查看: 3113|回复: 0
[RTE运行引擎] NI-DAQmx 9.3 Runtime Win32/64中文/德语/日语/法语/英文/韩语 NI-DAQmx9.3运行引擎下载
    10 小时前
    发表于 2020-11-2 08:06:28 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    NI-DAQmx
    9.3 Runtime
    文件大小: 163048114 字节 (155.49 MB)
    修改日期: 2012-02-18 04:25
    MD5: 18d8130b222ae74a18b8131e37eb3312(官方正确)
    SHA1: 75ae2443687ed088e5774c163ff6e478a12f1643
    SHA256: 9076bb8ce8a4fe7bb259b24ca1fdbf9b2541267479fdaf0a2bc1eaaab1403c1d
    CRC32: 1fe226e9
    NIDAQmxWin9.3RT.txt (277 Bytes, 下载次数: 0, 售价: 5 圆)
    NI-DAQmx 9.3 Readme
    February 2011
    Thank you for using NI-DAQmx, version 9.3. The readme contains the following main sections:
    • New features added in NI-DAQmx 9.3
    • Important Notice: Microsoft Hotfix for USB DAQ Devices and Windows XP
    • Fixed issues
    • NI-DAQmx considerations
    • Upgrade considerations
    • Software support in NI-DAQmx 9.3
    • Device support in NI-DAQmx
    • System requirements
    New Features Added in NI-DAQmx 9.3
    The following features were added in NI-DAQmx 9.3:
    • Support for the NI cDAQ-9171 USB chassis and the NI cDAQ-9181 Ethernet chassis.
    • Support for external calibration in CompactDAQ with the NI 9217, 9225, and 9227 C Series devices.
    • Support for the NI 2571 switch module.
    • TDMS usability enhancements.
    If you are using NI-DAQmx with a USB DAQ device on Windows XP, you should install the Microsoft hotfix reported in Microsoft Knowledge Base 969238.
    Fixed Issues
    The following issues were fixed in NI-DAQmx 9.3:
    CAR IDSummary
    106314Shunt cal and offset null in a strain task do not work properly if a custom scale is selected
    187820NI USB-4431 may output stale data at the start of a task if the sample rate has changed from the last task's rate
    206282Starting an AO task on an NI USB-4431 causes a glitch on the channel
    235725The NI WLS-9163 may experience connection issues with international wireless routers
    239962Starting an acquisition using multiple NI 9219 devices takes 10-20 seconds
    242484Explicitly committing a task with events on a simulated cDAQ chassis can result in a system crash
    242611NI 9203 may return improperly scaled data with an NI 9174, 9178, or 9188 chassis when mixing bipolar and unipolar channels
    245504NI USB-4431 doesn't support DAQmxGetWriteTotalSampPerChanGenerated property
    246579DAQ Assistant hangs when creating a digital NI-DAQmx task from a LabVIEW Project
    246651Master Timebase cannot be shared between tasks in a cDAQ chassis
    248436Using the DAQ Assistant to calibrate a strain channel on the NI 9235/6 gives error -200077
    249685Scaled units for acceleration measurement type should support in/s^2
    250609NI-DAQmx Test Panels Are Taller Than 600 Pixels
    251790NI LabVIEW SignalExpress 2010 freezes when generating a calibration report
    252395Repeatedly creating, starting, stopping, and clearing AO tasks on an NI 4461 may cause it to output full scale noise
    252811Setting timeout to -1 can timeout with a Frequency Measurement DAQmx Global Virtual Channel
    253284NI USB-4431 AO tasks do not stop generating at task stop when "Allow Regeneration" and "Use Only Onboard Memory" are enabled
    255249NI USB-4431/32 inputs invert the polarity of out of range voltage signals
    277095Value of DAQmx Channels to Read property changes when you modify other NI-DAQmx properties
    278121NI WLS-9163 may become unresponsive during long-term use
    278249NI USB-4431 AO to AI synchronization may vary when the unit is power cycled
    278838NI USB-4431 may output data from previous tasks if continuous AO tasks are stopped and restarted
    279016NI USB X Series digital I/O lines glitch on Windows restart
    280611NI USB-4431 may not update the output for short finite output tasks
    281238In an NI 9172, on-demand digital output can tri-state other lines on the same NI 9401
    282045Error -200152 may be reported repeatedly for NI ENET-9163 or NI WLS-9163 devices
    282383C Series modules used with the NI WLS/ENET-9163 may return corrupted data in adverse network conditions
    NI-DAQmx Considerations
    This section covers known issues and considerations specific to NI-DAQmx.
