查看: 3077|回复: 0
[RTE运行引擎] NI-SLSC 18.5 Runtime Driver Win32/64Eng NI开关负载信号调理设备驱动18.5版运行引擎下载
    昨天 08:40
  • 签到天数: 3765 天
    连续签到: 16 天
    发表于 2020-11-8 23:48:47 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    NI-SLSC
    NI-SLSC驱动用于支持在NI数据采集设备(如PXI和CompactRIO)上使用开关、负载和信号调理(SLSC)设备。
    NI-SLSC是一种仪器驱动程序,为SLSC(开关、负载和信号调理)硬件提供支持。它集成了开关、负载和信号调理功能,可扩展基于PXI和C系列平台的系统功能。SLSC可将连接标准化,并提供模块化方法,适用于信号调理、故障插入和其他测试需求。NI-SLSC还包括一个开关路由API,使您能够在LabVIEW中控制和配置NI和第三方SLSC开关。
    18.5RT
    文件大小: 108563884 字节 (103.53 MB)
    修改日期: 2018-11-13 02:45
    MD5: 13802fbea14323a9f41011c81e1bf54c(官方正确)
    SHA1: 3b7ba69d413d83f13633e48611d2523306c9e0b9
    SHA256: d3d3a12632f459f1b220fb9a24ffda5136ed437fe7af02e2144996bcd072eac7
    CRC32: dce05bc0
    SLSC18.5RT.txt (267 Bytes, 下载次数: 0, 售价: 5 圆)
    NI-SLSC 18.5 Readme
    October 2018
    This file contains important information about the NI-SLSC driver software, including new features and known issues.
    NI-SLSC 18.5 supports the following operating systems:
    • Windows 10/8.11/7 SP12
    • Windows Server 2012 R21
    • Windows Server 2008 R2 SP12
    Note  In 2016 NI-SLSC dropped support for Windows Vista, Windows XP, Windows Server 2003, and installations of Windows 7 without any service packs. NI-SLSC 18.5 will not install or run on an unsupported OS. You cannot deploy or distribute applications that use NI-SLSC 18.5 to an unsupported OS. Additionally, after installing NI-SLSC 18.5, you cannot use any installers built on this computer with any version of LabVIEW, LabWindows™/CVI™, NI TestStand™, or Measurement Studio on an unsupported OS.
    NI-SLSC 18.5 supports the following application software versions, including service packs.
    Application SoftwareVersions Supported by NI-SLSC
    LabVIEW2015, 2016, 2017, 2018
    LabVIEW Real-Time Module12015, 2016, 2017, 2018
    1 NI-SLSC supports Phar Lap ETS and NI Linux Real-Time targets, but does not support VxWorks targets.
    • Added the following VIs:
      • Get Chassis IP or Hostname VI
      • Get Module Name VI
      • Update Chassis Firmware VI
      • Rename Chassis and All Connected Modules VI
    • Added support for LabVIEW 2018 SP1.
    • For VeriStand, added support for PXI controllers with NI Linux Real-Time—PXIe-8840 Quad-Core and PXIe-8880.
    • Added support for NVMEM flash writing protection. You can use a password to protect the capabilities area, the identification area, the raw area, and other areas if needed in the NVMEM of an SLSC module. Refer to the SLSC Design Guidelines Version 1.3 for more information.
    • Added example VIs for the FIU/DIO Module.
    • SLSC-12001 chassis
    • SLSC modules that comply with SLSC MDK 1.3 or earlier
    You can access the software and documentation known issues list online. Visit ni.com/info and enter the Info Code ex2t83 for an up-to-date list of known issues in the NI-SLSC 18.5.
    Refer to the NI-SLSC Help, accessible by navigating to the C:\Users\Public\Documents\National Instruments\NI-SLSC\Documentation directory and opening NI-SLSC Help.chm, for information about the NI-SLSC driver software. You can also refer to the NI-SLSC VI Reference Help, accessible by selecting Help»NI-SLSC VI Reference Help in LabVIEW, for information about SLSC VIs.
    © 2016–2018 National Instruments. All rights reserved.
    376773F-01
    GMT+8, 2026-1-8 06:09
