 isolated frequency input channel module
    • NI SCXI-1127 32-channel relay multiplexer/matrix
    • NI SCXI-1128 32-channel SSR multiplexer/matrix
    • NI SCXI-1129 256-crosspoint relay matrix
    • NI SCXI-1130 256-channel reed relay multiplexer/matrix
    • NI SCXI-1140 track-and-hold module
    • NI SCXI-1141 lowpass filter module
    • NI SCXI-1142 lowpass filter module
    • NI SCXI-1143 lowpass filter module
    • NI SCXI-1160 16-SPDT general-purpose relay module
    • NI SCXI-1161 8-SPDT power relay module
    • NI SCXI-1162 digital I/O module
    • NI SCXI-1162HV digital I/O module
    • NI SCXI-1163 digital I/O module
    • NI SCXI-1163R 32-channel solid state relay
    • NI SCXI-1166 32-SPDT relay module
    • NI SCXI-1167 64-channel relay driver
    • NI SCXI-1169 100-channel SPST relay module
    • NI SCXI-1175 196x1 relay multiplexer
    • NI SCXI-1190 1.3 GHz quad 4x1 50 ohm multiplexer
    • NI SCXI-1191 4 GHz quad 4x1 50 ohm multiplexer
    • NI SCXI-1192 18 GHz 8-SPDT 50 ohm relay module
    • NI SCXI-1193 quad 8x1 50 ohm multiplexer
    • NI SCXI-1194 quad 1x4 2.5 GHz multiplexer
    • NI SCXI-1195 quad 1x4 5.5 GHz multiplexer
    • NI SCXI-1314T TEDS device
    • NI SCXI-1502 thermocouple amplifier module
    • NI SCXI-1503 16-channel RTD input module
    • NI SCXI-1520 strain gage input module
    • NI SCXI-1521/B signal conditioning module
    • NI SCXI-1530 module for accelerometers and microphones
    • NI SCXI-1531 module for accelerometers and microphones
    • NI SCXI-1540 linear variable differential transformers (LVDT) module
    • NI SCXI-1581 current excitation analog output module
    • NI USB-4431 24-bit, 4 analog input, 1 analog output device.
    • NI USB-4432 24-bit, 5 analog input device.
    • NI USB-6008 (does not have NI-DAQmx simulated device capability)
    • NI USB-6009 (does not have NI-DAQmx simulated device capability)
    • NI USB-6210 250 kS/s (aggregate), 16-bit, 16 single-ended or 8 differential analog input channel M Series device
    • NI USB-6211 250 kS/s (aggregate), 16-bit, 16 single-ended or 8 differential analog input channel, 2 analog output channel M Series device
    • NI USB-6212 400 kS/s (aggregate), 16-bit, 16 single-ended or 8 differential analog input channel, 2 analog output channel, 32 digital I/O channel M Series device
    • NI USB-6212 BNC 16 analog input channel, 400 kS/s, 16-bit M Series device
    • NI USB-6212 Mass Termination M Series device
    • NI USB-6215 250 kS/s (aggregate), 16-bit, 16 single-ended or 8 differential analog input channel, 2 analog output channel Isolated M Series device
    • NI USB-6216 400 kS/s (aggregate), 16-bit, 16 single-ended or 8 differential analog input channel, 2 analog output channel, 32 digital I/O channel, Isolated M Series device
    • NI USB-6216 BNC 16 analog input channel, 400 kS/s, 16-bit Isolated M Series device
    • NI USB-6216 400 kS/s Mass Termination Isolated M Series device
    • NI USB-6218 250 kS/s (aggregate), 16-bit, 32 single-ended or 16 differential analog input channel, 4 analog output channel Isolated M Series device
    • NI USB-6218 BNC 32 analog input channel, 250 kS/s, 16-bit Isolated M Series device
    • NI USB-6221 BNC, 16 analog input channel, 250 kS/s, 16-bit M Series device
    • NI USB-6221 Screw Terminal
    • NI USB-6225 Mass Termination 80 analog input channel, 250 kS/s, 16-bit M Series device (does not have NI-DAQmx simulated device capability)
    • NI USB-6225 Screw Terminal
    • NI USB-6229 BNC, 32 analog input channel, 250 kS/s, 16-bit M Series device
    • NI USB-6229 Screw Terminal
    • NI USB-6251 BNC, 16 analog input channel, 1 MS/s, 16-bit M Series device
    • NI USB-6251 Mass Termination
    • NI USB-6251 Screw Terminal
    • NI USB-6255 Mass Termination 80 analog input channel, 1.25 MS/s, 16-bit M Series device (does not have NI-DAQmx simulated device capability)
    • NI USB-6255 Screw Terminal
    • NI USB-6259 BNC, 32 analog input channel, 1 MS/s, 16-bit M Series device
    • NI USB-6259 Mass Termination
    • NI USB-6259 Screw Terminal
    • NI USB-6281 Mass Termination 16 analog input channel, 500 kS/s, 18-bit M Series device
    • NI USB-6281 Screw Terminal