    Microsoft Silverlight Required for NI cDAQ-918x Configuration
    The NI cDAQ-918x configuration, both with the NI Web-based configuration and in MAX, requires Microsoft Silverlight. Silverlight is available from microsoft.com/silverlight. To find out more about using Microsoft Silverlight with NI software, visit ni.com/info and enter the info code Silverlight.
    NI cDAQ-918x Works Incorrectly if Path Includes Non-ASCII (Multi-Byte) Characters
    The NI cDAQ-918x might not function correctly if NI-DAQmx is installed in a path with non-ASCII (or multi-byte) characters. This issue most commonly affects NI-DAQmx installations on Korean, Japanese, and Chinese versions of Windows. If your NI-DAQmx installation path contains non-ASCII characters, uninstall NI-DAQmx and other NI application development software and then reinstall your software to a path without non-ASCII characters.
    Web-Based Configuration for the NI cDAQ-918x Available Only for Windows and Macintosh
    Web-based configuration is available for the NI cDAQ-918x by accessing the device in a Microsoft Silverlight-enabled Web browser via its host name or IP address. This support is only accessible from Windows-based or Macintosh-based systems. Refer to the chassis user guide for more information.
    Firmware Update Required to Use NI cDAQ-9188 in NI-DAQmx 9.3
    You must update the firmware on the NI cDAQ-9188 to use it with NI-DAQmx 9.3. Firmware files for Network DAQ devices are named nifw.cfg (for instance, ni9188fw.cfg). You can obtain the latest version of firmware in the Firmware directory on the NI-DAQmx media or by going to ni.com/downloads.
    Required Firmware Updates for Network DAQ Devices in NI-DAQmx
    If you receive Error -201340, you need to update the firmware on your Network DAQ device. Firmware files for Network DAQ devices are named nifw.cfg (for instance, ni9188fw.cfg). You can obtain the version of firmware supported by your version of NI-DAQmx by going to ni.com/info and entering the info code exkpzt. If you installed NI-DAQmx from a DVD, you can also find a compatible version in the Firmware directory on that DVD.
    New Error Returned when Loading an Invalid Device Name
    In NI-DAQmx 9.3 and later, an invalid device name returns Error –200220, kErrorInvalidDeviceID, instead of Error –200170, kErrorPhysicalChanDoesNotExist. This change has no impact on newly created applications but can affect existing applications if the applications are performing error checking by looking for the specific error number (–200170).
    NI USB-4431 Specifications Changes
    The NI USB-4431 specifications have changed. The AO offset is specified with a higher level of uncertainty. The analog inputs and outputs also have a higher gain uncertainty than previously specified. In particular, sample rates of less than 40 kHz result in an accuracy drop. The newest version of the NI USB-443x Specifications reflects these changes. A separate document, Notice of Specification Change - USB 4431, details these changes as well.
    Aborting Single-Point Reads and Writes in LabVIEW
    Single-point reads and writes do not respond to the Abort Execution button in LabVIEW.
    Configuring MAX Strain Tasks
    MAX strain tasks do not support configuring terminal configurations. By default, the configuration in MAX is differential. For the NI SC-2043-SG, the terminal configuration is NRSE. To avoid configuration issues, use the NI-DAQmx API to create the task.
    DAQ Assistant Maximum Channel Count
    The maximum number of channels you can have in a task created with the DAQ Assistant is 4096 channels.
    NI DAQCard-6715 Analog Output
    Hardware-timed single-point mode and hardware-timed nonbuffered mode are nonfunctional. Your application is using hardware-timed nonbuffered mode if you have set up a sample clock and a buffer size of 0, or set up a sample clock, but do not begin writing until after you start the task. All other waveform and static analog output modes work as expected.
    NI ENET/WLS-9215 Times Out Unexpectedly
    On the NI ENET/WLS-9215, an unexpected timeout can occur in continuous tasks using an external or very slow sample clock. The last sample may not be returned until the next sample clock pulse. To avoid the timeout, increase the timeout time (to allow the next sample clock pulse to occur) or acquire an even number of samples.
