查看: 2682|回复: 0
[NI驱动程序] NI-SLSC 19.0 Driver Win32/64Eng NI开关负载信号调理设备驱动19.0版下载
    昨天 08:40
  • 签到天数: 3765 天
    连续签到: 16 天
    发表于 2020-11-8 23:51:25 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    NI-SLSC
    NI-SLSC驱动用于支持在NI数据采集设备(如PXI和CompactRIO)上使用开关、负载和信号调理(SLSC)设备。
    NI-SLSC是一种仪器驱动程序,为SLSC(开关、负载和信号调理)硬件提供支持。它集成了开关、负载和信号调理功能,可扩展基于PXI和C系列平台的系统功能。SLSC可将连接标准化,并提供模块化方法,适用于信号调理、故障插入和其他测试需求。NI-SLSC还包括一个开关路由API,使您能够在LabVIEW中控制和配置NI和第三方SLSC开关。
    19.0
    文件大小: 694130688 字节 (661.97 MB)
    修改日期: 2019-06-14 06:47
    MD5: 04df47d67eee8c9d69520af5db5b625c(官方正确)
    SHA1: 528af13f15016728f8f6debf2fed1f9f858c80b9
    SHA256: bdcd023ddc6c12b7b4ef303ebd200d98df8e3336eb949bf3ff9fca4a0ecfb333
    CRC32: 621b8490
    SLSC19.0.txt (275 Bytes, 下载次数: 0, 售价: 10 圆)
    NI-SLSC 19.0 Readme
    May 2019
    This file contains important information about the NI-SLSC driver software, including new features and known issues.
    NI-SLSC Drops Support for Windows 7 (32- and 64-Bit), Windows Server 2008 R2, and All 32-Bit Windows Operating Systems in 2021
    NI-SLSC 19.0 supports the following operating systems:
    • Windows 10/8.11/7 SP12
    • Windows Server 2012 R21
    • Windows Server 2008 R2 SP12
    Note  Refer to NI-SLSC Drops Support for Windows 7 (32- and 64-Bit), Windows Server 2008 R2, and All 32-Bit Windows Operating Systems in 2021 for information about future OS support.
    Note  In 2016 NI-SLSC dropped support for Windows Vista, Windows XP, Windows Server 2003, and installations of Windows 7 without any service packs. NI-SLSC 19.0 will not install or run on an unsupported OS. You cannot deploy or distribute applications that use NI-SLSC 19.0 to an unsupported OS. Additionally, after installing NI-SLSC 19.0, you cannot use any installers built on this computer with any version of LabVIEW, LabWindows™/CVI™, NI TestStand™, or Measurement Studio on an unsupported OS.
    NI-SLSC 19.0 supports the following application software versions, including service packs.
    Versions Supported by NI-SLSC
    LabVIEW2016, 2017, 2018, 2019
    LabVIEW Real-Time Module12016, 2017, 2018, 2019
    1 NI-SLSC supports Phar Lap ETS and NI Linux Real-Time targets, but does not support VxWorks targets.
    • Added Scaling VIs. You can use Scaling VIs to get and set scaling parameters and equations.
    • Added support for the scaling NVMEM area. Refer to the SLSC Module Design Specifications, Version 1.4 for more information.
    • Added the Connect to Chassis by IP Address or Hostname VI. You can use this VI to open a network connection for a chassis by IP address or hostname.
    • Added support for PXI controllers with NI Linux Real-Time—PXIe-8840 Quad-Core, PXIe-8861, and PXIe-8880. This support no longer relies on VeriStand.
    • Added support for LabVIEW 2019.
    • SLSC-12001 chassis
    • SLSC modules that comply with SLSC MDK 1.4 or earlier
    You can access the software and documentation known issues list online. Visit ni.com/info and enter the Info Code ex2t83 for an up-to-date list of known issues in the NI-SLSC 19.0.
    Refer to the NI-SLSC Help, accessible by navigating to the C:\Users\Public\Documents\National Instruments\NI-SLSC\Documentation directory and opening NI-SLSC Help.chm, for information about the NI-SLSC driver software. You can also refer to the NI-SLSC VI Reference Help, accessible by selecting Help»NI-SLSC VI Reference Help in LabVIEW, for information about SLSC VIs.
    NI-SLSC will drop support for Windows 7 (32- and 64-bit), Windows Server 2008 R2, and all 32-bit Windows operating systems starting in 2021. Versions of this product that ship after May 1, 2021, will not install or run on these operating systems. For detailed information about NI operating system support, visit ni.com/r/win32bitsupport.
    Info Code
    LabWindows/CVIcvi_lifecycle
    © 2016–2019 National Instruments. All rights reserved.
    376773G-01
    GMT+8, 2026-1-8 06:09