    • NI USB-6289 Mass Termination 32 analog input channel, 500 kS/s, 18-bit M Series device
    • NI USB-6289 Screw Terminal
    • NI USB-6501 (does not have NI-DAQmx simulated device capability)
    • NI USB-6509 industrial 96-channel 5V/TTL/CMOS digital I/O device with high current (24 mA)
    • NI USB-6525 (does not have NI-DAQmx simulated device capability)
    • NI USB-9201 500 kS/s, 12-bit, 8-channel scanned analog input device
    • NI USB-9211A 12 S/s, 24-bit, thermocouple analog input, 4-channel scanned analog input device
    • NI USB-9213 thermocouple input device
    • NI USB-9215A 100 kS/s, 16-bit, 4-channel isolated SMIO analog input device
    • NI USB-9219 C Series 4-channel, 24-bit, universal analog input module
    • NI USB-9221 8-channel scanned analog input device
    • NI USB-9229 C Series 4-channel, ±60 V, 24-bit, simultaneous analog input module
    • NI USB-9229 (BNC)
    • NI USB-9233 50 kS/s, 24-bit, 4-channel dynamic signal acquisition device
    • NI USB-9234 51.2 kS/s, 24-bit, 4-channel dynamic signal acquisition device
    • NI USB-9237 4-channel, 24 bit half/full-bridge analog input module
    • NI USB-9239 C Series 4-channel, ±10 V, 24-bit, simultaneous analog input module
    • NI USB-9263 10 V analog output module
    • NI USB-9264 16-channel, ±10 V, 16-bit analog voltage output module
    • NI USB-9265 4-channel, 0-20 mA, 16-bit analog current output module
    • NI USB-9421 8-channel digital input module
    • NI USB-9472 8-channel digital output module
    • NI USB-9481 4-channel Form A SPST Relay digital output module
    • NI USB-TC01 1-channel thermocouple device
    • NI WLS-9206 802.11 b/g wireless analog input module
    • NI WLS-9211 14 S/s, 24-bit, thermocouple analog input, 4-channel scanned 802.11 b/g wireless analog input module
    • NI WLS-9213 16-channel, 75 S/s, 24-bit, thermocouple input 802.11 b/g wireless module
    • NI WLS-9215 100 kS/s, 16-bit, 4-channel isolated SMIO 802.11 b/g wireless analog input module
    • NI WLS-9219 4-channel, 24-bit, universal 802.11 b/g wireless analog input module
    • NI WLS-9234 4-channel, 51.2 kS/s, 24-bit software selectable IEPE and AC/DC 802.11 b/g wireless analog input module
    • NI WLS-9237 4-channel, 24-bit half/full-bridge 802.11 b/g wireless analog input module
    • NI WLS-9421 8-channel, 24 V 802.11 b/g wireless digital input module
    • NI WLS-9421(DSUB) 8-channel, 24 V 802.11 b/g wireless digital input module
    • NI WLS-9472 8-channel, 24 V 802.11 b/g wireless digital output module
    • NI WLS-9472(DSUB) 8-channel, 24 V 802.11 b/g wireless digital output module
    • NI WLS-9481 4-channel Form A SPST Relay 802.11 b/g wireless digital output module
    • SensorDAQ (does not have NI-DAQmx simulated device capability)
    The following devices are not supported in NI-DAQmx on Windows 7/Vista (32-bit and 64-bit versions):
    The following devices are supported in NI-DAQmx on the 32-bit versions of Windows 7/Vista. They are not supported on the 64-bit versions of Windows 7/Vista:
    • NI SCXI-1600 USB module
    The following products are not supported in NI-DAQmx 8.3 and later and will not be supported in future versions of NI-DAQmx:
    • NI PCI-7041/6040E device for LabVIEW RT is supported in NI-DAQmx 8.1 and earlier.
    Note  The NI PXI-6040E and NI PCI-MIO-16E-4 continue to be supported in NI-DAQmx.
    System RequirementsDevelopment
    Minimum ProcessorPentium III/Celeron 600 MHz or Equivalent
    RAM128 MB
    Screen resolution800 x 600 pixels
    Operating systemWindows 7/Vista/XP
    Recommended ProcessorPentium 4 or Equivalent
    RAM256 MB
    Screen resolution1024 x 768 pixels
    Deployment
    Minimum ProcessorPentium 200 MHz or Equivalent
    RAM64 MB
    Screen resolution800 x 600 pixels or no screen
    Recommended ProcessorPentium III/Celeron 600 MHz or Equivalent
    RAM256 MB
    Screen resolution1024 x 768 pixels or no screen
    You must have Internet Explorer version 5.0 or later to use some features of the NI-DAQmx 7.x and later documentation, including the help system and Device Document Browser.
    Copyright 2003–2010 National Instruments. All rights reserved.
    GMT+8, 2025-12-8 19:22