    NI-DAQmx Events
    Not all NI-DAQmx events will fire if the conditions for the event occur more quickly than the system can process.
    Samples Not Acquired on NI 660x or NI 6624 Devices
    When using pulse width, semi-period or two-edge separation buffered measurements with the NI 660x and NI 6624 on counters 0 and 1, some samples may not be acquired under certain circumstances.
    Microsoft Windows 7/Vista and Visual Studio C++, C#, Visual Basic .NET, and ANSI C Examples
    Running certain applications on Microsoft Windows 7/Vista requires administrator privileges, because the application name contains keywords such as setup, update, or install. To avoid this problem, you must add an additional manifest to the application that specifies the privileges required to run the application. Some NI-DAQmx ANSI C, Measurement Studio Visual C++, C#, and Visual Basic .NET examples include these keywords. Therefore, some examples for these application development environments include an additional manifest file that you must embed in the example executable.
    In ANSI C, Measurement Studio Visual C++ , C#, and Visual Basic .NET, the manifest file is named [ExampleName].exe.manifest, where [ExampleName] is the NI-provided example name. The steps for embedding an example varies depending on the programming language. Refer to the comments included with affected examples for additional information.
    Compiling Visual Studio 2005 examples can generate the following warning: manifest authoring warning 81010002: Unrecognized Element "requestedPrivileges" in namespace "urn:schemas-microsoft-com:asm.v3". For more information, refer to the Microsoft Feedback web page. This warning does not affect example execution and can be ignored. This warning happens because of the version of mt.exe that is shipped with Visual Studio 2005. The mt.exe tool embeds the additional manifest in the example executable.
    Important: Performing these steps on Windows XP Service Pack 2 (SP2) may cause your computer to restart when you run the application. Refer to the Microsoft Knowledge Base entry for more information. To avoid a computer restart, build your application using Visual Studio 2005 SP1.
    Upgrade Considerations
    This section covers changes in NI-DAQmx functionality.
    DAQmx Is Read or Write Late Obsoleted
    The existing DAQmx Is Read or Write Late function/VI has been obsoleted and no longer has any effect. Applications that must check whether they are maintaining real-time behavior have two options. For the strictest checking, use the Wait for Next Sample Clock function/VI. Refer to your API reference help, such as the LabVIEW Help or the NI-DAQmx C Function Reference Help, for more information on this function/VI. To check only whether the application misses any analog input samples, set the Report Missed Samples property to True on the analog input task. In LabVIEW, the Report Missed Samples property is in the Real Time property node. For more details, National Instruments strongly recommends that you read the document referred to by the Wait for Next Sample Clock function/VI.
    Duplicate Count Prevention Defaults
    As of NI-DAQmx 7.4, the default setting for the duplicate count prevention attribute/property on M Series and TIO-based counters has been changed. This change affects all input counter operations, with the exception of single-point edge counting and position measurements. Duplicate count prevention is now on by default as long as the following conditions are met:
    • The duplicate count prevention attribute/property has not been explicitly set.
    • The selected counter timebase source is not set to an internal timebase.
    • The prescaler attribute/property has not been set.
    • The counter output event has not been configured.
    To learn more, refer to Duplicate Count Prevention in the NI-DAQmx help.
    Existing .NET Project Produces Build Errors
    If you are using NI-DAQmx with a .NET language, an existing project can produce build errors from an assembly that is not referenced. To eliminate this error, add a reference to the NationalInstruments.Common assembly to the project.
    Multichannel SCXI Convert Clock Default Rate Change in NI-DAQmx 8.5
    Starting in NI-DAQmx 8.5, a delay of 20 μs was added to the fastest possible channel conversion rate on an SCXI chassis connected to a 16-bit or 18-bit E or M Series device. If a sample rate is set fast enough to require a convert clock rate greater than the default rate, warning 200011 is generated, informing the user that the accuracy of the measurement might be compromised. However, since this is a warning, the convert clock used is based on the rate needed by the sample clock set by the user (that is, convert clock = sample clock * number of channels).
    For SCXI chassis containing a module with track-and-hold circuitry, 10 μs of padding is now added to the fastest possible conversion rate when connected to a 12-bit E Series device.
