查看: 3180|回复: 0
[LV工具模块] LabVIEW 2012 Adaptive Filter Toolkit Win32Eng LabVIEW自适应滤波器工具包2012版
    9 小时前
    发表于 2020-11-7 23:50:50 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    算法包括: LMS, 归一化LMS, 漏溢式LMS, 快速LMS, sign LMS, RLS和QR-RLS
    用于主动噪音/振动控制的X滤波LMS和归一化X滤波LMS
    范例包括: 自适应噪声/回声消除, 自适应系统辨识, LPC
    用于定点LMS自适应滤波器的仿真和NI LabVIEW FPGA代码自动生成
    2012
    文件大小: 60422792 字节 (57.62 MB)
    修改日期: 2012-06-20 04:49
    MD5: c6ee5bef2b3442f7cf5f0f9f7ea78c04(重复下载一致)
    SHA1: 42b946ceaa79a7673decdc1555049bda19615696
    SHA256: 7045d280de331dca042fa0a8f4be8205fe2826155266041516d23ac214216922
    CRC32: 019edfec
    百度网盘和NI官方下载下载:
    AFTK2012.txt (680 Bytes, 下载次数: 0, 售价: 10 圆)
    LabVIEW 2012 Adaptive Filter Toolkit Readme
    Version 12.0.0
    June 2012
    The LabVIEW 2012 Adaptive Filter Toolkit updates the Adaptive Filter Toolkit 2011 to support LabVIEW 2012. This release is a maintenance release.
    The Adaptive Filter Toolkit includes tools for designing, analyzing, and simulating adaptive filters, including fixed-point adaptive filters. This file contains the following information about the Adaptive Filter Toolkit.
    An adaptive filter is a computational device that iteratively models the relationship between the input and output signals of the filter. An adaptive filter self-adjusts the filter coefficients according to an adaptive algorithm. You can use the Adaptive Filter Toolkit to create adaptive filters with the following adaptive algorithms:
    • Least mean squares (LMS) and the variants, such as normalized LMS, leaky LMS, normalized leaky LMS, sign LMS, and fast block LMS
    • Filtered-x LMS and normalized filtered-x LMS
    • Recursive least squares (RLS) and QR decomposition-based RLS (QR-RLS)
    You can apply the adaptive filters that you create to different applications, such as adaptive noise cancellation, adaptive echo cancellation, system identification, and so on. You also can create and implement fixed-point adaptive filters on National Instruments FPGA targets.
    In addition to the system requirements for the LabVIEW Development System, the Adaptive Filter Toolkit has the following requirements:
    • LabVIEW 2012 Full or Professional Development System (32-bit)
    • At least 50 MB of disk space
    Refer to the LabVIEW Readme for additional system requirements and supported operating systems for LabVIEW 2012.
    Note:  If you want to use the Adaptive Filter Toolkit to generate LabVIEW FPGA code for a fixed-point adaptive filter, you must install the LabVIEW FPGA Module on the host computer.
    You can install all of your LabVIEW products—including the Adaptive Filter Toolkit—using the LabVIEW 2012 Platform DVDs. Refer to the LabVIEW Installation Guide on the LabVIEW Platform DVD 1 for installation instructions and system requirements.
    To request additional LabVIEW Platform DVDs, refer to the National Instruments website.
    Note:  If you purchased this product with an NI Software Suite or NI Product Bundle, use the installation media that shipped with your purchase to install this product.
    You can access the software and documentation known issues list online. Refer to the National Instruments website for an up-to-date list of known issues in the Adaptive Filter Toolkit.
    Refer to the LabVIEW Help, accessible by selecting Help»LabVIEW Help from LabVIEW, for information about the Adaptive Filter Toolkit.
    You can access the examples for the Adaptive Filter Toolkit by selecting Help»Find Examples to display the NI Example Finder and then navigating to the Toolkits and Modules»Adaptive Filters folder. You also can click the Find Examples link in the Examples section of the Getting Started window to display the NI Example Finder. You can modify an example VI to fit an application, or you can copy and paste from one or more examples into a VI that you create.
    You also can find the examples for the Adaptive Filter Toolkit in the labview\examples\Adaptive Filters directory.
    Important Information
    © 2012 National Instruments. All rights reserved.
    GMT+8, 2025-12-8 18:22
