查看: 3202|回复: 0
[LV工具模块] LabVIEW 2013 Jitter Analysis Toolkit Win32Eng LabVIEW抖动分析工具包2013版下载
    昨天 08:18
  • 签到天数: 3733 天
    连续签到: 60 天
    发表于 2020-11-9 23:00:06 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    LabVIEW抖动分析工具包
    LabVIEW抖动分析工具包可帮助您使用示波器或数字化仪自动执行测试测量。
    LabVIEW抖动分析工具包是LabVIEW的一款软件附件,提供了一个函数库,可用于在自动化验证和生产测试环境中执行高吞吐量的抖动、眼图和相位噪声测量。该附件支持眼图模板定义和模板极限测试(mask limit),而且如果使用的是多核机器,该附件可以加速线程安全测量。您可以创建和显示眼图和浴盆曲线。LabVIEW抖动分析工具包适用于使用第三方示波器和数字化仪或者PXI IF数字化仪、PXI示波器、C系列数字化仪模块等NI硬件的测试系统。此外,该附件还提供眼图、模板(mask)测试和随机抖动/确定性抖动(RJ/DJ)分离相关的示例程序。
    2013(有两个EXE版本,大小,校验和,有所不同)
    文件大小: 147600160 字节 (140.76 MB)
    修改日期: 2013-07-03 00:47
    MD5: 575e3b7980a34b25ddd2b7d5e08db2d7(重复下载一致,可秒传)
    SHA1: 046eefd9d4434f546d4f22069ceb900d8b2a659e
    SHA256: f53a9dae30de532bb6a2ac18896e025575c42d4162947cf7890215789b0d2cf7
    CRC32: 4451390b
    版本2
    文件大小: 147563296 字节 (140.73 MB)
    修改日期: 2013-08-21 04:44
    MD5: 53494131b3b678aeb8551f6bbd1680ed(官方正确)
    SHA1: 8320a4ccc5544113c083dcafa1a083070dfdc7ec
    SHA256: c299c4d5da885b6c04a86dfb9d4fa1c390dc57a4f6b1865d832ec8083e8638af
    CRC32: 955c027d
    百度和NI官方下载地址:
    JAT2013.txt (1.07 KB, 下载次数: 0, 售价: 10 圆)
    LabVIEW 2013 Jitter Analysis Toolkit Readme
    Version 13.0.0
    June 2013
    This file contains important information about the LabVIEW Jitter Analysis Toolkit, including installation instructions, and known issues.
    The Jitter Analysis Toolkit provides a library of VIs optimized for performing high-throughput, automated jitter, eye diagram, and phase-noise measurements. The toolkit is hardware-independent and can be used with NI high-speed and high-resolution digitizers as well as third-party oscilloscopes and digitizers.
    In addition to the system requirements for the LabVIEW Development System, the LabVIEW 2013 Jitter Analysis Toolkit has the following requirements:
    • LabVIEW 2013 Full or Professional Development System (32-bit)
    • At least 150 MB of disk space
    Refer to the LabVIEW Readme for additional system requirements and supported operating systems for LabVIEW 2013.
    You can install all of your LabVIEW products—including the Jitter Analysis Toolkit—using the LabVIEW 2013 Platform DVDs. Refer to the LabVIEW Installation Guide on the LabVIEW Platform DVD 1 for installation instructions and system requirements.
    To request additional LabVIEW Platform DVDs, refer to the National Instruments website.
    Note If you purchased this product with an NI Software Suite or NI Product Bundle, use the installation media that shipped with your purchase to install this product.
    Jitter Analysis Toolkit Updates and Notifications
    You can access the software and documentation known issues list online. Refer to the National Instruments website for an up-to-date list of known issues in the Jitter Analysis Toolkit.
    Refer to the LabVIEW Help, accessible by selecting Help»LabVIEW Help from LabVIEW, for information about the Jitter Analysis Toolkit.
    Select Help»Find Examples from LabVIEW to launch the NI Example Finder. LabVIEW examples for the Jitter Analysis Toolkit are located in the labview\examples\Jitter Analysis directory. You can modify an example VI to fit an application, or you can copy and paste from one or more examples into a VI that you create.
    Using NI Launcher
    Finding All Programs
    NI LabVIEW Jitter Analysis Toolkit Drops Support for Microsoft Windows Vista, Windows XP, and Windows Server 2003 in 2016
    National Instruments LabVIEW Jitter Analysis Toolkit will drop support for Microsoft Windows Vista, Windows XP, and Windows Server 2003 as of July 1, 2016. Versions of Jitter Analysis Toolkit that ship after July 1, 2016 will not install or run on Windows Vista, Windows XP, or Windows Server 2003. For detailed information about NI application software product life cycles, visit ni.com/info and enter one of the following Info Codes:
    NI LabVIEWlifecycle
    NI TestStandtslcp
    NI DIAdemddlcp
    NI SignalExpressselcp
    NI VeriStandnivslifecycle
    Important Information
    © 2010–2013 National Instruments. All rights reserved.
    相关帖子
    GMT+8, 2025-12-6 00:18