    These changes ensure the most accurate data is being acquired. However, if the effect on the performance due to this change is too great (such as on an RT system using hardware-timed single point in a control loop), then the convert clock rate attribute can be explicitly set, overriding the default rate.
    This change affects only multichannel acquisitions.
    In versions prior to NI-DAQmx 8.5, only 10 μs of delay was added to the fastest possible channel conversion rate on an SCXI chassis without a track-and-hold module connected to any DAQ device. In these versions of NI-DAQmx, no warning was generated when the sample rate needed a faster convert clock than was chosen by default. When an SCXI chassis with a track-and-hold module was present, the convert clock rate selected was the fastest possible rate that the DAQ device can handle, up to 333 kHz.
    NI PCI-6704 and PXI-6704 Current Output Accuracy
    NI-DAQmx 8.3 changes the algorithm used to scale the 20 mA current outputs of the NI 6704 to a method that matches the behavior of Traditional NI-DAQ (Legacy). Previous versions of the NI-DAQmx driver use a second method.
    The effect of the change is that when NI-DAQmx programs the 6704 to output current, the actual current level of the 6704 is 10 μA higher with NI-DAQmx 8.3 compared to previous versions of NI-DAQmx. The actual current output with NI-DAQmx 8.3 is the same compared to Traditional NI-DAQ (Legacy) drivers. This change has no effect on the voltage outputs of the 6704.
    Because of this change, NI recommends that you externally calibrate NI 6704 devices with NI-DAQmx 8.3 (or later) before using devices with the NI-DAQmx 8.3 (or later) driver. NI 6704 devices that ship with NI-DAQmx 8.3 have already been calibrated with NI-DAQmx 8.3. For other NI 6704 devices, refer to the manual calibration procedure available at ni.com/calibration.
    USB-9xxx Devices
    Unplug your USB-9xxx and plug it back in or power the USB device down and up after upgrading NI-DAQmx. If the USB-9xxx is connected to a USB hub, make sure to disconnect the USB-9xxx from the hub, not the hub from the computer. Disconnecting power from the USB device causes installed devices to load the correct version of the firmware.
    Virtual TEDS Data for the USB-9233/9237
    If you connect hardware TEDS to USB-9233/9237 channels configured with virtual TEDS, the virtual TEDS will be replaced with hardware TEDS data after upgrading to NI-DAQmx 8.6 or later.
    Software Support in NI-DAQmx 9.3Operating System Support
    The following operating systems are supported in NI-DAQmx 9.3:
    • Windows Vista Business edition (32-bit and 64-bit)
    • Windows XP, Service Pack 2 or greater
    For OS-specific device support information, refer to ni.com/support/daq/versions.
    Note  Support for Windows Server 2003 R2 may require disabling physical address extensions (PAE). To learn how this might affect your use of Windows Server 2003 and what actions you might have to take, visit ni.com/info and enter the info code PAESupport.
    NI-DAQmx 9.3 supports Phar Lap only with the LabVIEW Real-Time Module 8.5 and later.
    Windows 2000 users must use NI-DAQmx 9.1.1 or earlier.
    To find and download an earlier version of NI-DAQmx that supports other operating systems, refer to ni.com/downloads.
    NI-DAQmx does not support guest accounts on Windows 7/Vista/XP. You must log into an administrative or user account to use NI-DAQmx on these OSes.
    The following table lists the NI application software versions supported by NI-DAQmx. If you are not using NI application software, refer to Microsoft Visual Studio Support.
    In NI-DAQmx 8.6 and prior, when you add the DAQ Component as a new item to your Visual Studio 2005 project, the DAQ Component is located in the Measurement Studio folder and the Visual Basic Items or Visual C# Project Items folders. In NI-DAQmx 8.7 and later, the DAQ Component is located only in the Visual Basic Items or Visual C# Project Items folder and named NI-DAQ Component.
    NI Application SoftwareVersions Supported by NI-DAQmx and the DAQ Assistant
    8.5.x, 8.6.x, 2009, and 2010
    8.5.x and later (including 2009 and later)
    LabWindows/CVI
    8.1 and later (including 2009 and later)
    LabWindows/CVI Real-Time Module
    Measurement Studio
    2.x and later (including 2009 and later)
    Measurement Studio Examples
    The directories that the Measurement Studio examples install to depends on which component is installed, the version of Visual Studio or the .NET Framework the example supports, the version of Measurement Studio installed, and the operating system. For detailed information on examples for Measurement Studio, refer to Where To Find Examples in the NI Measurement Studio Help.
