查看: 3297|回复: 0
[LV工具模块] LabVIEW 2012 Jitter Analysis Toolkit Win32Eng LabVIEW抖动分析工具包2012版下载
  • 签到天数: 3820 天
    连续签到: 13 天
    发表于 2020-11-9 22:57:13 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    LabVIEW抖动分析工具包
    LabVIEW抖动分析工具包可帮助您使用示波器或数字化仪自动执行测试测量。
    LabVIEW抖动分析工具包是LabVIEW的一款软件附件,提供了一个函数库,可用于在自动化验证和生产测试环境中执行高吞吐量的抖动、眼图和相位噪声测量。该附件支持眼图模板定义和模板极限测试(mask limit),而且如果使用的是多核机器,该附件可以加速线程安全测量。您可以创建和显示眼图和浴盆曲线。LabVIEW抖动分析工具包适用于使用第三方示波器和数字化仪或者PXI IF数字化仪、PXI示波器、C系列数字化仪模块等NI硬件的测试系统。此外,该附件还提供眼图、模板(mask)测试和随机抖动/确定性抖动(RJ/DJ)分离相关的示例程序。
    2012(有两个EXE版本,大小,校验和,有所不同)
    文件大小: 123570824 字节 (117.85 MB)
    修改日期: 2012-06-15 22:17
    MD5: 3f50f2f530b53e25de2d6ae51037e6ca(重复下载一致,可秒传)
    SHA1: 3fe4ce670cfcda36444dac635858bb055356255e
    SHA256: 4c0911c1a161dffb5ce3a9a1153969ce5330cc4e856552c6348734dc4849f29d
    CRC32: e4fab34a
    版本2
    文件大小: 123558536 字节 (117.83 MB)
    修改日期: 2013-08-03 06:40
    MD5: 364d94e1cb4598c29452840015f2ee20(官方正确)
    SHA1: 4ecd232d4c19202518c063ca269b93aea6d1143f
    SHA256: d24d2ab3f861f173bd183c5940debe36ca4ff4ec1f6436f078e265c2acad6947
    CRC32: 67e60478
    百度和NI官方下载地址:
    JAT2012.txt (1.08 KB, 下载次数: 0, 售价: 10 圆)
    LabVIEW 2012 Jitter Analysis Toolkit Readme
    Version 12.0
    June 2012
    This file contains information to introduce you to the LabVIEW 2012 Jitter Analysis Toolkit. This file also contains important information about the toolkit, including system requirements, installation instructions, new features, and known issues.
    Accessing the Toolkit and Help
    The LabVIEW Jitter Analysis Toolkit provides a library of VIs optimized for performing high-throughput, automated jitter, eye diagram, and phase-noise measurements. The toolkit is hardware-independent and can be used with NI high-speed and high-resolution digitizers as well as third-party oscilloscopes and digitizers.
    In addition to the system requirements for the LabVIEW Development System, the Jitter Analysis Toolkit has the following requirements:
    • LabVIEW 2012 Full or Professional Development System (32-bit)
    • At least 150 MB of disk space
    Refer to the LabVIEW Readme file in the labview directory for additional system requirements and supported operating systems for LabVIEW 2012.
    You can install all of your LabVIEW products—including the Jitter Analysis Toolkit—using the LabVIEW 2012 Platform DVDs. Refer to the LabVIEW Installation Guide on the LabVIEW Platform DVD 1 for installation instructions and system requirements.
    To request additional LabVIEW Platform DVDs, refer to the National Instruments website.
    The LabVIEW 2012 Jitter Analysis Toolkit introduces the following new features.
    Characterizing Random and Periodic Jitter
    The Jitter palette includes the new RJ PJ Separation VI, which separates the random and periodic components of jitter in a jitter sequence and returns their RMS and peak-to-peak values.
