查看: 3060|回复: 0
[RTE运行引擎] NI-SLSC 1.0 Runtime Driver Win32/64Eng NI开关负载信号调理设备驱动1.0版运行引擎下载
    昨天 08:14
  • 签到天数: 3701 天
    连续签到: 28 天
    发表于 2020-11-8 23:33:16 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    NI-SLSC
    NI-SLSC驱动用于支持在NI数据采集设备(如PXI和CompactRIO)上使用开关、负载和信号调理(SLSC)设备。
    NI-SLSC是一种仪器驱动程序,为SLSC(开关、负载和信号调理)硬件提供支持。它集成了开关、负载和信号调理功能,可扩展基于PXI和C系列平台的系统功能。SLSC可将连接标准化,并提供模块化方法,适用于信号调理、故障插入和其他测试需求。NI-SLSC还包括一个开关路由API,使您能够在LabVIEW中控制和配置NI和第三方SLSC开关。
    1.0RT
    文件大小: 75975812 字节 (72.46 MB)
    修改日期: 2019-06-25 03:09
    MD5: 5d8b805907529b53b001100a12f55486(官方正确)
    SHA1: 0055bdb6fe445a7ee694b7e845729cc754287300
    SHA256: 93062aeb359848dc13ba2f1dad6e5677f75a8ffb2ffde26e193401cc2ac539f4
    CRC32: d9bae972
    SLSC1.0RT.txt (265 Bytes, 下载次数: 0, 售价: 5 圆)
    NI-SLSC 1.0 Readme
    November 2016
    This file contains important information about NI-SLSC, including any system requirements and any known issues for the application and the driver software.
    Supported Devices
    NI-SLSC supports the following operating systems:
    • Windows 10/8.1/7 SP11
    • Windows Embedded Standard 7 SP11
    • Windows Server 2012 R2
    • Windows Server 2008 R2 SP11
    1 NI software is signed with a SHA-256 certificate. Windows 7 SP1, Windows Embedded Standard 7 SP1, and Windows Server 2008 R2 SP1 require Microsoft updates to support SHA-256. Refer to Microsoft KB3033929 for more information about how to install this security update.
    The following table lists the NI application software versions, including service packs, supported by NI-SLSC.
    Application SoftwareVersions Supported by NI-SLSC
    LabVIEW2015
    LabWindows Real-Time Module12015
    1 NI-SLSC supports Phar Lap ETS targets. It does not support Linux RT or VxWorks targets.
    Supported Devices
    • SLSC-12001 chassis
    • SLSC modules that comply with SLSC MDK 1.0
    You can access the software and documentation known issues list online. Refer to the NI website for an up-to-date list of known issues in NI-SLSC.
    © 2016 National Instruments. All rights reserved.
    376773A-01
    GMT+8, 2025-11-4 04:39