    The following table lists the programming languages and Microsoft Visual Studio versions supported by NI-DAQmx.
    Programming LanguageVisual Studio Versions Supported by NI-DAQmx
    ANSI C
    2003, 2005, 2008, and 2010
    Visual C++ MFC1
    20052 and 20083
    .NET Framework 2.0 Languages
    (C# and Visual Basic.NET)
    2005
    .NET Framework 3.5 Languages
    2008
    .NET Framework 4.0 Languages
    20104
    Visual Basic 61
    6
    1 NI-DAQmx includes limited support for Visual Basic 6 and Visual Studio C++ MFC. For more information, visit ni.com/info and enter the info code daqmxvstudio.
    2 Requires Measurement Studio 8.0.1 — Measurement Studio 2009
    3 Requires Measurement Studio 8.6 — Measurement Studio 2009
    4 With Windows XP, Service Pack 3 or later is required
    Earlier versions of NI-DAQmx support other application software and language versions. To find and download an earlier version of a driver, refer to ni.com/downloads.
    If you are using the DAQmx .NET Library, the .NET 2.0 Framework, .NET 3.5 Framework, or .NET 4.0 Framework is required.
    NI-DAQmx 9.2 is the last release that includes full feature support for Visual C++ MFC 2005 and 2008.
    If you are using the .NET Framework 1.1 or Visual C++ MFC 2003, you must use NI-DAQmx 9.1.5 or earlier. For more information on NI-DAQmx support for .NET Framework 1.1 or Visual C++ MFC 2003, including considerations for users upgrading from NI-DAQmx 9.1.5 or earlier, visit ni.com/info and enter the info code ex6rzd.
    Device Support in NI-DAQmx
    The following lists detail the devices supported in NI-DAQmx. Device support is divided into the following categories:
    • Devices supported in NI-DAQmx
    • Devices Not Supported in NI-DAQmx on Windows 7/Vista
    For MXI-3 and MXI-4 OS-specific support information, refer to ni.com/kb and search for KnowledgeBase entry 45MA9LF7.
    Devices Supported in NI-DAQmx
    Note  In the device support tables that follow, a ✓ indicates that the device is supported, a blank cell indicates that the device either does not exist or is not supported in NI-DAQmx, and an X indicates that the device is no longer supported in NI-DAQmx.
    • X Series DAQ
    • M Series DAQ
    • E Series DAQ
    • S Series DAQ
    • SC Express
    • C Series, Network DAQ, and USB DAQ
    • CompactDAQ Chassis
    • AO Series
    • Digital I/O
    • TIO Series
    • Dynamic Signal Acquisition
    • SC Series DAQ
    • Switches
    • SCXI Chassis
    • SCXI Modules
    • TEDS Interface
    • Academic Devices
    • Legacy DAQ Devices
    • Low-Cost USB Devices
    X Series DAQ
    The following X Series DAQ devices are supported:
    DevicePCIePXIeUSB
    NI 6320
    NI 6321
    NI 6323
    NI 6341
    NI 6343
    NI 6351
    NI 6353
    NI 6356
    NI 6358
    NI 6361
    NI 6363
    NI 6366
    NI 6368
    M Series DAQ
    The following M Series DAQ devices are supported:
    DevicePCIPCIePXIPXIeUSB
    NI 6210/11/12/15/16/18
    NI 6220
    NI 6221
    NI 6224
    NI 62251
    NI 6229
    NI 6230/32/33/36/38/39
    NI 6250
    NI 6251
    NI 6254
    NI 62551
    NI 6259
    NI 6280
    NI 6281
    NI 6284
    NI 6289
    1USB versions do not have NI-DAQmx simulated device capability.
    E Series DAQ
    The following E Series DAQ devices are supported.