    Support for Waveforms Represented by Integers
    Depending on how you acquire waveform data, the Y data values that are part of the waveform data type might be double-precision, floating-point numeric values or 8-bit signed integers. Analyzing waveforms represented by integers reduces the size of the data you must analyze, which requires less memory. The following VIs include polymorphic instances that can operate on the waveform data type when it contains double-precision floating-point data or 8-bit signed integers:
    • Area VI
    • Burst Width
    • Clock Recovery (Mean Clock)
    • Clock Recovery by PLL Filter
    • Clock Recovery by Second Order PLL
    • Eye Data Generation
    • Eye Height and Width
    • Eye Pattern Limit Test
    • Fall Time
    • Find Transitions
    • Level Crossing
    • Max and Min Voltage
    • Overshoot and Undershoot
    • Peak to Peak Voltage
    • Quality Factor
    • Reference Bit Waveform Creation
    • Reference Levels
    • Rise Time
    • Root Mean Square Voltage
    • State Levels
    Miscellaneous VI Enhancements and Behavior Changes
    The LabVIEW 2012 Jitter Analysis Toolkit includes the following VI enhancements and behavior changes:
    • The Signal with Jitter VI contains a PJmetrics output, which returns characteristics of the periodic jitter contained in the waveform this VI generates.
    • The Sequence to XY Graph VI no longer appears on the Jitter subpalette of the Jitter Analysis palette.
    Upgrade Issues and Compatibility Issues
    You might encounter the following compatibility issues when you upgrade to the LabVIEW 2012 Jitter Analysis Toolkit:
    • LabVIEW no longer supports the Periodic Jitter VI. Replace this VI in your applications with the nTone instance of the RJ PJ Separation VI.
    • If you open VIs saved in a previous version of LabVIEW that contain the Level Crossing, Reference Levels, or Eye Height and Width VI, LabVIEW might prompt you to find missing subVIs. Click the Ignore Item button to dismiss the dialog, and LabVIEW opens the VI without errors.
    • The Clock Recovery (Mean Clock) VI no longer contains a reset input.
    You can access the software and documentation known issues list online. Refer to the LabVIEW Toolkits Known Issues website for an up-to-date list of any known issues in the Jitter Analysis Toolkit.
    The following items are the IDs and titles of a subset of issues fixed between the LabVIEW 2011 Jitter Anlaysis Toolkit and the LabVIEW 2012 Jitter Anlaysis Toolkit. This is not an exhaustive list of issues fixed in the current version of the Jitter Analysis Toolkit. If you have a CAR ID, you can search this list to validate the issue has been fixed.
    336767Clock Recovery (Mean Clock) VI returns error -20068 when processing certain waveforms
    334701Rj Dj Separation VI does not appear on the Jitter Analysis Toolkit palette
    334182Duty cycle distortion values yield inconsistent results
    321442The high state level parameter is miscalculated and yields results that are higher than expected
    288897Glitch appears in eye diagram even though actual waveform is correct
    288895Clock Recovery (Mean Clock) VI does not sufficiently estimate unit interval for Eye Data Generation VI
    285695Jitter Analysis Toolkit example VIs do not show up in Example Finder
    To access the Jitter Analysis Toolkit VIs, select View»Functions Palette from the block diagram in LabVIEW and navigate to the Addons»Jitter Analysis palette. You also can right-click any blank space on the block diagram to display the Functions palette.
    Refer to the Toolkits»Jitter Analysis VIs book on the Contents tab of the LabVIEW Help for more information about the Jitter Analysis Toolkit.
    Select Help»Find Examples from LabVIEW to launch the NI Example Finder. LabVIEW examples for the Jitter Analysis Toolkit are located in the labview\examples\Jitter Analysis directory. You can modify an example VI to fit an application, or you can copy and paste from one or more examples into a VI that you create.
    Important Information
    © 2010–2012 National Instruments. All rights reserved.
    相关帖子
    GMT+8, 2026-3-9 13:49
