查看: 3040|回复: 0
[RTE运行引擎] NI-SLSC 17.5 Runtime Driver Win32/64Eng NI开关负载信号调理设备驱动17.5版运行引擎下载
    昨天 08:40
  • 签到天数: 3765 天
    连续签到: 16 天
    发表于 2020-11-8 23:41:11 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    NI-SLSC
    NI-SLSC驱动用于支持在NI数据采集设备(如PXI和CompactRIO)上使用开关、负载和信号调理(SLSC)设备。
    NI-SLSC是一种仪器驱动程序,为SLSC(开关、负载和信号调理)硬件提供支持。它集成了开关、负载和信号调理功能,可扩展基于PXI和C系列平台的系统功能。SLSC可将连接标准化,并提供模块化方法,适用于信号调理、故障插入和其他测试需求。NI-SLSC还包括一个开关路由API,使您能够在LabVIEW中控制和配置NI和第三方SLSC开关。
    17.5RT
    文件大小: 104375981 字节 (99.54 MB)
    修改日期: 2019-06-25 03:09
    MD5: 861f216deb1b9f4d4bc66d58a354fc99(官方正确)
    SHA1: 2b5d6589b6075ea87f2fd6e2c24b02140570c125
    SHA256: 07399fb9c6649958a7910eb4f3a2a18bc8c9e3cb6424fdcd1529a5f84cc8ec46
    CRC32: 315ae49d
    SLSC17.5RT.txt (267 Bytes, 下载次数: 0, 售价: 5 圆)
    NI-SLSC 17.5 Readme
    October 2017
    This file contains important information about the NI-SLSC driver software, including new features and known issues.
    NI-SLSC 17.5 supports the following operating systems:
    • Windows 10/8.11/7 SP12
    • Windows Server 2012 R21
    • Windows Server 2008 R2 SP12
    Note  In 2016 NI-SLSC dropped support for Windows Vista, Windows XP, Windows Server 2003, and installations of Windows 7 without any service packs. NI-SLSC 17.5 will not install or run on an unsupported OS. You cannot deploy or distribute applications that use NI-SLSC 17.5 to an unsupported OS. Additionally, after installing NI-SLSC 17.5, you cannot use any installers built on this computer with any version of LabVIEW, LabWindows™/CVI™, NI TestStand™, or Measurement Studio on an unsupported OS.
    NI-SLSC 17.5 supports the following application software versions, including service packs.
    Application SoftwareVersions Supported by NI-SLSC
    LabVIEW2015, 2016, 2017
    LabVIEW Real-Time Module12015, 2016, 2017
    1 NI-SLSC supports Phar Lap ETS and Linux RT targets, but does not support VxWorks targets.
    • Added NI Measurement & Automation Explorer (MAX) support for the SLSC chassis
    • Added support for the following actions for SLSC module initialization:
      • Write registers
      • Set/Commit properties
      • Execute commands
    • Added the following properties for the SLSC Property Node:
      • Prop.Unit
      • Prop.MinValue
      • Prop.MaxValue
    • Improved the ability of the SLSC chassis to detect a single fan failure
    • Updated the firmware of the SLSC-12001 chassis for changed network settings to take effect without restarting the SLSC chassis
    • SLSC-12001 chassis
    • SLSC modules that comply with SLSC MDK 1.1 or earlier
    You can access the software and documentation known issues list online. Refer to the NI website for an up-to-date list of known issues in the NI-SLSC 17.5.
    © 2016–2017 National Instruments. All rights reserved.
    376773C-01
    GMT+8, 2026-1-8 06:07