    DevicePCMCIAPCIPXI
    NI 6023E
    NI 6024E
    NI 6025E
    NI 6030E
    NI 6031E
    NI 6032E/33E/34E/35E
    NI 6036E
    NI 6040E
    NI 6052E
    NI 6062E
    NI 6070E
    NI 6071E
    NI PCI-MIO-16E-1
    NI PCI-MIO-16E-4
    NI PCI-MIO-16XE-10
    X
    NI PCI-MIO-16XE-50
    X
    S Series DAQ
    The following S Series DAQ devices are supported:
    DevicePCIPXIPXIe
    NI 6110
    NI 6111
    NI 6115
    NI 6120
    NI 6122
    NI 6123
    NI 6124
    NI 6132
    NI 6133
    NI 6143
    NI 6154
    SC Express
    The following SC Express devices are supported:
    DevicePXIe
    NI 4300
    NI 4330
    NI 4331
    NI 4353
    The following C Series, Network DAQ, and USB DAQ devices are supported:
    DeviceCompactDAQ Chassis1Legacy Chassis and Carriers
    NI ENET/WLS-9163NI USB-9162NI cDAQ-9172
    NI 9201
    NI 9203
    NI 9205
    NI 9206
    NI 9207
    NI 9208
    NI 9211
    NI 9211A
    NI 9213
    NI 9214
    NI 9215
    NI 9215A
    NI 9217
    NI 9219
    NI 9221
    NI 9222
    NI 9223
    NI 9225
    NI 9227
    NI 9229
    NI 9233
    NI 9234
    NI 9234B
    NI 9235
    NI 9236
    NI 9237
    NI 9239
    NI 9263
    NI 9264
    NI 9265
    NI 9269
    NI 9401
    NI 9402
    NI 9403
    NI 9411
    NI 9421
    NI 9422
    NI 9423
    NI 9425
    NI 9426
    NI 9435
    NI 9472
    NI 9474
    NI 9475
    NI 9476
    NI 9477
    NI 9478
    NI 9481
    NI 9485
    1Does not include the NI cDAQ-9172.
    CompactDAQ Chassis
    The following CompactDAQ chassis are supported:
    NI cDAQ-9171
    NI cDAQ-9172
    NI cDAQ-9174
    NI cDAQ-9178
    NI cDAQ-9181
    NI cDAQ-9188
    AO Series
    The following AO Series devices are supported:
    DeviceDAQCardPCIPXI
    NI 6703
    NI 6704
    NI 6711
    NI 6713
    NI 6715
    NI 6722
    NI 6723
    NI 6731
    NI 6733
    Digital I/O
    The following digital I/O devices are supported.
    DeviceDAQCardPCIPCIePXIPXIeUSB
    NI 65011
    NI 6503
    NI 6508
    NI 6509
    NI 6510
    NI 6511
    NI 6512
    NI 6513
    NI 6514
    NI 6515
    NI 6516
    NI 6517
    NI 6518
    NI 6519
    NI 6520
    NI 6521
    NI 6525
    NI 6527
    NI 6528
    NI 6529
    NI 6533
    X
    NI 6534
    NI 6535
    NI 6536
    NI 6537
    NI DIO-24
    NI DIO-32HS
    NI DIO-96
    1Does not have NI-DAQmx simulated device capability.
    TIO Series
    The following TIO series devices are supported:
    DevicePCIPXI
    NI 6601
    NI 6602
    NI 6608
    NI 6624
    Dynamic Signal Acquisition (DSA)
    The following DSA devices are supported:
    DevicePCIPXIPXIeUSB
    NI 4431
    NI 4432
    NI 4461
    NI 4462
    NI 4472/B
    NI 4474
    NI 4492
    NI 4495
    NI 4496
    NI 4497
    NI 4498
    NI 4499
    SC Series DAQ
    The following SC Series DAQ devices are supported:
    DevicePXI
    NI 4200
    NI 4204
    NI 4220
    NI 4224
    Switches
    The following switches are supported:
    DevicePCIPXIPXIe
    NI 4021
    NI 2501
    NI 2503
    NI 2510
    NI 2512
    NI 2514
    NI 2515
    NI 2527
    NI 2529
    NI 2530
    NI 2531
    NI 2532
    NI 2533
    NI 2534
    NI 2535
    NI 2536
    NI 2545
    NI 2546
    NI 2547
    NI 2548
    NI 2549
    NI 2554
    NI 2555
    NI 2556
    NI 2557
    NI 2558
    NI 2559
    NI 2564
    NI 2565
    NI 2566
    NI 2567
    NI 2568
