查看: 3464|回复: 0
[LV工具模块] LabVIEW 2011 Adaptive Filter Toolkit Win32Eng LabVIEW自适应滤波器工具包2011版
    9 小时前
    发表于 2020-11-7 23:47:58 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    算法包括: LMS, 归一化LMS, 漏溢式LMS, 快速LMS, sign LMS, RLS和QR-RLS
    用于主动噪音/振动控制的X滤波LMS和归一化X滤波LMS
    范例包括: 自适应噪声/回声消除, 自适应系统辨识, LPC
    用于定点LMS自适应滤波器的仿真和NI LabVIEW FPGA代码自动生成
    2011
    文件大小: 59210336 字节 (56.47 MB)
    修改日期: 2011-07-14 23:24
    MD5: 52ec0b494276ee0e1910512639e9f757(重复下载一致)
    SHA1: 58e5d40ef57ac1bf874d69e0f23ca0cceaf63159
    SHA256: 9cffd78db978316c55252acb02b1807e425843925cede9533a1be96a4e3b1b8e
    CRC32: baebc36d
    百度网盘和NI官方下载下载:
    AFTK2011.txt (570 Bytes, 下载次数: 1, 售价: 10 圆)
    LabVIEW 2011 Adaptive Filter Toolkit Readme
    Version 11.0.0
    June 2011
    The LabVIEW 2011 Adaptive Filter Toolkit updates the Adaptive Filter Toolkit 2010 to support LabVIEW 2011. This release is a maintenance release.
    The Adaptive Filter Toolkit includes tools for designing, analyzing, and simulating adaptive filters, including fixed-point adaptive filters. This file contains the following information about the Adaptive Filter Toolkit.
    An adaptive filter is a computational device that iteratively models the relationship between the input and output signals of the filter. An adaptive filter self-adjusts the filter coefficients according to an adaptive algorithm. You can use the Adaptive Filter Toolkit to create adaptive filters with the following adaptive algorithms:
    • Least mean squares (LMS) and the variants, such as normalized LMS, leaky LMS, normalized leaky LMS, sign LMS, and fast block LMS
    • Filtered-x LMS and normalized filtered-x LMS
    • Recursive least squares (RLS) and QR decomposition-based RLS (QR-RLS)
    You can apply the adaptive filters that you create to different applications, such as adaptive noise cancellation, adaptive echo cancellation, system identification, and so on. You also can create and implement fixed-point adaptive filters on National Instruments FPGA targets.
    The computer you are using must meet the following minimum system requirements to run the Adaptive Filter Toolkit:
    • Supported operating systems
      • Windows XP Service Pack 2 or later
    • 50 MB free disk space
    • LabVIEW 2011 Full or Professional Development System (32-bit)
    Note: The Adaptive Filter Toolkit does not support Windows NT/Me/2000/98/95 or the Windows Server non-R2 editions.
    Note: If you want to use the Adaptive Filter Toolkit to generate LabVIEW FPGA code for a fixed-point adaptive filter, you must install the LabVIEW FPGA Module on the host computer.
    You can install all of your LabVIEW products—including the Adaptive Filter Toolkit—using the LabVIEW 2011 Platform DVDs. You can find installation instructions for the Adaptive Filter Toolkit along with activation instructions in the following locations:
    • LabVIEW 2011 Platform DVDs Readme, which is available on the top-level of LabVIEW Platform DVD 1.
    To request additional LabVIEW 2011 Platform DVDs, refer to the National Instruments Web site.
    Refer to the LabVIEW Help, accessible by selecting Help»LabVIEW Help from the pull-down menu in LabVIEW, for information about using the Adaptive Filter Toolkit.
    You can access the examples for the Adaptive Filter Toolkit by selecting Help»Find Examples to display the NI Example Finder and then navigating to the Toolkits and Modules»Adaptive Filters folder. You also can click the Find Examples link in the Examples section of the Getting Started window to display the NI Example Finder. You can modify an example VI to fit an application, or you can copy and paste from one or more examples into a VI that you create.
    You also can find the examples for the Adaptive Filter Toolkit in the labview\examples\Adaptive Filters directory.
    You can access the software and documentation known issues list online. Refer to the National Instruments Web site for an up-to-date list of known issues in the Adaptive Filter Toolkit.
    Important Information
    GMT+8, 2025-12-8 18:21