    NI 2569
    NI 2570
    NI 2571
    NI 2575
    NI 2576
    NI 2584
    NI 2585
    NI 2586
    NI 2590
    NI 2591
    NI 2593
    NI 2594
    NI 2595
    NI 2596
    NI 2597
    NI 2598
    NI 2599
    NI 2800
    NI 2810
    NI 2811
    NI 2815
    NI 2816
    SCXI Chassis
    The following SCXI Chassis are supported:
    DevicePXISCXI
    NI 1010
    NI 1011
    NI SCXI-1000/DC
    NI SCXI-1001
    SCXI Modules
    The following SCXI modules are supported:
    • NI SCXI-1100
    • NI SCXI-1102
    • NI SCXI-1102B/C
    • NI SCXI-1104/C
    • NI SCXI-1112
    • NI SCXI-1120/D
    • NI SCXI-1121
    • NI SCXI-1122
    • NI SCXI-1124
    • NI SCXI-1125
    • NI SCXI-1126
    • NI SCXI-1127
    • NI SCXI-1128
    • NI SCXI-1129
    • NI SCXI-1130
    • NI SCXI-1140
    • NI SCXI-1141
    • NI SCXI-1142
    • NI SCXI-1143
    • NI SCXI-1160
    • NI SCXI-1161
    • NI SCXI-1162
    • NI SCXI-1162HV
    • NI SCXI-1163
    • NI SCXI-1163R
    • NI SCXI-1166
    • NI SCXI-1167
    • NI SCXI-1169
    • NI SCXI-1175
    • NI SCXI-1190
    • NI SCXI-1191
    • NI SCXI-1192
    • NI SCXI-1193
    • NI SCXI-1194
    • NI SCXI-1195
    • NI SCXI-1314T
    • NI SCXI-1502
    • NI SCXI-1503
    • NI SCXI-1520
    • NI SCXI-1521/B
    • NI SCXI-1530
    • NI SCXI-1531
    • NI SCXI-1540
    • NI SCXI-1581
    TEDS Interface
    The following TEDS devices are supported:
    • NI SC-2350
    • NI BNC-2096
    • NI SCXI-1314T
    Academic Devices
    The following academic devices are supported:
    • NI ELVIS II
    • NI ELVIS II+
    • NI myDAQ
    Legacy DAQ Devices
    The following legacy DAQ devices are supported. These do not have NI-DAQmx simulated device capability:
    DeviceDAQ PadPCIUSB
    NI DAQPad-6015
    NI DAQPad-6016
    NI PCI-6013
    NI PCI-6014
    SensorDAQ
    Low-Cost USB
    The following low-cost USB devices are supported. These do not have NI-DAQmx simulated device capability:
    DeviceUSB
    NI 6008
    NI 6009
    NI TC01
    The following devices are not supported in NI-DAQmx on Windows 7/Vista (32-bit and 64-bit versions):
    • NI DAQPad-6015 for USB
    • NI DAQPad-6015 for USB (BNC)
    • NI DAQPad-6015 for USB (Mass Termination)
    • NI DAQPad-6016 for USB
    The following devices are supported in NI-DAQmx on the 32-bit versions of Windows 7/Vista. They are not supported on the 64-bit versions of Windows 7/Vista:
    • NI DAQCard-6024E 200 kS/s, 12-bit, 16 analog input channel, two analog output channel, 8 digital I/O line, two counter/timer device
    • NI DAQCard-6036E 200 kS/s, 16-bit, 16 analog input channel, two analog output channel, 8 digital I/O line, two counter/timer device
    • NI DAQCard-6062E 500 kS/s, 12-bit, 16 analog input channel device
    • NI DAQCard-6715 for PCMCIA 1 MS/s 12-bit analog output device
    • NI DAQCard-DIO-24 for PCMCIA 24-channel 5V/TTL/CMOS digital I/O device
    • NI SCXI-1600 USB module
    System UseRAMProcessor
    Development1 GBPentium IV or later
    Deployment256 MBPentium III/Celeron 600 MHz or Equivalent
    Notice
    The mDNSResponder notice is installed with NI-DAQmx. By default, the notice is installed at Program Files\National Instruments\Shared\mDNS Responder\mDNS Responder FOSS notices.doc.
    Copyright 2003–2011 National Instruments. All rights reserved.
    GMT+8, 2025-12-8 19:18
